[Minotaur-dev] [minotaur-solver/minotaur] e0fe3a: Added a function to fetch problem stats.
Meenarli Sharma noreply at github.com
Fri Sep 25 07:47:01 CDT 2020
  Branch: refs/heads/master
  Home:   https://github.com/minotaur-solver/minotaur
  Commit: e0fe3a18ba831da066082a952557f1b81e9c63d5
      https://github.com/minotaur-solver/minotaur/commit/e0fe3a18ba831da066082a952557f1b81e9c63d5
  Author: meenarli <kukku.meenarli at gmail.com>
  Date:   2020-09-25 (Fri, 25 Sep 2020)
  Changed paths:
    M src/algorithms/QGAdv.cpp
  Log Message:
  Commit: a0db02a8814d59a91cf21829804ef1c99c217437
      https://github.com/minotaur-solver/minotaur/commit/a0db02a8814d59a91cf21829804ef1c99c217437
  Changed paths:
    M src/base/PerspCon.cpp
  Log Message:
  Added function for finding analytical center.
  Commit: ca2aa62e789a63e2681f43845964bb888a426bd6
      https://github.com/minotaur-solver/minotaur/commit/ca2aa62e789a63e2681f43845964bb888a426bd6
  Changed paths:
    M src/base/PerspCon.h
  Log Message:
  Added some variable description.
  Commit: e2a97513a9bfe253b9173016db6112723732a6bb
      https://github.com/minotaur-solver/minotaur/commit/e2a97513a9bfe253b9173016db6112723732a6bb
  Changed paths:
    M src/base/QGHandlerAdvance.cpp
    M src/base/QGHandlerAdvance.h
  Log Message:
  Functionality for adding perspective cuts.
Adding perspective cuts at nodes yielding integer optimal LP solution.
  Commit: 57e8131ca8c7f86ce0f4e33018c697669f5d51b4
      https://github.com/minotaur-solver/minotaur/commit/57e8131ca8c7f86ce0f4e33018c697669f5d51b4
  Changed paths:
    M src/base/PerspCutGenerator.cpp
    M src/base/PerspCutGenerator.h
  Log Message:
  Functions for adding various perspective cuts.
  Commit: 7acf79c186b953770445412654d2c138716173c7
      https://github.com/minotaur-solver/minotaur/commit/7acf79c186b953770445412654d2c138716173c7
  Changed paths:
    M src/base/IntVarHandler.cpp
  Log Message:
  Added implied binary and integer check.
Added check for the values of implied binary and integer variables in
isFeasible function.
  Commit: 58be6288bc9eb694b1154bdab9ff4848f561e491
      https://github.com/minotaur-solver/minotaur/commit/58be6288bc9eb694b1154bdab9ff4848f561e491
  Changed paths:
    M src/base/ParReliabilityBrancher.cpp
  Log Message:
  Merge branch 'master' of https://github.com/minotaur-solver/minotaur
Compare: https://github.com/minotaur-solver/minotaur/compare/78ebdaa9892f...58be6288bc9e
More information about the Minotaur-dev mailing list
