[MOAB-dev] r1227 - MOAB/trunk/tools/qvdual
tautges at mcs.anl.gov
Thu Aug 2 05:23:08 CDT 2007
Author: tautges
Date: 2007-08-02 05:23:08 -0500 (Thu, 02 Aug 2007)
New Revision: 1227
Removed:
MOAB/trunk/tools/qvdual/QVTKWidget.cxx
MOAB/trunk/tools/qvdual/QVTKWidget.h
MOAB/trunk/tools/qvdual/QVTKWidget.xpm
MOAB/trunk/tools/qvdual/QVTKWidgetPlugin.cxx
MOAB/trunk/tools/qvdual/QVTKWidgetPlugin.h
Modified:
MOAB/trunk/tools/qvdual/DrawDual.cpp
MOAB/trunk/tools/qvdual/Makefile.am
MOAB/trunk/tools/qvdual/uiQVDual.ui.h
Log:
QVDual changes:
- removed QVTK stuff, which is now part of vtk proper
- updated Makefile.am to account for QVTK removal
- added QVTK to the vtk libs to check for and link in
Modified: MOAB/trunk/tools/qvdual/DrawDual.cpp
--- MOAB/trunk/tools/qvdual/DrawDual.cpp 2007-08-02 10:22:38 UTC (rev 1226)
+++ MOAB/trunk/tools/qvdual/DrawDual.cpp 2007-08-02 10:23:08 UTC (rev 1227)
@@ -1064,7 +1064,7 @@
x_xform = 1.0;
y_xform = 1.0;
- std::cout << "Didn't find transform." << std::endl;
+ if (my_debug) std::cout << "Didn't find transform." << std::endl;
return MB_FAILURE;
@@ -1089,16 +1089,13 @@
if (MB_SUCCESS != result) {
std::cerr << "Trouble resetting drawing data for sheet." << std::endl;
- delete this_wid;
- this_wid = NULL;
if (NULL == this_wid) {
vtkRenderer *this_ren = vtkRenderer::New();
pd = vtkPolyData::New();
- const bool twod = false;
+ const bool twod = true;
if (twod) {
@@ -1882,8 +1879,8 @@
if (NULL != this_gw.qvtkWidget) {
- delete this_gw.qvtkWidget;
- this_gw.qvtkWidget = NULL;
+// delete this_gw.qvtkWidget;
+// this_gw.qvtkWidget = NULL;
Modified: MOAB/trunk/tools/qvdual/Makefile.am
--- MOAB/trunk/tools/qvdual/Makefile.am 2007-08-02 10:22:38 UTC (rev 1226)
+++ MOAB/trunk/tools/qvdual/Makefile.am 2007-08-02 10:23:08 UTC (rev 1227)
@@ -9,10 +9,6 @@
CropToolpopup.ui.h \
DrawDual.cpp \
DrawDual.hpp \
- QVTKWidget.cxx \
- QVTKWidget.h \
- QVTKWidgetPlugin.cxx \
- QVTKWidgetPlugin.h \
main.cpp \
uiQVDual.ui \
uiQVDual.ui.h \
@@ -25,8 +21,7 @@
uiQVDual.o \
moc_uiQVDual.o \
CropToolpopup.o \
- moc_CropToolpopup.o \
- moc_QVTKWidget.o
+ moc_CropToolpopup.o
LDADD = $(extra_depends) $(QVDUAL_LIBS) $(top_builddir)/libMOAB.la
AM_LDFLAGS = -R $(VTK_LIB_DIR)
@@ -44,9 +39,10 @@
moc_CropToolpopup.cpp: CropToolpopup.h
$(MOC) -o $@ CropToolpopup.h
-moc_QVTKWidget.cpp: QVTKWidget.h
- $(MOC) -o $@ QVTKWidget.h
+uiQVDual.ui : uiQVDual.ui.h
+uiQVDual.o: uiQVDual.cpp
.ui.h:
$(UIC) -o $@ $<
Deleted: MOAB/trunk/tools/qvdual/QVTKWidget.cxx
--- MOAB/trunk/tools/qvdual/QVTKWidget.cxx 2007-08-02 10:22:38 UTC (rev 1226)
+++ MOAB/trunk/tools/qvdual/QVTKWidget.cxx 2007-08-02 10:23:08 UTC (rev 1227)
@@ -1,880 +0,0 @@
- * Copyright 2004 Sandia Corporation.
- * Under the terms of Contract DE-AC04-94AL85000, there is a non-exclusive
- * license for use of this work by or on behalf of the
- * U.S. Government. Redistribution and use in source and binary forms, with
- * or without modification, are permitted provided that this Notice and any
- * statement of authorship are reproduced on all copies.
