[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan mahajan at mcs.anl.gov
Mon Mar 4 23:18:44 CST 2019
Minotaur daily test report
Mon Mar  4 22:57:01 CST 2019
petsc.mcs.anl.gov
Linux petsc 3.13.0-121-generic #170-Ubuntu SMP Wed Jun 14 09:04:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at  http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-116-g3cef152
./daily-lnx-test.sh: line 272: 19075 Killed                  valgrind --leak-check=full --show-reachable=yes ./unittest all >> ../../../${NAME}.out 2>> ../../../${NAME}.err
Summary
compiling build-base: OK.
make utest output for build-base: OK (41)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (41)
compiling build-base-static: OK.
make utest output for build-base-static: OK (41)
compiling build-filter: OK.
make utest output for build-filter: OK (41)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (41)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (41)
compiling build-ipopt: OK.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: ERROR
compiling build-osi: OK.
make utest output for build-osi: OK (41)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (41)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (41)
compiling build-ampl: OK.
make utest output for build-ampl: OK (60)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (60)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (60)
compiling build-all: OK.
make utest output for build-all: ERROR
compiling build-all-debug: OK.
make utest output for build-all-debug: ERROR
compiling build-all-static: OK.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. bin/qg not built.
Errors:
Errors in build-all-debug:
In file included from /sandbox/mahajan/minotaur-test/src/base/ParQGBranchAndBound.cpp:30:0:
/sandbox/mahajan/minotaur-test/src/base/NodeProcessor.h:95:20: warning: ‘virtual void Minotaur::NodeProcessor::setCutManager(Minotaur::CutManager*)’ was hidden [-Woverloaded-virtual]
       virtual void setCutManager(CutManager *) {};
In file included from /sandbox/mahajan/minotaur-test/src/base/ParQGBranchAndBound.cpp:34:0:
/sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.h:96:10: warning:   by ‘void Minotaur::ParPCBProcessor::setCutManager(Minotaur::ParCutMan*)’ [-Woverloaded-virtual]
     void setCutManager(ParCutMan* cutman);
In file included from /sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.h:17:0,
                 from /sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.cpp:27:
In file included from /sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.cpp:27:0:
                 from /sandbox/mahajan/minotaur-test/src/algorithms/McQG.cpp:40:
In file included from /sandbox/mahajan/minotaur-test/src/algorithms/McQG.cpp:40:0:
: logger ok! unittest: /sandbox/mahajan/minotaur-test/minotaur-externals/boost/smart_ptr/shared_ptr.hpp:710: typename boost::detail::sp_member_access<T>::type boost::shared_ptr<T>::operator->() const [with T = Minotaur::Environment; typename boost::detail::sp_member_access<T>::type = Minotaur::Environment*]: Assertion `px != 0' failed.
/bin/sh: line 1: 18970 Aborted                 (core dumped) /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest all
make[3]: *** [CMakeFiles/utest] Error 134
make[2]: *** [CMakeFiles/utest.dir/all] Error 2
make[1]: *** [CMakeFiles/utest.dir/rule] Error 2
make: *** [utest] Error 2
==19075== Memcheck, a memory error detector
==19075== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==19075== Using Valgrind-3.10.1 and LibVEX; rerun with -h for copyright info
==19075== Command: ./unittest all
==19075==
==19075==
==19075== HEAP SUMMARY:
==19075==     in use at exit: 331,411 bytes in 4,336 blocks
==19075==   total heap usage: 11,558 allocs, 7,222 frees, 1,287,548 bytes allocated
==19075==
==19075== 0 bytes in 1 blocks are still reachable in loss record 1 of 3,576
==19075==    at 0x4C2B800: operator new[](unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==19075==    by 0x71ACFD9: Minotaur::HessianOfLag::setupRowCol() (HessianOfLag.cpp:180)
==19075==    by 0x71AC31C: Minotaur::HessianOfLag::HessianOfLag(Minotaur::Problem*) (HessianOfLag.cpp:58)
==19075==    by 0x72800CE: Minotaur::Problem::setNativeDer() (Problem.cpp:1348)
==19075==    by 0x4707EC: JacobianUT::testLinearEval() (JacobianUT.cpp:60)
==19075==    by 0x477AA5: CppUnit::TestCaller<JacobianUT>::runTest() (TestCaller.h:166)
==19075==    by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==19075==    by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==19075==    by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==19075==    by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==19075==    by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==19075==    by 0x4E59952: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==19075==
==19075== 0 bytes in 1 blocks are still reachable in loss record 2 of 3,576
==19075==    by 0x4788D9: HessianOfLagUT::testEmpty() (HessianOfLagUT.cpp:67)
==19075==    by 0x47D8ED: CppUnit::TestCaller<HessianOfLagUT>::runTest() (TestCaller.h:166)
==19075==
==19075== 0 bytes in 1 blocks are still reachable in loss record 3 of 3,576
==19075==    by 0x478C8C: HessianOfLagUT::testLinearEval() (HessianOfLagUT.cpp:78)
==19075==
==19075== 4 bytes in 1 blocks are still reachable in loss record 4 of 3,576
==19075==    by 0x71ACCA2: Minotaur::HessianOfLag::setupRowCol() (HessianOfLag.cpp:152)
==19075==
==19075== 4 bytes in 1 blocks are still reachable in loss record 5 of 3,576
==19075==
==19075== 4 bytes in 1 blocks are still reachable in loss record 6 of 3,576
==19075==    at 0x4C2B0E0: operator new(unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==19075==    by 0x7147C4B: __gnu_cxx::new_allocator<unsigned int>::allocate(unsigned long, void const*) (new_allocator.h:104)
==19075==    by 0x7144D44: std::_Vector_base<unsigned int, std::allocator<unsigned int> >::_M_allocate(unsigned long) (in /sandbox/mahajan/minotaur-test/build-all-debug/src/base/libminotaur.so)
==19075==    by 0x7141BFA: std::vector<unsigned int, std::allocator<unsigned int> >::_M_insert_aux(__gnu_cxx::__normal_iterator<unsigned int*, std::vector<unsigned int, std::allocator<unsigned int> > >, unsigned int const&) (vector.tcc:345)
==19075==    by 0x713F31B: std::vector<unsigned int, std::allocator<unsigned int> >::push_back(unsigned int const&) (stl_vector.h:913)
==19075==    by 0x72AC762: Minotaur::QuadraticFunction::prepHess() (QuadraticFunction.cpp:460)
==19075==    by 0x72AA90C: Minotaur::QuadraticFunction::fillHessStor(Minotaur::LTHessStor*) (QuadraticFunction.cpp:190)
==19075==    by 0x71AA3FF: Minotaur::Function::fillHessStor(Minotaur::LTHessStor*) (Function.cpp:444)
==19075==    by 0x71ACE9C: Minotaur::HessianOfLag::setupRowCol() (HessianOfLag.cpp:167)
==19075==
==19075== 4 bytes in 1 blocks are still reachable in loss record 7 of 3,576
==19075==
==19075== 5 bytes in 1 blocks are still reachable in loss record 8 of 3,576
==19075==    at 0x4C2AB80: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==19075==    by 0x529AB84: ??? (in /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
==19075==    by 0x535EEC2: ??? (in /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
==19075==    by 0x52981F7: ??? (in /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
==19075==    by 0x40101D9: call_init.part.0 (dl-init.c:78)
==19075==    by 0x40102C2: call_init (dl-init.c:36)
==19075==    by 0x40102C2: _dl_init (dl-init.c:126)
==19075==    by 0x4001299: ??? (in /lib/x86_64-linux-gnu/ld-2.19.so)
==19075==    by 0x1: ???
==19075==    by 0xFFF000E22: ???
==19075==    by 0xFFF000E2D: ???
==19075==
==19075== 6 bytes in 1 blocks are still reachable in loss record 9 of 3,576
==19075==    by 0x535EF9A: ??? (in /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
==19075==
==19075== 6 bytes in 1 blocks are still reachable in loss record 10 of 3,576
==19075==    by 0x535F072: ??? (in /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 11 of 3,576
==19075==    by 0x4E585B9: CppUnit::SynchronizedObject::SynchronizedObject(CppUnit::SynchronizedObject::SynchronizationObject*) (SynchronizedObject.cpp:9)
==19075==    by 0x4E61410: CppUnit::TestSuccessListener::TestSuccessListener(CppUnit::SynchronizedObject::SynchronizationObject*) (TestSuccessListener.cpp:9)
==19075==    by 0x4E608CD: CppUnit::TestResultCollector::TestResultCollector(CppUnit::SynchronizedObject::SynchronizationObject*) (TestResultCollector.cpp:9)
==19075==    by 0x4E62DF3: CppUnit::TextTestRunner::TextTestRunner(CppUnit::Outputter*) (TextTestRunner.cpp:23)
==19075==    by 0x45DC93: main (unittest.cpp:31)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 12 of 3,576
==19075==    by 0x4E5F6DB: CppUnit::TestResult::TestResult(CppUnit::SynchronizedObject::SynchronizationObject*) (TestResult.cpp:18)
==19075==    by 0x4E62E0E: CppUnit::TextTestRunner::TextTestRunner(CppUnit::Outputter*) (TextTestRunner.cpp:23)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 13 of 3,576
==19075==    by 0x4E5F880: CppUnit::TestResult::TestResult(CppUnit::SynchronizedObject::SynchronizationObject*) (TestResult.cpp:20)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 14 of 3,576
==19075==    by 0x45DD12: main (unittest.cpp:33)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 15 of 3,576
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 16 of 3,576
==19075==    by 0x45DD33: main (unittest.cpp:34)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 17 of 3,576
==19075==    by 0x48BAAC: CppUnit::ConcretTestFixtureFactory<LoggerUT>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x48B3E1: CppUnit::TestSuiteBuilderContext<LoggerUT>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x48AF73: LoggerUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LoggerUT.h:30)
==19075==    by 0x48B2A0: LoggerUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x48BA56: CppUnit::TestSuiteFactory<LoggerUT>::makeTest() (TestSuiteFactory.h:20)
==19075==    by 0x4E59C81: CppUnit::TestFactoryRegistry::addTestToSuite(CppUnit::TestSuite*) (TestFactoryRegistry.cpp:149)
==19075==    by 0x4E59D00: CppUnit::TestFactoryRegistry::makeTest() (TestFactoryRegistry.cpp:136)
==19075==    by 0x45DE5D: main (unittest.cpp:42)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 18 of 3,576
==19075==    by 0x48B03C: LoggerUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LoggerUT.h:31)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 19 of 3,576
==19075==    by 0x4E61695: allocate (new_allocator.h:104)
==19075==    by 0x4E61695: _M_allocate (stl_vector.h:168)
==19075==    by 0x4E61695: std::vector<CppUnit::Test*, std::allocator<CppUnit::Test*> >::_M_insert_aux(__gnu_cxx::__normal_iterator<CppUnit::Test**, std::vector<CppUnit::Test*, std::allocator<CppUnit::Test*> > >, CppUnit::Test* const&) (vector.tcc:345)
==19075==    by 0x4E615DD: push_back (stl_vector.h:913)
==19075==    by 0x4E615DD: CppUnit::TestSuite::addTest(CppUnit::Test*) (TestSuite.cpp:38)
==19075==    by 0x48CF83: ObjectiveUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (ObjectiveUT.h:32)
==19075==    by 0x48D15C: ObjectiveUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x48DD96: CppUnit::TestSuiteFactory<ObjectiveUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 20 of 3,576
==19075==    by 0x4ABBAE: TimerUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (TimerUT.h:28)
==19075==    by 0x4ABD88: TimerUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4AC210: CppUnit::TestSuiteFactory<TimerUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 21 of 3,576
==19075==    by 0x4B65BE: IpoptEngineUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (IpoptEngineUT.h:33)
==19075==    by 0x4B6798: IpoptEngineUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4B7FD6: CppUnit::TestSuiteFactory<IpoptEngineUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 22 of 3,576
==19075==    by 0x4D7306: PolySolverUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (PolySolverUT.h:44)
==19075==    by 0x4D74E0: PolySolverUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4D799A: CppUnit::TestSuiteFactory<PolySolverUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 23 of 3,576
==19075==    by 0x4DA799: AMPLBqpdUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (AMPLBqpdUT.h:34)
==19075==    by 0x4DA972: AMPLBqpdUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DB390: CppUnit::TestSuiteFactory<AMPLBqpdUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 24 of 3,576
==19075==    by 0x4DE587: AMPLIpoptUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (AMPLIpoptUT.h:34)
==19075==    by 0x4DE760: AMPLIpoptUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DEBE8: CppUnit::TestSuiteFactory<AMPLIpoptUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 25 of 3,576
==19075==    by 0x45DE72: main (unittest.cpp:42)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 26 of 3,576
==19075==    by 0x45DF4E: main (unittest.cpp:49)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 27 of 3,576
==19075==    by 0x71971CD: Minotaur::Environment::Environment() (Environment.cpp:34)
==19075==    by 0x4ADB29: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:293)
==19075==    by 0x4B4A37: CppUnit::TestCaller<NLPBnbUT>::runTest() (TestCaller.h:166)
==19075==    by 0x4E5986D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==19075==
==19075== 8 bytes in 1 blocks are still reachable in loss record 28 of 3,576
==19075==    by 0x5B5388F: std::vector<Ipopt::SmartPtr<Ipopt::Journal>, std::allocator<Ipopt::SmartPtr<Ipopt::Journal> > >::_M_insert_aux(__gnu_cxx::__normal_iterator<Ipopt::SmartPtr<Ipopt::Journal>*, std::vector<Ipopt::SmartPtr<Ipopt::Journal>, std::allocator<Ipopt::SmartPtr<Ipopt::Journal> > > >, Ipopt::SmartPtr<Ipopt::Journal> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B5357A: Ipopt::Journalist::AddJournal(Ipopt::SmartPtr<Ipopt::Journal>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B5325C: Ipopt::Journalist::AddFileJournal(std::string const&, std::string const&, Ipopt::EJournalLevel) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A391A9: Ipopt::IpoptApplication::IpoptApplication(bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x57C26E9: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:300)
==19075==    by 0x507AE4F: Minotaur::EngineFactory::getNLPEngine() (EngineFactory.cpp:119)
==19075==    by 0x4AE092: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:314)
==19075==
==19075== 8 bytes in 1 blocks are definitely lost in loss record 29 of 3,576
==19075==    by 0x71ACBB5: Minotaur::HessianOfLag::setupRowCol() (HessianOfLag.cpp:150)
==19075==
==19075== 8 bytes in 1 blocks are definitely lost in loss record 30 of 3,576
==19075==
==19075== 8 bytes in 1 blocks are definitely lost in loss record 31 of 3,576
==19075==
==19075== 12 bytes in 1 blocks are still reachable in loss record 32 of 3,576
==19075==    by 0x71CD952: Minotaur::LinearHandler::LinearHandler(boost::shared_ptr<Minotaur::Environment>, boost::shared_ptr<Minotaur::Problem>) (LinearHandler.cpp:73)
==19075==    by 0x4ADF22: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:307)
==19075==
==19075== 16 bytes in 1 blocks are still reachable in loss record 33 of 3,576
==19075==    by 0x45DD41: main (unittest.cpp:36)
==19075==
==19075== 16 bytes in 1 blocks are still reachable in loss record 34 of 3,576
==19075==    by 0x476B8C: JacobianUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (JacobianUT.h:35)
==19075==    by 0x476DB2: JacobianUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x477910: CppUnit::TestSuiteFactory<JacobianUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 16 bytes in 1 blocks are still reachable in loss record 35 of 3,576
==19075==    by 0x48B07B: LoggerUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LoggerUT.h:31)
==19075==
==19075== 16 bytes in 1 blocks are still reachable in loss record 36 of 3,576
==19075==    by 0x4942DE: PerspRefUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (PerspRefUT.h:36)
==19075==    by 0x494504: PerspRefUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x494BA4: CppUnit::TestSuiteFactory<PerspRefUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 16 bytes in 1 blocks are still reachable in loss record 37 of 3,576
==19075==    by 0x49A059: PolyUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (PolyUT.h:31)
==19075==    by 0x49A27E: PolyUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x49AE70: CppUnit::TestSuiteFactory<PolyUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 16 bytes in 1 blocks are still reachable in loss record 38 of 3,576
==19075==    by 0x4AF63F: NLPBnbUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (NLPBnbUT.h:70)
==19075==    by 0x4AF864: NLPBnbUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4B48A2: CppUnit::TestSuiteFactory<NLPBnbUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 16 bytes in 1 blocks are still reachable in loss record 39 of 3,576
==19075==    by 0x4DCC85: AMPLFilterSQPUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (AMPLFilterSQPUT.h:36)
==19075==    by 0x4DCEAA: AMPLFilterSQPUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DD5D4: CppUnit::TestSuiteFactory<AMPLFilterSQPUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 16 bytes in 1 blocks are still reachable in loss record 40 of 3,576
==19075==    by 0x7186C53: __gnu_cxx::new_allocator<boost::shared_ptr<Minotaur::Constraint> >::allocate(unsigned long, void const*) (new_allocator.h:104)
==19075==    by 0x71843FA: std::_Vector_base<boost::shared_ptr<Minotaur::Constraint>, std::allocator<boost::shared_ptr<Minotaur::Constraint> > >::_M_allocate(unsigned long) (in /sandbox/mahajan/minotaur-test/build-all-debug/src/base/libminotaur.so)
==19075==    by 0x7182680: std::vector<boost::shared_ptr<Minotaur::Constraint>, std::allocator<boost::shared_ptr<Minotaur::Constraint> > >::_M_insert_aux(__gnu_cxx::__normal_iterator<boost::shared_ptr<Minotaur::Constraint>*, std::vector<boost::shared_ptr<Minotaur::Constraint>, std::allocator<boost::shared_ptr<Minotaur::Constraint> > > >, boost::shared_ptr<Minotaur::Constraint> const&) (vector.tcc:345)
==19075==    by 0x71807F1: std::vector<boost::shared_ptr<Minotaur::Constraint>, std::allocator<boost::shared_ptr<Minotaur::Constraint> > >::push_back(boost::shared_ptr<Minotaur::Constraint> const&) (stl_vector.h:913)
==19075==    by 0x727D99F: Minotaur::Problem::newConstraint(boost::shared_ptr<Minotaur::Function>, double, double, std::string) (Problem.cpp:1019)
==19075==    by 0x727DC30: Minotaur::Problem::newConstraint(boost::shared_ptr<Minotaur::Function>, double, double) (Problem.cpp:1040)
==19075==    by 0x4AD69A: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:275)
==19075==    by 0x4ADD55: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:296)
==19075==
==19075== 16 bytes in 1 blocks are still reachable in loss record 41 of 3,576
==19075==    by 0x727FE64: Minotaur::Problem::setInitialPoint(double const*) (Problem.cpp:1304)
==19075==    by 0x4AD7DA: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:286)
==19075==
==19075== 16 bytes in 1 blocks are still reachable in loss record 42 of 3,576
==19075==    by 0x5B69E49: std::vector<Ipopt::RegisteredOption::string_entry, std::allocator<Ipopt::RegisteredOption::string_entry> >::_M_insert_aux(__gnu_cxx::__normal_iterator<Ipopt::RegisteredOption::string_entry*, std::vector<Ipopt::RegisteredOption::string_entry, std::allocator<Ipopt::RegisteredOption::string_entry> > >, Ipopt::RegisteredOption::string_entry const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B6A256: Ipopt::RegisteredOption::AddValidStringSetting(std::string, std::string) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B65C66: Ipopt::RegisteredOptions::AddStringOption1(std::string const&, std::string const&, std::string const&, std::string const&, std::string const&, std::string const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A344AB: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A3363C: Ipopt::RegisterOptions_Interfaces(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A357F8: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A39098: Ipopt::IpoptApplication::IpoptApplication(bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 16 bytes in 1 blocks are still reachable in loss record 43 of 3,576
==19075==    by 0x5A34B7F: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 20 bytes in 1 blocks are still reachable in loss record 44 of 3,576
==19075==    by 0x473125: JacobianUT::testQuadEval() (JacobianUT.cpp:129)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 45 of 3,576
==19075==    by 0x536668A: ??? (in /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
==19075==    by 0x535EEE9: ??? (in /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 46 of 3,576
==19075==    by 0x535EFC1: ??? (in /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 47 of 3,576
==19075==    by 0x535F09C: ??? (in /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 48 of 3,576
==19075==    by 0x4E62E39: CppUnit::TextTestRunner::TextTestRunner(CppUnit::Outputter*) (TextTestRunner.cpp:26)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 49 of 3,576
==19075==    by 0x46396E: CppUnit::ConcretTestFixtureFactory<CGraphUT>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x462855: CppUnit::TestSuiteBuilderContext<CGraphUT>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x4621A5: CGraphUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (CGraphUT.h:32)
==19075==    by 0x462616: CGraphUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x463952: CppUnit::TestSuiteFactory<CGraphUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 50 of 3,576
==19075==    by 0x462287: CGraphUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (CGraphUT.h:33)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 51 of 3,576
==19075==    by 0x462350: CGraphUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (CGraphUT.h:34)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 52 of 3,576
==19075==    by 0x480B78: CppUnit::ConcretTestFixtureFactory<LapackTest>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x4807BB: CppUnit::TestSuiteBuilderContext<LapackTest>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x480279: LapackTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LapackUT.h:32)
==19075==    by 0x4806D4: LapackTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x480B5C: CppUnit::TestSuiteFactory<LapackTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 53 of 3,576
==19075==    by 0x48035B: LapackTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LapackUT.h:33)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 54 of 3,576
==19075==    by 0x480424: LapackTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LapackUT.h:34)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 55 of 3,576
==19075==    by 0x490B20: CppUnit::ConcretTestFixtureFactory<OperationsTest>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x4906DF: CppUnit::TestSuiteBuilderContext<OperationsTest>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x49018A: OperationsTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (OperationsUT.h:29)
==19075==    by 0x4905E6: OperationsTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x490B04: CppUnit::TestSuiteFactory<OperationsTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 56 of 3,576
==19075==    by 0x49026C: OperationsTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (OperationsUT.h:30)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 57 of 3,576
==19075==    by 0x490335: OperationsTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (OperationsUT.h:31)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 58 of 3,576
==19075==    by 0x49AE8C: CppUnit::ConcretTestFixtureFactory<PolyUT>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x49A3FB: CppUnit::TestSuiteBuilderContext<PolyUT>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x499F51: PolyUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (PolyUT.h:30)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 59 of 3,576
==19075==    by 0x49A01A: PolyUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (PolyUT.h:31)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 60 of 3,576
==19075==    by 0x4B48BE: CppUnit::ConcretTestFixtureFactory<NLPBnbUT>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x4B00A9: CppUnit::TestSuiteBuilderContext<NLPBnbUT>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x4AF537: NLPBnbUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (NLPBnbUT.h:69)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 61 of 3,576
==19075==    by 0x4AF600: NLPBnbUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (NLPBnbUT.h:70)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 62 of 3,576
==19075==    by 0x463025: boost::detail::shared_count::shared_count<Minotaur::Variable>(Minotaur::Variable*) (shared_count.hpp:137)
==19075==    by 0x462D50: void boost::detail::sp_pointer_construct<Minotaur::Variable, Minotaur::Variable>(boost::shared_ptr<Minotaur::Variable>*, Minotaur::Variable*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x462B20: boost::shared_ptr<Minotaur::Variable>::shared_ptr<Minotaur::Variable>(Minotaur::Variable*) (shared_ptr.hpp:362)
==19075==    by 0x727EB85: Minotaur::Problem::newVariable(double, double, Minotaur::VariableType, std::string, Minotaur::VarSrcType) (Problem.cpp:1146)
==19075==    by 0x727D61F: Minotaur::Problem::newBinaryVariable() (Problem.cpp:994)
==19075==    by 0x46C4D0: ProblemTest::testVarTypes() (ProblemUT.cpp:103)
==19075==    by 0x46FCB5: CppUnit::TestCaller<ProblemTest>::runTest() (TestCaller.h:166)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 63 of 3,576
==19075==    by 0x727E9BB: Minotaur::Problem::newVariable(double, double, Minotaur::VariableType, Minotaur::VarSrcType) (Problem.cpp:1134)
==19075==    by 0x46E2C6: ProblemTest::testaddToObj() (ProblemUT.cpp:143)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 64 of 3,576
==19075==    by 0x7282143: boost::detail::shared_count::shared_count<Minotaur::ProblemSize>(Minotaur::ProblemSize*) (shared_count.hpp:137)
==19075==    by 0x7281ACE: void boost::detail::sp_pointer_construct<Minotaur::ProblemSize, Minotaur::ProblemSize>(boost::shared_ptr<Minotaur::ProblemSize>*, Minotaur::ProblemSize*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x72812F2: boost::shared_ptr<Minotaur::ProblemSize>::shared_ptr<Minotaur::ProblemSize>(Minotaur::ProblemSize*) (shared_ptr.hpp:362)
==19075==    by 0x7277BDE: Minotaur::Problem::calculateSize(bool) (Problem.cpp:111)
==19075==    by 0x7280040: Minotaur::Problem::setNativeDer() (Problem.cpp:1345)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 65 of 3,576
==19075==    by 0x7280067: Minotaur::Problem::setNativeDer() (Problem.cpp:1347)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 66 of 3,576
==19075==    by 0x728257B: boost::detail::shared_count::shared_count<Minotaur::Jacobian>(Minotaur::Jacobian*) (shared_count.hpp:137)
==19075==    by 0x7281FC7: void boost::detail::sp_pointer_construct<Minotaur::Jacobian, Minotaur::Jacobian>(boost::shared_ptr<Minotaur::Jacobian>*, Minotaur::Jacobian*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x72818F0: boost::shared_ptr<Minotaur::Jacobian>::shared_ptr<Minotaur::Jacobian>(Minotaur::Jacobian*) (shared_ptr.hpp:362)
