[MOAB-announce] Parallel Test Failure
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Fri Oct 24 07:14:04 CDT 2014
can you send your config.log file?
Iulian
From: moab-announce-bounces at mcs.anl.gov [moab-announce-bounces at mcs.anl.gov] on behalf of Grabner, Friedrich [F.M.Grabner at warwick.ac.uk]
Sent: Friday, October 24, 2014 4:22 AM
To: moab-announce at mcs.anl.gov
Subject: [MOAB-announce] Parallel Test Failure
Hi All,
I am trying to install moab-4.6.3 on my HPC system following the instructions on following webpage:
http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingAndUsingMOAB
I have run everything exactly as specified on my desktop and successfully installed it however on hpc I receive error:
PASS: pcomm_unit
FAIL: parallel_unit_tests
PASS: uber_parallel_test
FAIL: scdtest
PASS: pcomm_serial
PASS: par_spatial_locator_test
FAIL: parallel_hdf5_test
PASS: mhdf_parallel
PASS: parallel_write_test
3 of 9 tests failed
See test/parallel/test-suite.log
make[4]: *** [test-suite.log] Error 1
make[4]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test/parallel'
make[3]: *** [check-TESTS] Error 2
make[3]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test/parallel'
make[2]: *** [check-am] Error 2
make[2]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test/parallel'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test
I have attached my test-suite.log file.
Thanks in advance, Friedrich
URL: <http://lists.mcs.anl.gov/pipermail/moab-announce/attachments/20141024/c2c51fae/attachment-0001.html>
More information about the moab-announce
