[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan
amahajan at iitb.ac.in
Tue Mar 15 12:34:14 CDT 2022
Minotaur daily test report
Tuesday 15 March 2022 10:37:01 PM IST
origin.ieor.iitb.ac.in
Linux origin 5.10.0-11-amd64 #1 SMP Debian 5.10.92-1 (2022-01-18) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.3-18-gd2db890
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
SHA256:Tf+eOWzBpXwkYieMm/Rtfmc8nHL/A2y7/Rfk1OnLW0k.
Please contact your system administrator.
Add correct host key in /home/amahajan/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /home/amahajan/.ssh/known_hosts:64
remove with:
ssh-keygen -f "/home/amahajan/.ssh/known_hosts" -R "10.119.2.10"
RSA host key for 10.119.2.10 has changed and you have requested strict checking.
Host key verification failed.
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(228) [sender=3.2.3]
remove with:
Summary
build-base: OK, all binaries compiled.
build-base: 0 errors and 1 warnings in compiling, utest output: OK (41)
build-base-debug: OK, all binaries compiled.
build-base-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-base-static-debug: OK, all binaries compiled.
build-base-static-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-base-static: OK, all binaries compiled.
build-base-static: 0 errors and 1 warnings in compiling, utest output: OK (41)
build-filter: OK, all binaries compiled.
build-filter: 0 errors and 1 warnings in compiling, utest output: OK (41)
build-filter-debug: OK, all binaries compiled.
build-filter-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-filter-static-debug: OK, all binaries compiled.
build-filter-static-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-filter-static: OK, all binaries compiled.
build-filter-static: 0 errors and 1 warnings in compiling, utest output: OK (41)
build-ipopt: OK, all binaries compiled.
build-ipopt: 0 errors and 1 warnings in compiling, utest output: OK (44)
build-ipopt-debug: OK, all binaries compiled.
build-ipopt-debug: 0 errors and 0 warnings in compiling, utest output: OK (44)
build-ipopt-static-debug: OK, all binaries compiled.
build-ipopt-static-debug: 0 errors and 0 warnings in compiling, utest output: OK (44)
build-ipopt-static: OK, all binaries compiled.
build-ipopt-static: 0 errors and 1 warnings in compiling, utest output: OK (44)
build-osi: OK, all binaries compiled.
build-osi: 0 errors and 1 warnings in compiling, utest output: OK (41)
build-osi-debug: OK, all binaries compiled.
build-osi-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-osi-static-debug: OK, all binaries compiled.
build-osi-static-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-osi-static: OK, all binaries compiled.
build-osi-static: 0 errors and 1 warnings in compiling, utest output: OK (41)
build-ampl: OK, all binaries compiled.
build-ampl: 0 errors and 1 warnings in compiling, utest output: OK (60)
build-ampl-debug: OK, all binaries compiled.
build-ampl-debug: 0 errors and 0 warnings in compiling, utest output: OK (60)
build-ampl-static-debug: OK, all binaries compiled.
build-ampl-static-debug: 0 errors and 0 warnings in compiling, utest output: OK (60)
build-ampl-static: OK, all binaries compiled.
build-ampl-static: 0 errors and 1 warnings in compiling, utest output: OK (60)
build-all: OK, all binaries compiled.
build-all: 0 errors and 1 warnings in compiling, utest output: OK (67)
build-all-debug: OK, all binaries compiled.
build-all-debug: 0 errors and 0 warnings in compiling, utest output: OK (67)
Valgrind:
==1575239== LEAK SUMMARY:
==1575239== definitely lost: 0 bytes in 0 blocks
==1575239== indirectly lost: 0 bytes in 0 blocks
==1575239== possibly lost: 0 bytes in 0 blocks
==1575239== still reachable: 8 bytes in 1 blocks
==1575239== suppressed: 0 bytes in 0 blocks
build-all-static-debug: OK, all binaries compiled.
build-all-static-debug: 0 errors and 0 warnings in compiling, utest output: OK (67)
build-all-static: OK, all binaries compiled.
build-all-static: 0 errors and 1 warnings in compiling, utest output: OK (67)
build-all-static-spew: OK, all binaries compiled.
build-all-static-spew: 0 errors and 1 warnings in compiling, utest output: OK (67)
build-all-manual: ERROR, binary lib/libminotaur.a not built.
build-all-manual: utest ERROR
build-all-manual: 0 errors and 0 warnings in compiling, utest output:
Tuesday 15 March 2022 11:04:14 PM IST
More information about the Minotaur-dev