==19075==    by 0x728008F: Minotaur::Problem::setNativeDer() (Problem.cpp:1347)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 67 of 3,576
==19075==    by 0x7282603: boost::detail::shared_count::shared_count<Minotaur::HessianOfLag>(Minotaur::HessianOfLag*) (shared_count.hpp:137)
==19075==    by 0x728202B: void boost::detail::sp_pointer_construct<Minotaur::HessianOfLag, Minotaur::HessianOfLag>(boost::shared_ptr<Minotaur::HessianOfLag>*, Minotaur::HessianOfLag*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x728195E: boost::shared_ptr<Minotaur::HessianOfLag>::shared_ptr<Minotaur::HessianOfLag>(Minotaur::HessianOfLag*) (shared_ptr.hpp:362)
==19075==    by 0x72800DD: Minotaur::Problem::setNativeDer() (Problem.cpp:1348)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 68 of 3,576
==19075==    by 0x469BA7: boost::detail::shared_count::shared_count<Minotaur::QuadraticFunction>(Minotaur::QuadraticFunction*) (shared_count.hpp:137)
==19075==    by 0x4695DA: void boost::detail::sp_pointer_construct<Minotaur::QuadraticFunction, Minotaur::QuadraticFunction>(boost::shared_ptr<Minotaur::QuadraticFunction>*, Minotaur::QuadraticFunction*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x468E6A: boost::shared_ptr<Minotaur::QuadraticFunction>::shared_ptr<Minotaur::QuadraticFunction>(Minotaur::QuadraticFunction*) (shared_ptr.hpp:362)
==19075==    by 0x4724EE: JacobianUT::testQuadEval() (JacobianUT.cpp:105)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 69 of 3,576
==19075==    by 0x469C4D: boost::detail::shared_count::shared_count<Minotaur::Function>(Minotaur::Function*) (shared_count.hpp:137)
==19075==    by 0x46967E: void boost::detail::sp_pointer_construct<Minotaur::Function, Minotaur::Function>(boost::shared_ptr<Minotaur::Function>*, Minotaur::Function*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x468FBC: boost::shared_ptr<Minotaur::Function>::shared_ptr<Minotaur::Function>(Minotaur::Function*) (shared_ptr.hpp:362)
==19075==    by 0x472733: JacobianUT::testQuadEval() (JacobianUT.cpp:109)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 70 of 3,576
==19075==    by 0x7282253: boost::detail::shared_count::shared_count<Minotaur::Constraint>(Minotaur::Constraint*) (shared_count.hpp:137)
==19075==    by 0x7281BE6: void boost::detail::sp_pointer_construct<Minotaur::Constraint, Minotaur::Constraint>(boost::shared_ptr<Minotaur::Constraint>*, Minotaur::Constraint*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x7281782: boost::shared_ptr<Minotaur::Constraint>::shared_ptr<Minotaur::Constraint>(Minotaur::Constraint*) (shared_ptr.hpp:362)
==19075==    by 0x727D8AD: Minotaur::Problem::newConstraint(boost::shared_ptr<Minotaur::Function>, double, double, std::string) (Problem.cpp:1012)
==19075==    by 0x472830: JacobianUT::testQuadEval() (JacobianUT.cpp:110)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 71 of 3,576
==19075==    by 0x472890: JacobianUT::testQuadEval() (JacobianUT.cpp:112)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 72 of 3,576
==19075==    by 0x469B01: boost::detail::shared_count::shared_count<Minotaur::LinearFunction>(Minotaur::LinearFunction*) (shared_count.hpp:137)
==19075==    by 0x469535: void boost::detail::sp_pointer_construct<Minotaur::LinearFunction, Minotaur::LinearFunction>(boost::shared_ptr<Minotaur::LinearFunction>*, Minotaur::LinearFunction*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x468D38: boost::shared_ptr<Minotaur::LinearFunction>::shared_ptr<Minotaur::LinearFunction>(Minotaur::LinearFunction*) (shared_ptr.hpp:362)
==19075==    by 0x4728E3: JacobianUT::testQuadEval() (JacobianUT.cpp:113)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 73 of 3,576
==19075==    by 0x472B59: JacobianUT::testQuadEval() (JacobianUT.cpp:117)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 74 of 3,576
==19075==    by 0x472C56: JacobianUT::testQuadEval() (JacobianUT.cpp:118)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 75 of 3,576
==19075==    by 0x472CB6: JacobianUT::testQuadEval() (JacobianUT.cpp:120)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 76 of 3,576
==19075==    by 0x472D09: JacobianUT::testQuadEval() (JacobianUT.cpp:121)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 77 of 3,576
==19075==    by 0x472FD4: JacobianUT::testQuadEval() (JacobianUT.cpp:126)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 78 of 3,576
==19075==    by 0x4730D1: JacobianUT::testQuadEval() (JacobianUT.cpp:127)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 79 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 80 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 81 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 82 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 83 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 84 of 3,576
==19075==    by 0x4786AC: HessianOfLagUT::testEmpty() (HessianOfLagUT.cpp:63)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 85 of 3,576
==19075==    by 0x478788: HessianOfLagUT::testEmpty() (HessianOfLagUT.cpp:65)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 86 of 3,576
==19075==    by 0x478885: HessianOfLagUT::testEmpty() (HessianOfLagUT.cpp:66)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 87 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 88 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 89 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 90 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 91 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 92 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 93 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 94 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 95 of 3,576
==19075==    by 0x478FDD: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:96)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 96 of 3,576
==19075==    by 0x479222: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:100)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 97 of 3,576
==19075==    by 0x47931F: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:101)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 98 of 3,576
==19075==    by 0x47937F: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:103)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 99 of 3,576
==19075==    by 0x4793D2: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:104)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 100 of 3,576
==19075==    by 0x479648: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:108)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 101 of 3,576
==19075==    by 0x479745: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:109)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 102 of 3,576
==19075==    by 0x4797A5: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:111)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 103 of 3,576
==19075==    by 0x4797F8: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:112)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 104 of 3,576
==19075==    by 0x479B06: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:117)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 105 of 3,576
==19075==    by 0x479C03: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:118)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 106 of 3,576
==19075==    by 0x479C57: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:120)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 107 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 108 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 109 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 110 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 111 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 112 of 3,576
==19075==    by 0x48BDE9: ObjectiveUT::setUp() (ObjectiveUT.cpp:27)
==19075==    by 0x48DF58: CppUnit::TestCaller<ObjectiveUT>::setUp() (TestCaller.h:177)
==19075==    by 0x4E59286: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:87)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 113 of 3,576
==19075==    by 0x48BE8D: ObjectiveUT::setUp() (ObjectiveUT.cpp:28)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 114 of 3,576
==19075==    by 0x48BF31: ObjectiveUT::setUp() (ObjectiveUT.cpp:29)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 115 of 3,576
==19075==    by 0x48BFD5: ObjectiveUT::setUp() (ObjectiveUT.cpp:30)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 116 of 3,576
==19075==    by 0x48C037: ObjectiveUT::setUp() (ObjectiveUT.cpp:32)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 117 of 3,576
==19075==    by 0x48D859: boost::detail::shared_count::shared_count<myNLFun2>(myNLFun2*) (shared_count.hpp:137)
==19075==    by 0x48D771: void boost::detail::sp_pointer_construct<myNLFun2, myNLFun2>(boost::shared_ptr<myNLFun2>*, myNLFun2*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x48D622: boost::shared_ptr<myNLFun2>::shared_ptr<myNLFun2>(myNLFun2*) (shared_ptr.hpp:362)
==19075==    by 0x48C194: ObjectiveUT::setUp() (ObjectiveUT.cpp:38)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 118 of 3,576
==19075==    by 0x48C213: ObjectiveUT::setUp() (ObjectiveUT.cpp:40)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 119 of 3,576
==19075==    by 0x48D8CD: boost::detail::shared_count::shared_count<Minotaur::Objective>(Minotaur::Objective*) (shared_count.hpp:137)
==19075==    by 0x48D7DB: void boost::detail::sp_pointer_construct<Minotaur::Objective, Minotaur::Objective>(boost::shared_ptr<Minotaur::Objective>*, Minotaur::Objective*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x48D6D0: boost::shared_ptr<Minotaur::Objective>::shared_ptr<Minotaur::Objective>(Minotaur::Objective*) (shared_ptr.hpp:362)
==19075==    by 0x48C293: ObjectiveUT::setUp() (ObjectiveUT.cpp:42)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 120 of 3,576
==19075==    by 0x71CB434: Minotaur::operator*(boost::shared_ptr<Minotaur::LinearFunction const>, boost::shared_ptr<Minotaur::LinearFunction const>) (LinearFunction.cpp:397)
==19075==    by 0x4A4296: QuadraticFunctionTest::testOperations() (QuadraticFunctionUT.cpp:177)
==19075==    by 0x4AAAA5: CppUnit::TestCaller<QuadraticFunctionTest>::runTest() (TestCaller.h:166)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 121 of 3,576
==19075==    by 0x48B801: boost::detail::shared_count::shared_count<Minotaur::Logger>(Minotaur::Logger*) (shared_count.hpp:137)
==19075==    by 0x48B75E: void boost::detail::sp_pointer_construct<Minotaur::Logger, Minotaur::Logger>(boost::shared_ptr<Minotaur::Logger>*, Minotaur::Logger*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x48B66C: boost::shared_ptr<Minotaur::Logger>::shared_ptr<Minotaur::Logger>(Minotaur::Logger*) (shared_ptr.hpp:362)
==19075==    by 0x719715D: Minotaur::Environment::Environment() (Environment.cpp:32)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 122 of 3,576
==19075==    by 0x71A3AA1: boost::detail::shared_count::shared_count<Minotaur::OptionDB>(Minotaur::OptionDB*) (shared_count.hpp:137)
==19075==    by 0x71A376C: void boost::detail::sp_pointer_construct<Minotaur::OptionDB, Minotaur::OptionDB>(boost::shared_ptr<Minotaur::OptionDB>*, Minotaur::OptionDB*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x71A2FD8: boost::shared_ptr<Minotaur::OptionDB>::shared_ptr<Minotaur::OptionDB>(Minotaur::OptionDB*) (shared_ptr.hpp:362)
==19075==    by 0x71971A0: Minotaur::Environment::Environment() (Environment.cpp:33)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 123 of 3,576
==19075==    by 0x6D43FE5: boost::detail::shared_count::shared_count<Minotaur::Option<bool> >(Minotaur::Option<bool>*) (shared_count.hpp:137)
==19075==    by 0x6D41FCC: void boost::detail::sp_pointer_construct<Minotaur::Option<bool>, Minotaur::Option<bool> >(boost::shared_ptr<Minotaur::Option<bool> >*, Minotaur::Option<bool>*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x6D40262: boost::shared_ptr<Minotaur::Option<bool> >::shared_ptr<Minotaur::Option<bool> >(Minotaur::Option<bool>*) (shared_ptr.hpp:362)
==19075==    by 0x7197430: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:55)
==19075==    by 0x7197213: Minotaur::Environment::Environment() (Environment.cpp:36)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 124 of 3,576
==19075==    by 0x7197572: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:60)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 125 of 3,576
==19075==    by 0x71976B4: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:65)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 126 of 3,576
==19075==    by 0x71977F6: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:70)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 127 of 3,576
==19075==    by 0x7197938: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:75)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 128 of 3,576
==19075==    by 0x7197A7A: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:80)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 129 of 3,576
==19075==    by 0x7197BBC: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:84)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 130 of 3,576
==19075==    by 0x7197CFE: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:88)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 131 of 3,576
==19075==    by 0x7197E40: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:92)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 132 of 3,576
==19075==    by 0x7197F82: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:96)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 133 of 3,576
==19075==    by 0x71980C4: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:101)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 134 of 3,576
==19075==    by 0x7198206: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:105)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 135 of 3,576
==19075==    by 0x7198348: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:109)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 136 of 3,576
==19075==    by 0x719848A: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:113)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 137 of 3,576
==19075==    by 0x71985CC: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:117)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 138 of 3,576
==19075==    by 0x719870E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:121)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 139 of 3,576
==19075==    by 0x7198850: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:125)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 140 of 3,576
==19075==    by 0x7198992: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:129)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 141 of 3,576
==19075==    by 0x7198AD4: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:133)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 142 of 3,576
==19075==    by 0x7198C16: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:137)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 143 of 3,576
==19075==    by 0x7198D58: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:141)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 144 of 3,576
==19075==    by 0x7198E9A: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:145)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 145 of 3,576
==19075==    by 0x7198FDC: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:149)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 146 of 3,576
==19075==    by 0x719911E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:153)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 147 of 3,576
==19075==    by 0x7199260: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:158)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 148 of 3,576
==19075==    by 0x71993A2: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:162)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 149 of 3,576
==19075==    by 0x71994E4: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:167)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 150 of 3,576
==19075==    by 0x7199626: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:172)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 151 of 3,576
==19075==    by 0x7199768: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:177)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 152 of 3,576
==19075==    by 0x71998AA: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:181)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 153 of 3,576
==19075==    by 0x71999EC: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:185)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 154 of 3,576
==19075==    by 0x7199B2E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:189)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 155 of 3,576
==19075==    by 0x7199C70: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:193)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 156 of 3,576
==19075==    by 0x7199DB2: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:197)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 157 of 3,576
==19075==    by 0x71A3C15: boost::detail::shared_count::shared_count<Minotaur::Option<int> >(Minotaur::Option<int>*) (shared_count.hpp:137)
==19075==    by 0x71A38B4: void boost::detail::sp_pointer_construct<Minotaur::Option<int>, Minotaur::Option<int> >(boost::shared_ptr<Minotaur::Option<int> >*, Minotaur::Option<int>*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x71A328C: boost::shared_ptr<Minotaur::Option<int> >::shared_ptr<Minotaur::Option<int> >(Minotaur::Option<int>*) (shared_ptr.hpp:362)
==19075==    by 0x7199F03: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:207)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 158 of 3,576
==19075==    by 0x719A040: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:212)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 159 of 3,576
==19075==    by 0x719A17D: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:217)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 160 of 3,576
==19075==    by 0x719A2BA: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:221)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 161 of 3,576
==19075==    by 0x719A3F7: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:225)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 162 of 3,576
==19075==    by 0x719A534: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:229)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 163 of 3,576
==19075==    by 0x719A671: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:233)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 164 of 3,576
==19075==    by 0x719A7AE: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:237)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 165 of 3,576
==19075==    by 0x719A8EB: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:242)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 166 of 3,576
==19075==    by 0x719AA28: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:246)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 167 of 3,576
==19075==    by 0x719AB65: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:250)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 168 of 3,576
==19075==    by 0x719ACA2: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:254)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 169 of 3,576
==19075==    by 0x719ADDF: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:259)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 170 of 3,576
==19075==    by 0x719AF1C: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:263)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 171 of 3,576
==19075==    by 0x719B059: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:267)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 172 of 3,576
==19075==    by 0x719B1A5: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:274)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 173 of 3,576
==19075==    by 0x719B2E2: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:279)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 174 of 3,576
==19075==    by 0x71A3CCF: boost::detail::shared_count::shared_count<Minotaur::Option<double> >(Minotaur::Option<double>*) (shared_count.hpp:137)
==19075==    by 0x71A3958: void boost::detail::sp_pointer_construct<Minotaur::Option<double>, Minotaur::Option<double> >(boost::shared_ptr<Minotaur::Option<double> >*, Minotaur::Option<double>*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x71A33C0: boost::shared_ptr<Minotaur::Option<double> >::shared_ptr<Minotaur::Option<double> >(Minotaur::Option<double>*) (shared_ptr.hpp:362)
==19075==    by 0x719B432: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:285)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 175 of 3,576
==19075==    by 0x719B582: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:289)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 176 of 3,576
==19075==    by 0x719B6D2: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:294)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 177 of 3,576
==19075==    by 0x719B822: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:299)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 178 of 3,576
==19075==    by 0x719B972: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:303)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 179 of 3,576
==19075==    by 0x719BAC2: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:308)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 180 of 3,576
==19075==    by 0x719BC12: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:313)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 181 of 3,576
==19075==    by 0x719BD62: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:318)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 182 of 3,576
==19075==    by 0x719BEB2: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:323)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 183 of 3,576
==19075==    by 0x719C002: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:329)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 184 of 3,576
==19075==    by 0x719C152: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:334)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 185 of 3,576
==19075==    by 0x719C28D: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:339)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 186 of 3,576
==19075==    by 0x71A3D89: boost::detail::shared_count::shared_count<Minotaur::Option<std::string> >(Minotaur::Option<std::string>*) (shared_count.hpp:137)
==19075==    by 0x71A39FC: void boost::detail::sp_pointer_construct<Minotaur::Option<std::string>, Minotaur::Option<std::string> >(boost::shared_ptr<Minotaur::Option<std::string> >*, Minotaur::Option<std::string>*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x71A34F4: boost::shared_ptr<Minotaur::Option<std::string> >::shared_ptr<Minotaur::Option<std::string> >(Minotaur::Option<std::string>*) (shared_ptr.hpp:362)
==19075==    by 0x719C403: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:347)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 187 of 3,576
==19075==    by 0x719C585: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:352)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 188 of 3,576
==19075==    by 0x719C707: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:356)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 189 of 3,576
==19075==    by 0x719C889: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:361)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 190 of 3,576
==19075==    by 0x719CA0B: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:366)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 191 of 3,576
==19075==    by 0x719CB8D: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:372)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 192 of 3,576
==19075==    by 0x719CD0F: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:377)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 193 of 3,576
==19075==    by 0x719CE91: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:382)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 194 of 3,576
==19075==    by 0x719D013: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:387)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 195 of 3,576
==19075==    by 0x719D192: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:392)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 196 of 3,576
==19075==    by 0x719D302: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:396)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 197 of 3,576
==19075==    by 0x719D472: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:400)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 198 of 3,576
==19075==    by 0x4B2633: boost::detail::shared_count::shared_count<Minotaur::Environment>(Minotaur::Environment*) (shared_count.hpp:137)
==19075==    by 0x4B186A: void boost::detail::sp_pointer_construct<Minotaur::Environment, Minotaur::Environment>(boost::shared_ptr<Minotaur::Environment>*, Minotaur::Environment*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x4B079C: boost::shared_ptr<Minotaur::Environment>::shared_ptr<Minotaur::Environment>(Minotaur::Environment*) (shared_ptr.hpp:362)
==19075==    by 0x4ADB3B: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:293)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 199 of 3,576
==19075==    by 0x7277596: Minotaur::Problem::Problem() (Problem.cpp:55)
==19075==    by 0x4AD318: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:258)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 200 of 3,576
==19075==    by 0x46F81D: boost::detail::shared_count::shared_count<Minotaur::Problem>(Minotaur::Problem*) (shared_count.hpp:137)
==19075==    by 0x46F77A: void boost::detail::sp_pointer_construct<Minotaur::Problem, Minotaur::Problem>(boost::shared_ptr<Minotaur::Problem>*, Minotaur::Problem*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x46F5D8: boost::shared_ptr<Minotaur::Problem>::shared_ptr<Minotaur::Problem>(Minotaur::Problem*) (shared_ptr.hpp:362)
==19075==    by 0x4AD32A: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:258)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 201 of 3,576
==19075==    by 0x4AD37D: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:261)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 202 of 3,576
==19075==    by 0x4AD3D0: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:264)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 203 of 3,576
==19075==    by 0x4B26A7: boost::detail::shared_count::shared_count<myNLFun5>(myNLFun5*) (shared_count.hpp:137)
==19075==    by 0x4B18CE: void boost::detail::sp_pointer_construct<myNLFun5, myNLFun5>(boost::shared_ptr<myNLFun5>*, myNLFun5*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x4B0936: boost::shared_ptr<myNLFun5>::shared_ptr<myNLFun5>(myNLFun5*) (shared_ptr.hpp:362)
