[MOAB-dev] r1463 - in MOAB/trunk: . tools/qvdual
tautges at mcs.anl.gov
Mon Dec 10 18:59:41 CST 2007
Author: tautges
Date: 2007-12-10 18:59:41 -0600 (Mon, 10 Dec 2007)
New Revision: 1463
Modified:
MOAB/trunk/DualTool.cpp
MOAB/trunk/tools/qvdual/DrawDual.cpp
Log:
Couple of changes from asserts to failures.
Modified: MOAB/trunk/DualTool.cpp
--- MOAB/trunk/DualTool.cpp 2007-12-10 19:12:17 UTC (rev 1462)
+++ MOAB/trunk/DualTool.cpp 2007-12-11 00:59:41 UTC (rev 1463)
@@ -2096,6 +2096,7 @@
if (on_bdy_tmp) {
assert(hstar_tmp.size() == qstar_tmp.size()-1);
hstar_tmp.push_back(0);
+ on_bdy = true;
// get the position of first split quad in star
@@ -2375,7 +2376,10 @@
result = mbImpl->get_connectivity(&middle_edge, 1, middle_connect); RR;
result = mbImpl->get_connectivity(&(*vit), 1, dum_connect); RR;
dum_connect = dum_connect.subtract(middle_connect);
- assert(dum_connect.size() == 1);
+ if (dum_connect.size() != 1) {
+ std::cerr << "Trouble traversing chord." << std::endl;
+ return MB_FAILURE;
// put in verts[0]
verts[0] = *dum_connect.begin();
@@ -2383,11 +2387,14 @@
// same with prev edge
vit++;
if (vit == chord_edges.end()) vit = chord_edges.begin();
- else vit++;
+ vit++;
dum_connect.clear();
// put in verts[1]
verts[1] = *dum_connect.begin();
@@ -2400,7 +2407,10 @@
verts[1] = dum_h;
- assert(0 != mtu.common_entity(verts[0], connect[0], 1));
+ if (0 == mtu.common_entity(verts[0], connect[0], 1)) {
return MB_SUCCESS;
Modified: MOAB/trunk/tools/qvdual/DrawDual.cpp
--- MOAB/trunk/tools/qvdual/DrawDual.cpp 2007-12-10 19:12:17 UTC (rev 1462)
+++ MOAB/trunk/tools/qvdual/DrawDual.cpp 2007-12-11 00:59:41 UTC (rev 1463)
@@ -344,7 +344,7 @@
gDrawDual->update_high_polydatas();
else if (picked_ent == *picked_ents.begin()) {
- std::cout << oss.str() << " (" << picked_ent << ")" << std::endl;
+ //std::cout << oss.str() << " (" << picked_ent << ")" << std::endl;
pickLine2->setText(pickLine1->displayText());
pickLine1->setText(QString(oss.str().c_str()));
@@ -863,7 +863,10 @@
int num_connect;
result = MBI->get_connectivity(*chord_edges[i].begin(), connect, num_connect); RR;
result = MBI->get_adjacencies(connect, num_connect, 1, false, middle_edges); RR;
- assert(1 == middle_edges.size());
+ if (1 != middle_edges.size()) {
+ // take off any edges that aren't on this sheet? no, just punt...
+ std::cout << "Warning: not a clear middle edge..." << std::endl;
// get the points for the two vertices and the 3 edges
// non-middle chord; get the edges too
@@ -1766,7 +1769,6 @@
// from another that's not in the 1st set
MBRange tmp_range;
result = MBI->get_entities_by_dimension(chords[0], 1, tmp_range); RR;
- assert(3 < tmp_range.size());
const MBEntityHandle *connect;
int num_connect;
result = MBI->get_connectivity(*tmp_range.begin(), connect, num_connect); RR;
@@ -2286,7 +2288,20 @@
// get all neighbor verts
MBRange nverts, tmp_edges;
result = mtu.get_bridge_adjacencies(this_point, 1, 0, nverts); RR;
- assert(4 == nverts.size() || 3 == nverts.size());
+ if (!(4 == nverts.size() || 3 == nverts.size())) {
+ std::cerr << "Smoothing sheet failed; dumping file." << std::endl;
+ dualTool->delete_whole_dual();
+ MBEntityHandle save_set;
+ MBErrorCode result = vtkMOABUtils::mbImpl->create_meshset(MESHSET_SET, save_set);
+ if (MB_SUCCESS != result) return MB_FAILURE;
+ MBRange hexes;
+ result = vtkMOABUtils::mbImpl->get_entities_by_type(0, MBHEX, hexes);
+ result = vtkMOABUtils::mbImpl->add_entities(save_set, hexes);
+ vtkMOABUtils::mbImpl->write_file("tmp.h5m", NULL, NULL, &save_set, 1);
for (MBRange::iterator rit = nverts.begin(); rit != nverts.end(); rit++) {
tmp_edges.clear();
