[MOAB-dev] r1453 - MOAB/trunk/tools/dagmc
kraftche at mcs.anl.gov
Fri Dec 7 16:33:51 CST 2007
Author: kraftche
Date: 2007-12-07 16:33:51 -0600 (Fri, 07 Dec 2007)
New Revision: 1453
Modified:
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/dagmc/DagMC.hpp
Log:
Portability fix from Byron: VC.Net 2002 things 'huge' is a keyword
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2007-12-07 21:34:19 UTC (rev 1452)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2007-12-07 22:33:51 UTC (rev 1453)
@@ -80,7 +80,7 @@
const int num_pts,
const double uuu, const double vvv, const double www,
const double xxx, const double yyy, const double zzz,
- const double huge,
+ const double huge_val,
double &dist_traveled, MBEntityHandle &next_surf_hit)
if (debug) {
@@ -105,7 +105,7 @@
const double dir[] = {uuu, vvv, www};
distances.clear();
surfaces.clear();
- double len = use_dist_limit() ? distance_limit() : huge;
+ double len = use_dist_limit() ? distance_limit() : huge_val;
rval = obbTree.ray_intersect_sets( distances,
surfaces,
@@ -124,7 +124,7 @@
<< "need an ACIS-based install of CGM." << std::endl;
return MB_NOT_IMPLEMENTED;
#else
- rval = CAD_ray_intersect(point, dir, huge,
+ rval = CAD_ray_intersect(point, dir, huge_val,
distances, surfaces, len);
if (MB_SUCCESS != rval) return rval;
#endif
@@ -134,9 +134,9 @@
// Find smallest intersection
if (distances.empty()) {
next_surf_hit = 0;
- dist_traveled = (use_dist_limit() ? len*10.0 : huge);
+ dist_traveled = (use_dist_limit() ? len*10.0 : huge_val);
if (debug) {
- std::cout << "next surf hit = " << 0 << ", dist = (huge)" << std::endl;
+ std::cout << "next surf hit = " << 0 << ", dist = (huge_val)" << std::endl;
return MB_SUCCESS;
@@ -151,9 +151,9 @@
next_surf_hit = 0;
- dist_traveled = (use_dist_limit() ? distance_limit()*10.0 : huge);
+ dist_traveled = (use_dist_limit() ? distance_limit()*10.0 : huge_val);
if (debug) {
return MB_SUCCESS;
@@ -1380,7 +1380,7 @@
MBErrorCode DagMC::CAD_ray_intersect(const double *point,
const double *dir,
std::vector<double> &distances,
std::vector<MBEntityHandle> &surfaces,
double &len)
@@ -1406,7 +1406,7 @@
ray_params.reset();
*dit = ray_params.get();
- else *dit = huge;
+ else *dit = huge_val;
// now bubble sort list
Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
--- MOAB/trunk/tools/dagmc/DagMC.hpp 2007-12-07 21:34:19 UTC (rev 1452)
+++ MOAB/trunk/tools/dagmc/DagMC.hpp 2007-12-07 22:33:51 UTC (rev 1453)
@@ -34,7 +34,7 @@
const int num_pts,
double &dist_traveled, MBEntityHandle &next_surf_hit);
// Test if point is inside or outside of a volume using unit sphere area method
@@ -153,7 +153,7 @@
MBErrorCode CAD_ray_intersect(const double *point,
const double *dir,
double &len);