-#include "QVTKWidget.h"
-#include "qevent.h"
-#include "qapplication.h"
-#if QT_VERSION >= 0x040000 && defined(Q_WS_X11)
-#include "qx11info_x11.h"
-#endif
-#include "vtkInteractorStyleTrackballCamera.h"
-#include "vtkRenderWindow.h"
-#include "vtkCommand.h"
-#include "vtkOStrStreamWrapper.h"
-#include <vtkObjectFactory.h>
-// VTK 4.5 added some major functionality, so we'll make a short define to use
-//#if (VTK_MAJOR_VERSION > 4) || (VTK_MAJOR_VERSION == 4 && VTK_MINOR_VERSION >=5)
-//#define QVTK_HAVE_VTK_4_5
-//#endif
-// function to get VTK keysyms from ascii characters
-static const char* ascii_to_key_sym(int);
-// function to get VTK keysyms from Qt keys
-static const char* qt_key_to_key_sym(Qt::Key);
-#if QT_VERSION < 0x040000
-/*! constructor */
-QVTKWidget::QVTKWidget(QWidget* parent, const char* name, Qt::WFlags f)
-#if QT_VERSION < 0x030000
- : QWidget(parent, name, f | 0x10000000) // WWinOwnDC
-#else
- : QWidget(parent, name, f | Qt::WWinOwnDC | Qt::WNoAutoErase)
-#endif
- , mRenWin(NULL)
- // default to strong focus
- this->setFocusPolicy(QWidget::StrongFocus);
- // default to enable mouse events when a mouse button isn't down
- // so we can send enter/leave events to VTK
- this->setMouseTracking(true);
- // set expanding to take up space for better default layouts
- this->setSizePolicy(
- QSizePolicy( QSizePolicy::Expanding, QSizePolicy::Expanding )
- // create a default vtk window
- vtkRenderWindow* win = vtkRenderWindow::New();
- this->SetRenderWindow(win);
- win->Delete();
-#endif
-/*! constructor */
-QVTKWidget::QVTKWidget(QWidget* parent, Qt::WFlags f)
- : QWidget(parent, f | Qt::WWinOwnDC), mRenWin(NULL)
- // we tell the window system not to provide a background
- // and also that we'll provide all the pixels for the entire window.
- // This prevents flickering.
- this->setAttribute(Qt::WA_PaintOnScreen);
- this->setAttribute(Qt::WA_NoSystemBackground);
- this->setFocusPolicy(Qt::StrongFocus);
- win->Delete();
-#endif
-/*! destructor */
-QVTKWidget::~QVTKWidget()
- // get rid of the VTK window
- this->SetRenderWindow(NULL);
-/*! get the render window
-vtkRenderWindow* QVTKWidget::GetRenderWindow()
- return this->mRenWin;
-/*! set the render window
- this will bind a VTK window with the Qt window
- it'll also replace an existing VTK window
-void QVTKWidget::SetRenderWindow(vtkRenderWindow* window)
- // do nothing if we don't have to
- if(window == mRenWin)
- return;
- // unregister previous window
- if(mRenWin)
-#if defined(QVTK_HAVE_VTK_4_5)
- //clean up window as one could remap it
- mRenWin->Finalize();
-#endif
- mRenWin->UnRegister(NULL);
- // now set the window
- mRenWin = window;
- if(mRenWin)
- // register new window
- mRenWin->Register(NULL);
-#ifdef Q_WS_MAC
- // give the Qt/Mac window handle to VTK and flag whether we have a parent
- mRenWin->SetWindowId(reinterpret_cast<void*>(this->handle()));
- mRenWin->SetParentId(reinterpret_cast<void*>(0x1));
-#else
- // give the qt window id to the vtk window for Windows and X11
- mRenWin->SetWindowId( reinterpret_cast<void*>(this->winId()));
-#endif
-#ifdef Q_WS_X11
- // give the qt display id to the vtk window
- mRenWin->SetDisplayId( this->x11Display() );
-#else
- mRenWin->SetDisplayId(QX11Info::display());
-#endif
-#endif
- // tell the vtk window what the size of this window is
- mRenWin->vtkRenderWindow::SetSize(this->width(), this->height());
- mRenWin->vtkRenderWindow::SetPosition(this->x(), this->y());
- // have VTK start this window and create the necessary graphics resources
- mRenWin->Start();
-#if defined (Q_WS_MAC)
- macFixRect();
-#endif
- // if an interactor wasn't provided, we'll make one by default
- if(!mRenWin->GetInteractor())
- // create a default interactor
- QVTKInteractor* iren = QVTKInteractor::New();
- mRenWin->SetInteractor(iren);
- iren->Initialize();
- // now set the default style
- vtkInteractorStyle* style = vtkInteractorStyleTrackballCamera::New();
- iren->SetInteractorStyle(style);
- iren->Delete();
- style->Delete();
- // tell the interactor the size of this window
- mRenWin->GetInteractor()->SetSize(this->width(), this->height());
-/*! get the Qt/VTK interactor
-QVTKInteractor* QVTKWidget::GetInteractor()
- return QVTKInteractor::SafeDownCast(mRenWin->GetInteractor());
-/*! overloaded Qt's event handler to capture additional keys that Qt has
- default behavior for (for example the Tab key)
-bool QVTKWidget::event(QEvent* e)
- if(e->type() == QEvent::KeyPress)
- QKeyEvent* ke = static_cast<QKeyEvent*>(e);
- keyPressEvent(ke);
- return ke->isAccepted();
- return QWidget::event(e);
-/*! handle resize event
-void QVTKWidget::resizeEvent(QResizeEvent* event)
- QWidget::resizeEvent(event);
- if(!mRenWin)
- return;
- // give the size to the interactor and vtk window
- this->mRenWin->vtkRenderWindow::SetSize(this->width(), this->height());
- if(mRenWin->GetInteractor())
- this->mRenWin->GetInteractor()->SetSize(this->width(), this->height());
- macFixRect();
-#endif
-void QVTKWidget::moveEvent(QMoveEvent* event)
- QWidget::moveEvent(event);
- if(!mRenWin)
- return;
- this->mRenWin->vtkRenderWindow::SetPosition(this->x(), this->y());
- macFixRect();
-#endif
-/*! handle paint event
-void QVTKWidget::paintEvent(QPaintEvent* )
- vtkRenderWindowInteractor* iren = NULL;
- if(mRenWin)
