[Minotaur-dev] [minotaur-solver/minotaur] 7aed06: Adjusted CplexLPEngine warmstarting for new cuts.
Prashant Palkar noreply at github.com
Mon Sep 9 05:06:24 CDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/minotaur-solver/minotaur
  Commit: 7aed069cce395a742960589ea62561890ba5c83b
      https://github.com/minotaur-solver/minotaur/commit/7aed069cce395a742960589ea62561890ba5c83b
  Author: ppalkar <ppalkar.iitb at gmail.com>
  Date:   2019-09-09 (Mon, 09 Sep 2019)
  Changed paths:
    M src/engines/Cplex/CplexLPEngine.cpp
    M src/engines/Cplex/CplexLPEngine.h
    M src/engines/Cplex/CplexMILPEngine.cpp
  Log Message:
The stored warmstart array for constraints in CplexLPEngine might be
outdated if new cuts are added to the problem. We adjust the size of
this array and assign a default value 1 (assuming that associated
slack, surplus, or artificial variable is basic) for the new cut.
  Commit: 2b372b6ddc1920a0501065c77fc02c96ff632501
      https://github.com/minotaur-solver/minotaur/commit/2b372b6ddc1920a0501065c77fc02c96ff632501
  Changed paths:
    M src/base/Linearizations.cpp
    M src/base/Linearizations.h
  Log Message:
  Merge branch 'master' of ssh://github.com/ashutoshmahajan/minotaur
Compare: https://github.com/minotaur-solver/minotaur/compare/8be4417e8ad9...2b372b6ddc19
More information about the Minotaur-dev mailing list
