[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan mahajan at mcs.anl.gov
Mon May 20 23:17:31 CDT 2019
Minotaur daily test report
Mon May 20 22:57:01 CDT 2019
petsc.mcs.anl.gov
Linux petsc 3.13.0-121-generic #170-Ubuntu SMP Wed Jun 14 09:04:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at  http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-153-g4354d41
Summary
compiling build-base: OK.
make utest output for build-base: OK (41)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (41)
compiling build-base-static: OK.
make utest output for build-base-static: OK (41)
compiling build-filter: OK.
make utest output for build-filter: OK (41)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (41)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (41)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (44)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (44)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (44)
compiling build-osi: OK.
make utest output for build-osi: OK (41)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (41)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (41)
compiling build-ampl: OK.
make utest output for build-ampl: OK (60)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (60)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (60)
compiling build-all: OK.
make utest output for build-all: OK (71)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (71)
compiling build-all-static: OK.
make utest output for build-all-static: OK (71)
compiling build-all-manual: ERROR. lib/libminotaur.a not built.
Errors:
Errors in build-all-debug:
/sandbox/mahajan/minotaur-test/src/base/OAHandler.cpp: In member function ‘void Minotaur::OAHandler::addInitLinearX_(const double*)’:
/sandbox/mahajan/minotaur-test/src/base/OAHandler.cpp:129:22: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
   ConstraintPtr con, newcon;
/sandbox/mahajan/minotaur-test/src/base/OAHandler.cpp: In member function ‘void Minotaur::OAHandler::objCutAtLpSol_(const double*, Minotaur::CutManager*, Minotaur::SeparationStatus*)’:
/sandbox/mahajan/minotaur-test/src/base/OAHandler.cpp:534:19: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
     ConstraintPtr newcon;
/sandbox/mahajan/minotaur-test/src/base/OAHandler.cpp: In member function ‘void Minotaur::OAHandler::consCutAtLpSol_(const double*, Minotaur::CutManager*, Minotaur::SeparationStatus*)’:
/sandbox/mahajan/minotaur-test/src/base/OAHandler.cpp:570:22: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
/sandbox/mahajan/minotaur-test/src/base/OAHandler.cpp: In member function ‘void Minotaur::OAHandler::addCut_(const double*, const double*, Minotaur::ConstraintPtr, Minotaur::CutManager*, Minotaur::SeparationStatus*)’:
/sandbox/mahajan/minotaur-test/src/base/OAHandler.cpp:610:17: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
/sandbox/mahajan/minotaur-test/src/base/OAHandler.cpp: In member function ‘void Minotaur::OAHandler::cutToObj_(const double*, const double*, Minotaur::CutManager*, Minotaur::SeparationStatus*)’:
/sandbox/mahajan/minotaur-test/src/base/OAHandler.cpp:655:19: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
/sandbox/mahajan/minotaur-test/src/base/ParQGHandler.cpp: In member function ‘void Minotaur::ParQGHandler::addInitLinearX_(const double*)’:
/sandbox/mahajan/minotaur-test/src/base/ParQGHandler.cpp:120:22: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
/sandbox/mahajan/minotaur-test/src/base/ParQGHandler.cpp: In member function ‘void Minotaur::ParQGHandler::oaCutEngLim_(const double*, Minotaur::CutManager*, Minotaur::SeparationStatus*)’:
/sandbox/mahajan/minotaur-test/src/base/ParQGHandler.cpp:500:22: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
/sandbox/mahajan/minotaur-test/src/base/ParQGHandler.cpp: In member function ‘void Minotaur::ParQGHandler::oaCutToObj_(const double*, const double*, Minotaur::CutManager*, Minotaur::SeparationStatus*)’:
/sandbox/mahajan/minotaur-test/src/base/ParQGHandler.cpp:592:19: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
/sandbox/mahajan/minotaur-test/src/base/ParReliabilityBrancher.cpp: In member function ‘void Minotaur::ParReliabilityBrancher::findCandidates_(Minotaur::UIntVector*, Minotaur::UIntVector*, Minotaur::DoubleVector*, Minotaur::DoubleVector*, Minotaur::UInt)’:
