[MOAB-dev] r1240 - MOAB/trunk/tools/iMesh/SIDL
kraftche at mcs.anl.gov
Fri Aug 17 09:19:28 CDT 2007
Author: kraftche
Date: 2007-08-17 09:19:28 -0500 (Fri, 17 Aug 2007)
New Revision: 1240
Modified:
MOAB/trunk/tools/iMesh/SIDL/Cclient.make
MOAB/trunk/tools/iMesh/SIDL/Fclient.make
MOAB/trunk/tools/iMesh/SIDL/Makefile.in
MOAB/trunk/tools/iMesh/SIDL/common.make.in
MOAB/trunk/tools/iMesh/SIDL/mserver.make
Log:
o Don't create empty babel.make stubs when building w/out babel--no longer needed
o Don't update timestamp if babel fails
o Add dependencies so that things rebuild when necessary
- NOTE: the C-binding headers are listed explicitly in common.make.in
as dependencies for the SIDL server IMPLSRC list. The
common.make.in will need to be updated if the C-binding
headers change.
Modified: MOAB/trunk/tools/iMesh/SIDL/Cclient.make
--- MOAB/trunk/tools/iMesh/SIDL/Cclient.make 2007-08-16 21:11:00 UTC (rev 1239)
+++ MOAB/trunk/tools/iMesh/SIDL/Cclient.make 2007-08-17 14:19:28 UTC (rev 1240)
@@ -1,6 +1,7 @@
include babel.make
TARGET_LIB = libiMeshCclient.la
+LTLIBS = ../mserver/libiMeshserver.la
C_SRCS = $(STUBSRCS)
CXX_SRCS =
LIBLINK = $(LINK)
Modified: MOAB/trunk/tools/iMesh/SIDL/Fclient.make
--- MOAB/trunk/tools/iMesh/SIDL/Fclient.make 2007-08-16 21:11:00 UTC (rev 1239)
+++ MOAB/trunk/tools/iMesh/SIDL/Fclient.make 2007-08-17 14:19:28 UTC (rev 1240)
@@ -1,6 +1,7 @@
include babel.make
TARGET_LIB = libiMeshFclient.la
CXX_SRCS =
LIBLINK = $(LINK)
Modified: MOAB/trunk/tools/iMesh/SIDL/Makefile.in
--- MOAB/trunk/tools/iMesh/SIDL/Makefile.in 2007-08-16 21:11:00 UTC (rev 1239)
+++ MOAB/trunk/tools/iMesh/SIDL/Makefile.in 2007-08-17 14:19:28 UTC (rev 1240)
@@ -192,30 +192,27 @@
@if test "x$(srcdir)" != "x."; then \
for p in $(SERVER_FILES); do \
$(ECHO) "cat $(srcdir)/$$p > $$p"; \
- cat $(srcdir)/$$p > $$p; \
+ cat $(srcdir)/$$p > $$p || exit 1; \
done \
fi
@if test "x$(USE_BABEL)" = "xyes"; then \
$(ECHO) '$(BABEL) -sC++ $(SIDL_FILES_PATH) -o mserver' ; \
- $(BABEL) -sC++ $(SIDL_FILES_PATH) -o mserver; \
+ $(BABEL) -sC++ $(SIDL_FILES_PATH) -o mserver && touch $@; \
fi
- touch $@
Cclient/babel.make: $(SIDL_FILES)
test -d Cclient || $(mkdir_p) Cclient || exit 1
$(ECHO) '$(BABEL) -cC $(SIDL_FILES_PATH) -o Cclient' ; \
- $(BABEL) -cC $(SIDL_FILES_PATH) -o Cclient; \
+ $(BABEL) -cC $(SIDL_FILES_PATH) -o Cclient && touch $@; \
fi
- touch $@
Fclient/babel.make: $(SIDL_FILES)
test -d Fclient || $(mkdir_p) Fclient || exit 1
$(ECHO) '$(BABEL) -cF77 $(SIDL_FILES_PATH) -o Fclient' ; \
- $(BABEL) -cF77 $(SIDL_FILES_PATH) -o Fclient; \
+ $(BABEL) -cF77 $(SIDL_FILES_PATH) -o Fclient && touch $@; \
fi
- touch $@
.SUFFIXES: .cpp .cc .c .lo
@@ -226,9 +223,13 @@
@$(ECHO) "./$< $(top_srcdir)/test/3k-tri-sphere.vtk"
@./$< $(top_srcdir)/test/3k-tri-sphere.vtk || $(ECHO) "<<<<<<<<<<<<<<<< testcxx FAILED >>>>>>>>>>>>>>>>>>>"
-testcxx : testcxx.lo all
+testcxx : testcxx.lo mserver/libiMeshserver.la
$(CXXLINK) $< mserver/libiMeshserver.la
+mserver/libiMeshserver.la : all
+testcxx.lo : mserver/babel.make
.cpp.lo:
$(LTCXXCOMPILE) -c -o $@ $<
Modified: MOAB/trunk/tools/iMesh/SIDL/common.make.in
--- MOAB/trunk/tools/iMesh/SIDL/common.make.in 2007-08-16 21:11:00 UTC (rev 1239)
+++ MOAB/trunk/tools/iMesh/SIDL/common.make.in 2007-08-17 14:19:28 UTC (rev 1240)
@@ -1,8 +1,6 @@
@SET_MAKE@
-LIBS = $(imesh_builddir)/libiMesh.la \
- $(top_builddir)/libMOAB.la \
- -L$(BABEL_DIR)/lib -lsidl
+LIBS = $(LTLIBS) -L$(BABEL_DIR)/lib -lsidl
INCLUDES = -I$(BABEL_DIR)/include \
-I$(builddir) -I$(srcdir) \
@@ -11,10 +9,10 @@
-I$(sidl_srcdir)
imesh_srcdir = $(sidl_srcdir)/..
