[MOAB-dev] r1266 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Fri Aug 31 11:38:22 CDT 2007
Author: kraftche
Date: 2007-08-31 11:38:22 -0500 (Fri, 31 Aug 2007)
New Revision: 1266
Modified:
   MOAB/trunk/DenseTagCollections.cpp
   MOAB/trunk/DenseTagCollections.hpp
   MOAB/trunk/MBBits.cpp
   MOAB/trunk/MBBits.hpp
   MOAB/trunk/SparseTagCollections.cpp
   MOAB/trunk/SparseTagCollections.hpp
   MOAB/trunk/TagServer.cpp
   MOAB/trunk/TagServer.hpp
Log:
o make TagServer::mTagTable a 2D array indexed by tag type and tag id
  (was a std::map from tag handle to TagInfo)
o make TagServer responsible for allocating tag ids, rather than the
  individual tag storage implementations (dense, sparse, bit)
Modified: MOAB/trunk/DenseTagCollections.cpp
--- MOAB/trunk/DenseTagCollections.cpp	2007-08-30 14:50:36 UTC (rev 1265)
+++ MOAB/trunk/DenseTagCollections.cpp	2007-08-31 16:38:22 UTC (rev 1266)
@@ -36,25 +36,23 @@
 const int DensePage::mPageSize = 1024;
 /*! returns an available tag id to use when getting and setting data */
-MBErrorCode DenseTagSuperCollection::reserve_tag_id(int num_bytes, const void* default_data, MBTagId& tag_id)
+MBErrorCode DenseTagSuperCollection::reserve_tag_id(int num_bytes, const void* default_data, MBTagId tag_id)
   // make sure we get a good number of bytes
   if(num_bytes <= 0 )
-    tag_id = 0;
     return MB_FAILURE;
-  for (tag_id = 0; tag_id < mDensePageGroups.size(); ++tag_id)
-    if (!mDensePageGroups[tag_id])
-      break;
+  // make sure we have storage for tag id
+  if (mDensePageGroups.size() <= tag_id)
+    mDensePageGroups.resize( tag_id+1, 0 );
-  if (tag_id == mDensePageGroups.size())
-    mDensePageGroups.push_back( new DensePageGroup( num_bytes, default_data ) );
-  else
-    mDensePageGroups[tag_id] = new DensePageGroup( num_bytes, default_data ) ;
+  // make sure tag_id isn't already in use
+  if (mDensePageGroups[tag_id])
+    return MB_FAILURE;
+  // allocate tag data
+  mDensePageGroups[tag_id] = new DensePageGroup( num_bytes, default_data ) ;
-  // can we really fail?
   return MB_SUCCESS;
Modified: MOAB/trunk/DenseTagCollections.hpp
--- MOAB/trunk/DenseTagCollections.hpp	2007-08-30 14:50:36 UTC (rev 1265)
+++ MOAB/trunk/DenseTagCollections.hpp	2007-08-31 16:38:22 UTC (rev 1266)
@@ -362,8 +362,8 @@
   void reset_data();
-  //! return an available tag id for use
-  MBErrorCode reserve_tag_id(int data_size, const void* default_data, MBTagId& tag_id);
+  //! allocate new tag id
+  MBErrorCode reserve_tag_id(int data_size, const void* default_data, MBTagId tag_id);
   //! release a tag id for reuse
   MBErrorCode release_tag_id(MBTagId tag_id);
   //! get the tag size
Modified: MOAB/trunk/MBBits.cpp
--- MOAB/trunk/MBBits.cpp	2007-08-30 14:50:36 UTC (rev 1265)
+++ MOAB/trunk/MBBits.cpp	2007-08-31 16:38:22 UTC (rev 1266)
@@ -45,41 +45,22 @@
 const int MBBitPage::mPageSize = 512;
 /*! returns an available tag id to use when getting and setting bits */
-MBErrorCode MBBitServer::reserve_tag_id(int num_bits, MBTagId& tag_id)
