[MOAB-dev] r1252 - MOAB/trunk
kraftche at mcs.anl.gov
Fri Aug 24 15:05:52 CDT 2007
Author: kraftche
Date: 2007-08-24 15:05:52 -0500 (Fri, 24 Aug 2007)
New Revision: 1252
Modified:
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBReaderIface.hpp
MOAB/trunk/ReadGmsh.cpp
MOAB/trunk/ReadGmsh.hpp
MOAB/trunk/ReadHDF5.cpp
MOAB/trunk/ReadHDF5.hpp
MOAB/trunk/ReadNCDF.cpp
MOAB/trunk/ReadNCDF.hpp
MOAB/trunk/ReadSTL.cpp
MOAB/trunk/ReadSTL.hpp
MOAB/trunk/ReadVtk.cpp
MOAB/trunk/ReadVtk.hpp
MOAB/trunk/Tqdcfr.cpp
MOAB/trunk/Tqdcfr.hpp
Log:
o Change MBReaderIface::load_file such that readers are required to
pass back an entity set containing all entities read from file.
o Update all readers to create and pass back an entity set containing
entities read from file (all but Tqdcfr already maintained such an
entity set internally.)
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/MBCore.cpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -359,7 +359,7 @@
MBReaderIface* reader = set->get_file_extension_reader( file_name );
if (reader)
- rval = reader->load_file( file_name, block_id_list, num_blocks );
+ rval = reader->load_file( file_name, file_set, block_id_list, num_blocks );
delete reader;
return rval;
@@ -371,7 +371,7 @@
MBReaderIface* reader = iter->make_reader( this );
if (NULL != reader)
delete reader;
if (MB_SUCCESS == rval)
return MB_SUCCESS;
Modified: MOAB/trunk/MBReaderIface.hpp
--- MOAB/trunk/MBReaderIface.hpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/MBReaderIface.hpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -38,12 +38,14 @@
* Method all readers must provide to import a mesh.
*\param file_name The file to read.
+ *\param file_set Output: a new entity set containing all data read from file.
*\param material_set_list A list of material sets to read, or NULL
* if the entire file is to be read.
*\param material_set_list_len The length of <code>material_set_list</code>
*\author Jason Kraftcheck
virtual MBErrorCode load_file( const char* file_name,
+ MBEntityHandle& file_set,
const int* material_set_list,
const int material_set_list_len ) = 0;
Modified: MOAB/trunk/ReadGmsh.cpp
--- MOAB/trunk/ReadGmsh.cpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/ReadGmsh.cpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -77,6 +77,7 @@
MBErrorCode ReadGmsh::load_file( const char* filename,
const int* blocks,
const int num_blocks )
@@ -94,6 +95,7 @@
mCurrentMeshHandle = 0;
+ file_set = mCurrentMeshHandle;
return result;
Modified: MOAB/trunk/ReadGmsh.hpp
--- MOAB/trunk/ReadGmsh.hpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/ReadGmsh.hpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -39,6 +39,7 @@
static MBReaderIface* factory( MBInterface* );
MBErrorCode load_file(const char *file_name,
const int num_material_sets );
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/ReadHDF5.cpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -107,7 +107,7 @@
H5Tclose( handleType );
-MBErrorCode ReadHDF5::load_file( const char* filename, const int*, const int num_blocks )
+MBErrorCode ReadHDF5::load_file( const char* filename, MBEntityHandle& file_set, const int*, const int num_blocks )
MBErrorCode rval;
mhdf_Status status;
@@ -116,9 +116,11 @@
char** tag_names = NULL;
char** groups = NULL;
std::list<ElemSet>::iterator el_itor;
+ std::list<ElemSet>::reverse_iterator rel_itor;
unsigned int i, num_groups;
MBEntityHandle all; // meshset of everything in file.
bool have_nodes = true;
+ file_set = 0;
if (num_blocks)
return MB_FAILURE;
@@ -211,6 +213,18 @@
DEBUGOUT("Finishing read.\n");
if (MB_SUCCESS != read_qa( all ))
goto read_fail;
+DEBUGOUT("Creating entity set for file contents\n")
+ if (MB_SUCCESS != iFace->create_meshset( MESHSET_SET, file_set ))
+ goto read_fail;
+ if (MB_SUCCESS != iFace->add_entities( file_set, setSet.range ))
+ goto read_fail;
+ for (rel_itor = elemList.rbegin(); rel_itor != elemList.rend(); ++rel_itor)
+ if (MB_SUCCESS != iFace->add_entities( file_set, rel_itor->range))
+ goto read_fail;
+ if (MB_SUCCESS != iFace->add_entities( file_set, nodeSet.range ))
+ goto read_fail;
// Clean up and exit.