- iren = mRenWin->GetInteractor();
- if(!iren || !iren->GetEnabled())
- return;
- iren->Render();
-/*! handle mouse press event
-void QVTKWidget::mousePressEvent(QMouseEvent* event)
- if(mRenWin)
- return;
- // give interactor the event information
- iren->SetEventInformationFlipY(event->x(), event->y(),
- (event->state() & Qt::ControlButton),
- (event->state() & Qt::ShiftButton ));
- // invoke appropriate vtk event
- switch(event->button())
- case Qt::LeftButton:
- iren->InvokeEvent(vtkCommand::LeftButtonPressEvent, NULL);
- break;
- case Qt::MidButton:
- iren->InvokeEvent(vtkCommand::MiddleButtonPressEvent, NULL);
- break;
- case Qt::RightButton:
- iren->InvokeEvent(vtkCommand::RightButtonPressEvent, NULL);
- break;
- default:
- break;
-/*! handle mouse move event
-void QVTKWidget::mouseMoveEvent(QMouseEvent* event)
- if(mRenWin)
- return;
- (event->state() & Qt::ShiftButton));
- // invoke vtk event
- iren->InvokeEvent(vtkCommand::MouseMoveEvent, NULL);
-/*! handle enter event
-void QVTKWidget::enterEvent(QEvent* )
- if(mRenWin)
- return;
- iren->InvokeEvent(vtkCommand::EnterEvent, NULL);
-/*! handle leave event
-void QVTKWidget::leaveEvent(QEvent* )
- if(mRenWin)
- return;
- iren->InvokeEvent(vtkCommand::LeaveEvent, NULL);
-/*! handle mouse release event
-void QVTKWidget::mouseReleaseEvent(QMouseEvent* event)
- if(mRenWin)
- return;
- // give vtk event information
- iren->InvokeEvent(vtkCommand::LeftButtonReleaseEvent, NULL);
- break;
- iren->InvokeEvent(vtkCommand::MiddleButtonReleaseEvent, NULL);
- break;
- iren->InvokeEvent(vtkCommand::RightButtonReleaseEvent, NULL);
- break;
- default:
- break;
-/*! handle key press event
-void QVTKWidget::keyPressEvent(QKeyEvent* event)
- if(mRenWin)
- return;
- // get key and keysym information
- int ascii_key = event->text().length() ? event->text().unicode()->latin1() : 0;
- const char* keysym = ascii_to_key_sym(ascii_key);
- if(!keysym)
- // get virtual keys
- keysym = qt_key_to_key_sym(static_cast<Qt::Key>(event->key()));
- if(!keysym)
- keysym = "None";
- // give interactor event information
- iren->SetKeyEventInformation(
- (event->state() & Qt::ShiftButton),
- ascii_key, event->count(), keysym);
- iren->InvokeEvent(vtkCommand::KeyPressEvent, NULL);
- // invoke char event only for ascii characters
- if(ascii_key)
- iren->InvokeEvent(vtkCommand::CharEvent, NULL);
-/*! handle key release event
-void QVTKWidget::keyReleaseEvent(QKeyEvent* event)
- if(mRenWin)
- return;
- if(!keysym)
- keysym = qt_key_to_key_sym((Qt::Key)event->key());
- if(!keysym)
- keysym = "None";
- // give event information to interactor
- ascii_key,
- event->count(), keysym);
- iren->InvokeEvent(vtkCommand::KeyReleaseEvent, NULL);
-#ifndef QT_NO_WHEELEVENT
-void QVTKWidget::wheelEvent(QWheelEvent* event)
- if(mRenWin)
- return;
-// VTK supports wheel mouse events only in version 4.5 or greater
- event->x(),
- event->y(),
- (event->state() & Qt::ShiftButton) );
- // if delta is positive, it is a forward wheel event
- if(event->delta() > 0)
- iren->InvokeEvent(vtkCommand::MouseWheelForwardEvent, NULL);
- else
- iren->InvokeEvent(vtkCommand::MouseWheelBackwardEvent, NULL);
-#else
- QWidget::wheelEvent(event);
-#endif
-#endif
-void QVTKWidget::focusInEvent(QFocusEvent*)
- // These prevent updates when the window
- // gains or loses focus. By default, Qt
- // does an update because the color group's
- // active status changes. We don't even use
- // color groups so we do nothing here.
-void QVTKWidget::focusOutEvent(QFocusEvent*)
-/*! handle reparenting of widgets
-void QVTKWidget::reparent(QWidget* parent, Qt::WFlags f, const QPoint& p, bool showit)
- // Finalize the window to remove graphics resources associated with this window
- this->mRenWin->Finalize();
- // have QWidget reparent as normal, but don't show
- QWidget::reparent(parent, f, p, false);
- // connect to new window
-#if defined(Q_WS_MAC)
-#else
-#endif
- // start up the window to create graphics resources for this window
- mRenWin->Start();
- // show if requested
- if(showit)
- show();
-#endif
-#else
-void QVTKWidget::setParent(QWidget* parent, Qt::WFlags f)
- QWidget::setParent(parent, f);
-#else
-#endif
- mRenWin->Start();
-#endif
-#endif
-void QVTKWidget::hide()
- // gotta finalize the window on the mac to make it really disappear
- // if it needs starting up again, paintEvent() will do that
-#endif
- QWidget::hide();
-void QVTKWidget::show()
- QWidget::show();
- // gotta start the window on the mac to make it come back
- this->mRenWin->Start();
-#endif
-/*! allocation method for Qt/VTK interactor
-vtkStandardNewMacro(QVTKInteractor);
-/*! constructor for Qt/VTK interactor
-QVTKInteractor::QVTKInteractor()
- QObject::connect(&mTimer, SIGNAL(timeout()), this, SLOT(TimerEvent()) );
-/*! start method for interactor
-void QVTKInteractor::Start()
- vtkErrorMacro(<<"QVTKInteractor cannot control the event loop.");
-/*! terminate the application
-void QVTKInteractor::TerminateApp()
- // we are in a GUI so let's terminate the GUI the normal way
- //qApp->exit();
-/*! handle timer event
-void QVTKInteractor::TimerEvent()
- if ( !this->GetEnabled() )
- return;
- this->InvokeEvent(vtkCommand::TimerEvent, NULL);
-/*! constructor
-QVTKInteractor::~QVTKInteractor()
-/*! create Qt timer with an interval of 10 msec.
