[MOAB-dev] r1225 - MOAB/trunk
pebay at mcs.anl.gov pebay at mcs.anl.gov
Wed Aug 1 20:57:04 CDT 2007
Author: pebay
Date: 2007-08-01 20:57:04 -0500 (Wed, 01 Aug 2007)
New Revision: 1225
Modified:
   MOAB/trunk/configure.in
Log:
COMP: The Verdict library changed its name.
COMP: libvtkIO requires libvtkmetaio
COMP: look in lib64 dirs for GraphViz libraries.
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in	2007-07-31 12:32:25 UTC (rev 1224)
+++ MOAB/trunk/configure.in	2007-08-02 01:57:04 UTC (rev 1225)
@@ -364,7 +364,7 @@
       AC_MSG_RESULT([$GRAPH_INC_DIR])
       AC_MSG_CHECKING([for GraphViz library dir])
       GRAPH_LIB_DIR=
-      for dir in ${GRAPH_DIR}/lib/graphviz /usr/lib/graphviz /usr/local/lib/graphviz /lib/graphviz; do
+      for dir in ${GRAPH_DIR}/lib64/graphviz ${GRAPH_DIR}/lib/graphviz /usr/lib64/graphviz /usr/lib/graphviz /usr/local/lib64/graphviz /usr/local/lib/graphviz /lib64/graphviz /lib/graphviz; do
         if test "x" = "x$GRAPH_LIB_DIR"; then
           if test -d $dir; then
             GRAPH_LIB_DIR=-L$dir
@@ -555,10 +555,11 @@
   SNL_CHECK_LIB_LIST([vtkftgl],       [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
   SNL_CHECK_LIB_LIST([vtkFiltering],  [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
   SNL_CHECK_LIB_LIST([vtkImaging],    [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
-  SNL_CHECK_LIB_LIST([verdict112],    [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+  SNL_CHECK_LIB_LIST([verdict],       [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
   SNL_CHECK_LIB_LIST([vtkGraphics],   [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
   SNL_CHECK_LIB_LIST([vtkNetCDF],     [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
   SNL_CHECK_LIB_LIST([vtkexoIIc],     [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+  SNL_CHECK_LIB_LIST([vtkmetaio],     [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
   SNL_CHECK_LIB_LIST([vtkIO],         [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
   SNL_CHECK_LIB_LIST([vtkRendering],  [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
   SNL_CHECK_LIB_LIST([vtkParallel],  [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