==19075==    by 0x4AD41F: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:267)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 204 of 3,576
==19075==    by 0x4AD495: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:268)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 205 of 3,576
==19075==    by 0x727E102: Minotaur::Problem::newObjective(boost::shared_ptr<Minotaur::Function>, double, Minotaur::ObjectiveType, std::string) (Problem.cpp:1072)
==19075==    by 0x727DF33: Minotaur::Problem::newObjective(boost::shared_ptr<Minotaur::Function>, double, Minotaur::ObjectiveType) (Problem.cpp:1061)
==19075==    by 0x4AD523: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:269)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 206 of 3,576
==19075==    by 0x4B274D: boost::detail::shared_count::shared_count<myNLFun6>(myNLFun6*) (shared_count.hpp:137)
==19075==    by 0x4B1978: void boost::detail::sp_pointer_construct<myNLFun6, myNLFun6>(boost::shared_ptr<myNLFun6>*, myNLFun6*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x4B0A8A: boost::shared_ptr<myNLFun6>::shared_ptr<myNLFun6>(myNLFun6*) (shared_ptr.hpp:362)
==19075==    by 0x4AD581: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:273)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 207 of 3,576
==19075==    by 0x4AD5F7: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:274)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 208 of 3,576
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 209 of 3,576
==19075==    by 0x4B27F3: boost::detail::shared_count::shared_count<myJac3>(myJac3*) (shared_count.hpp:137)
==19075==    by 0x4B1A22: void boost::detail::sp_pointer_construct<myJac3, myJac3>(boost::shared_ptr<myJac3>*, myJac3*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x4B0BDE: boost::shared_ptr<myJac3>::shared_ptr<myJac3>(myJac3*) (shared_ptr.hpp:362)
==19075==    by 0x4AD6EF: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:278)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 210 of 3,576
==19075==    by 0x4B2867: boost::detail::shared_count::shared_count<myHess3>(myHess3*) (shared_count.hpp:137)
==19075==    by 0x4B1A86: void boost::detail::sp_pointer_construct<myHess3, myHess3>(boost::shared_ptr<myHess3>*, myHess3*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x4B0C4C: boost::shared_ptr<myHess3>::shared_ptr<myHess3>(myHess3*) (shared_ptr.hpp:362)
==19075==    by 0x4AD713: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:281)
==19075==    by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==19075==    by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==19075==    by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==19075==    by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==19075==    by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 211 of 3,576
==19075==    by 0x725867B: boost::detail::shared_count::shared_count<Minotaur::NodeHeap>(Minotaur::NodeHeap*) (shared_count.hpp:137)
==19075==    by 0x72584DE: void boost::detail::sp_pointer_construct<Minotaur::NodeHeap, Minotaur::NodeHeap>(boost::shared_ptr<Minotaur::NodeHeap>*, Minotaur::NodeHeap*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x72581E4: boost::shared_ptr<Minotaur::NodeHeap>::shared_ptr<Minotaur::NodeHeap>(Minotaur::NodeHeap*) (shared_ptr.hpp:362)
==19075==    by 0x72DC37D: Minotaur::TreeManager::TreeManager(boost::shared_ptr<Minotaur::Environment>) (TreeManager.cpp:55)
==19075==    by 0x7130306: Minotaur::BranchAndBound::BranchAndBound(boost::shared_ptr<Minotaur::Environment>, boost::shared_ptr<Minotaur::Problem>) (BranchAndBound.cpp:68)
==19075==    by 0x4ADE17: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:304)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 212 of 3,576
==19075==    at 0x4C2B0E0: operator new(unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==19075==    by 0x7134C77: boost::detail::shared_count::shared_count<Minotaur::TreeManager>(Minotaur::TreeManager*) (shared_count.hpp:137)
==19075==    by 0x7134463: void boost::detail::sp_pointer_construct<Minotaur::TreeManager, Minotaur::TreeManager>(boost::shared_ptr<Minotaur::TreeManager>*, Minotaur::TreeManager*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x7133974: boost::shared_ptr<Minotaur::TreeManager>::shared_ptr<Minotaur::TreeManager>(Minotaur::TreeManager*) (shared_ptr.hpp:362)
==19075==    by 0x7130315: Minotaur::BranchAndBound::BranchAndBound(boost::shared_ptr<Minotaur::Environment>, boost::shared_ptr<Minotaur::Problem>) (BranchAndBound.cpp:68)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 213 of 3,576
==19075==    by 0x7134D31: boost::detail::shared_count::shared_count<Minotaur::BabOptions>(Minotaur::BabOptions*) (shared_count.hpp:137)
==19075==    by 0x7134508: void boost::detail::sp_pointer_construct<Minotaur::BabOptions, Minotaur::BabOptions>(boost::shared_ptr<Minotaur::BabOptions>*, Minotaur::BabOptions*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x7133A4C: boost::shared_ptr<Minotaur::BabOptions>::shared_ptr<Minotaur::BabOptions>(Minotaur::BabOptions*) (shared_ptr.hpp:362)
==19075==    by 0x7130385: Minotaur::BranchAndBound::BranchAndBound(boost::shared_ptr<Minotaur::Environment>, boost::shared_ptr<Minotaur::Problem>) (BranchAndBound.cpp:69)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 214 of 3,576
==19075==    by 0x4B28DB: boost::detail::shared_count::shared_count<Minotaur::IntVarHandler>(Minotaur::IntVarHandler*) (shared_count.hpp:137)
==19075==    by 0x4B1AF6: void boost::detail::sp_pointer_construct<Minotaur::IntVarHandler, Minotaur::IntVarHandler>(boost::shared_ptr<Minotaur::IntVarHandler>*, Minotaur::IntVarHandler*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x4B0D9E: boost::shared_ptr<Minotaur::IntVarHandler>::shared_ptr<Minotaur::IntVarHandler>(Minotaur::IntVarHandler*) (shared_ptr.hpp:362)
==19075==    by 0x4ADEA9: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:306)
==19075==    by 0x4E59952: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 215 of 3,576
==19075==    by 0x4B294F: boost::detail::shared_count::shared_count<Minotaur::LinearHandler>(Minotaur::LinearHandler*) (shared_count.hpp:137)
==19075==    by 0x4B1B5A: void boost::detail::sp_pointer_construct<Minotaur::LinearHandler, Minotaur::LinearHandler>(boost::shared_ptr<Minotaur::LinearHandler>*, Minotaur::LinearHandler*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x4B0E0C: boost::shared_ptr<Minotaur::LinearHandler>::shared_ptr<Minotaur::LinearHandler>(Minotaur::LinearHandler*) (shared_ptr.hpp:362)
==19075==    by 0x4ADF34: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:307)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 216 of 3,576
==19075==    by 0x57C2671: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:298)
==19075==
==19075== 24 bytes in 1 blocks are still reachable in loss record 217 of 3,576
==19075==    by 0x4B768D: boost::detail::shared_count::shared_count<Minotaur::IpoptEngine>(Minotaur::IpoptEngine*) (shared_count.hpp:137)
==19075==    by 0x4B740A: void boost::detail::sp_pointer_construct<Minotaur::IpoptEngine, Minotaur::IpoptEngine>(boost::shared_ptr<Minotaur::IpoptEngine>*, Minotaur::IpoptEngine*, boost::detail::shared_count&) (shared_ptr.hpp:284)
==19075==    by 0x4B7098: boost::shared_ptr<Minotaur::IpoptEngine>::shared_ptr<Minotaur::IpoptEngine>(Minotaur::IpoptEngine*) (shared_ptr.hpp:362)
==19075==    by 0x507AE5E: Minotaur::EngineFactory::getNLPEngine() (EngineFactory.cpp:119)
==19075==
==19075== 24 bytes in 3 blocks are still reachable in loss record 218 of 3,576
==19075==    at 0x4C2B800: operator new[](unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==19075==    by 0x72AC615: Minotaur::QuadraticFunction::prepHess() (QuadraticFunction.cpp:441)
==19075==    by 0x72AA90C: Minotaur::QuadraticFunction::fillHessStor(Minotaur::LTHessStor*) (QuadraticFunction.cpp:190)
==19075==    by 0x71AA3FF: Minotaur::Function::fillHessStor(Minotaur::LTHessStor*) (Function.cpp:444)
==19075==    by 0x71ACE9C: Minotaur::HessianOfLag::setupRowCol() (HessianOfLag.cpp:167)
==19075==    by 0x71AC31C: Minotaur::HessianOfLag::HessianOfLag(Minotaur::Problem*) (HessianOfLag.cpp:58)
==19075==    by 0x72800CE: Minotaur::Problem::setNativeDer() (Problem.cpp:1348)
==19075==    by 0x477AA5: CppUnit::TestCaller<JacobianUT>::runTest() (TestCaller.h:166)
==19075==
==19075== 24 bytes in 3 blocks are still reachable in loss record 219 of 3,576
==19075==    by 0x72AC64A: Minotaur::QuadraticFunction::prepHess() (QuadraticFunction.cpp:443)
==19075==
==19075== 24 bytes in 3 blocks are still reachable in loss record 220 of 3,576
==19075==    by 0x72ACA65: Minotaur::QuadraticFunction::prepHess() (QuadraticFunction.cpp:501)
==19075==
==19075== 26 bytes in 1 blocks are possibly lost in loss record 221 of 3,576
==19075==    by 0x7888248: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7889970: char* std::string::_S_construct<char const*>(char const*, char const*, std::allocator<char> const&, std::forward_iterator_tag) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7889D87: std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x5A3442C: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 26 bytes in 1 blocks are possibly lost in loss record 222 of 3,576
==19075==    by 0x5A34B1E: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 26 bytes in 1 blocks are possibly lost in loss record 223 of 3,576
==19075==    by 0x5B5A50A: Ipopt::OptionsList::SetIntegerValue(std::string const&, int, bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x57C4B36: Minotaur::IpoptEngine::setOptionsForRepeatedSolve() (IpoptEngine.cpp:636)
==19075==    by 0x57C2703: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:301)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 224 of 3,576
==19075==    by 0x719CB51: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:372)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 225 of 3,576
==19075==    by 0x5A3465D: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 226 of 3,576
==19075==    by 0x5A3467E: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 227 of 3,576
==19075==    by 0x5A34817: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 228 of 3,576
==19075==    by 0x5A3482D: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 229 of 3,576
==19075==    by 0x5A349B0: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x4B4A37: CppUnit::TestCaller<NLPBnbUT>::runTest() (TestCaller.h:166)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 230 of 3,576
==19075==    by 0x5A349C6: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 231 of 3,576
==19075==    by 0x5A34C79: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 232 of 3,576
==19075==    by 0x5A34C8F: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 233 of 3,576
==19075==    by 0x5A34E12: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x57C26E9: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:300)
==19075==    by 0x507AE4F: Minotaur::EngineFactory::getNLPEngine() (EngineFactory.cpp:119)
==19075==    by 0x4AE092: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:314)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 234 of 3,576
==19075==    by 0x5A34E28: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 235 of 3,576
==19075==    by 0x5A34FF8: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 236 of 3,576
==19075==    by 0x5A3500E: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 237 of 3,576
==19075==    by 0x5A3518E: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 238 of 3,576
==19075==    by 0x5A351A4: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 239 of 3,576
==19075==    by 0x5A450CA: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A336AD: Ipopt::RegisterOptions_Interfaces(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 240 of 3,576
==19075==    by 0x5A450E3: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 241 of 3,576
==19075==    by 0x5A457C2: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 242 of 3,576
==19075==    by 0x5A457DB: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 243 of 3,576
==19075==    by 0x5A7458B: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A825A9: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A35800: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 244 of 3,576
==19075==    by 0x5A745AF: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 245 of 3,576
==19075==    by 0x5A92595: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A825FB: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 246 of 3,576
==19075==    by 0x5A925AB: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 247 of 3,576
==19075==    by 0x5A92727: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 248 of 3,576
==19075==    by 0x5A9273D: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 249 of 3,576
==19075==    by 0x5A928F7: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 250 of 3,576
==19075==    by 0x5A9290D: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 251 of 3,576
==19075==    by 0x5A7AD98: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8264D: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 252 of 3,576
==19075==    by 0x5A7ADB4: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A39098: Ipopt::IpoptApplication::IpoptApplication(bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 253 of 3,576
==19075==    by 0x5A89F8E: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8269F: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 254 of 3,576
==19075==    by 0x5A89FB5: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 255 of 3,576
==19075==    by 0x5A8A1D3: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 256 of 3,576
==19075==    by 0x5A8A1FA: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 257 of 3,576
==19075==    by 0x5A8B071: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 258 of 3,576
==19075==    by 0x5A8B090: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 259 of 3,576
==19075==    by 0x5A8B3CF: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 260 of 3,576
==19075==    by 0x5A8B3EB: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 261 of 3,576
==19075==    by 0x5A9D07E: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A826F1: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 262 of 3,576
==19075==    by 0x5A9D216: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 263 of 3,576
==19075==    by 0x5AA49A2: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82865: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 264 of 3,576
==19075==    by 0x5AA49C3: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 265 of 3,576
==19075==    by 0x5AA4C49: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 266 of 3,576
==19075==    by 0x5AA4C5F: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 267 of 3,576
==19075==    by 0x5AA4E1B: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 268 of 3,576
==19075==    by 0x5AA4E31: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 269 of 3,576
==19075==    by 0x5AA4E5D: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 270 of 3,576
==19075==    by 0x5ACF8EB: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82948: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 271 of 3,576
==19075==    by 0x5ACF904: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 272 of 3,576
==19075==    by 0x5ADE55C: Ipopt::MonotoneMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8298F: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 273 of 3,576
==19075==    by 0x5AE9C23: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82A2B: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 274 of 3,576
==19075==    by 0x5AE9E27: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 275 of 3,576
==19075==    by 0x5AE9E3D: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 276 of 3,576
==19075==    by 0x5AE9FF7: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 277 of 3,576
==19075==    by 0x5AEA00D: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 278 of 3,576
==19075==    by 0x5AEA189: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 279 of 3,576
==19075==    by 0x5AEA19F: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 280 of 3,576
==19075==    by 0x5AEA31B: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 281 of 3,576
==19075==    by 0x5AEA331: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 282 of 3,576
==19075==    by 0x5AEA4AD: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 283 of 3,576
==19075==    by 0x5AEA4C3: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 284 of 3,576
==19075==    by 0x5AF59C3: Ipopt::OrigIterationOutput::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82A7D: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 285 of 3,576
==19075==    by 0x5AF59F2: Ipopt::OrigIterationOutput::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 286 of 3,576
==19075==    by 0x5B03E49: Ipopt::PDSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82AC4: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 287 of 3,576
==19075==    by 0x5B03E67: Ipopt::PDSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 288 of 3,576
==19075==    by 0x5AFB13B: Ipopt::PDFullSpaceSolver::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82B0E: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 289 of 3,576
==19075==    by 0x5B0205D: Ipopt::PDPerturbationHandler::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82B60: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 290 of 3,576
==19075==    by 0x5B02073: Ipopt::PDPerturbationHandler::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 291 of 3,576
==19075==    by 0x5B163B5: Ipopt::RestoIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82CFA: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 292 of 3,576
==19075==    by 0x5B2CEE6: Ipopt::WarmStartIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82DF0: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 293 of 3,576
==19075==    by 0x5B2CEFC: Ipopt::WarmStartIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 294 of 3,576
==19075==    by 0x5A6FCFC: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A6D312: Ipopt::RegisterOptions_CGPenalty(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A35808: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 295 of 3,576
==19075==    by 0x5A6FD12: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 296 of 3,576
==19075==    by 0x5A67968: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A6D34B: Ipopt::RegisterOptions_CGPenalty(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 297 of 3,576
==19075==    by 0x5A67986: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 298 of 3,576
==19075==    by 0x5B351C5: Ipopt::TSymLinearSolver::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B319EC: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 299 of 3,576
==19075==    by 0x5B38730: Ipopt::Ma27TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31A5D: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 300 of 3,576
==19075==    by 0x5B38751: Ipopt::Ma27TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 301 of 3,576
==19075==    by 0x5B388F8: Ipopt::Ma27TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 302 of 3,576
==19075==    by 0x5B3890E: Ipopt::Ma27TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 303 of 3,576
==19075==    by 0x5B3B397: Ipopt::Ma57TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31ACE: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 304 of 3,576
==19075==    by 0x5B3B3AD: Ipopt::Ma57TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 305 of 3,576
==19075==    by 0x5B427D1: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31C21: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 306 of 3,576
==19075==    by 0x5B427ED: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 307 of 3,576
==19075==    by 0x5B4BD7C: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31D03: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 308 of 3,576
==19075==    by 0x5B4BD95: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 309 of 3,576
==19075==    by 0x5B4BF28: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 310 of 3,576
==19075==    by 0x5B4BF41: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 311 of 3,576
==19075==    by 0x5B4C172: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 312 of 3,576
==19075==    by 0x5B4C18B: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 313 of 3,576
==19075==    by 0x5B4CCBE: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 27 bytes in 1 blocks are possibly lost in loss record 314 of 3,576
==19075==    by 0x5B4CCD7: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 3 blocks are still reachable in loss record 315 of 3,576
==19075==    by 0x479C57: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:120)
==19075==    by 0x47D8ED: CppUnit::TestCaller<HessianOfLagUT>::runTest() (TestCaller.h:166)
==19075==
==19075== 28 bytes in 3 blocks are still reachable in loss record 316 of 3,576
==19075==
==19075== 28 bytes in 3 blocks are still reachable in loss record 317 of 3,576
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 318 of 3,576
==19075==    by 0x719C3C7: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:347)
==19075==    by 0x7197213: Minotaur::Environment::Environment() (Environment.cpp:36)
==19075==    by 0x4ADB29: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:293)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 319 of 3,576
==19075==    by 0x719C6CB: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:356)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 320 of 3,576
==19075==    by 0x719C9CF: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:366)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 321 of 3,576
==19075==    by 0x4E58470: char* std::string::_S_construct<char*>(char*, char*, std::allocator<char> const&, std::forward_iterator_tag) (basic_string.tcc:138)
==19075==    by 0x7868F37: std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::str() const (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x727DE8C: Minotaur::Problem::newObjective(boost::shared_ptr<Minotaur::Function>, double, Minotaur::ObjectiveType) (Problem.cpp:1060)
==19075==    by 0x4ADD55: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:296)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 322 of 3,576
==19075==    by 0x5A34627: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A3363C: Ipopt::RegisterOptions_Interfaces(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A357F8: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 323 of 3,576
==19075==    by 0x5A347EC: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 324 of 3,576
==19075==    by 0x5A34985: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 325 of 3,576
==19075==    by 0x5A34C4E: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 326 of 3,576
==19075==    by 0x5A34DE7: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 327 of 3,576
==19075==    by 0x5A34FCD: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 328 of 3,576
==19075==    by 0x5A35163: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 329 of 3,576
==19075==    by 0x5A4495F: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 330 of 3,576
==19075==    by 0x5A4509A: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 331 of 3,576
==19075==    by 0x5A45792: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 332 of 3,576
==19075==    by 0x5A74543: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 333 of 3,576
==19075==    by 0x5A9256B: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 334 of 3,576
==19075==    by 0x5A926FD: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 335 of 3,576
==19075==    by 0x5A928CD: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 336 of 3,576
==19075==    by 0x5A7AD65: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 337 of 3,576
==19075==    by 0x5A89F43: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 338 of 3,576
==19075==    by 0x5A8A182: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 339 of 3,576
==19075==    by 0x5A8A6D3: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 340 of 3,576
==19075==    by 0x5A8A735: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 341 of 3,576
==19075==    by 0x5A8B039: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 342 of 3,576
==19075==    by 0x5A8B397: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 343 of 3,576
==19075==    by 0x5A9D04E: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 344 of 3,576
==19075==    by 0x5A9D097: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 345 of 3,576
==19075==    by 0x5A9D1E6: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 346 of 3,576
==19075==    by 0x5A9D22F: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 347 of 3,576
==19075==    by 0x5B06832: Ipopt::PenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82743: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 348 of 3,576
==19075==    by 0x5AA4960: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 349 of 3,576
==19075==    by 0x5AA4C1D: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 350 of 3,576
==19075==    by 0x5AA4DEC: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 351 of 3,576
==19075==    by 0x5AC9EE3: Ipopt::IpoptData::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A828AC: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 352 of 3,576
==19075==    by 0x5AAC60F: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A828F6: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 353 of 3,576
==19075==    by 0x5ACF110: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 354 of 3,576
==19075==    by 0x5ACF8BB: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 355 of 3,576
==19075==    by 0x5ADE525: Ipopt::MonotoneMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 356 of 3,576
==19075==    by 0x5ADE572: Ipopt::MonotoneMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 357 of 3,576
==19075==    by 0x5A829FE: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 358 of 3,576
==19075==    by 0x5AE9BE3: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 359 of 3,576
==19075==    by 0x5AE9C44: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 360 of 3,576
==19075==    by 0x5AE9DFD: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 361 of 3,576
==19075==    by 0x5AE9F5F: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 362 of 3,576
==19075==    by 0x5AE9FCD: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 363 of 3,576
==19075==    by 0x5AEA15F: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 364 of 3,576
==19075==    by 0x5AEA2F1: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 365 of 3,576
==19075==    by 0x5AEA483: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 366 of 3,576
==19075==    by 0x5AF5965: Ipopt::OrigIterationOutput::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 367 of 3,576
==19075==    by 0x5B03E07: Ipopt::PDSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 368 of 3,576
==19075==    by 0x5AFB165: Ipopt::PDFullSpaceSolver::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 369 of 3,576