-int QVTKInteractor::CreateTimer(int )
- // single-shot is fine
- return mTimer.start(10, true);
-/*! destroy timer
-int QVTKInteractor::DestroyTimer()
- return 1;
-// ***** keysym stuff below *****
-static const char *AsciiToKeySymTable[] = {
- 0, 0, 0, 0, 0, 0, 0, 0, 0, "Tab", 0, 0, 0, 0, 0, 0,
- 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- "space", "exclam", "quotedbl", "numbersign",
- "dollar", "percent", "ampersand", "quoteright",
- "parenleft", "parenright", "asterisk", "plus",
- "comma", "minus", "period", "slash",
- "0", "1", "2", "3", "4", "5", "6", "7",
- "8", "9", "colon", "semicolon", "less", "equal", "greater", "question",
- "at", "A", "B", "C", "D", "E", "F", "G",
- "H", "I", "J", "K", "L", "M", "N", "O",
- "P", "Q", "R", "S", "T", "U", "V", "W",
- "X", "Y", "Z", "bracketleft",
- "backslash", "bracketright", "asciicircum", "underscore",
- "quoteleft", "a", "b", "c", "d", "e", "f", "g",
- "h", "i", "j", "k", "l", "m", "n", "o",
- "p", "q", "r", "s", "t", "u", "v", "w",
- "x", "y", "z", "braceleft", "bar", "braceright", "asciitilde", "Delete",
- 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
-const char* ascii_to_key_sym(int i)
- return AsciiToKeySymTable[i];
-#define QVTK_HANDLE(x,y) \
- case x : \
- ret = y; \
- break;
-const char* qt_key_to_key_sym(Qt::Key i)
- const char* ret = 0;
- switch(i)
- // Cancel
- QVTK_HANDLE(Qt::Key_Backspace, "BackSpace")
- QVTK_HANDLE(Qt::Key_Tab, "Tab")
- QVTK_HANDLE(Qt::Key_BackTab, "Tab")
- //QVTK_HANDLE(Qt::Key_Clear, "Clear")
- QVTK_HANDLE(Qt::Key_Return, "Return")
- QVTK_HANDLE(Qt::Key_Enter, "Return")
- QVTK_HANDLE(Qt::Key_Shift, "Shift_L")
- QVTK_HANDLE(Qt::Key_Control, "Control_L")
- QVTK_HANDLE(Qt::Key_Alt, "Alt_L")
- QVTK_HANDLE(Qt::Key_Pause, "Pause")
- QVTK_HANDLE(Qt::Key_CapsLock, "Caps_Lock")
- QVTK_HANDLE(Qt::Key_Escape, "Escape")
- QVTK_HANDLE(Qt::Key_Space, "space")
- QVTK_HANDLE(Qt::Key_Prior, "Prior")
- QVTK_HANDLE(Qt::Key_Next, "Next")
- QVTK_HANDLE(Qt::Key_End, "End")
- QVTK_HANDLE(Qt::Key_Home, "Home")
- QVTK_HANDLE(Qt::Key_Left, "Left")
- QVTK_HANDLE(Qt::Key_Up, "Up")
- QVTK_HANDLE(Qt::Key_Right, "Right")
- QVTK_HANDLE(Qt::Key_Down, "Down")
- // Select
- // Execute
- QVTK_HANDLE(Qt::Key_SysReq, "Snapshot")
- QVTK_HANDLE(Qt::Key_Insert, "Insert")
- QVTK_HANDLE(Qt::Key_Delete, "Delete")
- QVTK_HANDLE(Qt::Key_Help, "Help")
- QVTK_HANDLE(Qt::Key_0, "0")
- QVTK_HANDLE(Qt::Key_1, "1")
- QVTK_HANDLE(Qt::Key_2, "2")
- QVTK_HANDLE(Qt::Key_3, "3")
- QVTK_HANDLE(Qt::Key_4, "4")
- QVTK_HANDLE(Qt::Key_5, "5")
- QVTK_HANDLE(Qt::Key_6, "6")
- QVTK_HANDLE(Qt::Key_7, "7")
- QVTK_HANDLE(Qt::Key_8, "8")
- QVTK_HANDLE(Qt::Key_9, "9")
- QVTK_HANDLE(Qt::Key_A, "a")
- QVTK_HANDLE(Qt::Key_B, "b")
- QVTK_HANDLE(Qt::Key_C, "c")
- QVTK_HANDLE(Qt::Key_D, "d")
- QVTK_HANDLE(Qt::Key_E, "e")
- QVTK_HANDLE(Qt::Key_F, "f")
- QVTK_HANDLE(Qt::Key_G, "g")
- QVTK_HANDLE(Qt::Key_H, "h")
- QVTK_HANDLE(Qt::Key_I, "i")
- QVTK_HANDLE(Qt::Key_J, "h")
- QVTK_HANDLE(Qt::Key_K, "k")
- QVTK_HANDLE(Qt::Key_L, "l")
- QVTK_HANDLE(Qt::Key_M, "m")
- QVTK_HANDLE(Qt::Key_N, "n")
- QVTK_HANDLE(Qt::Key_O, "o")
- QVTK_HANDLE(Qt::Key_P, "p")
- QVTK_HANDLE(Qt::Key_Q, "q")
- QVTK_HANDLE(Qt::Key_R, "r")
- QVTK_HANDLE(Qt::Key_S, "s")
- QVTK_HANDLE(Qt::Key_T, "t")
- QVTK_HANDLE(Qt::Key_U, "u")
- QVTK_HANDLE(Qt::Key_V, "v")
- QVTK_HANDLE(Qt::Key_W, "w")
- QVTK_HANDLE(Qt::Key_X, "x")
- QVTK_HANDLE(Qt::Key_Y, "y")
- QVTK_HANDLE(Qt::Key_Z, "z")
