[MOAB-dev] r1457 - MOAB/trunk
kraftche at mcs.anl.gov
Fri Dec 7 16:52:26 CST 2007
Author: kraftche
Date: 2007-12-07 16:52:26 -0600 (Fri, 07 Dec 2007)
New Revision: 1457
Modified:
MOAB/trunk/MBOrientedBox.cpp
MOAB/trunk/MBOrientedBox.hpp
Log:
add constructor because Microsoft compiler can't do struct initialization if struct has non-intrinsic members
Modified: MOAB/trunk/MBOrientedBox.cpp
--- MOAB/trunk/MBOrientedBox.cpp 2007-12-07 22:47:18 UTC (rev 1456)
+++ MOAB/trunk/MBOrientedBox.cpp 2007-12-07 22:52:26 UTC (rev 1457)
@@ -426,7 +426,7 @@
const MBRange& vertices )
// Sum input CovarienceData structures
- CovarienceData data_sum = { 0.0, MBCartVect(0.0), 0.0 };
+ CovarienceData data_sum( MBMatrix3(0.0), MBCartVect(0.0), 0.0 );
for (const CovarienceData* const end = data+data_length; data != end; ++data) {
data_sum.matrix += data->matrix;
data_sum.center += data->center;
Modified: MOAB/trunk/MBOrientedBox.hpp
--- MOAB/trunk/MBOrientedBox.hpp 2007-12-07 22:47:18 UTC (rev 1456)
+++ MOAB/trunk/MBOrientedBox.hpp 2007-12-07 22:52:26 UTC (rev 1457)
@@ -97,6 +97,9 @@
* and resulting box orientation.
struct CovarienceData {
+ CovarienceData() {}
+ CovarienceData( const MBMatrix3& m, const MBCartVect& c, double a)
+ : matrix(m), center(c), area(a) {}
MBMatrix3 matrix; //!< Running sum for covariance matrix
MBCartVect center; //!< Sum of triangle centroids weighted by 2*triangle area
double area; //!< 2x the sum of the triangle areas