+MBErrorCode MBBitServer::reserve_tag_id(int num_bits, MBTagId tag_id)
-  tag_id = 0;
+  for(int i=0; i<(int)MBMAXTYPE; i++)
+    if (tag_id >= mBitPageGroups[i].size())
+      mBitPageGroups[i].resize( tag_id + 1, 0 );
+    if (mBitPageGroups[i][tag_id-1])
-  // make sure we get a good number of bits
-  if(num_bits <= 0 || num_bits >8)
-    return MB_FAILURE;
-  // see if we have any bit page groups that aren't being used
-  for(std::vector<MBBitPageGroup*>::iterator iter = (*mBitPageGroups).begin();
-      iter != (*mBitPageGroups).end(); ++iter)
-    if(*iter == NULL)
-      tag_id = iter - (*mBitPageGroups).begin() + 1;
-      break;
-  // if they are all being used, make space for a new one
-  if(!tag_id)
-    for(int i=0; i<(int)MBMAXTYPE; i++)
-      mBitPageGroups[i].push_back( NULL );
-    tag_id = (*mBitPageGroups).size();
     mBitPageGroups[i][tag_id-1] = new MBBitPageGroup(num_bits);
   mBitPageGroupsSize = (*mBitPageGroups).size();
   return MB_SUCCESS;
Modified: MOAB/trunk/MBBits.hpp
--- MOAB/trunk/MBBits.hpp	2007-08-30 14:50:36 UTC (rev 1265)
+++ MOAB/trunk/MBBits.hpp	2007-08-31 16:38:22 UTC (rev 1266)
@@ -453,8 +453,8 @@
   void reset_data();
-  MBErrorCode reserve_tag_id(int num_bits, MBTagId& tag_id);
+  //! allocate data for tag with specified ID
+  MBErrorCode reserve_tag_id(int num_bits, MBTagId tag_id);
Modified: MOAB/trunk/SparseTagCollections.cpp
--- MOAB/trunk/SparseTagCollections.cpp	2007-08-30 14:50:36 UTC (rev 1265)
+++ MOAB/trunk/SparseTagCollections.cpp	2007-08-31 16:38:22 UTC (rev 1266)
@@ -60,20 +60,17 @@
-MBErrorCode SparseTagSuperCollection::reserve_tag_id(int data_size, MBTagId& tag_id)
+MBErrorCode SparseTagSuperCollection::reserve_tag_id(int data_size, MBTagId tag_id)
   if(data_size<=0)
     return MB_FAILURE;
-  // start at 1
-  tag_id = 1;
-  while (tag_id < mDataTags.size() && mDataTags[tag_id])
-    ++tag_id;
   if (tag_id >= mDataTags.size())
     mDataTags.resize( tag_id+1, 0 );
+  if (mDataTags[tag_id])
   mDataTags[tag_id] = new SparseTagCollection(data_size);
   return MB_SUCCESS;
Modified: MOAB/trunk/SparseTagCollections.hpp
--- MOAB/trunk/SparseTagCollections.hpp	2007-08-30 14:50:36 UTC (rev 1265)
+++ MOAB/trunk/SparseTagCollections.hpp	2007-08-31 16:38:22 UTC (rev 1266)
@@ -137,8 +137,8 @@
   void reset_data();
-  //! reserves an MBTagId for use
-  MBErrorCode reserve_tag_id(int data_size, MBTagId& tag_id);
+  MBErrorCode reserve_tag_id(int data_size, MBTagId tag_id);
   //! releases an MBTagId
Modified: MOAB/trunk/TagServer.cpp
--- MOAB/trunk/TagServer.cpp	2007-08-30 14:50:36 UTC (rev 1265)
+++ MOAB/trunk/TagServer.cpp	2007-08-31 16:38:22 UTC (rev 1266)
@@ -58,19 +58,24 @@
    return sizes[t];
+void TagInfo::invalidate()
+  mTagName.clear();
+  isValid = false;
+  delete [] mDefaultValue;
+  mDefaultValue = 0;
+  delete [] mMeshValue;
+  mMeshValue = 0;
   TagServer functions ----------------------------------
 TagServer::TagServer()
-  // we need these tag properties to be in order.