- // KP_0 - KP_9
- QVTK_HANDLE(Qt::Key_Asterisk, "asterisk")
- QVTK_HANDLE(Qt::Key_Plus, "plus")
- // bar
- QVTK_HANDLE(Qt::Key_Minus, "minus")
- QVTK_HANDLE(Qt::Key_Period, "period")
- QVTK_HANDLE(Qt::Key_Slash, "slash")
- QVTK_HANDLE(Qt::Key_F1, "F1")
- QVTK_HANDLE(Qt::Key_F2, "F2")
- QVTK_HANDLE(Qt::Key_F3, "F3")
- QVTK_HANDLE(Qt::Key_F4, "F4")
- QVTK_HANDLE(Qt::Key_F5, "F5")
- QVTK_HANDLE(Qt::Key_F6, "F6")
- QVTK_HANDLE(Qt::Key_F7, "F7")
- QVTK_HANDLE(Qt::Key_F8, "F8")
- QVTK_HANDLE(Qt::Key_F9, "F9")
- QVTK_HANDLE(Qt::Key_F10, "F10")
- QVTK_HANDLE(Qt::Key_F11, "F11")
- QVTK_HANDLE(Qt::Key_F12, "F12")
- QVTK_HANDLE(Qt::Key_F13, "F13")
- QVTK_HANDLE(Qt::Key_F14, "F14")
- QVTK_HANDLE(Qt::Key_F15, "F15")
- QVTK_HANDLE(Qt::Key_F16, "F16")
- QVTK_HANDLE(Qt::Key_F17, "F17")
- QVTK_HANDLE(Qt::Key_F18, "F18")
- QVTK_HANDLE(Qt::Key_F19, "F19")
- QVTK_HANDLE(Qt::Key_F20, "F20")
- QVTK_HANDLE(Qt::Key_F21, "F21")
- QVTK_HANDLE(Qt::Key_F22, "F22")
- QVTK_HANDLE(Qt::Key_F23, "F23")
- QVTK_HANDLE(Qt::Key_F24, "F24")
- QVTK_HANDLE(Qt::Key_NumLock, "Num_Lock")
- QVTK_HANDLE(Qt::Key_ScrollLock, "Scroll_Lock")
- default:
- break;
- return ret;
-// gotta do some special stuff on the MAC to make it work right
-// this stuff will need changing when using Qt4 with HIViews
-#include <AGL/agl.h>
-void QVTKWidget::macFixRect()
- if(!this->isTopLevel())
- AGLContext context = (AGLContext)this->GetRenderWindow()->GetGenericDisplayId();
- GLint bufRect[4];
- // always do AGL_BUFFER_RECT if we have a parent
- if(!aglIsEnabled(context, AGL_BUFFER_RECT))
- aglEnable(context, AGL_BUFFER_RECT);
- // get the clip region
- QRegion clip = this->clippedRegion();
- QRect clip_rect = clip.boundingRect();
- // get the position of this widget with respect to the top level widget
- QPoint mp(posInWindow(this));
- int win_height = this->topLevelWidget()->height();
- win_height -= win_height - this->topLevelWidget()->clippedRegion(FALSE).boundingRect().height();
- // give the position and size to agl
- bufRect[0] = mp.x();
- bufRect[1] = win_height -(mp.y() + this->height());
- bufRect[2] = this->width();
- bufRect[3] = this->height();
- aglSetInteger(context, AGL_BUFFER_RECT, bufRect);
- if(clip_rect.isEmpty())
- // no clipping, disable it
- if(!aglIsEnabled(context, AGL_CLIP_REGION))
- aglDisable(context, AGL_CLIP_REGION);
- else
- // we are clipping, so lets enable it
- aglEnable(context, AGL_CLIP_REGION);
- // give agl the clip region
- aglSetInteger(context, AGL_CLIP_REGION, (const GLint*)clip.handle(TRUE));
- else
- // update the context
- aglUpdateContext((AGLContext)this->GetRenderWindow()->GetGenericDisplayId());
-void QVTKWidget::setRegionDirty(bool b)
- // the region is dirty and needs redrawn, but not yet
- // signal that it needs to be done when it is possible
- QWidget::setRegionDirty(b);
- QTimer::singleShot(1, this, SLOT(internalMacFixRect()));
-void QVTKWidget::macWidgetChangedWindow()
- macFixRect();
-#endif
-// slot to update the draw region and draw the scene
-void QVTKWidget::internalMacFixRect()
- this->macFixRect();
- this->update();
-#endif
Deleted: MOAB/trunk/tools/qvdual/QVTKWidget.h
--- MOAB/trunk/tools/qvdual/QVTKWidget.h 2007-08-02 10:22:38 UTC (rev 1226)
+++ MOAB/trunk/tools/qvdual/QVTKWidget.h 2007-08-02 10:23:08 UTC (rev 1227)
@@ -1,170 +0,0 @@
- Program: Visualization Toolkit
- Module: $RCSfile$
- Language: C++
- Date: $Date$
- Version: $Revision$
- Copyright 2004 Sandia Corporation.