-imesh_builddir = $(sidl_builddir)/..
-sidl_srcdir = $(srcdir)/..
-sidl_builddir = $(builddir)/..
-srcdir = ../@srcdir@
+imesh_builddir = ../..
+sidl_srcdir = ../@srcdir@
+sidl_builddir = ..
+srcdir = ../@srcdir@/$(bdir)
top_srcdir = ../@top_srcdir@
VPATH =
pkgdatadir = $(datadir)/@PACKAGE@
@@ -168,13 +166,22 @@
OBJECTS = $(C_SRCS:.c=.lo) $(CXX_SRCS:.cc=.lo)
HEADERS = $(IMPLHDRS) $(IORHDRS) $(STUBHDRS)
-all: $(TARGET_LIB)
+all: debug $(TARGET_LIB)
+debug:
+ pwd
+ @echo "srcdir = $(srcdir)"
+ @echo "builddir = $(builddir)"
+ @echo "sidl_srcdir = $(sidl_srcdir)"
+ @echo "sidl_builddir = $(sidl_builddir)"
+ @echo "imesh_srcdir = $(imesh_srcdir)"
+ @echo "imesh_builddir = $(imesh_builddir)"
install: install-lib install-headers
uninstall: uninstall-lib uninstall-headers
-$(TARGET_LIB): $(OBJECTS)
+$(TARGET_LIB): $(OBJECTS) $(LTLIBS)
$(LIBLINK) -rpath $(libdir) $(LDFLAGS) $(OBJECTS) $(LIBADD) $(LIBS)
@@ -211,3 +218,22 @@
# Tell versions [3.59,3.63) of GNU make to not export all variables.
# Otherwise a system limit (for SysV at least) may be exceeded.
.NOEXPORT:
+# dependencies
+# babel generates a babel.make.dependencies, but at least for
+# 0.10.10, everything it lists depends either directly or
+# indirectly on the SIDL file. As we're using the 'babel.make'
+# as a timestamp, just depend on that to achieve nearly the
+# same effect.
+$(OBJECTS) : babel.make
+# server implementation files also depend on the C interface
+IMESH_C_INC = $(imesh_srcdir)/iBase.h \
+ $(imesh_srcdir)/iMesh.h \
+ $(imesh_builddir)/iBase_FCDefs.h \
+ $(imesh_srcdir)/iMesh_protos.h
+IMPLOBJS = $(IMPLSRCS:.cc=.lo)
+$(IMPLOBJS) : $(IMESH_C_INC)
Modified: MOAB/trunk/tools/iMesh/SIDL/mserver.make
--- MOAB/trunk/tools/iMesh/SIDL/mserver.make 2007-08-16 21:11:00 UTC (rev 1239)
+++ MOAB/trunk/tools/iMesh/SIDL/mserver.make 2007-08-17 14:19:28 UTC (rev 1240)
@@ -1,6 +1,7 @@
include babel.make
TARGET_LIB = libiMeshserver.la
+LTLIBS = ../../libiMesh.la
C_SRCS = $(IORSRCS)
CXX_SRCS = $(IMPLSRCS) $(SKELSRCS) $(STUBSRCS)
LIBLINK = $(CXXLINK)