-  // if this order is changed, then change reset_data() as well
-  assert(MB_TAG_BIT    < MB_TAG_SPARSE);
-  assert(MB_TAG_SPARSE < MB_TAG_DENSE );
-  assert(MB_TAG_DENSE  < MB_TAG_MESH  );
-  assert(MB_TAG_MESH   < MB_TAG_LAST  );
   mSparseData = new SparseTagSuperCollection;
   mDenseData = new DenseTagSuperCollection;
   mBitServer = new MBBitServer;
@@ -78,12 +83,9 @@
 TagServer::~TagServer()
-  if(mSparseData)
-    delete mSparseData;
-  if(mDenseData)
-    delete mDenseData;
-  if(mBitServer)
-    delete mBitServer;
+  delete mSparseData;
+  delete mDenseData;
+  delete mBitServer;
@@ -104,96 +106,90 @@
                                 MBTag &tag_handle,
                                 const void *default_value)
+    // Check if name is already in use
+    // if so, pass back the existing tag handle.
+    // NOTE: If name is NULL or empty (tag is unnamed),
+    // get_handle will return zero, so no explicit
+    // check is required here.
+  tag_handle = get_handle( tag_name );
+  if (tag_handle)
+    return MB_ALREADY_ALLOCATED;
-  if(NULL != tag_name && strcmp(tag_name, "") != 0)
-    // verify that the name doesn't already exist for this entity type
-    for(std::map<MBTag, TagInfo>::iterator tag_iterator = mTagTable.begin();
-        tag_iterator != mTagTable.end();
-        ++tag_iterator)
-      // if the type and name matches, another tag, return a "null" handle
-      if(strcmp(tag_name, tag_iterator->second.get_name().c_str()) == 0)
-        tag_handle = tag_iterator->first;
-        return MB_ALREADY_ALLOCATED;
-  MBErrorCode result = MB_FAILURE;;
-  MBTagId id;
     // Input size must be a multiple of the size of the data type.
   int typesize = TagInfo::size_from_data_type( data_type );
   if (data_size % typesize)
     return MB_FAILURE;
-  switch(storage) {
+    // data type must be BIT of tag storage type is BIT
+  if (storage == MB_TAG_BIT && data_type != MB_TYPE_BIT)
+    // find an unused tag id
+  std::vector<TagInfo>& list = mTagTable[storage];
+  std::vector<TagInfo>::iterator i;
+  for (i = list.begin(); i != list.end(); ++i)
+    if (!i->is_valid())
+      break;
+    // add TagInfo entry for new tag
+  if (i == list.end())
+    i = list.insert( i, TagInfo( tag_name, data_size, data_type, default_value ) );
+  else
+    *i = TagInfo( tag_name, data_size, data_type, default_value );
+  MBTagId tag_id = i - list.begin() + 1;
+  tag_handle = TAG_HANDLE_FROM_ID( tag_id, storage );
+  MBErrorCode result = MB_FAILURE;
+  switch (storage) {
     case MB_TAG_BIT:
-      if (data_type != MB_TYPE_BIT)
-      result = mBitServer->reserve_tag_id(data_size, id);
+      result = mBitServer->reserve_tag_id( data_size, tag_id );
       break;
     case MB_TAG_SPARSE:
-      result = mSparseData->reserve_tag_id(data_size, id);
+      result = mSparseData->reserve_tag_id(data_size, tag_id);
       break;
     case MB_TAG_DENSE:
-      result = mDenseData->reserve_tag_id(data_size, default_value, id);
+      result = mDenseData->reserve_tag_id(data_size, default_value, tag_id);
       break;
     case MB_TAG_MESH:
-      result = reserve_mesh_tag_id( id );
+      result = MB_SUCCESS;
       break;
-  if(result != MB_SUCCESS)
-    return result;
-  tag_handle = TAG_HANDLE_FROM_ID( id, storage );
-  // we have a valid id, lets register it
-  if(tag_handle > 0)
-    TagInfo tag_info(tag_name, data_size, data_type, default_value);