- Under the terms of Contract DE-AC04-94AL85000, there is a non-exclusive
- license for use of this work by or on behalf of the
- U.S. Government. Redistribution and use in source and binary forms, with
- or without modification, are permitted provided that this Notice and any
- statement of authorship are reproduced on all copies.
-#ifndef Q_VTK_WIDGET_H
-#define Q_VTK_WIDGET_H
-#include <qwidget.h>
-#include <qtimer.h>
-class vtkRenderWindow;
-class QVTKInteractor;
-#include <vtkRenderWindowInteractor.h>
-#if defined(WIN32) && defined(BUILD_SHARED_LIBS)
-#if defined(QVTK_EXPORTS) || defined(QVTKWidgetPlugin_EXPORTS)
-#define QVTK_EXPORT __declspec( dllexport )
-#else
-#define QVTK_EXPORT __declspec( dllimport )
-#endif
-#else
-#endif
-//! QVTKWidget displays a VTK window in a Qt window.
-class QVTK_EXPORT QVTKWidget : public QWidget
- Q_OBJECT
- public:
- //! constructor for Qt 3
- QVTKWidget(QWidget* parent = NULL, const char* name = NULL, Qt::WFlags f = 0);
-#else
- //! constructor for Qt 4
- QVTKWidget(QWidget* parent = NULL, Qt::WFlags f = 0);
-#endif
- //! destructor
- virtual ~QVTKWidget();
- //! set the vtk render window, if you wish to use your own vtkRenderWindow
- void SetRenderWindow(vtkRenderWindow*);
- //! get the vtk render window
- vtkRenderWindow* GetRenderWindow();
- //! get the Qt/vtk interactor that was either created by default or set by the user
- QVTKInteractor* GetInteractor();
- //! handle reparenting of this widget
- virtual void reparent(QWidget* parent, Qt::WFlags f, const QPoint& p, bool showit);
-#else
- virtual void setParent(QWidget* parent, Qt::WFlags f);
-#endif
- //! handle hides
- virtual void hide();
- //! handle shows
- virtual void show();
- protected:
- //! overloaded resize handler
- virtual void resizeEvent(QResizeEvent* event);
- //! overloaded move handler
- virtual void moveEvent(QMoveEvent* event);
- //! overloaded paint handler
- virtual void paintEvent(QPaintEvent* event);
- //! overloaded mouse press handler
- virtual void mousePressEvent(QMouseEvent* event);
- //! overloaded mouse move handler
- virtual void mouseMoveEvent(QMouseEvent* event);
- //! overloaded mouse release handler
- virtual void mouseReleaseEvent(QMouseEvent* event);
- //! overloaded key press handler
- virtual void keyPressEvent(QKeyEvent* event);
- //! overloaded key release handler
- virtual void keyReleaseEvent(QKeyEvent* event);
- //! overloaded enter event
- virtual void enterEvent(QEvent*);
- //! overloaded leave event
- virtual void leaveEvent(QEvent*);
- //! overload wheel mouse event
- virtual void wheelEvent(QWheelEvent*);
-#endif
- //! overload focus event
- virtual void focusInEvent(QFocusEvent*);
- virtual void focusOutEvent(QFocusEvent*);
- //! overload Qt's event() to capture more keys
- bool event( QEvent* e );
- //! the vtk render window
- vtkRenderWindow* mRenWin;
- void macFixRect();
- virtual void setRegionDirty(bool);
- virtual void macWidgetChangedWindow();
-#endif
- private slots:
- void internalMacFixRect();
- private:
- //! unimplemented operator=
- QVTKWidget const& operator=(QVTKWidget const&);
- //! unimplemented copy
- QVTKWidget(const QVTKWidget&);
-//! Qt/VTK interactor class
-class QVTK_EXPORT QVTKInteractor : public QObject, public vtkRenderWindowInteractor
- Q_OBJECT
-public:
- //! allocation method
- static QVTKInteractor* New();
- vtkTypeMacro(QVTKInteractor,vtkRenderWindowInteractor);
- //! overloaded terminiate app
- virtual void TerminateApp();
- //! overloaded start method
- virtual void Start();
- //! overloaded create timer method
- virtual int CreateTimer(int);
- //! overloaded destroy timer method
- virtual int DestroyTimer();
-public slots:
- //! timer event slot
- virtual void TimerEvent();
-protected:
- //! constructor
- QVTKInteractor();
- //! destructor
- ~QVTKInteractor();
-private:
- //! timer
- QTimer mTimer;
- QVTKInteractor(const QVTKInteractor&);
- void operator=(const QVTKInteractor&);
-#endif
Deleted: MOAB/trunk/tools/qvdual/QVTKWidget.xpm
--- MOAB/trunk/tools/qvdual/QVTKWidget.xpm 2007-08-02 10:22:38 UTC (rev 1226)
+++ MOAB/trunk/tools/qvdual/QVTKWidget.xpm 2007-08-02 10:23:08 UTC (rev 1227)
@@ -1,40 +0,0 @@
-/* XPM */
-static const char *QVTKWidget_image[]={