free( dataBuffer );
@@ -223,6 +237,9 @@
read_fail:
+ if (file_set)
+ iFace->delete_entities( &file_set, 1 );
if (dataBuffer)
free( dataBuffer );
Modified: MOAB/trunk/ReadHDF5.hpp
--- MOAB/trunk/ReadHDF5.hpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/ReadHDF5.hpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -47,6 +47,7 @@
* \param export_set_count Length of <code>export_sets</code> array.
MBErrorCode load_file( const char* filename,
int material_set_count );
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/ReadNCDF.cpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -406,9 +406,11 @@
MBErrorCode ReadNCDF::load_file(const char *exodus_file_name,
const int *blocks_to_load,
const int num_blocks)
+ file_set = 0;
// this function directs the reading of an exoii file, but doesn't do any of
// the actual work
@@ -460,6 +462,7 @@
// what about properties???
return MB_SUCCESS;
Modified: MOAB/trunk/ReadNCDF.hpp
--- MOAB/trunk/ReadNCDF.hpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/ReadNCDF.hpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -64,6 +64,7 @@
//! load an ExoII file
MBErrorCode load_file(const char *exodus_file_name,
const int* blocks_to_load,
const int num_blocks);
Modified: MOAB/trunk/ReadSTL.cpp
--- MOAB/trunk/ReadSTL.cpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/ReadSTL.cpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -78,9 +78,10 @@
-MBErrorCode ReadSTL::load_file( const char* filename,
- const int* blocks,
- const int num_blocks )
+MBErrorCode ReadSTL::load_file( const char* filename,
+ const int* blocks,
+ const int num_blocks )
const MBErrorCode result = load_file_impl( filename, blocks, num_blocks );
@@ -96,6 +97,7 @@
return result;
Modified: MOAB/trunk/ReadSTL.hpp
--- MOAB/trunk/ReadSTL.hpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/ReadSTL.hpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -74,6 +74,7 @@
//! Generic file loading code for both binary and ASCII readers.
//! Calls reader-specific read_triangles function to do actual I/O.
Modified: MOAB/trunk/ReadVtk.cpp
--- MOAB/trunk/ReadVtk.cpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/ReadVtk.cpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -53,9 +53,11 @@
MBErrorCode ReadVtk::load_file(const char *filename,
const int*, const int)
MBErrorCode result;
+ file_set = 0;
int major, minor;
char vendor_string[257];
@@ -182,6 +184,7 @@
return result;
return MB_SUCCESS;
Modified: MOAB/trunk/ReadVtk.hpp
--- MOAB/trunk/ReadVtk.hpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/ReadVtk.hpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -31,6 +31,7 @@
//! load a file
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/Tqdcfr.cpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -170,9 +170,11 @@
MBErrorCode Tqdcfr::load_file(const char *file_name,
MBErrorCode result;
+ file_set = mFileSet = 0;
// open file
cubFile = fopen(file_name, "rb");
@@ -183,6 +185,12 @@
if (!(char_buf[0] == 'C' && char_buf[1] == 'U' &&
char_buf[2] == 'B' && char_buf[3] == 'E'))
return MB_FAILURE;
+ // create meshset to contain file
+ result = mdbImpl->create_meshset( MESHSET_SET, file_set );
+ if (MB_SUCCESS != result)
+ return result;
+ mFileSet = file_set;
// read model header type information...