-    mTagTable.insert( std::pair<MBTag, TagInfo>( tag_handle, tag_info ) );
-  return MB_SUCCESS;
+  if (MB_SUCCESS != result)
+    i->invalidate();
+  return result;
 MBErrorCode TagServer::remove_tag(const MBTag tag_handle)
-  const std::map<MBTag, TagInfo>::iterator iterator = mTagTable.find(tag_handle);
-  if(iterator == mTagTable.end())
+  const MBTagId tag_id = ID_FROM_TAG_HANDLE( tag_handle );
+  const MBTagType tag_type = PROP_FROM_TAG_HANDLE( tag_handle );
+  const unsigned tag_idx = tag_id - 1;
+  if (tag_idx >= mTagTable[tag_type].size() ||
+      !mTagTable[tag_type][tag_idx].is_valid())
     return MB_TAG_NOT_FOUND;
-  MBErrorCode status = MB_FAILURE;
-  MBTagId id = ID_FROM_TAG_HANDLE(tag_handle);
-  switch (PROP_FROM_TAG_HANDLE(tag_handle)) {
+  MBErrorCode status = MB_FAILURE;
+  switch (tag_type) {
     case MB_TAG_BIT:
-      status = mBitServer->release_tag_id(id);
+      status = mBitServer->release_tag_id(tag_id);
       break;
     case MB_TAG_SPARSE:
-      status = mSparseData->release_tag_id(id);
+      status = mSparseData->release_tag_id(tag_id);
       break;
     case MB_TAG_DENSE:
-      status = mDenseData->release_tag_id(id);
+      status = mDenseData->release_tag_id(tag_id);
       break;
     case MB_TAG_MESH:
       status = MB_SUCCESS;
       break;
-  if (MB_SUCCESS == status) {
-    mTagTable.erase(iterator);
+  mTagTable[tag_type][tag_idx].invalidate();
   return status;
@@ -201,36 +197,22 @@
 //! this is used to clean out stale data that might be referenced again
 MBErrorCode TagServer::reset_data(MBEntityHandle entity_handle)
-  // note: this algorithm assumes that tag properties are
-  // BITS < SPARSE < DENSE < STATIC.
-  // if that is not the case anymore, then rearrange this algorithm
-  if(TYPE_FROM_HANDLE(entity_handle) >= MBMAXTYPE)
-    return MB_TYPE_OUT_OF_RANGE;
+  MBTagId tag_id;
-  std::map<MBTag, TagInfo>::iterator iter;
+  for (tag_id = 1; tag_id <= mTagTable[MB_TAG_BIT].size(); ++tag_id)
+    if (mTagTable[MB_TAG_BIT][tag_id-1].is_valid())
+        // default data for bits is zero
+      mBitServer->weak_set_bits( tag_id, entity_handle, 0 );
-  // go through and clean out the bits
-  MBTag max_tag = TAG_HANDLE_FROM_ID(0,MB_TAG_SPARSE);
-  for(iter = mTagTable.begin(); iter != mTagTable.end() && iter->first < max_tag; ++iter)
-    // default data for bits is zero
-    mBitServer->weak_set_bits(ID_FROM_TAG_HANDLE(iter->first), entity_handle, 0);
+  for (tag_id = 1; tag_id <= mTagTable[MB_TAG_SPARSE].size(); ++tag_id)
+    if (mTagTable[MB_TAG_SPARSE][tag_id-1].is_valid())
+      mSparseData->remove_data( tag_id, entity_handle );
-  // now clean out the sparse data
-  max_tag = TAG_HANDLE_FROM_ID(0,MB_TAG_DENSE);
-  for( ; iter != mTagTable.end() && iter->first < max_tag; ++iter)
-    mSparseData->remove_data(ID_FROM_TAG_HANDLE(iter->first), entity_handle);
-  // now clean out the dense data
-  max_tag = TAG_HANDLE_FROM_ID(0,MB_TAG_MESH);
-    mDenseData->remove_data(ID_FROM_TAG_HANDLE(iter->first), entity_handle);
+  for (tag_id = 1; tag_id <= mTagTable[MB_TAG_DENSE].size(); ++tag_id)
+    if (mTagTable[MB_TAG_DENSE][tag_id-1].is_valid())
+      mDenseData->remove_data( tag_id, entity_handle );
   return MB_SUCCESS;
@@ -588,30 +570,23 @@
   return MB_SUCCESS;
-MBTag TagServer::get_handle(const char *tag_name)
+MBTag TagServer::get_handle(const char *tag_name) const