==19075==    by 0x5AFB17B: Ipopt::PDFullSpaceSolver::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 370 of 3,576
==19075==    by 0x5B0202B: Ipopt::PDPerturbationHandler::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 371 of 3,576
==19075==    by 0x5B0C6C1: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82C04: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 372 of 3,576
==19075==    by 0x5B16378: Ipopt::RestoIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 373 of 3,576
==19075==    by 0x5B163D3: Ipopt::RestoIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 374 of 3,576
==19075==    by 0x5B2CEB7: Ipopt::WarmStartIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 375 of 3,576
==19075==    by 0x5A6FCCA: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 376 of 3,576
==19075==    by 0x5A67926: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 377 of 3,576
==19075==    by 0x5B35183: Ipopt::TSymLinearSolver::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 378 of 3,576
==19075==    by 0x5B351E3: Ipopt::TSymLinearSolver::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 379 of 3,576
==19075==    by 0x5B386E8: Ipopt::Ma27TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 380 of 3,576
==19075==    by 0x5B388CE: Ipopt::Ma27TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 381 of 3,576
==19075==    by 0x5B3B360: Ipopt::Ma57TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 382 of 3,576
==19075==    by 0x5B498B2: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31B3F: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 383 of 3,576
==19075==    at 0x4C2B0E0: operator new(unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==19075==    by 0x5B498C8: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 384 of 3,576
==19075==    by 0x5B3E402: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31BB0: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 385 of 3,576
==19075==    by 0x5B3E44D: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 386 of 3,576
==19075==    by 0x5B42447: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 387 of 3,576
==19075==    by 0x5B42799: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 388 of 3,576
==19075==    by 0x5B4BD47: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 389 of 3,576
==19075==    by 0x5B4BEF3: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 390 of 3,576
==19075==    by 0x5B4C13D: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 391 of 3,576
==19075==    by 0x5B4C45B: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 392 of 3,576
==19075==    by 0x5B4C493: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 393 of 3,576
==19075==    by 0x5B4CC89: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 28 bytes in 1 blocks are possibly lost in loss record 394 of 3,576
==19075==    by 0x57C4BBC: Minotaur::IpoptEngine::setOptionsForRepeatedSolve() (IpoptEngine.cpp:652)
==19075==    by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==19075==    by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 395 of 3,576
==19075==    by 0x727D597: Minotaur::Problem::newBinaryVariable() (Problem.cpp:993)
==19075==    by 0x46C4D0: ProblemTest::testVarTypes() (ProblemUT.cpp:103)
==19075==    by 0x46FCB5: CppUnit::TestCaller<ProblemTest>::runTest() (TestCaller.h:166)
==19075==    by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==19075==    by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 396 of 3,576
==19075==    by 0x727E914: Minotaur::Problem::newVariable(double, double, Minotaur::VariableType, Minotaur::VarSrcType) (Problem.cpp:1133)
==19075==    by 0x46E2C6: ProblemTest::testaddToObj() (ProblemUT.cpp:143)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 397 of 3,576
==19075==    by 0x7888248: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7889970: char* std::string::_S_construct<char const*>(char const*, char const*, std::allocator<char> const&, std::forward_iterator_tag) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7889D87: std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x719CFD7: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:387)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 398 of 3,576
==19075==    by 0x4AD37D: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:261)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 399 of 3,576
==19075==    by 0x4AD3D0: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:264)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 400 of 3,576
==19075==    by 0x5A44DE3: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 401 of 3,576
==19075==    by 0x5A44E13: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 402 of 3,576
==19075==    by 0x5A44E82: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 403 of 3,576
==19075==    by 0x5A44EA6: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 404 of 3,576
==19075==    by 0x5A453AE: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 405 of 3,576
==19075==    by 0x5A453C7: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 406 of 3,576
==19075==    by 0x5A795F5: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 407 of 3,576
==19075==    by 0x5A79691: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x4B4A37: CppUnit::TestCaller<NLPBnbUT>::runTest() (TestCaller.h:166)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 408 of 3,576
==19075==    by 0x5A796E2: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 409 of 3,576
==19075==    by 0x5A79730: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 410 of 3,576
==19075==    by 0x5A7977E: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 411 of 3,576
==19075==    by 0x5A797CC: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x57C26E9: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:300)
==19075==    by 0x507AE4F: Minotaur::EngineFactory::getNLPEngine() (EngineFactory.cpp:119)
==19075==    by 0x4AE092: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:314)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 412 of 3,576
==19075==    by 0x5A79C1E: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 413 of 3,576
==19075==    by 0x5A79C56: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 414 of 3,576
==19075==    by 0x5A79C72: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 415 of 3,576
==19075==    by 0x5A79F21: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 416 of 3,576
==19075==    by 0x5A7A393: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 417 of 3,576
==19075==    by 0x5A7A61D: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 418 of 3,576
==19075==    by 0x5A8A669: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 419 of 3,576
==19075==    by 0x5A9CE7A: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 420 of 3,576
==19075==    by 0x5A9CE9B: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 421 of 3,576
==19075==    by 0x5A9D037: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 422 of 3,576
==19075==    by 0x5A9D1CF: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A35800: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 423 of 3,576
==19075==    by 0x5ACF156: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 424 of 3,576
==19075==    by 0x5ACF17A: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 425 of 3,576
==19075==    by 0x5B0C6F1: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 426 of 3,576
==19075==    by 0x5B0C70A: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 427 of 3,576
==19075==    by 0x5B0C918: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 428 of 3,576
==19075==    by 0x5B0C931: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 429 of 3,576
==19075==    by 0x5B3E14A: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 430 of 3,576
==19075==    by 0x5B3E198: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 431 of 3,576
==19075==    by 0x5B3E1E0: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 432 of 3,576
==19075==    by 0x5B3E20F: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 433 of 3,576
==19075==    by 0x5B3E434: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A39098: Ipopt::IpoptApplication::IpoptApplication(bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 434 of 3,576
==19075==    by 0x5B4070A: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 435 of 3,576
==19075==    by 0x5B40758: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 436 of 3,576
==19075==    by 0x5B407B9: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 437 of 3,576
==19075==    by 0x5B40820: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 438 of 3,576
==19075==    by 0x5B40AD6: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 439 of 3,576
==19075==    by 0x5B40B0E: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 440 of 3,576
==19075==    by 0x5B40B46: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 441 of 3,576
==19075==    by 0x5B40B7E: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 442 of 3,576
==19075==    by 0x5B40B9A: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 443 of 3,576
==19075==    by 0x5B41379: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 444 of 3,576
==19075==    by 0x5B413B1: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 445 of 3,576
==19075==    by 0x5B413E9: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 446 of 3,576
==19075==    by 0x5B41421: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 447 of 3,576
==19075==    by 0x5B4143D: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 448 of 3,576
==19075==    by 0x5B41B6C: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 449 of 3,576
==19075==    by 0x5B41BA4: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 450 of 3,576
==19075==    by 0x5B41BDC: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 451 of 3,576
==19075==    by 0x5B41C14: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 452 of 3,576
==19075==    by 0x5B41C30: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 453 of 3,576
==19075==    by 0x5B4247F: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 454 of 3,576
==19075==    by 0x5B424B7: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 455 of 3,576
==19075==    by 0x5B424D3: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 456 of 3,576
==19075==    by 0x5B4C387: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 457 of 3,576
==19075==    by 0x5B4C3BC: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 29 bytes in 1 blocks are possibly lost in loss record 458 of 3,576
==19075==    by 0x5B4C4AF: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 459 of 3,576
==19075==    by 0x4727C3: JacobianUT::testQuadEval() (JacobianUT.cpp:110)
==19075==    by 0x477AA5: CppUnit::TestCaller<JacobianUT>::runTest() (TestCaller.h:166)
==19075==    by 0x4E59952: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 460 of 3,576
==19075==    by 0x472BE9: JacobianUT::testQuadEval() (JacobianUT.cpp:118)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 461 of 3,576
==19075==    by 0x473064: JacobianUT::testQuadEval() (JacobianUT.cpp:127)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 462 of 3,576
==19075==    by 0x478818: HessianOfLagUT::testEmpty() (HessianOfLagUT.cpp:66)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 463 of 3,576
==19075==    by 0x4792B2: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:101)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 464 of 3,576
==19075==    by 0x4796D8: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:109)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 465 of 3,576
==19075==    by 0x479B96: HessianOfLagUT::testQuadEval() (HessianOfLagUT.cpp:118)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 466 of 3,576
==19075==    by 0x78883D5: std::string::_M_mutate(unsigned long, unsigned long, unsigned long) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7888545: std::string::_M_leak_hard() (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x788860A: std::string::operator[](unsigned long) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7225600: Minotaur::toLowerCase(std::string&) (Operations.cpp:374)
==19075==    by 0x7226E0B: Minotaur::Option<bool>::Option(std::string const&, std::string const&, bool, bool) (Option.cpp:32)
==19075==    by 0x7198980: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:130)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 467 of 3,576
==19075==    by 0x719924E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:159)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 468 of 3,576
==19075==    by 0x4ADCD2: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:295)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 469 of 3,576
==19075==    by 0x727DB76: Minotaur::Problem::newConstraint(boost::shared_ptr<Minotaur::Function>, double, double) (Problem.cpp:1037)
==19075==    by 0x4AD69A: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:275)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 470 of 3,576
==19075==    by 0x5A44E45: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A336AD: Ipopt::RegisterOptions_Interfaces(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 471 of 3,576
==19075==    by 0x5A45960: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 472 of 3,576
==19075==    by 0x5A45979: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 473 of 3,576
==19075==    by 0x5A795A7: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8264D: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 474 of 3,576
==19075==    by 0x5A797F3: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 475 of 3,576
==19075==    by 0x5A9C68B: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A826F1: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 476 of 3,576
==19075==    by 0x5A9C732: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 477 of 3,576
==19075==    by 0x5AAC589: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 478 of 3,576
==19075==    by 0x5AEA67D: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82A2B: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 479 of 3,576
==19075==    by 0x5AEA693: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 480 of 3,576
==19075==    by 0x5B0C8E8: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 481 of 3,576
==19075==    by 0x5B49880: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 482 of 3,576
==19075==    by 0x5B3E3D2: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 483 of 3,576
==19075==    by 0x5B40DD0: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 484 of 3,576
==19075==    by 0x5B40FE7: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 485 of 3,576
==19075==    by 0x5B41673: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 486 of 3,576
==19075==    by 0x5B417FB: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 487 of 3,576
==19075==    by 0x5B41817: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 488 of 3,576
==19075==    by 0x5B41E66: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 489 of 3,576
==19075==    by 0x5B41FEE: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 490 of 3,576
==19075==    by 0x5B4200A: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 491 of 3,576
==19075==    by 0x5B4240F: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 30 bytes in 1 blocks are possibly lost in loss record 492 of 3,576
==19075==    by 0x5B4C423: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 493 of 3,576
==19075==    by 0x499D6A: __static_initialization_and_destruction_0(int, int) (PolyUT.cpp:17)
==19075==    by 0x499DEE: _GLOBAL__sub_I__ZN6PolyUT8monomialEv (PolyUT.cpp:144)
==19075==    by 0x56952C: __libc_csu_init (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x7D09ED4: (below main) (libc-start.c:246)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 494 of 3,576
==19075==    by 0x4E6300F: CppUnit::TypeInfoHelper::getClassName(std::type_info const&) (TypeInfoHelper.cpp:33)
==19075==    by 0x4E5AA44: CppUnit::TestNamer::TestNamer(std::type_info const&) (TestNamer.cpp:12)
==19075==    by 0x499E7E: PolyUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x49A1F4: PolyUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x49AE70: CppUnit::TestSuiteFactory<PolyUT>::makeTest() (TestSuiteFactory.h:20)
==19075==    by 0x4E59C81: CppUnit::TestFactoryRegistry::addTestToSuite(CppUnit::TestSuite*) (TestFactoryRegistry.cpp:149)
==19075==    by 0x4E59D00: CppUnit::TestFactoryRegistry::makeTest() (TestFactoryRegistry.cpp:136)
==19075==    by 0x45DE5D: main (unittest.cpp:42)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 495 of 3,576
==19075==    by 0x719910C: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:155)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 496 of 3,576
==19075==    by 0x7199B1C: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:190)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 497 of 3,576
==19075==    by 0x7199DA0: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:199)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 498 of 3,576
==19075==    by 0x719C84D: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:361)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 499 of 3,576
==19075==    by 0x719D2C9: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:396)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 500 of 3,576
==19075==    by 0x5A342CF: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 501 of 3,576
==19075==    by 0x5A73C25: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A825A9: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 502 of 3,576
==19075==    by 0x5A73CD3: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 503 of 3,576
==19075==    by 0x5A7481A: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 504 of 3,576
==19075==    by 0x5A748B0: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 505 of 3,576
==19075==    by 0x5A79561: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 506 of 3,576
==19075==    by 0x5A7AB40: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 507 of 3,576
==19075==    by 0x5A7AB5C: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 508 of 3,576
==19075==    by 0x5A8A7ED: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8269F: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 509 of 3,576
==19075==    by 0x5A8A822: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 510 of 3,576
==19075==    by 0x5A9CE40: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 511 of 3,576
==19075==    by 0x5B06793: Ipopt::PenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 512 of 3,576
==19075==    by 0x5AAC85D: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 513 of 3,576
==19075==    by 0x5AAC889: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 514 of 3,576
==19075==    by 0x5AAC8AA: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 515 of 3,576
==19075==    by 0x5AF58BD: Ipopt::OrigIterationOutput::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82A7D: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 516 of 3,576
==19075==    by 0x5B0C328: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 517 of 3,576
==19075==    by 0x5B0C40F: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 518 of 3,576
==19075==    by 0x5B49714: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 519 of 3,576
==19075==    by 0x5B3DFB7: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 520 of 3,576
==19075==    by 0x5B40511: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31C21: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 31 bytes in 1 blocks are possibly lost in loss record 521 of 3,576
==19075==    by 0x5B4C3EE: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31D03: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 522 of 3,576
==19075==    by 0x4E61695: allocate (new_allocator.h:104)
==19075==    by 0x4E61695: _M_allocate (stl_vector.h:168)
==19075==    by 0x4E61695: std::vector<CppUnit::Test*, std::allocator<CppUnit::Test*> >::_M_insert_aux(__gnu_cxx::__normal_iterator<CppUnit::Test**, std::vector<CppUnit::Test*, std::allocator<CppUnit::Test*> > >, CppUnit::Test* const&) (vector.tcc:345)
==19075==    by 0x4E615DD: push_back (stl_vector.h:913)
==19075==    by 0x4E615DD: CppUnit::TestSuite::addTest(CppUnit::Test*) (TestSuite.cpp:38)
==19075==    by 0x46238F: CGraphUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (CGraphUT.h:34)
==19075==    by 0x462616: CGraphUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x463952: CppUnit::TestSuiteFactory<CGraphUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 523 of 3,576
==19075==    by 0x46836D: FunctionTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (FunctionUT.h:39)
==19075==    by 0x4686E8: FunctionTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x46A66A: CppUnit::TestSuiteFactory<FunctionTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 524 of 3,576
==19075==    by 0x47CDD2: HessianOfLagUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (HessianOfLagUT.h:40)
==19075==    by 0x47D044: HessianOfLagUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x47D758: CppUnit::TestSuiteFactory<HessianOfLagUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 525 of 3,576
==19075==    by 0x480463: LapackTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LapackUT.h:34)
==19075==    by 0x4806D4: LapackTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x480B5C: CppUnit::TestSuiteFactory<LapackTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 526 of 3,576
==19075==    by 0x489B3F: LinearFunctionTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LinearFunctionUT.h:35)
==19075==    by 0x489EBA: LinearFunctionTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x48A7FE: CppUnit::TestSuiteFactory<LinearFunctionTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 527 of 3,576
==19075==    by 0x490374: OperationsTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (OperationsUT.h:31)
==19075==    by 0x4905E6: OperationsTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x490B04: CppUnit::TestSuiteFactory<OperationsTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 528 of 3,576
==19075==    by 0x4A88B3: QuadraticFunctionTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (QuadraticFunctionUT.h:35)
==19075==    by 0x4A8C2E: QuadraticFunctionTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4AA910: CppUnit::TestSuiteFactory<QuadraticFunctionTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 529 of 3,576
==19075==    by 0x4AC22C: CppUnit::ConcretTestFixtureFactory<TimerUT>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x4ABE6F: CppUnit::TestSuiteBuilderContext<TimerUT>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x4ABB6F: TimerUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (TimerUT.h:28)
==19075==    by 0x4ABD88: TimerUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4AC210: CppUnit::TestSuiteFactory<TimerUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 530 of 3,576
==19075==    by 0x4D8E47: TransformerUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (TransformerUT.h:50)
==19075==    by 0x4D90B8: TransformerUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4D9700: CppUnit::TestSuiteFactory<TransformerUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 531 of 3,576
==19075==    by 0x4DB3AC: CppUnit::ConcretTestFixtureFactory<AMPLBqpdUT>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x4DAA95: CppUnit::TestSuiteBuilderContext<AMPLBqpdUT>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x4DA75A: AMPLBqpdUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (AMPLBqpdUT.h:34)
==19075==    by 0x4DA972: AMPLBqpdUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DB390: CppUnit::TestSuiteFactory<AMPLBqpdUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 532 of 3,576
==19075==    by 0x4DD5F0: CppUnit::ConcretTestFixtureFactory<AMPLFilterSQPUT>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x4DCFAF: CppUnit::TestSuiteBuilderContext<AMPLFilterSQPUT>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x4DCB7D: AMPLFilterSQPUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (AMPLFilterSQPUT.h:35)
==19075==    by 0x4DCEAA: AMPLFilterSQPUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DD5D4: CppUnit::TestSuiteFactory<AMPLFilterSQPUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 533 of 3,576
==19075==    by 0x4DCC46: AMPLFilterSQPUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (AMPLFilterSQPUT.h:36)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 534 of 3,576
==19075==    by 0x4DEC04: CppUnit::ConcretTestFixtureFactory<AMPLIpoptUT>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x4DE847: CppUnit::TestSuiteBuilderContext<AMPLIpoptUT>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x4DE548: AMPLIpoptUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (AMPLIpoptUT.h:34)
==19075==    by 0x4DE760: AMPLIpoptUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DEBE8: CppUnit::TestSuiteFactory<AMPLIpoptUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 535 of 3,576
==19075==    by 0x4E3325: AMPLOsiUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (AMPLOsiUT.h:38)
==19075==    by 0x4E36A0: AMPLOsiUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4E406C: CppUnit::TestSuiteFactory<AMPLOsiUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 536 of 3,576
==19075==    by 0x4E569E6: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:73)
==19075==    by 0x4E5986D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==19075==    by 0x4E5EEE1: CppUnit::TestResult::runTest(CppUnit::Test*) (TestResult.cpp:148)
==19075==    by 0x4E611BD: CppUnit::TestRunner::run(CppUnit::TestResult&, std::string const&) (TestRunner.cpp:96)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 537 of 3,576
==19075==    by 0x7186C53: __gnu_cxx::new_allocator<boost::shared_ptr<Minotaur::Constraint> >::allocate(unsigned long, void const*) (new_allocator.h:104)
==19075==    by 0x71843FA: std::_Vector_base<boost::shared_ptr<Minotaur::Constraint>, std::allocator<boost::shared_ptr<Minotaur::Constraint> > >::_M_allocate(unsigned long) (in /sandbox/mahajan/minotaur-test/build-all-debug/src/base/libminotaur.so)
==19075==    by 0x7182680: std::vector<boost::shared_ptr<Minotaur::Constraint>, std::allocator<boost::shared_ptr<Minotaur::Constraint> > >::_M_insert_aux(__gnu_cxx::__normal_iterator<boost::shared_ptr<Minotaur::Constraint>*, std::vector<boost::shared_ptr<Minotaur::Constraint>, std::allocator<boost::shared_ptr<Minotaur::Constraint> > > >, boost::shared_ptr<Minotaur::Constraint> const&) (vector.tcc:345)
==19075==    by 0x71807F1: std::vector<boost::shared_ptr<Minotaur::Constraint>, std::allocator<boost::shared_ptr<Minotaur::Constraint> > >::push_back(boost::shared_ptr<Minotaur::Constraint> const&) (stl_vector.h:913)
==19075==    by 0x727D99F: Minotaur::Problem::newConstraint(boost::shared_ptr<Minotaur::Function>, double, double, std::string) (Problem.cpp:1019)
==19075==    by 0x470497: JacobianUT::setUp() (JacobianUT.cpp:43)
==19075==    by 0x477AD2: CppUnit::TestCaller<JacobianUT>::setUp() (TestCaller.h:177)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 538 of 3,576
==19075==    by 0x478287: HessianOfLagUT::setUp() (HessianOfLagUT.cpp:44)