-"22 22 15 1",
-". c none",
-"l c #004000",
-"g c #007100",
-"f c #007500",
-"m c #007900",
-"a c #007d00",
-"c c #008100",
-"e c #008500",
-"k c #009900",
-"b c #00a500",
-"# c #00b200",
-"h c #00c200",
-"d c #00c600",
-"j c #00ca00",
-"i c #00f600",
-"........#aaaaab.......",
-".......ccaaaaacccd....",
-"......cecaaaaaccff....",
-"....ecacaaeeaecgfg....",
-"....dhdhdiaaaagfgf....",
-"....jdhdhdjjjkgggg....",
-"....lhdhdjjjjjgfgf....",
-".....hdhdjjjjjgfgf....",
-".....ddddjjjjjfgfg....",
-".....hdhdjjjjjgfg.....",
-".....djdjdhhdhfff.....",
-"......djdhddddff......",
-"........jdhdddf.......",
-"............ddm.......",
Deleted: MOAB/trunk/tools/qvdual/QVTKWidgetPlugin.cxx
--- MOAB/trunk/tools/qvdual/QVTKWidgetPlugin.cxx 2007-08-02 10:22:38 UTC (rev 1226)
+++ MOAB/trunk/tools/qvdual/QVTKWidgetPlugin.cxx 2007-08-02 10:23:08 UTC (rev 1227)
@@ -1,145 +0,0 @@
-#include "QVTKWidgetPlugin.h"
-#include "qpixmap.h"
-#include "qplugin.h"
-#endif
-#include "vtkRenderer.h"
-#include "vtkSphereSource.h"
-#include "vtkDataSetMapper.h"
-#include "vtkPolyData.h"
-#include "vtkElevationFilter.h"
-#include "vtkActor.h"
-#include "QVTKWidget.xpm"
-// macro for debug printing
-#define qDebug(a)
-//#define qDebug(a) printf(a)
-QVTKWidgetPlugin::QVTKWidgetPlugin()
- qDebug("QVTKWidgetPlugin instantiated\n");
-QVTKWidgetPlugin::~QVTKWidgetPlugin()
- qDebug("QVTKWidgetPlugin destructed\n");
-QStringList QVTKWidgetPlugin::keys() const
- qDebug("QVTKWidgetPlugin::keys\n");
- QStringList list;
- list << "QVTKWidget";
- return list;
-QWidget* QVTKWidgetPlugin::create( const QString& key, QWidget* parent, const char* name)
- qDebug("QVTKWidgetPlugin::create\n");
- if(key == "QVTKWidget")
- QVTKWidget* widget = new QVTKWidget(parent);
- widget->setObjectName(name);
-#else
- QVTKWidget* widget = new QVTKWidget(parent, name);
-#endif
- // gotta make a renderer so we get a nice black background in the designer
- vtkRenderer* ren = vtkRenderer::New();
- widget->GetRenderWindow()->AddRenderer(ren);
- // also for fun, let's make a cylinder and put it in the window
- // this REALLY lets the user know that a QVTKWidget works in the designer
- vtkSphereSource* cyl = vtkSphereSource::New();
- vtkElevationFilter* ele = vtkElevationFilter::New();
- ele->SetLowPoint(0.0, -0.5, 0.0);
- ele->SetHighPoint(0.0, 0.5, 0.0);
- ele->SetInput(cyl->GetOutput());
- vtkDataSetMapper* mapper = vtkDataSetMapper::New();
- mapper->SetInput(ele->GetOutput());
- ele->Delete();
- cyl->Delete();
- vtkActor* actor = vtkActor::New();
- actor->SetMapper(mapper);
- mapper->Delete();
- ren->AddProp(actor);
- actor->Delete();
- ren->Delete();
- // return the widget
- return widget;
- return 0;
-QString QVTKWidgetPlugin::group( const QString& feature ) const
- qDebug("QVTKWidgetPlugin::group\n");
- if(feature == "QVTKWidget")
- return "Display";
- return QString::null;
-QIconSet QVTKWidgetPlugin::iconSet( const QString& ) const
- qDebug("QVTKWidgetPlugin::iconSet\n");
- return QIconSet( QPixmap( QVTKWidget_image ) );
-#else
-QIcon QVTKWidgetPlugin::iconSet( const QString& ) const
- return QIcon( QPixmap( QVTKWidget_image ) );
-#endif
-QString QVTKWidgetPlugin::includeFile( const QString& feature ) const
- qDebug("QVTKWidgetPlugin::includeFile\n");
- if ( feature == "QVTKWidget" )
- return "QVTKWidget.h";
-QString QVTKWidgetPlugin::toolTip( const QString& feature ) const
- qDebug("QVTKWidgetPlugin::toolTip\n");
- return "Qt VTK Widget";
-QString QVTKWidgetPlugin::whatsThis( const QString& feature ) const
- qDebug("QVTKWidgetPlugin::whatsThis\n");
- return "A Qt/VTK Graphics Window";
-bool QVTKWidgetPlugin::isContainer( const QString& ) const
- qDebug("QVTKWidgetPlugin::isContainer\n");
- return false;
-Q_EXPORT_PLUGIN( QVTKWidgetPlugin )
Deleted: MOAB/trunk/tools/qvdual/QVTKWidgetPlugin.h
--- MOAB/trunk/tools/qvdual/QVTKWidgetPlugin.h 2007-08-02 10:22:38 UTC (rev 1226)
+++ MOAB/trunk/tools/qvdual/QVTKWidgetPlugin.h 2007-08-02 10:23:08 UTC (rev 1227)
@@ -1,63 +0,0 @@
- Module: $RCSfile$
- Language: C++
- Date: $Date$
-#ifndef Q_VTK_WIDGET_PLUGIN_H
-#define Q_VTK_WIDGET_PLUGIN_H
-Plugin code to allow QVTKWidget plugin in the Qt designer
-Build this and put it in your plugin path.
