[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan amahajan at iitb.ac.in
Mon Sep 2 12:33:45 CDT 2019
Minotaur daily test report
Mon Sep  2 22:37:01 IST 2019
origin.ieor.iitb.ac.in
Linux origin 4.19.0-5-amd64 #1 SMP Debian 4.19.37-5+deb10u2 (2019-08-08) x86_64 GNU/Linux
Detailed log available at  http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-396-gc195ff6
./daily-lnx-iit-test.sh: line 409:  3732 Segmentation fault      valgrind --leak-check=full --show-reachable=yes ./unittest all &> ../../../${NAME}-valgrind.out
rsync: change_dir "/home/amahajan/tmp/minotaur-test/build-all/doxygen/html" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1207) [sender=3.1.3]
Summary
build-base: OK, all binaries compiled.
build-base: 0 errors and 20 warnings in compiling, utest output: OK (41)
build-base-debug: OK, all binaries compiled.
build-base-debug: 0 errors and 18 warnings in compiling, utest output: OK (41)
build-base-static-debug: OK, all binaries compiled.
build-base-static-debug: 0 errors and 18 warnings in compiling, utest output: OK (41)
build-base-static: OK, all binaries compiled.
build-base-static: 0 errors and 21 warnings in compiling, utest output: OK (41)
build-filter: OK, all binaries compiled.
build-filter: 0 errors and 20 warnings in compiling, utest output: OK (41)
build-filter-debug: OK, all binaries compiled.
build-filter-debug: 0 errors and 18 warnings in compiling, utest output: OK (41)
build-filter-static-debug: OK, all binaries compiled.
build-filter-static-debug: 0 errors and 18 warnings in compiling, utest output: OK (41)
build-filter-static: OK, all binaries compiled.
build-filter-static: 0 errors and 21 warnings in compiling, utest output: OK (41)
build-ipopt: OK, all binaries compiled.
build-ipopt: 0 errors and 21 warnings in compiling, utest output: OK (44)
build-ipopt-debug: OK, all binaries compiled.
build-ipopt-debug: 0 errors and 19 warnings in compiling, utest output: OK (44)
build-ipopt-static-debug: OK, all binaries compiled.
build-ipopt-static-debug: 0 errors and 19 warnings in compiling, utest output: OK (44)
build-ipopt-static: OK, all binaries compiled.
build-ipopt-static: 0 errors and 22 warnings in compiling, utest output: OK (44)
build-osi: OK, all binaries compiled.
build-osi: 0 errors and 20 warnings in compiling, utest output: OK (41)
build-osi-debug: OK, all binaries compiled.
build-osi-debug: 0 errors and 18 warnings in compiling, utest output: OK (41)
build-osi-static-debug: OK, all binaries compiled.
build-osi-static-debug: 0 errors and 18 warnings in compiling, utest output: OK (41)
build-osi-static: OK, all binaries compiled.
build-osi-static: 0 errors and 21 warnings in compiling, utest output: OK (41)
build-cbc: OK, all binaries compiled.
build-cbc: 0 errors and 24 warnings in compiling, utest output: OK (41)
build-cbc-debug: OK, all binaries compiled.
build-cbc-debug: 0 errors and 22 warnings in compiling, utest output: OK (41)
build-cbc-static-debug: OK, all binaries compiled.
build-cbc-static-debug: 0 errors and 22 warnings in compiling, utest output: OK (41)
build-cbc-static: OK, all binaries compiled.
build-cbc-static: 0 errors and 25 warnings in compiling, utest output: OK (41)
build-ampl: OK, all binaries compiled.
build-ampl: 0 errors and 23 warnings in compiling, utest output: OK (60)
build-ampl-debug: OK, all binaries compiled.
build-ampl-debug: 0 errors and 21 warnings in compiling, utest output: OK (60)
build-ampl-static-debug: OK, all binaries compiled.
build-ampl-static-debug: 0 errors and 21 warnings in compiling, utest output: OK (60)
build-ampl-static: OK, all binaries compiled.
build-ampl-static: 0 errors and 24 warnings in compiling, utest output: OK (60)
build-all: OK, all binaries compiled.
build-all: utest ERROR
build-all: 0 errors and 30 warnings in compiling, utest output:
build-all-debug: OK, all binaries compiled.
build-all-debug: utest ERROR
build-all-debug: 0 errors and 28 warnings in compiling, utest output:
Valgrind:
==3732== LEAK SUMMARY:
==3732==    definitely lost: 0 bytes in 0 blocks
==3732==    indirectly lost: 0 bytes in 0 blocks
==3732==      possibly lost: 0 bytes in 0 blocks
==3732==    still reachable: 25,770,066 bytes in 1,275 blocks
==3732==         suppressed: 0 bytes in 0 blocks
build-all-static-debug: OK, all binaries compiled.
build-all-static-debug: utest ERROR
build-all-static-debug: 0 errors and 28 warnings in compiling, utest output:
build-all-static: OK, all binaries compiled.
build-all-static: utest ERROR
build-all-static: 0 errors and 31 warnings in compiling, utest output:
build-all-static-spew: OK, all binaries compiled.
build-all-static-spew: utest ERROR
build-all-static-spew: 0 errors and 32 warnings in compiling, utest output:
build-all-manual: ERROR, binary bin/bnb not built.
build-all-manual: utest ERROR
build-all-manual: 4 errors and 60 warnings in compiling, utest output:
Mon Sep  2 23:03:45 IST 2019
More information about the Minotaur-dev mailing list