==19075==    by 0x47D91A: CppUnit::TestCaller<HessianOfLagUT>::setUp() (TestCaller.h:177)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 539 of 3,576
==19075==    by 0x7197402: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:55)
==19075==    by 0x7197213: Minotaur::Environment::Environment() (Environment.cpp:36)
==19075==    by 0x4ADB29: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:293)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 540 of 3,576
==19075==    by 0x7197544: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:60)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 541 of 3,576
==19075==    by 0x7197686: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:65)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 542 of 3,576
==19075==    by 0x71977C8: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:70)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 543 of 3,576
==19075==    by 0x719790A: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:75)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 544 of 3,576
==19075==    by 0x7197A4C: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:80)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 545 of 3,576
==19075==    by 0x7197B8E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:84)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 546 of 3,576
==19075==    by 0x7197CD0: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:88)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 547 of 3,576
==19075==    by 0x7197E12: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:92)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 548 of 3,576
==19075==    by 0x7197F54: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:96)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 549 of 3,576
==19075==    by 0x7198096: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:101)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 550 of 3,576
==19075==    by 0x71981D8: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:105)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 551 of 3,576
==19075==    by 0x719831A: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:109)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 552 of 3,576
==19075==    by 0x719845C: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:113)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 553 of 3,576
==19075==    by 0x719859E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:117)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 554 of 3,576
==19075==    by 0x71986E0: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:121)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 555 of 3,576
==19075==    by 0x7198822: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:125)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 556 of 3,576
==19075==    by 0x7198964: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:129)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 557 of 3,576
==19075==    by 0x7198AA6: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:133)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 558 of 3,576
==19075==    by 0x7198BE8: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:137)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 559 of 3,576
==19075==    by 0x7198D2A: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:141)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 560 of 3,576
==19075==    by 0x7198E6C: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:145)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 561 of 3,576
==19075==    by 0x7198FAE: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:149)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 562 of 3,576
==19075==    by 0x71990F0: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:153)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 563 of 3,576
==19075==    by 0x7199232: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:158)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 564 of 3,576
==19075==    by 0x7199374: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:162)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 565 of 3,576
==19075==    by 0x71994B6: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:167)
==19075==    by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 566 of 3,576
==19075==    by 0x71995F8: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:172)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 567 of 3,576
==19075==    by 0x719973A: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:177)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 568 of 3,576
==19075==    by 0x719987C: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:181)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 569 of 3,576
==19075==    by 0x71999BE: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:185)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 570 of 3,576
==19075==    by 0x7199B00: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:189)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 571 of 3,576
==19075==    by 0x7199C42: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:193)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 572 of 3,576
==19075==    by 0x7199D84: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:197)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 573 of 3,576
==19075==    by 0x7199ED5: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:207)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 574 of 3,576
==19075==    by 0x719A012: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:212)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 575 of 3,576
==19075==    at 0x4C2B0E0: operator new(unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==19075==    by 0x719A14F: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:217)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 576 of 3,576
==19075==    by 0x719A28C: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:221)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 577 of 3,576
==19075==    by 0x719A3C9: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:225)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 578 of 3,576
==19075==    by 0x719A506: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:229)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 579 of 3,576
==19075==    by 0x719A643: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:233)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 580 of 3,576
==19075==    by 0x719A780: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:237)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 581 of 3,576
==19075==    by 0x719A8BD: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:242)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 582 of 3,576
==19075==    by 0x719A9FA: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:246)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 583 of 3,576
==19075==    by 0x719AB37: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:250)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 584 of 3,576
==19075==    by 0x719AC74: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:254)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 585 of 3,576
==19075==    by 0x719ADB1: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:259)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 586 of 3,576
==19075==    by 0x719AEEE: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:263)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 587 of 3,576
==19075==    by 0x719B02B: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:267)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 588 of 3,576
==19075==    by 0x719B177: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:274)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 589 of 3,576
==19075==    by 0x719B2B4: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:279)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 590 of 3,576
==19075==    by 0x469EB1: __gnu_cxx::new_allocator<boost::shared_ptr<Minotaur::Variable> >::allocate(unsigned long, void const*) (new_allocator.h:104)
==19075==    by 0x469A5E: std::_Vector_base<boost::shared_ptr<Minotaur::Variable>, std::allocator<boost::shared_ptr<Minotaur::Variable> > >::_M_allocate(unsigned long) (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4692F8: std::vector<boost::shared_ptr<Minotaur::Variable>, std::allocator<boost::shared_ptr<Minotaur::Variable> > >::_M_insert_aux(__gnu_cxx::__normal_iterator<boost::shared_ptr<Minotaur::Variable>*, std::vector<boost::shared_ptr<Minotaur::Variable>, std::allocator<boost::shared_ptr<Minotaur::Variable> > > >, boost::shared_ptr<Minotaur::Variable> const&) (vector.tcc:345)
==19075==    by 0x468CEF: std::vector<boost::shared_ptr<Minotaur::Variable>, std::allocator<boost::shared_ptr<Minotaur::Variable> > >::push_back(boost::shared_ptr<Minotaur::Variable> const&) (stl_vector.h:913)
==19075==    by 0x727EBF4: Minotaur::Problem::newVariable(double, double, Minotaur::VariableType, std::string, Minotaur::VarSrcType) (Problem.cpp:1149)
==19075==    by 0x727D61F: Minotaur::Problem::newBinaryVariable() (Problem.cpp:994)
==19075==    by 0x4ADD55: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:296)
==19075==    by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 591 of 3,576
==19075==    by 0x4AD6D5: NLPBnbUT::createInstance1_() (NLPBnbUT.cpp:278)
==19075==    by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==19075==    by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==19075==    by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 592 of 3,576
==19075==    by 0x4B38A3: __gnu_cxx::new_allocator<boost::shared_ptr<Minotaur::Handler> >::allocate(unsigned long, void const*) (new_allocator.h:104)
==19075==    by 0x4B2C0A: std::_Vector_base<boost::shared_ptr<Minotaur::Handler>, std::allocator<boost::shared_ptr<Minotaur::Handler> > >::_M_allocate(unsigned long) (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4B1D36: std::vector<boost::shared_ptr<Minotaur::Handler>, std::allocator<boost::shared_ptr<Minotaur::Handler> > >::_M_insert_aux(__gnu_cxx::__normal_iterator<boost::shared_ptr<Minotaur::Handler>*, std::vector<boost::shared_ptr<Minotaur::Handler>, std::allocator<boost::shared_ptr<Minotaur::Handler> > > >, boost::shared_ptr<Minotaur::Handler> const&) (vector.tcc:345)
==19075==    by 0x4B0EEB: std::vector<boost::shared_ptr<Minotaur::Handler>, std::allocator<boost::shared_ptr<Minotaur::Handler> > >::push_back(boost::shared_ptr<Minotaur::Handler> const&) (stl_vector.h:913)
==19075==    by 0x4ADFD3: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:309)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 593 of 3,576
==19075==    by 0x5B69E49: std::vector<Ipopt::RegisteredOption::string_entry, std::allocator<Ipopt::RegisteredOption::string_entry> >::_M_insert_aux(__gnu_cxx::__normal_iterator<Ipopt::RegisteredOption::string_entry*, std::vector<Ipopt::RegisteredOption::string_entry, std::allocator<Ipopt::RegisteredOption::string_entry> > >, Ipopt::RegisteredOption::string_entry const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B6A256: Ipopt::RegisteredOption::AddValidStringSetting(std::string, std::string) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B663F8: Ipopt::RegisteredOptions::AddStringOption2(std::string const&, std::string const&, std::string const&, std::string const&, std::string const&, std::string const&, std::string const&, std::string const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A346F1: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A3363C: Ipopt::RegisterOptions_Interfaces(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A357F8: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 594 of 3,576
==19075==    by 0x5A3488A: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 595 of 3,576
==19075==    by 0x5A34A23: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x4B4A37: CppUnit::TestCaller<NLPBnbUT>::runTest() (TestCaller.h:166)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 596 of 3,576
==19075==    by 0x5A34CEC: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 597 of 3,576
==19075==    by 0x5A34E85: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 598 of 3,576
==19075==    by 0x5A3506B: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 599 of 3,576
==19075==    by 0x5A35200: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x57C26E9: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:300)
==19075==    by 0x507AE4F: Minotaur::EngineFactory::getNLPEngine() (EngineFactory.cpp:119)
==19075==    by 0x4AE092: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:314)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 600 of 3,576
==19075==    by 0x5A45140: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 601 of 3,576
==19075==    by 0x5A45838: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 602 of 3,576
==19075==    by 0x5A459D6: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 603 of 3,576
==19075==    by 0x5A7464D: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 604 of 3,576
==19075==    by 0x5A92465: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A825FB: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 605 of 3,576
==19075==    by 0x5A92602: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 606 of 3,576
==19075==    by 0x5A92794: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 607 of 3,576
==19075==    by 0x5A92967: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 608 of 3,576
==19075==    by 0x5A7A250: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 609 of 3,576
==19075==    by 0x5A7A984: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A35800: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 610 of 3,576
==19075==    by 0x5A7AE26: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 611 of 3,576
==19075==    by 0x5A8A062: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 612 of 3,576
==19075==    by 0x5A8A291: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 613 of 3,576
==19075==    by 0x5A8B11A: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 614 of 3,576
==19075==    by 0x5A8B476: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 615 of 3,576
==19075==    by 0x5A9D0EE: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 616 of 3,576
==19075==    by 0x5A9D286: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 617 of 3,576
==19075==    by 0x5AA4A3A: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82865: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 618 of 3,576
==19075==    by 0x5AA4CB8: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 619 of 3,576
==19075==    by 0x5AA4E8B: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 620 of 3,576
==19075==    by 0x5ACF1F2: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82948: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A39098: Ipopt::IpoptApplication::IpoptApplication(bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 621 of 3,576
==19075==    by 0x5ACF964: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 622 of 3,576
==19075==    by 0x5ADE5D0: Ipopt::MonotoneMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8298F: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 623 of 3,576
==19075==    by 0x5AE9CB9: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 624 of 3,576
==19075==    by 0x5AE9E94: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 625 of 3,576
==19075==    by 0x5AEA064: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 626 of 3,576
==19075==    by 0x5AEA1F6: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 627 of 3,576
==19075==    by 0x5AEA388: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 628 of 3,576
==19075==    by 0x5AEA51A: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 629 of 3,576
==19075==    by 0x5AEA6EA: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 630 of 3,576
==19075==    by 0x5AEA87F: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 631 of 3,576
==19075==    by 0x5AF5A7A: Ipopt::OrigIterationOutput::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 632 of 3,576
==19075==    by 0x5AF5C47: Ipopt::OrigIterationOutput::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 633 of 3,576
==19075==    by 0x5B03ED0: Ipopt::PDSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82AC4: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 634 of 3,576
==19075==    by 0x5AFB1DA: Ipopt::PDFullSpaceSolver::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82B0E: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 635 of 3,576
==19075==    by 0x5B020D6: Ipopt::PDPerturbationHandler::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82B60: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 636 of 3,576
==19075==    by 0x5B0C991: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82C04: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 637 of 3,576
==19075==    by 0x5B16438: Ipopt::RestoIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82CFA: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 638 of 3,576
==19075==    by 0x5B2CF5A: Ipopt::WarmStartIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82DF0: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 639 of 3,576
==19075==    by 0x5A6FD75: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A6D312: Ipopt::RegisterOptions_CGPenalty(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A35808: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 640 of 3,576
==19075==    by 0x5A679ED: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A6D34B: Ipopt::RegisterOptions_CGPenalty(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 641 of 3,576
==19075==    by 0x5B35242: Ipopt::TSymLinearSolver::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B319EC: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 642 of 3,576
==19075==    by 0x5B387D0: Ipopt::Ma27TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31A5D: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 643 of 3,576
==19075==    by 0x5B38969: Ipopt::Ma27TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 644 of 3,576
==19075==    by 0x5B3B40B: Ipopt::Ma57TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31ACE: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 645 of 3,576
==19075==    by 0x5B4992B: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31B3F: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 646 of 3,576
==19075==    by 0x5B42861: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 647 of 3,576
==19075==    by 0x5B4BDF7: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 648 of 3,576
==19075==    by 0x5B4BFA3: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 649 of 3,576
==19075==    by 0x5B4C1ED: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 650 of 3,576
==19075==    by 0x5B4CD39: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are still reachable in loss record 651 of 3,576
==19075==    by 0x4B2D2A: std::_Vector_base<boost::shared_ptr<Minotaur::Handler>, std::allocator<boost::shared_ptr<Minotaur::Handler> > >::_M_create_storage(unsigned long) (stl_vector.h:181)
==19075==    by 0x4B2050: std::_Vector_base<boost::shared_ptr<Minotaur::Handler>, std::allocator<boost::shared_ptr<Minotaur::Handler> > >::_Vector_base(unsigned long, std::allocator<boost::shared_ptr<Minotaur::Handler> > const&) (stl_vector.h:136)
==19075==    by 0x4B105C: std::vector<boost::shared_ptr<Minotaur::Handler>, std::allocator<boost::shared_ptr<Minotaur::Handler> > >::vector(std::vector<boost::shared_ptr<Minotaur::Handler>, std::allocator<boost::shared_ptr<Minotaur::Handler> > > const&) (stl_vector.h:312)
==19075==    by 0x4AE113: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:316)
==19075==
==19075== 32 bytes in 2 blocks are still reachable in loss record 652 of 3,576
==19075==    by 0x4AA2BB: __gnu_cxx::new_allocator<double>::allocate(unsigned long, void const*) (new_allocator.h:104)
==19075==    by 0x4A9E7E: std::_Vector_base<double, std::allocator<double> >::_M_allocate(unsigned long) (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x718E918: std::vector<double, std::allocator<double> >::_M_fill_insert(__gnu_cxx::__normal_iterator<double*, std::vector<double, std::allocator<double> > >, unsigned long, double const&) (vector.tcc:483)
==19075==    by 0x718DEF9: std::vector<double, std::allocator<double> >::insert(__gnu_cxx::__normal_iterator<double*, std::vector<double, std::allocator<double> > >, unsigned long, double const&) (stl_vector.h:1024)
==19075==    by 0x718D897: std::vector<double, std::allocator<double> >::resize(unsigned long, double) (stl_vector.h:707)
==19075==    by 0x71CA7E9: Minotaur::LinearFunction::prepJac(std::_Rb_tree_const_iterator<boost::shared_ptr<Minotaur::Variable> >, std::_Rb_tree_const_iterator<boost::shared_ptr<Minotaur::Variable> >) (LinearFunction.cpp:267)
==19075==    by 0x71AA2DD: Minotaur::Function::prepJac() (Function.cpp:430)
==19075==    by 0x71AF885: Minotaur::Jacobian::Jacobian(std::vector<boost::shared_ptr<Minotaur::Constraint>, std::allocator<boost::shared_ptr<Minotaur::Constraint> > > const&, unsigned int) (Jacobian.cpp:34)
==19075==    by 0x7280080: Minotaur::Problem::setNativeDer() (Problem.cpp:1347)
==19075==    by 0x4707EC: JacobianUT::testLinearEval() (JacobianUT.cpp:60)
==19075==    by 0x477AA5: CppUnit::TestCaller<JacobianUT>::runTest() (TestCaller.h:166)
==19075==
==19075== 32 bytes in 2 blocks are still reachable in loss record 653 of 3,576
==19075==    by 0x4788D9: HessianOfLagUT::testEmpty() (HessianOfLagUT.cpp:67)
==19075==    by 0x47D8ED: CppUnit::TestCaller<HessianOfLagUT>::runTest() (TestCaller.h:166)
==19075==
==19075== 32 bytes in 2 blocks are still reachable in loss record 654 of 3,576
==19075==    by 0x478C8C: HessianOfLagUT::testLinearEval() (HessianOfLagUT.cpp:78)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 655 of 3,576
==19075==    by 0x7888248: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7889970: char* std::string::_S_construct<char const*>(char const*, char const*, std::allocator<char> const&, std::forward_iterator_tag) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7889D87: std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x4AB5FA: __static_initialization_and_destruction_0(int, int) (TimerUT.cpp:13)
==19075==    by 0x4AB67E: _GLOBAL__sub_I__ZN7TimerUT5setUpEv (TimerUT.cpp:52)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 656 of 3,576
==19075==    by 0x4ABAA3: TimerUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4ABCFE: TimerUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 657 of 3,576
==19075==    by 0x78883D5: std::string::_M_mutate(unsigned long, unsigned long, unsigned long) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7888545: std::string::_M_leak_hard() (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x788860A: std::string::operator[](unsigned long) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7225600: Minotaur::toLowerCase(std::string&) (Operations.cpp:374)
==19075==    by 0x72269E4: Minotaur::Option<int>::Option(std::string const&, std::string const&, bool, int) (Option.cpp:32)
==19075==    by 0x719A79C: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:239)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 658 of 3,576
==19075==    by 0x719ADCD: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:260)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 659 of 3,576
==19075==    by 0x7227239: Minotaur::Option<double>::Option(std::string const&, std::string const&, bool, double) (Option.cpp:32)
==19075==    by 0x719B810: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:300)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 660 of 3,576
==19075==    by 0x7227695: Minotaur::Option<std::string>::Option(std::string const&, std::string const&, bool, std::string) (Option.cpp:32)
==19075==    by 0x719D183: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:393)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 661 of 3,576
==19075==    by 0x5A39188: Ipopt::IpoptApplication::IpoptApplication(bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 662 of 3,576
==19075==    by 0x5A79643: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8264D: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 663 of 3,576
==19075==    by 0x5A7A3CB: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 664 of 3,576
==19075==    by 0x5A7A655: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 665 of 3,576
==19075==    by 0x5A7AAD5: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 666 of 3,576
==19075==    by 0x5A9C5D6: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A826F1: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 667 of 3,576
==19075==    by 0x5A9C7DD: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 668 of 3,576
==19075==    by 0x5A9CAA7: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 669 of 3,576
==19075==    by 0x5B066EC: Ipopt::PenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82743: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 670 of 3,576
==19075==    by 0x5AAC673: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A828F6: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 671 of 3,576
==19075==    by 0x5ACF32E: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 672 of 3,576
==19075==    by 0x5ACF360: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 673 of 3,576
==19075==    by 0x5ACF392: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 674 of 3,576
==19075==    by 0x5ACF3CA: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 675 of 3,576
==19075==    by 0x5ACF3E6: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 676 of 3,576
==19075==    by 0x5ADE251: Ipopt::MonotoneMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 677 of 3,576
==19075==    by 0x5ADE6BD: Ipopt::MonotoneMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 678 of 3,576
==19075==    by 0x5A67C2D: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 679 of 3,576
==19075==    by 0x5A67E1C: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 680 of 3,576
==19075==    by 0x5A67F66: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 681 of 3,576
==19075==    by 0x5B406B1: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 682 of 3,576
==19075==    by 0x5B40852: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 32 bytes in 1 blocks are possibly lost in loss record 683 of 3,576
==19075==    by 0x57C4D76: Minotaur::IpoptEngine::setOptionsForRepeatedSolve() (IpoptEngine.cpp:658)
==19075==    by 0x57C2703: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:301)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 684 of 3,576
==19075==    by 0x712FB41: __static_initialization_and_destruction_0(int, int) (Branch.cpp:25)
==19075==    by 0x712FBA3: _GLOBAL__sub_I_Branch.cpp (Branch.cpp:79)
==19075==    by 0x40101D9: call_init.part.0 (dl-init.c:78)
==19075==    by 0x40102C2: call_init (dl-init.c:36)
==19075==    by 0x40102C2: _dl_init (dl-init.c:126)
==19075==    by 0x4001299: ??? (in /lib/x86_64-linux-gnu/ld-2.19.so)
==19075==    by 0x1: ???
