[MOAB-dev] r1445 - MOAB/trunk/mhdf/src
kraftche at mcs.anl.gov
Fri Dec 7 14:42:03 CST 2007
Author: kraftche
Date: 2007-12-07 14:42:03 -0600 (Fri, 07 Dec 2007)
New Revision: 1445
Modified:
MOAB/trunk/mhdf/src/file.c
Log:
fix bug passing back max file ID
Modified: MOAB/trunk/mhdf/src/file.c
--- MOAB/trunk/mhdf/src/file.c 2007-12-07 18:35:36 UTC (rev 1444)
+++ MOAB/trunk/mhdf/src/file.c 2007-12-07 20:42:03 UTC (rev 1445)
@@ -266,7 +266,6 @@
FileHandle* file_ptr;
unsigned int flags;
hid_t group_id;
- unsigned long long max_id = 0;
API_BEGIN;
/* Check if file is HDF5 */
@@ -307,7 +306,7 @@
if (max_id_out)
- *max_id_out = max_id;
+ *max_id_out = file_ptr->max_id;
mhdf_setOkay( status );
API_END_H(1);
