[Minotaur-dev] [minotaur-solver/minotaur] 1ac261: Initial point is no longer stored as a vector.
Ashutosh Mahajan noreply at github.com
Tue Sep 3 20:40:23 CDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/minotaur-solver/minotaur
  Commit: 1ac261710461eb694b28c6a9dcfb73a2a9e6913e
      https://github.com/minotaur-solver/minotaur/commit/1ac261710461eb694b28c6a9dcfb73a2a9e6913e
  Author: Ashutosh Mahajan <amahajan at iitb.ac.in>
  Date:   2019-09-04 (Wed, 04 Sep 2019)
  Changed paths:
    M src/algorithms/Bnb.cpp
    M src/algorithms/Bnc.cpp
    M src/algorithms/McBnb.cpp
    M src/algorithms/MiDfo.cpp
    M src/algorithms/MsBnb.cpp
    M src/base/LPRelaxation.cpp
    M src/base/LinearHandler.cpp
    M src/base/Linearizations.cpp
    M src/base/NLPRelaxation.cpp
    M src/base/Problem.cpp
    M src/base/Problem.h
    M src/base/Relaxation.cpp
    M src/base/Variable.cpp
    M src/base/Variable.h
    M src/engines/Bqpd/BqpdEngine.cpp
    M src/engines/FilterSQP/FilterSQPEngine.cpp
    M src/engines/Ipopt/IpoptEngine.cpp
  Log Message:
Instead of storing initial point of a problem as a vector, each variable
now stores its own starting value. It makes it easy to modify the
initial point when adding and deleting variables.
  Commit: d23848b22dbae9049c1f83f8a9dd01e90a0fc8a8
      https://github.com/minotaur-solver/minotaur/commit/d23848b22dbae9049c1f83f8a9dd01e90a0fc8a8
  Changed paths:
    M src/engines/Cplex/CplexLPEngine.cpp
    M src/engines/Cplex/CplexLPEngine.h
  Log Message:
  Merge branch 'master' of github:minotaur-solver/minotaur
Compare: https://github.com/minotaur-solver/minotaur/compare/82bbae31dc12...d23848b22dba
More information about the Minotaur-dev mailing list