==19075==    by 0xFFF000E22: ???
==19075==    by 0xFFF000E2D: ???
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 685 of 3,576
==19075==    by 0x461CAC: __static_initialization_and_destruction_0(int, int) (CGraphUT.cpp:17)
==19075==    by 0x461D30: _GLOBAL__sub_I__ZN8CGraphUT13testIdenticalEv (CGraphUT.cpp:134)
==19075==    by 0x56952C: __libc_csu_init (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x7D09ED4: (below main) (libc-start.c:246)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 686 of 3,576
==19075==    by 0x480093: __static_initialization_and_destruction_0(int, int) (LapackUT.cpp:13)
==19075==    by 0x480117: _GLOBAL__sub_I_foobar_ (LapackUT.cpp:206)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 687 of 3,576
==19075==    by 0x48AD62: __static_initialization_and_destruction_0(int, int) (LoggerUT.cpp:13)
==19075==    by 0x48ADE6: _GLOBAL__sub_I__ZN8LoggerUT13testMsgStreamEv (LoggerUT.cpp:39)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 688 of 3,576
==19075==    by 0x4AF233: __static_initialization_and_destruction_0(int, int) (NLPBnbUT.cpp:26)
==19075==    by 0x4AF2B7: _GLOBAL__sub_I__ZN8NLPBnbUT15createInstance_Ev (NLPBnbUT.cpp:462)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 689 of 3,576
==19075==    by 0x4E6300F: CppUnit::TypeInfoHelper::getClassName(std::type_info const&) (TypeInfoHelper.cpp:33)
==19075==    by 0x4E5AA44: CppUnit::TestNamer::TestNamer(std::type_info const&) (TestNamer.cpp:12)
==19075==    by 0x4620D2: CGraphUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x46258C: CGraphUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4E59C81: CppUnit::TestFactoryRegistry::addTestToSuite(CppUnit::TestSuite*) (TestFactoryRegistry.cpp:149)
==19075==    by 0x4E59D00: CppUnit::TestFactoryRegistry::makeTest() (TestFactoryRegistry.cpp:136)
==19075==    by 0x45DE5D: main (unittest.cpp:42)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 690 of 3,576
==19075==    by 0x48AEA0: LoggerUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x48B216: LoggerUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x48BA56: CppUnit::TestSuiteFactory<LoggerUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 691 of 3,576
==19075==    by 0x4AF464: NLPBnbUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4AF7DA: NLPBnbUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4B48A2: CppUnit::TestSuiteFactory<NLPBnbUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 692 of 3,576
==19075==    by 0x7226E0B: Minotaur::Option<bool>::Option(std::string const&, std::string const&, bool, bool) (Option.cpp:32)
==19075==    by 0x7197BAA: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:85)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 693 of 3,576
==19075==    by 0x719C3F1: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:349)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 694 of 3,576
==19075==    by 0x719D463: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:401)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 695 of 3,576
==19075==    by 0x5A44DCC: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A336AD: Ipopt::RegisterOptions_Interfaces(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 696 of 3,576
==19075==    by 0x5A44DFA: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 697 of 3,576
==19075==    by 0x5A7484C: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A825A9: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 698 of 3,576
==19075==    by 0x5A9238C: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 699 of 3,576
==19075==    by 0x5A923CC: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 700 of 3,576
==19075==    by 0x5A923ED: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 701 of 3,576
==19075==    by 0x5A7A192: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 702 of 3,576
==19075==    by 0x5A7A1C5: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 703 of 3,576
==19075==    by 0x5A7A1E1: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 704 of 3,576
==19075==    by 0x5A7A8C6: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 705 of 3,576
==19075==    by 0x5A8A48E: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8269F: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 706 of 3,576
==19075==    by 0x5AA4A0D: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 707 of 3,576
==19075==    by 0x5AAC831: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 708 of 3,576
==19075==    by 0x5ACF2FE: Ipopt::LimMemQuasiNewtonUpdater::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 709 of 3,576
==19075==    by 0x5AE710C: Ipopt::OptimalityErrorConvergenceCheck::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A829D9: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 710 of 3,576
==19075==    by 0x5AF5B73: Ipopt::OrigIterationOutput::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82A7D: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 711 of 3,576
==19075==    by 0x5AF5BB8: Ipopt::OrigIterationOutput::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 712 of 3,576
==19075==    by 0x5AF5BD2: Ipopt::OrigIterationOutput::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 713 of 3,576
==19075==    by 0x5B0C36E: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 714 of 3,576
==19075==    by 0x5A6FA12: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 715 of 3,576
==19075==    by 0x5B40F99: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31C21: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 716 of 3,576
==19075==    by 0x5B417C3: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 717 of 3,576
==19075==    by 0x5B41FB6: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 718 of 3,576
==19075==    by 0x5B4BB2F: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31D03: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 719 of 3,576
==19075==    by 0x5B4C6F2: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 720 of 3,576
==19075==    by 0x5B4C796: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 721 of 3,576
==19075==    by 0x5B4C84E: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 722 of 3,576
==19075==    by 0x5B4C8F2: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 723 of 3,576
==19075==    by 0x5B4C996: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 724 of 3,576
==19075==    by 0x5B4CA4E: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 725 of 3,576
==19075==    by 0x5B4CB06: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 726 of 3,576
==19075==    by 0x5B4CBAA: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 33 bytes in 1 blocks are possibly lost in loss record 727 of 3,576
==19075==    by 0x57C4C99: Minotaur::IpoptEngine::setOptionsForRepeatedSolve() (IpoptEngine.cpp:657)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 728 of 3,576
==19075==    by 0x716A2F4: __static_initialization_and_destruction_0(int, int) (CutMan1.cpp:34)
==19075==    by 0x716A356: _GLOBAL__sub_I_CutMan1.cpp (CutMan1.cpp:207)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 729 of 3,576
==19075==    by 0x7280FFB: __static_initialization_and_destruction_0(int, int) (Problem.cpp:36)
==19075==    by 0x728105D: _GLOBAL__sub_I_Problem.cpp (Problem.cpp:1486)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 730 of 3,576
==19075==    by 0x4629BB: CppUnit::AutoRegisterSuite<CGraphUT>::AutoRegisterSuite() (AutoRegisterSuite.h:34)
==19075==    by 0x461C77: __static_initialization_and_destruction_0(int, int) (CGraphUT.cpp:16)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 731 of 3,576
==19075==    by 0x46E6D1: __static_initialization_and_destruction_0(int, int) (ProblemUT.cpp:20)
==19075==    by 0x46E755: _GLOBAL__sub_I__ZN11ProblemTest5setUpEv (ProblemUT.cpp:147)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 732 of 3,576
==19075==    by 0x4E2EE3: __static_initialization_and_destruction_0(int, int) (AMPLOsiUT.cpp:23)
==19075==    by 0x4E2F67: _GLOBAL__sub_I__ZN9AMPLOsiUT5setUpEv (AMPLOsiUT.cpp:157)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 733 of 3,576
==19075==    by 0x4E60F91: CppUnit::TestRunner::TestRunner() (TestRunner.cpp:71)
==19075==    by 0x4E62DCE: CppUnit::TextTestRunner::TextTestRunner(CppUnit::Outputter*) (TextTestRunner.cpp:23)
==19075==    by 0x45DC93: main (unittest.cpp:31)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 734 of 3,576
==19075==    by 0x4E3043: AMPLOsiUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4E3616: AMPLOsiUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4E406C: CppUnit::TestSuiteFactory<AMPLOsiUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 735 of 3,576
==19075==    by 0x7197E2E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:93)
==19075==    by 0x7197213: Minotaur::Environment::Environment() (Environment.cpp:36)
==19075==    by 0x4ADB29: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:293)
==19075==    by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 736 of 3,576
==19075==    by 0x719A16B: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:218)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 737 of 3,576
==19075==    by 0x719A3E5: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:226)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 738 of 3,576
==19075==    at 0x4C2B0E0: operator new(unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==19075==    by 0x719A65F: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:234)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 739 of 3,576
==19075==    by 0x719AB53: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:251)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 740 of 3,576
==19075==    by 0x719C877: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:363)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 741 of 3,576
==19075==    by 0x719D001: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:389)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 742 of 3,576
==19075==    by 0x5A34B32: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 743 of 3,576
==19075==    by 0x5A44E2C: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 744 of 3,576
==19075==    by 0x5A73F91: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 745 of 3,576
==19075==    by 0x5A7A41F: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 746 of 3,576
==19075==    by 0x5A9C888: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 747 of 3,576
==19075==    by 0x5A9CB45: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 748 of 3,576
==19075==    by 0x5AE78A4: Ipopt::OptimalityErrorConvergenceCheck::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 749 of 3,576
==19075==    by 0x5B0C1A0: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 750 of 3,576
==19075==    by 0x5B0C24F: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 751 of 3,576
==19075==    by 0x5A67EC1: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 752 of 3,576
==19075==    by 0x5A6800B: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 753 of 3,576
==19075==    by 0x5A68155: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 754 of 3,576
==19075==    by 0x5A683E9: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 755 of 3,576
==19075==    by 0x5B497CA: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 756 of 3,576
==19075==    by 0x5B3E069: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31BB0: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 757 of 3,576
==19075==    by 0x5B405CF: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 758 of 3,576
==19075==    by 0x5B40EFD: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 759 of 3,576
==19075==    by 0x5B41753: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 760 of 3,576
==19075==    by 0x5B41F46: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 761 of 3,576
==19075==    by 0x5B54A52: Ipopt::OptionsList::lowercase(std::string) const (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B5914A: Ipopt::OptionsList::SetStringValue(std::string const&, std::string const&, bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x57C4DB5: Minotaur::IpoptEngine::setOptionsForRepeatedSolve() (IpoptEngine.cpp:658)
==19075==
==19075== 34 bytes in 1 blocks are possibly lost in loss record 762 of 3,576
==19075==    by 0x7888E0A: std::string::_Rep::_M_clone(std::allocator<char> const&, unsigned long) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x788948B: std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::string const&) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x5B593B5: Ipopt::OptionsList::SetStringValue(std::string const&, std::string const&, bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 763 of 3,576
==19075==    by 0x7218E4B: __static_initialization_and_destruction_0(int, int) (NlWriter.cpp:38)
==19075==    by 0x7218EAD: _GLOBAL__sub_I_NlWriter.cpp (NlWriter.cpp:414)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 764 of 3,576
==19075==    by 0x72600B1: __static_initialization_and_destruction_0(int, int) (PerspCon.cpp:28)
==19075==    by 0x7260113: _GLOBAL__sub_I_PerspCon.cpp (PerspCon.cpp:519)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 765 of 3,576
==19075==    by 0x467E78: __static_initialization_and_destruction_0(int, int) (FunctionUT.cpp:20)
==19075==    by 0x467EFC: _GLOBAL__sub_I__ZN12FunctionTest5setUpEv (FunctionUT.cpp:124)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 766 of 3,576
==19075==    by 0x4767D1: __static_initialization_and_destruction_0(int, int) (JacobianUT.cpp:15)
==19075==    by 0x476855: _GLOBAL__sub_I__ZN10JacobianUT5setUpEv (JacobianUT.cpp:179)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 767 of 3,576
==19075==    by 0x493FDE: __static_initialization_and_destruction_0(int, int) (PerspRefUT.cpp:18)
==19075==    by 0x494062: _GLOBAL__sub_I__ZN10PerspRefUT9iterativeEv (PerspRefUT.cpp:170)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 768 of 3,576
==19075==    by 0x4DA57B: __static_initialization_and_destruction_0(int, int) (AMPLBqpdUT.cpp:17)
==19075==    by 0x4DA5FF: _GLOBAL__sub_I__ZN10AMPLBqpdUT7testNLPEv (AMPLBqpdUT.cpp:69)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 769 of 3,576
==19075==    by 0x4769B1: JacobianUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x476D28: JacobianUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x477910: CppUnit::TestSuiteFactory<JacobianUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 770 of 3,576
==19075==    by 0x4801A6: LapackTest::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x48064A: LapackTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x480B5C: CppUnit::TestSuiteFactory<LapackTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 771 of 3,576
==19075==    by 0x494103: PerspRefUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x49447A: PerspRefUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x494BA4: CppUnit::TestSuiteFactory<PerspRefUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 772 of 3,576
==19075==    by 0x4DA68E: AMPLBqpdUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DA8E8: AMPLBqpdUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DB390: CppUnit::TestSuiteFactory<AMPLBqpdUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 773 of 3,576
==19075==    by 0x719A522: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:230)
==19075==    by 0x4B4A37: CppUnit::TestCaller<NLPBnbUT>::runTest() (TestCaller.h:166)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 774 of 3,576
==19075==    by 0x719B420: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:286)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 775 of 3,576
==19075==    by 0x719BD50: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:320)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 776 of 3,576
==19075==    by 0x719BEA0: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:325)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 777 of 3,576
==19075==    by 0x719CCFD: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:379)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 778 of 3,576
==19075==    by 0x5A347D8: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A3363C: Ipopt::RegisterOptions_Interfaces(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A357F8: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x57C26E9: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:300)
==19075==    by 0x507AE4F: Minotaur::EngineFactory::getNLPEngine() (EngineFactory.cpp:119)
==19075==    by 0x4AE092: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:314)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 779 of 3,576
==19075==    by 0x5A74801: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A35800: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 780 of 3,576
==19075==    by 0x5A91F60: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A825FB: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 781 of 3,576
==19075==    by 0x5A9200F: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 782 of 3,576
==19075==    by 0x5A9285F: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 783 of 3,576
==19075==    by 0x5A7AB08: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 784 of 3,576
==19075==    by 0x5A8A786: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 785 of 3,576
==19075==    by 0x5A9D065: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 786 of 3,576
==19075==    by 0x5A9D1FD: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 787 of 3,576
==19075==    by 0x5A9D422: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 788 of 3,576
==19075==    by 0x5AAC74F: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 789 of 3,576
==19075==    by 0x5AE9D8F: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82A2B: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A39098: Ipopt::IpoptApplication::IpoptApplication(bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 790 of 3,576
==19075==    by 0x5B0C306: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 791 of 3,576
==19075==    by 0x5B0C68F: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 792 of 3,576
==19075==    by 0x5A82DC3: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 793 of 3,576
==19075==    by 0x5B4951A: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 794 of 3,576
==19075==    by 0x5B495C2: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 795 of 3,576
==19075==    by 0x5B498FC: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 796 of 3,576
==19075==    by 0x5B3DDC9: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 797 of 3,576
==19075==    by 0x5B3DE6D: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 798 of 3,576
==19075==    by 0x5B3E479: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 799 of 3,576
==19075==    by 0x5B403AE: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 800 of 3,576
==19075==    by 0x5B4045E: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 801 of 3,576
==19075==    by 0x5B40B62: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 802 of 3,576
==19075==    by 0x5B40E61: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 803 of 3,576
==19075==    by 0x5B41405: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 804 of 3,576
==19075==    by 0x5B416E3: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 805 of 3,576
==19075==    by 0x5B41BF8: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 806 of 3,576
==19075==    by 0x5B41ED6: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 807 of 3,576
==19075==    by 0x5B4250B: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 35 bytes in 1 blocks are possibly lost in loss record 808 of 3,576
