[Minotaur-dev] [minotaur-solver/minotaur] 9c78ab: adding only those linearizations that violate LP s...
Meenarli Sharma noreply at github.com
Wed Sep 4 13:12:52 CDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/minotaur-solver/minotaur
  Commit: 9c78abc836a4d9afcef4cf5681627b6db96c55a8
      https://github.com/minotaur-solver/minotaur/commit/9c78abc836a4d9afcef4cf5681627b6db96c55a8
  Author: meenarli <kukku.meenarli at gmail.com>
  Date:   2019-08-27 (Tue, 27 Aug 2019)
  Changed paths:
    M src/base/ParQGHandler.cpp
    M src/base/ParQGHandler.h
  Log Message:
  adding only those linearizations that violate LP solution
  Commit: 18633283adf1ab1a76fc8d84eeabe6b9fa7b9ca3
      https://github.com/minotaur-solver/minotaur/commit/18633283adf1ab1a76fc8d84eeabe6b9fa7b9ca3
  Date:   2019-09-03 (Tue, 03 Sep 2019)
  Changed paths:
    M src/base/ParBranchAndBound.cpp
    M src/base/ParQGBranchAndBound.cpp
    M src/engines/Cplex/CplexLPEngine.cpp
    M src/engines/Ipopt/IpoptEngine.cpp
    M src/engines/Ipopt/IpoptEngine.h
  Log Message:
  Merge branch 'master' of https://github.com/minotaur-solver/minotaur
  Commit: aac7eab81e96d2fd898edd3f682191cca258f80b
      https://github.com/minotaur-solver/minotaur/commit/aac7eab81e96d2fd898edd3f682191cca258f80b
  Date:   2019-09-04 (Wed, 04 Sep 2019)
  Changed paths:
    M src/base/Linearizations.cpp
    M src/base/Linearizations.h
  Log Message:
  root linearization schemes for general case
  Commit: 1781a9a37aa131c1443fb71fd9678ba398c50ce0
      https://github.com/minotaur-solver/minotaur/commit/1781a9a37aa131c1443fb71fd9678ba398c50ce0
  Changed paths:
    M src/algorithms/Bnb.cpp
    M src/algorithms/Bnc.cpp
    M src/algorithms/McBnb.cpp
    M src/algorithms/MiDfo.cpp
    M src/algorithms/MsBnb.cpp
    M src/base/LPRelaxation.cpp
    M src/base/LinearHandler.cpp
    M src/base/NLPRelaxation.cpp
    M src/base/ParReliabilityBrancher.cpp
    M src/base/ParReliabilityBrancher.h
    M src/base/Problem.cpp
    M src/base/Problem.h
    M src/base/Relaxation.cpp
    M src/base/Variable.cpp
    M src/base/Variable.h
    M src/engines/Bqpd/BqpdEngine.cpp
    M src/engines/Cplex/CplexLPEngine.h
    M src/engines/FilterSQP/FilterSQPEngine.cpp
  Log Message:
  Commit: d78add0960d6e8a98358b5062c5e4906c8d02420
      https://github.com/minotaur-solver/minotaur/commit/d78add0960d6e8a98358b5062c5e4906c8d02420
  Changed paths:
    M src/base/Environment.cpp
  Log Message:
  options for root linearizations for general case
Compare: https://github.com/minotaur-solver/minotaur/compare/937cc0d35e9a...d78add0960d6
More information about the Minotaur-dev mailing list