-  // perhaps speed this up since tag handles are sorted by tag properties
-  // then sorted by entity type
-  std::map<MBTag, TagInfo>::iterator iterator;
-  for(iterator = mTagTable.begin(); iterator != mTagTable.end(); ++iterator)
-    if (strcmp(tag_name, iterator->second.get_name().c_str()) == 0)
-        return iterator->first;
+  if (tag_name && *tag_name)
+    for (int i = 0; i < MB_TAG_LAST; ++i)
+      for (MBTagId j = 0; j < mTagTable[i].size(); ++j)
+        if (mTagTable[i][j].is_valid() && mTagTable[i][j].get_name() == tag_name)
+          return TAG_HANDLE_FROM_ID( j + 1, (MBTagType)i );
   return 0;
 MBErrorCode TagServer::get_tags(std::vector<MBTag> &all_tags)
-    all_tags.push_back(iterator->first);
+      if (mTagTable[i][j].is_valid())
+        all_tags.push_back( TAG_HANDLE_FROM_ID( j + 1, (MBTagType)i ) );
   return MB_SUCCESS;
@@ -634,10 +609,11 @@
 MBErrorCode TagServer::get_mesh_tags( std::vector<MBTag>& all_tags ) const
-  std::map<MBTag,TagInfo>::const_iterator i;
-  for (i = mTagTable.begin(); i != mTagTable.end(); ++i)
-    if (i->second.get_mesh_value())
-      all_tags.push_back( i->first );
+      if (mTagTable[i][j].is_valid() && mTagTable[i][j].get_mesh_value())
   return MB_SUCCESS;
@@ -1014,7 +990,7 @@
 unsigned long TagServer::get_memory_use( MBTag tag_handle ) const
-  if (mTagTable.find(tag_handle) == mTagTable.end())
+  if (!get_tag_info(tag_handle))
     return 0;
   unsigned long result = 0, tmp;
@@ -1070,23 +1046,6 @@
   return MB_SUCCESS;
-MBErrorCode TagServer::reserve_mesh_tag_id( MBTagId& id_out ) const
-  MBTag tag = TAG_HANDLE_FROM_ID( 1, MB_TAG_MESH );
-  std::map<MBTag,TagInfo>::const_iterator i = mTagTable.lower_bound( tag );
-  if (i == mTagTable.end() || i->first > tag) {
-    id_out = 1;
-  tag = i->first + 1;
-  for (++i; i != mTagTable.end() && tag == i->first; ++i)
-  id_out = ID_FROM_TAG_HANDLE( tag );
Modified: MOAB/trunk/TagServer.hpp
--- MOAB/trunk/TagServer.hpp	2007-08-30 14:50:36 UTC (rev 1265)
+++ MOAB/trunk/TagServer.hpp	2007-08-31 16:38:22 UTC (rev 1266)
@@ -37,7 +37,6 @@
 #include <string>
 #include <vector>
-#include <map>
 #include "MBTypes.h"
 #include "MBInternals.hpp"
@@ -55,6 +54,7 @@
   //! constructor
   TagInfo() : mTagName(""),
               mDataSize(0),
+              isValid(false),
               mDefaultValue(NULL),
               mMeshValue(NULL),
               dataType(MB_TYPE_OPAQUE)
@@ -101,6 +101,9 @@
   inline void set_data_type( MBDataType t )   { dataType = t; }
   static int size_from_data_type( MBDataType t );
+  bool is_valid() const { return isValid; }
+  void invalidate();
 private:
@@ -111,6 +114,9 @@
   //! stores the size of the data for this tag
   unsigned short mDataSize;
+  //! flag to mark unused entries
+  bool isValid;
   //! stores the default data, if any
   unsigned char *mDefaultValue;
@@ -245,7 +251,7 @@
   MBEntityHandle find_entity( const MBTag tag_handle, const void* data );
   //! gets a tag handle by name and entity handle
-  MBTag get_handle(const char *tag_name);
+  MBTag get_handle(const char *tag_name) const;
   //! get all the tags which have been defined for this entity
   MBErrorCode get_tags(const MBEntityHandle entity, std::vector<MBTag> &all_tags);
@@ -275,14 +281,11 @@
 private:
-  MBErrorCode reserve_mesh_tag_id( MBTagId& id_out ) const;
+  //! Table of tag ids and tag information
+  //! Primary (array) index is tag type.