==19075==    by 0x7258A55: Minotaur::PCBProcessor::PCBProcessor(boost::shared_ptr<Minotaur::Environment>, boost::shared_ptr<Minotaur::Engine>, std::vector<boost::shared_ptr<Minotaur::Handler>, std::allocator<boost::shared_ptr<Minotaur::Handler> > >) (PCBProcessor.cpp:43)
==19075==    by 0x4AE138: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:316)
==19075==    by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==19075==    by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==19075==    by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 809 of 3,576
==19075==    by 0x723ADD8: __static_initialization_and_destruction_0(int, int) (ParCutMan.cpp:34)
==19075==    by 0x723AE3A: _GLOBAL__sub_I_ParCutMan.cpp (ParCutMan.cpp:222)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 810 of 3,576
==19075==    by 0x7276861: __static_initialization_and_destruction_0(int, int) (Presolver.cpp:32)
==19075==    by 0x72768C3: _GLOBAL__sub_I_Presolver.cpp (Presolver.cpp:256)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 811 of 3,576
==19075==    by 0x728B012: __static_initialization_and_destruction_0(int, int) (QGHandler.cpp:47)
==19075==    by 0x728B074: _GLOBAL__sub_I_QGHandler.cpp (QGHandler.cpp:769)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 812 of 3,576
==19075==    by 0x72B43BD: __static_initialization_and_destruction_0(int, int) (RCHandler.cpp:28)
==19075==    by 0x72B441F: _GLOBAL__sub_I_RCHandler.cpp (RCHandler.cpp:198)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 813 of 3,576
==19075==    by 0x48CB8A: __static_initialization_and_destruction_0(int, int) (ObjectiveUT.cpp:16)
==19075==    by 0x48CC0E: _GLOBAL__sub_I__ZN11ObjectiveUT5setUpEv (ObjectiveUT.cpp:62)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 814 of 3,576
==19075==    by 0x4DE368: __static_initialization_and_destruction_0(int, int) (AMPLIpoptUT.cpp:19)
==19075==    by 0x4DE3EC: _GLOBAL__sub_I__ZN11AMPLIpoptUT7testNLPEv (AMPLIpoptUT.cpp:69)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 815 of 3,576
==19075==    by 0x46E84B: ProblemTest::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x46F148: ProblemTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x46FB20: CppUnit::TestSuiteFactory<ProblemTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 816 of 3,576
==19075==    by 0x48CE78: ObjectiveUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x48D0D2: ObjectiveUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x48DD96: CppUnit::TestSuiteFactory<ObjectiveUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 817 of 3,576
==19075==    by 0x4DE47C: AMPLIpoptUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DE6D6: AMPLIpoptUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DEBE8: CppUnit::TestSuiteFactory<AMPLIpoptUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 818 of 3,576
==19075==    by 0x7197A68: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:81)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 819 of 3,576
==19075==    by 0x719883E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:126)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 820 of 3,576
==19075==    by 0x7198D46: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:142)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 821 of 3,576
==19075==    by 0x7198E88: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:146)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 822 of 3,576
==19075==    by 0x7198FCA: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:150)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 823 of 3,576
==19075==    by 0x71994D2: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:169)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 824 of 3,576
==19075==    by 0x7199614: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:174)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 825 of 3,576
==19075==    by 0x719B193: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:276)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 826 of 3,576
==19075==    by 0x719B960: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:305)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 827 of 3,576
==19075==    by 0x719BAB0: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:310)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 828 of 3,576
==19075==    by 0x719C140: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:336)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 829 of 3,576
==19075==    by 0x719C573: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:353)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 830 of 3,576
==19075==    by 0x719C9F9: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:368)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 831 of 3,576
==19075==    by 0x719D2F3: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:397)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 832 of 3,576
==19075==    by 0x5A3435C: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 833 of 3,576
==19075==    by 0x5A3448B: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 834 of 3,576
==19075==    by 0x5A4537C: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 835 of 3,576
==19075==    by 0x5A73B72: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 836 of 3,576
==19075==    by 0x5A79BEB: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 837 of 3,576
==19075==    by 0x5A79E07: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 838 of 3,576
==19075==    by 0x5A7A219: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 839 of 3,576
==19075==    by 0x5A7AA61: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 840 of 3,576
==19075==    by 0x5A82672: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 841 of 3,576
==19075==    by 0x5A8A01F: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 842 of 3,576
==19075==    by 0x5A8A889: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 843 of 3,576
==19075==    by 0x7888248: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7889970: char* std::string::_S_construct<char const*>(char const*, char const*, std::allocator<char> const&, std::forward_iterator_tag) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7889D87: std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x5A826C4: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 844 of 3,576
==19075==    by 0x5A9C93D: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 845 of 3,576
==19075==    by 0x5A9CBEC: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 846 of 3,576
==19075==    by 0x5A9CDFD: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 847 of 3,576
==19075==    by 0x5A82716: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 848 of 3,576
==19075==    by 0x5A82768: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 849 of 3,576
==19075==    by 0x5A827BA: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 850 of 3,576
==19075==    by 0x5AA47FF: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82865: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 851 of 3,576
==19075==    by 0x5AA4889: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 852 of 3,576
==19075==    by 0x5AC9E76: Ipopt::IpoptData::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A828AC: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 853 of 3,576
==19075==    by 0x5AAC4FF: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 854 of 3,576
==19075==    by 0x5AAC6EB: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 855 of 3,576
==19075==    by 0x5AAC7C7: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 856 of 3,576
==19075==    by 0x5A829AC: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 857 of 3,576
==19075==    by 0x5A6F75A: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A6D312: Ipopt::RegisterOptions_CGPenalty(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A35808: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 858 of 3,576
==19075==    by 0x5A6F8B6: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 859 of 3,576
==19075==    by 0x5A6F964: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 860 of 3,576
==19075==    by 0x5A6FAC0: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 861 of 3,576
==19075==    by 0x5A67AD5: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A6D34B: Ipopt::RegisterOptions_CGPenalty(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 862 of 3,576
==19075==    by 0x5A680B0: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 863 of 3,576
==19075==    by 0x5B38344: Ipopt::Ma27TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31A5D: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 864 of 3,576
==19075==    by 0x5B3B091: Ipopt::Ma57TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31ACE: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 865 of 3,576
==19075==    by 0x5B4966D: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31B3F: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 866 of 3,576
==19075==    by 0x5B3DF14: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 867 of 3,576
==19075==    by 0x5B40D98: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 868 of 3,576
==19075==    by 0x5B4100E: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 869 of 3,576
==19075==    by 0x5B4163B: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 870 of 3,576
==19075==    by 0x5B41E2E: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 871 of 3,576
==19075==    by 0x5B42367: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 872 of 3,576
==19075==    by 0x5B4BA6D: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 873 of 3,576
==19075==    by 0x5B47DB0: Ipopt::Ma28TDependencyDetector::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31D74: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 874 of 3,576
==19075==    by 0x5B5A636: Ipopt::OptionsList::SetIntegerValue(std::string const&, int, bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x57C4B36: Minotaur::IpoptEngine::setOptionsForRepeatedSolve() (IpoptEngine.cpp:636)
==19075==    by 0x57C2703: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:301)
==19075==
==19075== 36 bytes in 1 blocks are possibly lost in loss record 875 of 3,576
==19075==    by 0x57C4CD8: Minotaur::IpoptEngine::setOptionsForRepeatedSolve() (IpoptEngine.cpp:657)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 876 of 3,576
==19075==    by 0x48FF98: __static_initialization_and_destruction_0(int, int) (OperationsUT.cpp:15)
==19075==    by 0x49001C: _GLOBAL__sub_I__ZN14OperationsTest7testGcdEv (OperationsUT.cpp:77)
==19075==    by 0x56952C: __libc_csu_init (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x7D09ED4: (below main) (libc-start.c:246)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 877 of 3,576
==19075==    by 0x4D5462: __static_initialization_and_destruction_0(int, int) (AMPLCGraphUT.cpp:22)
==19075==    by 0x4D54E6: _GLOBAL__sub_I__ZN12AMPLCGraphUT5setUpEv (AMPLCGraphUT.cpp:515)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 878 of 3,576
==19075==    by 0x4D70D6: __static_initialization_and_destruction_0(int, int) (PolySolverUT.cpp:14)
==19075==    by 0x4D715A: _GLOBAL__sub_I__ZN12PolySolverUT5setUpEv (PolySolverUT.cpp:60)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 879 of 3,576
==19075==    by 0x4E9499: __static_initialization_and_destruction_0(int, int) (BqpdEngine.cpp:44)
==19075==    by 0x4E94EF: _GLOBAL__sub_I__ZN8Minotaur10BqpdEngine3me_E (BqpdEngine.cpp:1195)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 880 of 3,576
==19075==    by 0x4E6300F: CppUnit::TypeInfoHelper::getClassName(std::type_info const&) (TypeInfoHelper.cpp:33)
==19075==    by 0x4E5AA44: CppUnit::TestNamer::TestNamer(std::type_info const&) (TestNamer.cpp:12)
==19075==    by 0x46808B: FunctionTest::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x46865E: FunctionTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x46A66A: CppUnit::TestSuiteFactory<FunctionTest>::makeTest() (TestSuiteFactory.h:20)
==19075==    by 0x4E59C81: CppUnit::TestFactoryRegistry::addTestToSuite(CppUnit::TestSuite*) (TestFactoryRegistry.cpp:149)
==19075==    by 0x4E59D00: CppUnit::TestFactoryRegistry::makeTest() (TestFactoryRegistry.cpp:136)
==19075==    by 0x45DE5D: main (unittest.cpp:42)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 881 of 3,576
==19075==    by 0x4D5587: AMPLCGraphUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4D60BA: AMPLCGraphUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4D662C: CppUnit::TestSuiteFactory<AMPLCGraphUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 882 of 3,576
==19075==    by 0x4D71FB: PolySolverUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4D7456: PolySolverUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4D799A: CppUnit::TestSuiteFactory<PolySolverUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 883 of 3,576
==19075==    by 0x78883D5: std::string::_M_mutate(unsigned long, unsigned long, unsigned long) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7888545: std::string::_M_leak_hard() (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x788860A: std::string::operator[](unsigned long) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7225600: Minotaur::toLowerCase(std::string&) (Operations.cpp:374)
==19075==    by 0x7226E0B: Minotaur::Option<bool>::Option(std::string const&, std::string const&, bool, bool) (Option.cpp:32)
==19075==    by 0x71976A2: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:67)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 884 of 3,576
==19075==    by 0x7197CEC: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:89)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 885 of 3,576
==19075==    by 0x7198478: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:114)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 886 of 3,576
==19075==    by 0x7198AC2: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:134)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 887 of 3,576
==19075==    by 0x72269E4: Minotaur::Option<int>::Option(std::string const&, std::string const&, bool, int) (Option.cpp:32)
==19075==    by 0x719A2A8: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:222)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 888 of 3,576
==19075==    by 0x719B2D0: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:281)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 889 of 3,576
==19075==    by 0x7227239: Minotaur::Option<double>::Option(std::string const&, std::string const&, bool, double) (Option.cpp:32)
==19075==    by 0x719BC00: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:315)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 890 of 3,576
==19075==    by 0x7227695: Minotaur::Option<std::string>::Option(std::string const&, std::string const&, bool, std::string) (Option.cpp:32)
==19075==    by 0x719CE7F: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:384)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 891 of 3,576
==19075==    by 0x5A34F56: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 892 of 3,576
==19075==    by 0x5A34FA5: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 893 of 3,576
==19075==    by 0x5A34FB9: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 894 of 3,576
==19075==    by 0x5A34FE1: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 895 of 3,576
==19075==    by 0x5A35024: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 896 of 3,576
==19075==    by 0x5A3513B: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 897 of 3,576
==19075==    by 0x5A3514F: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 898 of 3,576
==19075==    by 0x5A35177: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 899 of 3,576
==19075==    by 0x5A351BA: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 900 of 3,576
==19075==    by 0x5A44B57: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A336AD: Ipopt::RegisterOptions_Interfaces(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 901 of 3,576
==19075==    by 0x5A4534A: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 902 of 3,576
==19075==    by 0x5A73D75: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A825A9: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 903 of 3,576
==19075==    by 0x5A79EE9: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8264D: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 904 of 3,576
==19075==    by 0x5A7ACF1: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 905 of 3,576
==19075==    by 0x5A89EB7: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8269F: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 906 of 3,576
==19075==    by 0x5A9CE61: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A826F1: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 907 of 3,576
==19075==    by 0x5AE71A9: Ipopt::OptimalityErrorConvergenceCheck::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A829D9: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 908 of 3,576
==19075==    by 0x5AE724D: Ipopt::OptimalityErrorConvergenceCheck::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 909 of 3,576
==19075==    by 0x5B2D069: Ipopt::WarmStartIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82DF0: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 910 of 3,576
==19075==    by 0x5A6D2D0: Ipopt::RegisterOptions_CGPenalty(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 911 of 3,576
==19075==    by 0x5A6F808: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 912 of 3,576
==19075==    by 0x5A6FC1C: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 913 of 3,576
==19075==    by 0x5B3E267: Ipopt::Ma86SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 914 of 3,576
==19075==    by 0x5B408BC: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31C21: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 915 of 3,576
==19075==    by 0x5B4105C: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 916 of 3,576
==19075==    by 0x5B4184F: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 917 of 3,576
==19075==    by 0x5B42042: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 918 of 3,576
==19075==    by 0x5B423D7: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 919 of 3,576
==19075==    by 0x5B50DDD: Ipopt::MumpsSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31C92: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 920 of 3,576
==19075==    at 0x4C2B0E0: operator new(unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==19075==    by 0x5B4BAD1: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31D03: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 921 of 3,576
==19075==    by 0x5B4BB61: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 922 of 3,576
==19075==    by 0x5B4C370: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 923 of 3,576
==19075==    by 0x5B4C3A3: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 37 bytes in 1 blocks are possibly lost in loss record 924 of 3,576
==19075==    by 0x5B4C43F: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 925 of 3,576
==19075==    by 0x71A299F: __static_initialization_and_destruction_0(int, int) (Environment.cpp:28)
==19075==    by 0x71A2A01: _GLOBAL__sub_I_Environment.cpp (Environment.cpp:808)
==19075==    by 0x40101D9: call_init.part.0 (dl-init.c:78)
==19075==    by 0x40102C2: call_init (dl-init.c:36)
==19075==    by 0x40102C2: _dl_init (dl-init.c:126)
==19075==    by 0x4001299: ??? (in /lib/x86_64-linux-gnu/ld-2.19.so)
==19075==    by 0x1: ???
==19075==    by 0xFFF000E22: ???
==19075==    by 0xFFF000E2D: ???
