[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan amahajan at iitb.ac.in
Tue Sep 27 12:16:11 CDT 2022
Minotaur daily test report
Tuesday 27 September 2022 10:37:01 PM IST
simplex
Linux simplex 5.10.0-16-amd64 #1 SMP Debian 5.10.127-2 (2022-07-23) x86_64 GNU/Linux
Detailed log available at  http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.3-62-g6ddd7bc
rsync: [sender] change_dir "/home/amahajan/tmp/minotaur-test/build-all/doxygen/html" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1333) [sender=3.2.3]
Summary
build-base: OK, all binaries compiled.
build-base: 0 errors and 7 warnings in compiling, utest output: OK (41)
build-base-debug: OK, all binaries compiled.
build-base-debug: 0 errors and 7 warnings in compiling, utest output: OK (41)
build-base-static-debug: OK, all binaries compiled.
build-base-static-debug: 0 errors and 7 warnings in compiling, utest output: OK (41)
build-base-static: OK, all binaries compiled.
build-base-static: 0 errors and 15 warnings in compiling, utest output: OK (41)
build-filter: OK, all binaries compiled.
build-filter: 0 errors and 7 warnings in compiling, utest output: OK (41)
build-filter-debug: OK, all binaries compiled.
build-filter-debug: 0 errors and 7 warnings in compiling, utest output: OK (41)
build-filter-static-debug: OK, all binaries compiled.
build-filter-static-debug: 0 errors and 7 warnings in compiling, utest output: OK (41)
build-filter-static: OK, all binaries compiled.
build-filter-static: 0 errors and 15 warnings in compiling, utest output: OK (41)
build-ipopt: OK, all binaries compiled.
build-ipopt: 0 errors and 7 warnings in compiling, utest output: OK (44)
build-ipopt-debug: OK, all binaries compiled.
build-ipopt-debug: 0 errors and 7 warnings in compiling, utest output: OK (44)
build-ipopt-static-debug: OK, all binaries compiled.
build-ipopt-static-debug: 0 errors and 7 warnings in compiling, utest output: OK (44)
build-ipopt-static: OK, all binaries compiled.
build-ipopt-static: 0 errors and 15 warnings in compiling, utest output: OK (44)
build-osi: OK, all binaries compiled.
build-osi: 0 errors and 7 warnings in compiling, utest output: OK (41)
build-osi-debug: OK, all binaries compiled.
build-osi-debug: 0 errors and 7 warnings in compiling, utest output: OK (41)
build-osi-static-debug: OK, all binaries compiled.
build-osi-static-debug: 0 errors and 7 warnings in compiling, utest output: OK (41)
build-osi-static: OK, all binaries compiled.
build-osi-static: 0 errors and 15 warnings in compiling, utest output: OK (41)
build-ampl: OK, all binaries compiled.
build-ampl: 0 errors and 7 warnings in compiling, utest output: OK (60)
build-ampl-debug: OK, all binaries compiled.
build-ampl-debug: 0 errors and 7 warnings in compiling, utest output: OK (60)
build-ampl-static-debug: OK, all binaries compiled.
build-ampl-static-debug: 0 errors and 7 warnings in compiling, utest output: OK (60)
build-ampl-static: OK, all binaries compiled.
build-ampl-static: 0 errors and 15 warnings in compiling, utest output: OK (60)
build-all: OK, all binaries compiled.
build-all: 0 errors and 7 warnings in compiling, utest output: OK (67)
build-all-debug: OK, all binaries compiled.
build-all-debug: 0 errors and 7 warnings in compiling, utest output: OK (67)
Valgrind:
==449469== LEAK SUMMARY:
==449469==    definitely lost: 0 bytes in 0 blocks
==449469==    indirectly lost: 0 bytes in 0 blocks
==449469==      possibly lost: 0 bytes in 0 blocks
==449469==    still reachable: 8 bytes in 1 blocks
==449469==         suppressed: 0 bytes in 0 blocks
build-all-static-debug: OK, all binaries compiled.
build-all-static-debug: 0 errors and 7 warnings in compiling, utest output: OK (67)
build-all-static: OK, all binaries compiled.
build-all-static: 0 errors and 15 warnings in compiling, utest output: OK (67)
build-all-static-spew: OK, all binaries compiled.
build-all-static-spew: 0 errors and 14 warnings in compiling, utest output: OK (67)
build-all-manual: ERROR, binary lib/libminotaur.a not built.
build-all-manual: utest ERROR
build-all-manual: 0 errors and 0 warnings in compiling, utest output:
Tuesday 27 September 2022 10:46:10 PM IST
More information about the Minotaur-dev mailing list