-That could be in $QTDIR/lib/plugin or any path/plugin pointed to by qtconfig.
-#include <qwidgetplugin.h>
-// derive from QWidgetPlugin and implement the plugin interface
-class QVTKWidgetPlugin : public QWidgetPlugin
- public:
- QVTKWidgetPlugin();
- ~QVTKWidgetPlugin();
- //! return a list of keys for what widgets this plugin makes
- QStringList keys() const;
- //! create a widget by key
- QWidget* create( const QString& key, QWidget* parent = 0, const char* name = 0);
- //! what group this plugin shows up in the designer
- QString group( const QString& ) const;
- //! the icons for the widgets
- QIconSet iconSet( const QString& ) const;
-#else
- QIcon iconSet( const QString& ) const;
-#endif
- //! the name of the include file for building an app with a widget
- QString includeFile( const QString& ) const;
- //! tool tip text
- QString toolTip( const QString& ) const;
- //! what's this text
- QString whatsThis( const QString& ) const;
- //! returns whether widget is a container
- bool isContainer( const QString& ) const;
-#endif
Modified: MOAB/trunk/tools/qvdual/uiQVDual.ui.h
--- MOAB/trunk/tools/qvdual/uiQVDual.ui.h 2007-08-02 10:22:38 UTC (rev 1226)
+++ MOAB/trunk/tools/qvdual/uiQVDual.ui.h 2007-08-02 10:23:08 UTC (rev 1227)
@@ -155,9 +155,9 @@
if (NULL == vtkWidget) {
vtkWidget = new QVTKWidget( centralWidget(), "vtkWidget" );
- vtkWidget->setGeometry( QRect( 400, 10, 470, 569 ) );
- vtkWidget->setSizePolicy( QSizePolicy( (QSizePolicy::SizeType)7, (QSizePolicy::SizeType)7, 5, 1, vtkWidget->sizePolicy().hasHeightForWidth() ) );
- vtkWidget->setMinimumSize( QSize( 0, 0 ) );
+// vtkWidget->setGeometry( QRect( 400, 10, 470, 569 ) );
+// vtkWidget->setSizePolicy( QSizePolicy( (QSizePolicy::SizeType)7, (QSizePolicy::SizeType)7, 5, 1, vtkWidget->sizePolicy().hasHeightForWidth() ) );
+// vtkWidget->setMinimumSize( QSize( 0, 0 ) );
vtkWidget->GetRenderWindow()->AddRenderer(ren);
@@ -193,7 +193,7 @@
QListViewItemIterator it = QListViewItemIterator(TagListView1);
while ( it.current() ) {
- std::string this_name((*it)->text(0));
+ QString this_name((*it)->text(0));
if (this_name == "DUAL_SURFACE") {
(*it)->setOpen(true);
@@ -276,7 +276,7 @@
QListViewItem *set_item;
for (i = 0, set_it = tag_sets.begin(); set_it != tag_sets.end(); set_it++, i++) {
// make an item for this set
- char set_name[CATEGORY_TAG_NAME_LENGTH];
+ char set_name[CATEGORY_TAG_SIZE];
result = vtkMOABUtils::get_set_category_name(*set_it, set_name);
if (MB_SUCCESS != result) sprintf(set_name, "(none)\0");
set_item = new QListViewItem(tags_item, set_name);
@@ -401,7 +401,7 @@
// has an actor, or contains sets; allocate a list item
vtkMOABUtils::get_set_category_name(set_handle, set_name);
set_item = new QListViewItem(item, set_name);
itemSetMap[set_item] = set_handle;
@@ -438,7 +438,7 @@
// has an actor, or parent sets; allocate a list item
@@ -710,7 +710,9 @@
if (NULL == vtkMOABUtils::drawDual) vtkMOABUtils::drawDual = new DrawDual(pickline1, pickline2);
// now draw them
- vtkMOABUtils::drawDual->draw_dual_surfs(dual_surfs);
+ bool success = vtkMOABUtils::drawDual->draw_dual_surfs(dual_surfs);
+ if (!success)
+ std::cout << "Problem drawing dual surface(s)." << std::endl;
@@ -810,7 +812,6 @@
return;
- MBEntityHandle new_hp;
result = dt.rev_atomic_pillow(sheet, chords);
std::cerr << "-AP failed." << std::endl;
@@ -831,7 +832,7 @@
// make sure the last picked entities are edges
MBEntityHandle edge1 = vtkMOABUtils::drawDual->lastPickedEnt,
- edge2 = vtkMOABUtils::drawDual->secondLastPickedEnt,;
+ edge2 = vtkMOABUtils::drawDual->secondLastPickedEnt;
if (0 == edge1 || 0 == edge2) {
std::cerr << "Didn't find a picked entity." << std::endl;
return;
@@ -1059,9 +1060,9 @@
void uiQVDual::redrawDisplay()
- resetDisplay();
+ //resetDisplay();
- this->init();
+ //this->init();
vtkMOABUtils::update_display();