/sandbox/mahajan/minotaur-test/src/base/ParReliabilityBrancher.cpp:249:15: warning: unused variable ‘v_ptr’ [-Wunused-variable]
   VariablePtr v_ptr;
/sandbox/mahajan/minotaur-test/src/base/PerspCon.cpp: In member function ‘bool Minotaur::PerspCon::boundBinVar(Minotaur::ConstraintPtr, Minotaur::Variable*&)’:
/sandbox/mahajan/minotaur-test/src/base/PerspCon.cpp:60:20: warning: unused variable ‘var’ [-Wunused-variable]
   ConstVariablePtr var;
/sandbox/mahajan/minotaur-test/src/base/PerspCutHandler.cpp: In member function ‘void Minotaur::PerspCutHandler::feasBisecPt(const double*, double*, Minotaur::UInt)’:
/sandbox/mahajan/minotaur-test/src/base/PerspCutHandler.cpp:729:17: warning: unused variable ‘cPtr’ [-Wunused-variable]
   ConstraintPtr cPtr = cons_[it];
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp: In member function ‘void Minotaur::QGHandler::addInitLinearX_(const double*)’:
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp:113:22: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp: In member function ‘void Minotaur::QGHandler::objCutAtLpSol_(const double*, Minotaur::CutManager*, Minotaur::SeparationStatus*)’:
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp:455:19: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp: In member function ‘void Minotaur::QGHandler::consCutAtLpSol_(const double*, Minotaur::CutManager*, Minotaur::SeparationStatus*)’:
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp:492:22: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp: In member function ‘void Minotaur::QGHandler::addCut_(const double*, const double*, Minotaur::ConstraintPtr, Minotaur::CutManager*, Minotaur::SeparationStatus*)’:
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp:532:17: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp: In member function ‘void Minotaur::QGHandler::cutToObj_(const double*, const double*, Minotaur::CutManager*, Minotaur::SeparationStatus*)’:
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp:578:19: warning: variable ‘newcon’ set but not used [-Wunused-but-set-variable]
/sandbox/mahajan/minotaur-test/src/algorithms/QG.cpp: In function ‘int main(int, char**)’:
/sandbox/mahajan/minotaur-test/src/algorithms/QG.cpp:264:13: warning: unused variable ‘proj_nlp_e’ [-Wunused-variable]
   EnginePtr proj_nlp_e = 0;
/sandbox/mahajan/minotaur-test/src/algorithms/QG.cpp:265:13: warning: unused variable ‘l1proj_nlp_e’ [-Wunused-variable]
   EnginePtr l1proj_nlp_e = 0;
: logger ok! OK (71)
==15402== Memcheck, a memory error detector
==15402== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==15402== Using Valgrind-3.10.1 and LibVEX; rerun with -h for copyright info
==15402== Command: ./unittest all
==15402==
: logger ok! ==15402== Conditional jump or move depends on uninitialised value(s)
==15402==    at 0x4DFEE4: bqpd_ (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==15402==    by 0x4D8AD2: Minotaur::BqpdEngine::solve_(int, double&) (BqpdEngine.cpp:512)
==15402==    by 0x4D8572: Minotaur::BqpdEngine::solve() (BqpdEngine.cpp:432)
==15402==    by 0x4CCE90: AMPLBqpdUT::testNLP() (AMPLBqpdUT.cpp:57)
==15402==    by 0x4CE2D3: CppUnit::TestCaller<AMPLBqpdUT>::runTest() (TestCaller.h:166)
==15402==    by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==15402==    by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==15402==    by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==15402==    by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==15402==    by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==15402==    by 0x4E59952: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==15402==    by 0x4E5986D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==15402==
OK (71)
==15402==
==15402== HEAP SUMMARY:
==15402==     in use at exit: 0 bytes in 0 blocks
==15402==   total heap usage: 218,723 allocs, 218,723 frees, 1,088,701,197 bytes allocated
==15402==
==15402== All heap blocks were freed -- no leaks are possible
==15402==
==15402== For counts of detected and suppressed errors, rerun with: -v
==15402== Use --track-origins=yes to see where uninitialised values come from
==15402== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
Errors in build-all:
/sandbox/mahajan/minotaur-test/src/base/LGCIGenerator.cpp: In member function ‘bool Minotaur::LGCIGenerator::hasGubCover(Minotaur::ConstraintConstIterator, Minotaur::ConstConstraintVectorPtr)’:
