[MOAB-announce] MOAB API changed relating to tags
Jason Kraftcheck
kraftche at cae.wisc.edu
Mon Jun 6 15:59:13 CDT 2011
The following is a list of upcoming changes to the subset of the MOAB API
that operates on tags. The primary focus of this set of changes is to
provide better type safety for tag data and to transition from working with
tag sizes specified as the number of bytes to tag sizes specified as the
number of values. However, some other minor changes have also been included.
Changes to be included in MOAB 4.1:
1. MOAB will now print a warning if a NULL handle array is passed to
tag_get/set_handle. It will still accept the NULL handle array as
a means of indicating the tag value on the MOAB instance. However,
the preferred method is to pass an actual handle with a zero value,
consistent with the way the MOAB instance is indicated in other calls
such as get_entities_by_type. That is:
mb.tag_get_data( tag, 0, 0, &value );
should now be:
const EntityHandle root = 0;
mb.tag_get_data( tag, &root, 1, &value );
2. MOAB contains a new tag_get_handle function that will replace the
previous tag_get_handle function as well as both variations of
tag_create and tag_create_variable_length. All the functionality
of all of those functions is available through the new tag_get_handle
function. The new function provides the added benefits of a) allowing
an application to specify that it is fine with either creating a new tag
or getting an existing one, such that the function either succeeds or
fails (no checking of MB_ALREADY_ALLOCATED), b) it works with sizes as
the number of values of the specified type rather than the number of
bytes and c) it does some type checking for the application when
retrieving an existing tag handle. For example, this call:
mb.tag_get_handle( GLOBAL_ID_TAG_NAME, tag );
becomes this:
mb.tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, tag );
where an error will be returned if the tag exists but does not contain
1 integer value for each instance of the tag on an entity.
Changes to be included in the next MOAB release (and in the current SVN trunk):
1. The change in 1. for 4.1 will be extended such that MOAB returns an error
rather than printing a warning when tag_get/set_data are passed a NULL
handle array.
2. All functions replaced by the new tag_get_handle in 2. above are marked
as deprecated in the documentation and with a gcc/g++ attribute.
3. tag_get_size will be marked as deprecated and two new replacements will
be added: tag_get_bytes() and tag_get_length(). The former will work
the same as the deprecated tag_get_size() except in the case of bit
tags, for which it will always return 1 (the amount of memory that must
be allocated per entity when requesting tag data.) The latter will
return the number of values of the base data type (e.g. number of int
or double). It will behave the same as the old tag_get_size and
tag_get_bytes for opaque tags.
4. The overloaded variants of tag_get_data and tag_set_data that work with
an array of pointers and an optional array of sizes will be marked as
deprecated, and replacements named tag_get_by_ptr and tag_set_by_ptr will
be added. The new functions will behave similar to the deprecated ones
with the exception that the size of each tag value is interpreted as the
number of values rather than the number of bytes. Also, renaming the
functions will avoid accidental matches to the non-pointer-array function
variants when the optional size array is not passed.
5. The optional size argument to the functions: tag_clear_data and
tag_get_default_value will be interpreted as the number of values
of the tag data type rather than the number of bytes. No deprecation,
warning, or renaming will provided for these functions as it is
unlikely that they are used anywhere outside of MOAB at this time.
All deprecated functions mentioned above will be removed in some future MOAB
release.
More information about the moab-announce
