[MOAB-dev] r1258 - MOAB/trunk
kraftche at mcs.anl.gov
Mon Aug 27 16:06:13 CDT 2007
Author: kraftche
Date: 2007-08-27 16:06:13 -0500 (Mon, 27 Aug 2007)
New Revision: 1258
Modified:
MOAB/trunk/MBParallelComm.cpp
MOAB/trunk/MBParallelComm.hpp
Log:
Add MBParallelComm::broadcast_entities
Modified: MOAB/trunk/MBParallelComm.cpp
--- MOAB/trunk/MBParallelComm.cpp 2007-08-27 16:01:06 UTC (rev 1257)
+++ MOAB/trunk/MBParallelComm.cpp 2007-08-27 21:06:13 UTC (rev 1258)
@@ -206,6 +206,59 @@
#endif
+MBErrorCode MBParallelComm::broadcast_entities( const int from_proc,
+ MBRange &entities,
+ const bool adjacencies,
+ const bool tags)
+#ifndef USE_MPI
+ return MB_FAILURE;
+#else
+ MBErrorCode result = MB_SUCCESS;
+ int success;
+ MBRange whole_range;
+ int buff_size;
+ allRanges.clear();
+ vertsPerEntity.clear();
+ setRange.clear();
+ setRanges.clear();
+ allTags.clear();
+ setSizes.clear();
+ optionsVec.clear();
+ setPcs.clear();
+ if ((int)procInfo.rank() == from_proc) {
+ result = pack_buffer( entities, adjacencies, tags, true, whole_range, buff_size ); RR;
+ success = MPI_Bcast( &buff_size, 1, MPI_INT, from_proc, MPI_COMM_WORLD );
+ if (MPI_SUCCESS != success)
+ if (!buff_size) // no data
+ return MB_SUCCESS;
+ myBuffer.reserve( buff_size );
+ int actual_buffer_size;
+ result = pack_buffer( entities, adjacencies, tags, false, whole_range, actual_buffer_size ); RR;
+ success = MPI_Bcast( &myBuffer[0], buff_size, MPI_UNSIGNED_CHAR, from_proc, MPI_COMM_WORLD );
+ if ((int)procInfo.rank() != from_proc) {
+ result = unpack_buffer( entities ); RR;
+#endif
MBErrorCode MBParallelComm::pack_buffer(MBRange &entities,
const bool tags,
Modified: MOAB/trunk/MBParallelComm.hpp
--- MOAB/trunk/MBParallelComm.hpp 2007-08-27 16:01:06 UTC (rev 1257)
+++ MOAB/trunk/MBParallelComm.hpp 2007-08-27 21:06:13 UTC (rev 1258)
@@ -57,6 +57,11 @@
const bool adjacencies = false,
const bool tags = true);
+ MBErrorCode broadcast_entities( const int from_proc,
+ MBRange& entities,
+ const bool adjacencies = false,
+ const bool tags = true );
//! pack a buffer (stored in this class instance) with ALL data for these entities
MBErrorCode pack_buffer(MBRange &entities,