@@ -567,7 +575,7 @@
if (!reverse.empty()) {
// need to make a new set, add a reverse sense tag, then add to the sideset
MBEntityHandle reverse_set;
- MBErrorCode tmp_result = mdbImpl->create_meshset(MESHSET_SET, reverse_set);
+ MBErrorCode tmp_result = create_set(reverse_set);
if (MB_SUCCESS != tmp_result) result = tmp_result;
tmp_result = mdbImpl->add_entities(reverse_set, &reverse[0], reverse.size());
if (tmp_result != MB_SUCCESS) result = tmp_result;
@@ -626,7 +634,7 @@
@@ -941,6 +949,8 @@
node_handle+entity->nodeCt-1);
MBErrorCode result = mdbImpl->add_entities(entity->setHandle, dum_range);
if (MB_SUCCESS != result) return result;
+ result = mdbImpl->add_entities( mFileSet, dum_range );
+ if (MB_SUCCESS != result) return result;
// check for id contiguity
long unsigned int node_offset = mdbImpl->id_from_handle( node_handle);
@@ -1109,6 +1119,8 @@
MBRange dum_range(start_handle, start_handle+num_elem-1);
+ result = mdbImpl->add_entities(mFileSet, dum_range);
// set cub ids
result = mdbImpl->tag_set_data(cubIdTag, dum_range, &int_buf[0]);
@@ -1356,7 +1368,7 @@
for (int i = 0; i < info.numEntities; i++) {
// create an entity set for this entity
- result = instance->mdbImpl->create_meshset(MESHSET_SET, geom_headers[i].setHandle);
+ result = instance->create_set(geom_headers[i].setHandle);
instance->FREADI(8);
@@ -1403,7 +1415,7 @@
- result = instance->mdbImpl->create_meshset(MESHSET_SET, group_headers[i].setHandle);
+ result = instance->create_set(group_headers[i].setHandle);
static const char group_category[CATEGORY_TAG_SIZE] = "Group\0";
@@ -1453,7 +1465,7 @@
- result = instance->mdbImpl->create_meshset(MESHSET_SET, block_headers[i].setHandle);
+ result = instance->create_set(block_headers[i].setHandle);
static const char material_category[CATEGORY_TAG_SIZE] = "Material Set\0";
@@ -1533,7 +1545,7 @@
- result = instance->mdbImpl->create_meshset(MESHSET_SET, nodeset_headers[i].setHandle);
+ result = instance->create_set(nodeset_headers[i].setHandle);
static const char dirichlet_category[CATEGORY_TAG_SIZE] = "Dirichlet Set\0";
@@ -1583,7 +1595,7 @@
- result = instance->mdbImpl->create_meshset(MESHSET_SET, sideset_headers[i].setHandle);
+ result = instance->create_set(sideset_headers[i].setHandle);
static const char neumann_category[CATEGORY_TAG_SIZE] = "Neumann Set\0";
@@ -2380,6 +2392,19 @@
<< std::endl;
+MBErrorCode Tqdcfr::create_set( MBEntityHandle& h, int flags )
+ MBErrorCode rval;
+ if (!mFileSet)
+ return MB_FAILURE;
+ rval = mdbImpl->create_meshset( flags, h );
+ if (MB_SUCCESS != rval)
+ return rval;
+ rval = mdbImpl->add_entities( mFileSet, &h, 1 );
+ mdbImpl->delete_entities( &h, 1 );
+ return rval;
#ifdef TEST_TQDCFR
#include "MBCore.hpp"
@@ -2400,8 +2425,9 @@
MBCore my_impl;
Tqdcfr my_tqd(&my_impl);
+ MBEntityHandle file_set;
- MBErrorCode result = my_tqd.load_file(file, 0, 0);
+ MBErrorCode result = my_tqd.load_file(file, file_set, 0, 0);
if (MB_SUCCESS == result)
std::cout << "Success." << std::endl;
Modified: MOAB/trunk/Tqdcfr.hpp
--- MOAB/trunk/Tqdcfr.hpp 2007-08-24 17:16:31 UTC (rev 1251)
+++ MOAB/trunk/Tqdcfr.hpp 2007-08-24 20:05:52 UTC (rev 1252)
@@ -285,6 +285,7 @@
// read cub file
const int* block_list,
int num_blocks );
MBErrorCode read_nodeset(ModelEntry *model,
@@ -318,9 +319,13 @@
static std::string BLOCK_NODESET_OFFSET_TAG_NAME;
static std::string BLOCK_SIDESET_OFFSET_TAG_NAME;
+ MBErrorCode create_set( MBEntityHandle& h, int flags = MESHSET_SET );
private:
+ MBEntityHandle mFileSet; // set containing read entities.
MBErrorCode convert_nodesets_sidesets();
MBErrorCode read_acis_records();
