[MOAB-dev] r1449 - in MOAB/trunk: . mhdf/src tools/dagmc
    kraftche at mcs.anl.gov
    Fri Dec  7 15:17:55 CST 2007
Author: kraftche
Date: 2007-12-07 15:17:55 -0600 (Fri, 07 Dec 2007)
New Revision: 1449
Modified:
   MOAB/trunk/MBOrientedBoxTreeTool.cpp
   MOAB/trunk/mhdf/src/tags.c
   MOAB/trunk/tools/dagmc/cgm2moab.cc
Log:
bug fixes from Byron
Modified: MOAB/trunk/MBOrientedBoxTreeTool.cpp
--- MOAB/trunk/MBOrientedBoxTreeTool.cpp	2007-12-07 21:10:23 UTC (rev 1448)
+++ MOAB/trunk/MBOrientedBoxTreeTool.cpp	2007-12-07 21:17:55 UTC (rev 1449)
@@ -321,6 +321,8 @@
   MBErrorCode rval;
   int count = sets.size();
+  if (0 == count)
+    return MB_FAILURE;
     // calculate box
   MBOrientedBox box;
Modified: MOAB/trunk/mhdf/src/tags.c
--- MOAB/trunk/mhdf/src/tags.c	2007-12-07 21:10:23 UTC (rev 1448)
+++ MOAB/trunk/mhdf/src/tags.c	2007-12-07 21:17:55 UTC (rev 1449)
@@ -65,7 +65,7 @@
         return sgn == H5T_SGN_NONE ? H5T_NATIVE_UINT   : H5T_NATIVE_INT;
       else if (sizeof(      long ) == size)
         return sgn == H5T_SGN_NONE ? H5T_NATIVE_ULONG  : H5T_NATIVE_LONG;
-      else if (sizeof( long long ) == size)
+      else if (H5Tget_size(H5T_NATIVE_LLONG) == size)
         return sgn == H5T_SGN_NONE ? H5T_NATIVE_ULLONG : H5T_NATIVE_LLONG;
       mhdf_setFail( status, "Invalid size for integer type: %d", size );
Modified: MOAB/trunk/tools/dagmc/cgm2moab.cc
--- MOAB/trunk/tools/dagmc/cgm2moab.cc	2007-12-07 21:10:23 UTC (rev 1448)
+++ MOAB/trunk/tools/dagmc/cgm2moab.cc	2007-12-07 21:17:55 UTC (rev 1449)
@@ -307,7 +307,7 @@
       // Special case for point curve
     if (points.size() < 2) {
-      if (start_vtx != end_vtx || curve->measure() > GEOMETRY_RESABS) {
+      if (start_vtx != end_vtx || curve->measure() > gqe->get_sme_resabs_tolerance()) {
         std::cerr << "Warning: No facetting for curve " << edge->id() << std::endl;
         continue;
@@ -318,15 +318,15 @@
       continue;
-    const bool closed = (points.front() - points.back()).length() < GEOMETRY_RESABS;
+    const bool closed = (points.front() - points.back()).length() < gqe->get_sme_resabs_tolerance();
     if (closed != (start_vtx == end_vtx)) {
       std::cerr << "Warning: topology and geometry inconsistant for possibly closed curve "
       // check proximity of vertices to end coordinates
-    if ((start_vtx->coordinates() - points.front()).length() > GEOMETRY_RESABS
-     || (  end_vtx->coordinates() - points.back() ).length() > GEOMETRY_RESABS) {
+    if ((start_vtx->coordinates() - points.front()).length() > gqe->get_sme_resabs_tolerance()
+     || (  end_vtx->coordinates() - points.back() ).length() > gqe->get_sme_resabs_tolerance()) {
       std::cerr << "Warning: vertices not at ends of curve " << edge->id() << std::endl;
@@ -392,7 +392,7 @@
         CubitVector vpos( data.point_list()[j].x,
                           data.point_list()[j].y,
                           data.point_list()[j].z );
-        if ((pos - vpos).length_squared() < GEOMETRY_RESABS*GEOMETRY_RESABS) {
+        if ((pos - vpos).length_squared() < gqe->get_sme_resabs_tolerance()*gqe->get_sme_resabs_tolerance()) {
           if (verts[j])
             std::cerr << "Warning: Coincident vertices in surface " << face->id() << std::endl;
           verts[j] = entmap[0][vtx];