/sandbox/mahajan/minotaur-test/src/base/LGCIGenerator.cpp:295:74: warning: ‘vartocover’ may be used uninitialized in this function [-Wmaybe-uninitialized]
     ConstConstraintVectorPtr vargubs = probstruct_->getVarGUBs(vartocover);
/sandbox/mahajan/minotaur-test/src/base/MultilinearTermsHandler.cpp: In member function ‘Minotaur::Variable* Minotaur::Hypergraph::maxWeightedDegreeVertex(bool&) const’:
/sandbox/mahajan/minotaur-test/src/base/MultilinearTermsHandler.cpp:1270:10: warning: ‘heavyV’ may be used uninitialized in this function [-Wmaybe-uninitialized]
   return heavyV;
/sandbox/mahajan/minotaur-test/src/base/MultilinearTermsHandler.cpp: In member function ‘Minotaur::Variable* Minotaur::Hypergraph::heaviestIncidentVertex(const SetOfVars&)’:
/sandbox/mahajan/minotaur-test/src/base/MultilinearTermsHandler.cpp:1252:10: warning: ‘bestv’ may be used uninitialized in this function [-Wmaybe-uninitialized]
   return bestv;
   VariablePtr v_ptr;
/sandbox/mahajan/minotaur-test/src/base/QuadHandler.cpp: In member function ‘virtual Minotaur::Branches Minotaur::QuadHandler::getBranches(Minotaur::BrCandPtr, Minotaur::DoubleVector&, Minotaur::RelaxationPtr, Minotaur::SolutionPoolPtr)’:
/sandbox/mahajan/minotaur-test/src/base/QuadHandler.cpp:210:63: warning: ‘v2’ may be used uninitialized in this function [-Wmaybe-uninitialized]
     mod    = (VarBoundModPtr) new VarBoundMod(v2, Lower, value);
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
/sandbox/mahajan/minotaur-test/src/base/PerspCutGenerator.cpp: In member function ‘void Minotaur::PerspCutGenerator::gPCut(Minotaur::FunctionPtr, double*)’:
/sandbox/mahajan/minotaur-test/src/base/PerspCutGenerator.cpp:103:19: warning: unused variable ‘newc’ [-Wunused-variable]
     ConstraintPtr newc;
/sandbox/mahajan/minotaur-test/src/base/PerspCutGenerator.cpp: In destructor ‘Minotaur::PerspCutGenerator::~PerspCutGenerator()’:
/sandbox/mahajan/minotaur-test/src/base/PerspCutGenerator.cpp:156:7: error: request for member ‘reset’ in ‘((Minotaur::PerspCutGenerator*)this)->Minotaur::PerspCutGenerator::cp_’, which is of pointer type ‘Minotaur::ConstConstraintPtr {aka const Minotaur::Constraint*}’ (maybe you meant to use ‘->’ ?)
   cp_.reset();
/sandbox/mahajan/minotaur-test/src/base/PerspCutGenerator.cpp:157:7: error: request for member ‘reset’ in ‘((Minotaur::PerspCutGenerator*)this)->Minotaur::PerspCutGenerator::bp_’, which is of pointer type ‘Minotaur::ConstVariablePtr {aka Minotaur::Variable*}’ (maybe you meant to use ‘->’ ?)
   bp_.reset();
make: *** [/sandbox/mahajan/minotaur-test/src/base/PerspCutGenerator.o] Error 1
Errors in build-all-static:
   return heavyV;
   return bestv;
/sandbox/mahajan/minotaur-test/src/base/MultilinearTermsHandler.cpp: In member function ‘void Minotaur::MultilinearTermsHandler::weightedDegreeHeuristic_()’:
/sandbox/mahajan/minotaur-test/src/base/MultilinearTermsHandler.cpp:1047:69: warning: ‘heavyV’ may be used uninitialized in this function [-Wmaybe-uninitialized]
       Hypergraph::ListOfSetOfVars edges = H_->incidentEdges(heavyVar);
   VariablePtr v_ptr;
Errors in build-ampl-debug:
   VariablePtr v_ptr;
: logger ok! OK (60)
Errors in build-ampl:
   return heavyV;
   return bestv;
   VariablePtr v_ptr;
Errors in build-ampl-static:
   return heavyV;
   return bestv;
   VariablePtr v_ptr;
Errors in build-base-debug:
   VariablePtr v_ptr;
: logger ok! OK (41)
Errors in build-base:
   return heavyV;
   return bestv;
   VariablePtr v_ptr;
Errors in build-base-static:
   return heavyV;
   return bestv;
   VariablePtr v_ptr;
Errors in build-filter-debug:
   VariablePtr v_ptr;
Errors in build-filter:
   return heavyV;
   return bestv;
   VariablePtr v_ptr;
Errors in build-filter-static:
   return heavyV;
   return bestv;
   VariablePtr v_ptr;
Errors in build-ipopt-debug:
   VariablePtr v_ptr;
: logger ok! OK (44)
Errors in build-ipopt:
   return heavyV;
   return bestv;
   VariablePtr v_ptr;
Errors in build-ipopt-static:
   return heavyV;
   return bestv;
   VariablePtr v_ptr;
Errors in build-osi-debug:
   VariablePtr v_ptr;
Errors in build-osi:
   return heavyV;
   return bestv;
   VariablePtr v_ptr;
Errors in build-osi-static:
   return heavyV;
   return bestv;
   VariablePtr v_ptr;
End of tests
More information about the Minotaur-dev mailing list