+  //! Secondary (std::vector) index is tag id less one (tag ids begin with 1).
+  std::vector<TagInfo> mTagTable[MB_TAG_LAST];
-  //! table of tag ids and tag information
-  //! do we really need to do it this way?
-  //! we at least need a table between names and tag ids
-  //! and we need information between tag ids and tag usage
-  std::map< MBTag, TagInfo >  mTagTable;
   //! container for storing the sparse data and tag ids
   SparseTagSuperCollection* mSparseData;
@@ -303,6 +306,7 @@
 inline TagInfo::TagInfo(const TagInfo& copy)
   : mTagName( copy.mTagName ),
     mDataSize( copy.mDataSize ),
+    isValid( copy.isValid ),
     mDefaultValue( 0 ),
     mMeshValue( 0 ),
     dataType( copy.dataType )
@@ -324,6 +328,7 @@
                          const void* default_value)
  : mTagName( name ),
    mDataSize( size ),
+   isValid( true ),
    mDefaultValue( 0 ),
    mMeshValue( 0 ),
    dataType( type )
@@ -338,6 +343,7 @@
   mTagName = rhs.mTagName;
   mDataSize = rhs.mDataSize;
+  isValid = rhs.isValid;
@@ -380,38 +386,28 @@
 inline const TagInfo* TagServer::get_tag_info( const char *tag_name ) const
-  if(NULL == tag_name || strcmp(tag_name, "") == 0)
-    return NULL;
-  std::map<MBTag, TagInfo>::const_iterator iterator;
-  const std::string temp_name = tag_name;
-      if ( temp_name.size()  == iterator->second.get_name().size() &&
-           std::equal(temp_name.begin(), temp_name.end(), iterator->second.get_name().begin() ) )
-        return &(iterator->second);
-  return NULL;
+  const MBTag handle = get_handle( tag_name );
+  return handle ? get_tag_info( handle ) : 0;
 inline const TagInfo* TagServer::get_tag_info( MBTag tag_handle ) const
-  std::map<MBTag, TagInfo>::const_iterator iterator = mTagTable.find(tag_handle);
-  if ( iterator != mTagTable.end() )
-  return NULL;
+  const MBTagId id = ID_FROM_TAG_HANDLE( tag_handle );
+  const MBTagType type = PROP_FROM_TAG_HANDLE( tag_handle );
+  if (id <= mTagTable[type].size() && mTagTable[type][id-1].is_valid())
+    return &mTagTable[type][id-1];
+  else
+    return NULL;
 inline TagInfo* TagServer::get_tag_info( MBTag tag_handle )
-  std::map<MBTag, TagInfo>::iterator i = mTagTable.find(tag_handle);
-  return (i == mTagTable.end()) ? (TagInfo*)0 : &(i->second);
+  else
+    return NULL;
 #endif //TAG_SERVER_HPP