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 926 of 3,576
==19075==    by 0x71F3F86: __static_initialization_and_destruction_0(int, int) (MsProcessor.cpp:36)
==19075==    by 0x71F3FE8: _GLOBAL__sub_I_MsProcessor.cpp (MsProcessor.cpp:1071)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 927 of 3,576
==19075==    by 0x72A77D8: __static_initialization_and_destruction_0(int, int) (QuadHandler.cpp:53)
==19075==    by 0x72A783A: _GLOBAL__sub_I_QuadHandler.cpp (QuadHandler.cpp:1175)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 928 of 3,576
==19075==    by 0x72C9E5C: __static_initialization_and_destruction_0(int, int) (SOS1Handler.cpp:40)
==19075==    by 0x72C9EBE: _GLOBAL__sub_I_SOS1Handler.cpp (SOS1Handler.cpp:402)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 929 of 3,576
==19075==    by 0x72CDE26: __static_initialization_and_destruction_0(int, int) (SOS2Handler.cpp:40)
==19075==    by 0x72CDE88: _GLOBAL__sub_I_SOS2Handler.cpp (SOS2Handler.cpp:528)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 930 of 3,576
==19075==    by 0x72D18F0: __static_initialization_and_destruction_0(int, int) (Transformer.cpp:45)
==19075==    by 0x72D1952: _GLOBAL__sub_I_Transformer.cpp (Transformer.cpp:335)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 931 of 3,576
==19075==    by 0x65B1F66: __static_initialization_and_destruction_0(int, int) (OsiLPEngine.cpp:53)
==19075==    by 0x65B1FC8: _GLOBAL__sub_I_OsiLPEngine.cpp (OsiLPEngine.cpp:705)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 932 of 3,576
==19075==    by 0x57C73B4: __static_initialization_and_destruction_0(int, int) (IpoptEngine.cpp:44)
==19075==    by 0x57C7416: _GLOBAL__sub_I_IpoptEngine.cpp (IpoptEngine.cpp:1126)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 933 of 3,576
==19075==    by 0x4B638E: __static_initialization_and_destruction_0(int, int) (IpoptEngineUT.cpp:19)
==19075==    by 0x4B6412: _GLOBAL__sub_I__ZN13IpoptEngineUT5setUpEv (IpoptEngineUT.cpp:241)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 934 of 3,576
==19075==    by 0x4D8A40: __static_initialization_and_destruction_0(int, int) (TransformerUT.cpp:17)
==19075==    by 0x4D8AC4: _GLOBAL__sub_I__ZN13TransformerUT5setUpEv (TransformerUT.cpp:94)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 935 of 3,576
==19075==    by 0x4B64B3: IpoptEngineUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4B670E: IpoptEngineUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4B7FD6: CppUnit::TestSuiteFactory<IpoptEngineUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 936 of 3,576
==19075==    by 0x4D8B8A: TransformerUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4D902E: TransformerUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4D9700: CppUnit::TestSuiteFactory<TransformerUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 937 of 3,576
==19075==    by 0x7197926: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:77)
==19075==    by 0x7197213: Minotaur::Environment::Environment() (Environment.cpp:36)
==19075==    by 0x4ADB29: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:293)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 938 of 3,576
==19075==    by 0x7197F70: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:98)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 939 of 3,576
==19075==    by 0x7198C04: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:138)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 940 of 3,576
==19075==    by 0x719A02E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:214)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 941 of 3,576
==19075==    by 0x5A34613: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 942 of 3,576
==19075==    by 0x5A794CF: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 943 of 3,576
==19075==    by 0x5A79844: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 944 of 3,576
==19075==    by 0x5A79B77: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 945 of 3,576
==19075==    by 0x5A7A5B2: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 946 of 3,576
==19075==    by 0x5A7A671: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 947 of 3,576
==19075==    by 0x5A7AB24: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 948 of 3,576
==19075==    by 0x5A7AD37: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 949 of 3,576
==19075==    by 0x5A8A4E2: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 950 of 3,576
==19075==    by 0x5A8ACC3: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 951 of 3,576
==19075==    by 0x5AE7395: Ipopt::OptimalityErrorConvergenceCheck::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 952 of 3,576
==19075==    by 0x5AEA7E5: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 953 of 3,576
==19075==    by 0x5AF5C0A: Ipopt::OrigIterationOutput::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82A7D: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 954 of 3,576
==19075==    by 0x5B2D018: Ipopt::WarmStartIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 955 of 3,576
==19075==    by 0x5A6FB6E: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 956 of 3,576
==19075==    by 0x5B319A7: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x4B4A37: CppUnit::TestCaller<NLPBnbUT>::runTest() (TestCaller.h:166)
==19075==    by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 957 of 3,576
==19075==    by 0x5B3870F: Ipopt::Ma27TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 958 of 3,576
==19075==    by 0x5B49478: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 959 of 3,576
==19075==    by 0x5B40BD2: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 960 of 3,576
==19075==    by 0x5B41475: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 961 of 3,576
==19075==    by 0x5B41C68: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x57C26E9: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:300)
==19075==    by 0x507AE4F: Minotaur::EngineFactory::getNLPEngine() (EngineFactory.cpp:119)
==19075==    by 0x4AE092: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:314)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 962 of 3,576
==19075==    by 0x5B4239F: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 963 of 3,576
==19075==    by 0x5B5111B: Ipopt::MumpsSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 964 of 3,576
==19075==    by 0x5B511BC: Ipopt::MumpsSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 965 of 3,576
==19075==    by 0x5B4C159: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 966 of 3,576
==19075==    by 0x5B4C4E7: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 38 bytes in 1 blocks are possibly lost in loss record 967 of 3,576
==19075==    by 0x5B31DA8: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 968 of 3,576
==19075==    by 0x712C464: __static_initialization_and_destruction_0(int, int) (BndProcessor.cpp:31)
==19075==    by 0x712C4C6: _GLOBAL__sub_I_BndProcessor.cpp (BndProcessor.cpp:405)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 969 of 3,576
==19075==    by 0x72498FE: __static_initialization_and_destruction_0(int, int) (ParQGHandler.cpp:52)
==19075==    by 0x7249960: _GLOBAL__sub_I_ParQGHandler.cpp (ParQGHandler.cpp:768)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 970 of 3,576
==19075==    by 0x725BF32: __static_initialization_and_destruction_0(int, int) (PCBProcessor.cpp:35)
==19075==    by 0x725BF94: _GLOBAL__sub_I_PCBProcessor.cpp (PCBProcessor.cpp:543)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 971 of 3,576
==19075==    by 0x7299DAB: __static_initialization_and_destruction_0(int, int) (QPDProcessor.cpp:41)
==19075==    by 0x7299E0D: _GLOBAL__sub_I_QPDProcessor.cpp (QPDProcessor.cpp:2097)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 972 of 3,576
==19075==    by 0x72BC54E: __static_initialization_and_destruction_0(int, int) (SimpleCutMan.cpp:33)
==19075==    by 0x72BC5B0: _GLOBAL__sub_I_SimpleCutMan.cpp (SimpleCutMan.cpp:175)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 973 of 3,576
==19075==    by 0x72C6791: __static_initialization_and_destruction_0(int, int) (SolutionPool.cpp:23)
==19075==    by 0x72C67F3: _GLOBAL__sub_I_SolutionPool.cpp (SolutionPool.cpp:97)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 974 of 3,576
==19075==    by 0x47C935: __static_initialization_and_destruction_0(int, int) (HessianOfLagUT.cpp:16)
==19075==    by 0x47C9B9: _GLOBAL__sub_I__ZN14HessianOfLagUT5setUpEv (HessianOfLagUT.cpp:170)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 975 of 3,576
==19075==    by 0x4C45BC: __static_initialization_and_destruction_0(int, int) (AMPLInstanceUT.cpp:20)
==19075==    by 0x4C4640: _GLOBAL__sub_I__ZN14AMPLInstanceUT5setUpEv (AMPLInstanceUT.cpp:396)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 976 of 3,576
==19075==    by 0x47CB15: HessianOfLagUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x47CFBA: HessianOfLagUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x47D758: CppUnit::TestSuiteFactory<HessianOfLagUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 977 of 3,576
==19075==    by 0x4900B7: OperationsTest::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x49055C: OperationsTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x490B04: CppUnit::TestSuiteFactory<OperationsTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 978 of 3,576
==19075==    by 0x4C4705: AMPLInstanceUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4C4EE6: AMPLInstanceUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4C577A: CppUnit::TestSuiteFactory<AMPLInstanceUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 979 of 3,576
==19075==    by 0x7199C5E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:194)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 980 of 3,576
==19075==    by 0x7199EF1: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:209)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 981 of 3,576
==19075==    by 0x719B047: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:268)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 982 of 3,576
==19075==    by 0x719B570: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:291)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 983 of 3,576
==19075==    by 0x719C6F5: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:358)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 984 of 3,576
==19075==    by 0x719CB24: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:372)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 985 of 3,576
==19075==    by 0x5A34CBB: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A3363C: Ipopt::RegisterOptions_Interfaces(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A357F8: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A39098: Ipopt::IpoptApplication::IpoptApplication(bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 986 of 3,576
==19075==    by 0x5A44BE2: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 987 of 3,576
==19075==    by 0x5A44C0E: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 988 of 3,576
==19075==    by 0x5A7487E: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A35800: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 989 of 3,576
==19075==    by 0x5A748CC: Ipopt::AdaptiveMuUpdate::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 990 of 3,576
==19075==    by 0x5A825CE: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 991 of 3,576
==19075==    by 0x5A79EB1: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 992 of 3,576
==19075==    by 0x5A79F3D: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 993 of 3,576
==19075==    by 0x5A7ADEC: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 994 of 3,576
==19075==    by 0x5A9C480: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 995 of 3,576
==19075==    by 0x5A9C52F: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 996 of 3,576
==19075==    by 0x5A9C9F2: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 997 of 3,576
==19075==    by 0x5A9CEE3: Ipopt::FilterLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 998 of 3,576
==19075==    by 0x5AAC847: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A828F6: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 999 of 3,576
==19075==    by 0x5AAC873: Ipopt::IpoptCalculatedQuantities::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,000 of 3,576
==19075==    by 0x5AE7439: Ipopt::OptimalityErrorConvergenceCheck::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,001 of 3,576
==19075==    by 0x5AEA1CB: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82A2B: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,002 of 3,576
==19075==    by 0x5AEA35D: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,003 of 3,576
==19075==    by 0x5AEA653: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,004 of 3,576
==19075==    by 0x5B0C3B6: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82C04: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,005 of 3,576
==19075==    by 0x5B0C43E: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,006 of 3,576
==19075==    by 0x5B13ADB: Ipopt::RestoConvergenceCheck::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82C56: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,007 of 3,576
==19075==    by 0x5B38403: Ipopt::Ma27TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,008 of 3,576
==19075==    by 0x5B3B150: Ipopt::Ma57TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,009 of 3,576
==19075==    by 0x5B3B208: Ipopt::Ma57TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,010 of 3,576
==19075==    by 0x5B493D0: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,011 of 3,576
==19075==    by 0x5B40BB6: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,012 of 3,576
==19075==    by 0x5B40F4B: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,013 of 3,576
==19075==    by 0x5B4178B: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,014 of 3,576
==19075==    by 0x5B41C4C: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,015 of 3,576
==19075==    by 0x5B41F7E: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 39 bytes in 1 blocks are possibly lost in loss record 1,016 of 3,576
==19075==    by 0x5B4C096: Ipopt::PardisoSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,017 of 3,576
==19075==    by 0x4E59C19: allocate (new_allocator.h:104)
==19075==    by 0x4E59C19: _M_get_node (stl_tree.h:370)
==19075==    by 0x4E59C19: _M_create_node (stl_tree.h:380)
==19075==    by 0x4E59C19: _M_insert_ (stl_tree.h:1023)
==19075==    by 0x4E59C19: _M_insert_unique (stl_tree.h:1382)
==19075==    by 0x4E59C19: insert (stl_set.h:463)
==19075==    by 0x4E59C19: CppUnit::TestFactoryRegistry::registerFactory(CppUnit::TestFactory*) (TestFactoryRegistry.cpp:114)
==19075==    by 0x462A10: CppUnit::AutoRegisterSuite<CGraphUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x461C77: __static_initialization_and_destruction_0(int, int) (CGraphUT.cpp:16)
==19075==    by 0x461D30: _GLOBAL__sub_I__ZN8CGraphUT13testIdenticalEv (CGraphUT.cpp:134)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,018 of 3,576
==19075==    by 0x462AB1: CppUnit::AutoRegisterSuite<CGraphUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x461CBD: __static_initialization_and_destruction_0(int, int) (CGraphUT.cpp:17)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,019 of 3,576
==19075==    by 0x468BAE: CppUnit::AutoRegisterSuite<FunctionTest>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x467E43: __static_initialization_and_destruction_0(int, int) (FunctionUT.cpp:19)
==19075==    by 0x467EFC: _GLOBAL__sub_I__ZN12FunctionTest5setUpEv (FunctionUT.cpp:124)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,020 of 3,576
==19075==    by 0x468C4F: CppUnit::AutoRegisterSuite<FunctionTest>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x467E89: __static_initialization_and_destruction_0(int, int) (FunctionUT.cpp:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,021 of 3,576
==19075==    by 0x46F4C8: CppUnit::AutoRegisterSuite<ProblemTest>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x46E69C: __static_initialization_and_destruction_0(int, int) (ProblemUT.cpp:19)
==19075==    by 0x46E755: _GLOBAL__sub_I__ZN11ProblemTest5setUpEv (ProblemUT.cpp:147)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,022 of 3,576
==19075==    by 0x46F569: CppUnit::AutoRegisterSuite<ProblemTest>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x46E6E2: __static_initialization_and_destruction_0(int, int) (ProblemUT.cpp:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,023 of 3,576
==19075==    by 0x4770EC: CppUnit::AutoRegisterSuite<JacobianUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x47679C: __static_initialization_and_destruction_0(int, int) (JacobianUT.cpp:14)
==19075==    by 0x476855: _GLOBAL__sub_I__ZN10JacobianUT5setUpEv (JacobianUT.cpp:179)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,024 of 3,576
==19075==    by 0x47718D: CppUnit::AutoRegisterSuite<JacobianUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4767E2: __static_initialization_and_destruction_0(int, int) (JacobianUT.cpp:15)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,025 of 3,576
==19075==    by 0x47D2D4: CppUnit::AutoRegisterSuite<HessianOfLagUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x47C900: __static_initialization_and_destruction_0(int, int) (HessianOfLagUT.cpp:15)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,026 of 3,576
==19075==    by 0x47D375: CppUnit::AutoRegisterSuite<HessianOfLagUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x47C946: __static_initialization_and_destruction_0(int, int) (HessianOfLagUT.cpp:16)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,027 of 3,576
==19075==    by 0x480946: CppUnit::AutoRegisterSuite<LapackTest>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x48005E: __static_initialization_and_destruction_0(int, int) (LapackUT.cpp:12)
==19075==    by 0x480117: _GLOBAL__sub_I_foobar_ (LapackUT.cpp:206)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,028 of 3,576
==19075==    by 0x4809E7: CppUnit::AutoRegisterSuite<LapackTest>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4800A4: __static_initialization_and_destruction_0(int, int) (LapackUT.cpp:13)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,029 of 3,576
==19075==    by 0x48A14A: CppUnit::AutoRegisterSuite<LinearFunctionTest>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4896F1: __static_initialization_and_destruction_0(int, int) (LinearFunctionUT.cpp:20)
==19075==    by 0x4897AA: _GLOBAL__sub_I__ZN18LinearFunctionTest5setUpEv (LinearFunctionUT.cpp:246)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,030 of 3,576
==19075==    by 0x48A1EB: CppUnit::AutoRegisterSuite<LinearFunctionTest>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x489737: __static_initialization_and_destruction_0(int, int) (LinearFunctionUT.cpp:21)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,031 of 3,576
==19075==    by 0x48B55C: CppUnit::AutoRegisterSuite<LoggerUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x48AD2D: __static_initialization_and_destruction_0(int, int) (LoggerUT.cpp:12)
==19075==    by 0x48ADE6: _GLOBAL__sub_I__ZN8LoggerUT13testMsgStreamEv (LoggerUT.cpp:39)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,032 of 3,576
==19075==    by 0x48B5FD: CppUnit::AutoRegisterSuite<LoggerUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x48AD73: __static_initialization_and_destruction_0(int, int) (LoggerUT.cpp:13)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,033 of 3,576
==19075==    by 0x48D512: CppUnit::AutoRegisterSuite<ObjectiveUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x48CB55: __static_initialization_and_destruction_0(int, int) (ObjectiveUT.cpp:15)
==19075==    by 0x48CC0E: _GLOBAL__sub_I__ZN11ObjectiveUT5setUpEv (ObjectiveUT.cpp:62)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,034 of 3,576
==19075==    by 0x48D5B3: CppUnit::AutoRegisterSuite<ObjectiveUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x48CB9B: __static_initialization_and_destruction_0(int, int) (ObjectiveUT.cpp:16)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,035 of 3,576
==19075==    by 0x49086A: CppUnit::AutoRegisterSuite<OperationsTest>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x48FF63: __static_initialization_and_destruction_0(int, int) (OperationsUT.cpp:14)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,036 of 3,576
==19075==    by 0x49090B: CppUnit::AutoRegisterSuite<OperationsTest>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x48FFA9: __static_initialization_and_destruction_0(int, int) (OperationsUT.cpp:15)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,037 of 3,576
==19075==    by 0x4947F2: CppUnit::AutoRegisterSuite<PerspRefUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x493FA9: __static_initialization_and_destruction_0(int, int) (PerspRefUT.cpp:17)
==19075==    by 0x494062: _GLOBAL__sub_I__ZN10PerspRefUT9iterativeEv (PerspRefUT.cpp:170)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,038 of 3,576
==19075==    by 0x494893: CppUnit::AutoRegisterSuite<PerspRefUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x493FEF: __static_initialization_and_destruction_0(int, int) (PerspRefUT.cpp:18)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,039 of 3,576
==19075==    by 0x49A586: CppUnit::AutoRegisterSuite<PolyUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x499D35: __static_initialization_and_destruction_0(int, int) (PolyUT.cpp:16)
==19075==    by 0x499DEE: _GLOBAL__sub_I__ZN6PolyUT8monomialEv (PolyUT.cpp:144)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,040 of 3,576
==19075==    by 0x49A627: CppUnit::AutoRegisterSuite<PolyUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x499D7B: __static_initialization_and_destruction_0(int, int) (PolyUT.cpp:17)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,041 of 3,576
==19075==    by 0x4A8F6E: CppUnit::AutoRegisterSuite<QuadraticFunctionTest>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4A8339: __static_initialization_and_destruction_0(int, int) (QuadraticFunctionUT.cpp:15)
==19075==    by 0x4A83F2: _GLOBAL__sub_I__ZN21QuadraticFunctionTest5setUpEv (QuadraticFunctionUT.cpp:211)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,042 of 3,576
==19075==    by 0x4A900F: CppUnit::AutoRegisterSuite<QuadraticFunctionTest>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4A837F: __static_initialization_and_destruction_0(int, int) (QuadraticFunctionUT.cpp:16)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,043 of 3,576
==19075==    by 0x4ABFFA: CppUnit::AutoRegisterSuite<TimerUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4AB5C5: __static_initialization_and_destruction_0(int, int) (TimerUT.cpp:12)
==19075==    by 0x4AB67E: _GLOBAL__sub_I__ZN7TimerUT5setUpEv (TimerUT.cpp:52)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,044 of 3,576
==19075==    by 0x4AC09B: CppUnit::AutoRegisterSuite<TimerUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4AB60B: __static_initialization_and_destruction_0(int, int) (TimerUT.cpp:13)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,045 of 3,576
==19075==    by 0x4B0234: CppUnit::AutoRegisterSuite<NLPBnbUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4AF1FE: __static_initialization_and_destruction_0(int, int) (NLPBnbUT.cpp:25)
==19075==    by 0x4AF2B7: _GLOBAL__sub_I__ZN8NLPBnbUT15createInstance_Ev (NLPBnbUT.cpp:462)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,046 of 3,576
==19075==    by 0x4B02D5: CppUnit::AutoRegisterSuite<NLPBnbUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4AF244: __static_initialization_and_destruction_0(int, int) (NLPBnbUT.cpp:26)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,047 of 3,576
==19075==    by 0x4B6C8C: CppUnit::AutoRegisterSuite<IpoptEngineUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4B6359: __static_initialization_and_destruction_0(int, int) (IpoptEngineUT.cpp:18)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,048 of 3,576
==19075==    by 0x4B6D2D: CppUnit::AutoRegisterSuite<IpoptEngineUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4B639F: __static_initialization_and_destruction_0(int, int) (IpoptEngineUT.cpp:19)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,049 of 3,576
==19075==    by 0x4C5212: CppUnit::AutoRegisterSuite<AMPLInstanceUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4C4587: __static_initialization_and_destruction_0(int, int) (AMPLInstanceUT.cpp:19)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,050 of 3,576
==19075==    by 0x4C52B3: CppUnit::AutoRegisterSuite<AMPLInstanceUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4C45CD: __static_initialization_and_destruction_0(int, int) (AMPLInstanceUT.cpp:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,051 of 3,576
==19075==    by 0x4D63E4: CppUnit::AutoRegisterSuite<AMPLCGraphUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4D542D: __static_initialization_and_destruction_0(int, int) (AMPLCGraphUT.cpp:21)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,052 of 3,576
==19075==    by 0x4D6485: CppUnit::AutoRegisterSuite<AMPLCGraphUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4D5473: __static_initialization_and_destruction_0(int, int) (AMPLCGraphUT.cpp:22)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,053 of 3,576
==19075==    by 0x4D7752: CppUnit::AutoRegisterSuite<PolySolverUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4D70A1: __static_initialization_and_destruction_0(int, int) (PolySolverUT.cpp:13)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,054 of 3,576
==19075==    by 0x4D77F3: CppUnit::AutoRegisterSuite<PolySolverUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4D70E7: __static_initialization_and_destruction_0(int, int) (PolySolverUT.cpp:14)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,055 of 3,576
==19075==    by 0x4D9372: CppUnit::AutoRegisterSuite<TransformerUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4D8A0B: __static_initialization_and_destruction_0(int, int) (TransformerUT.cpp:16)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,056 of 3,576
==19075==    by 0x4D9413: CppUnit::AutoRegisterSuite<TransformerUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4D8A51: __static_initialization_and_destruction_0(int, int) (TransformerUT.cpp:17)
==19075==    by 0x56952C: __libc_csu_init (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x7D09ED4: (below main) (libc-start.c:246)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,057 of 3,576
==19075==    by 0x4DAC20: CppUnit::AutoRegisterSuite<AMPLBqpdUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4DA546: __static_initialization_and_destruction_0(int, int) (AMPLBqpdUT.cpp:16)
==19075==    by 0x4DA5FF: _GLOBAL__sub_I__ZN10AMPLBqpdUT7testNLPEv (AMPLBqpdUT.cpp:69)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,058 of 3,576
==19075==    by 0x4DACC1: CppUnit::AutoRegisterSuite<AMPLBqpdUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4DA58C: __static_initialization_and_destruction_0(int, int) (AMPLBqpdUT.cpp:17)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,059 of 3,576
==19075==    by 0x4DD13A: CppUnit::AutoRegisterSuite<AMPLFilterSQPUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4DC961: __static_initialization_and_destruction_0(int, int) (AMPLFilterSQPUT.cpp:16)
==19075==    by 0x4DCA1A: _GLOBAL__sub_I__ZN15AMPLFilterSQPUT7testNLPEv (AMPLFilterSQPUT.cpp:89)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,060 of 3,576
==19075==    by 0x4DD1DB: CppUnit::AutoRegisterSuite<AMPLFilterSQPUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4DC9A7: __static_initialization_and_destruction_0(int, int) (AMPLFilterSQPUT.cpp:17)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,061 of 3,576
==19075==    by 0x4DE9D2: CppUnit::AutoRegisterSuite<AMPLIpoptUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4DE333: __static_initialization_and_destruction_0(int, int) (AMPLIpoptUT.cpp:18)
==19075==    by 0x4DE3EC: _GLOBAL__sub_I__ZN11AMPLIpoptUT7testNLPEv (AMPLIpoptUT.cpp:69)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,062 of 3,576
==19075==    by 0x4DEA73: CppUnit::AutoRegisterSuite<AMPLIpoptUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4DE379: __static_initialization_and_destruction_0(int, int) (AMPLIpoptUT.cpp:19)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,063 of 3,576
==19075==    by 0x4E39B4: CppUnit::AutoRegisterSuite<AMPLOsiUT>::AutoRegisterSuite() (AutoRegisterSuite.h:36)
==19075==    by 0x4E2EAE: __static_initialization_and_destruction_0(int, int) (AMPLOsiUT.cpp:22)
==19075==    by 0x4E2F67: _GLOBAL__sub_I__ZN9AMPLOsiUT5setUpEv (AMPLOsiUT.cpp:157)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,064 of 3,576
==19075==    by 0x4E3A55: CppUnit::AutoRegisterSuite<AMPLOsiUT>::AutoRegisterSuite(std::string const&) (AutoRegisterSuite.h:45)
==19075==    by 0x4E2EF4: __static_initialization_and_destruction_0(int, int) (AMPLOsiUT.cpp:23)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,065 of 3,576
==19075==    by 0x4E60F9B: CppUnit::TestRunner::TestRunner() (TestRunner.cpp:71)
==19075==    by 0x4E62DCE: CppUnit::TextTestRunner::TextTestRunner(CppUnit::Outputter*) (TextTestRunner.cpp:23)
==19075==    by 0x45DC93: main (unittest.cpp:31)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,066 of 3,576
==19075==    by 0x45DCC8: main (unittest.cpp:32)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,067 of 3,576
==19075==    by 0x4E59CD5: CppUnit::TestFactoryRegistry::makeTest() (TestFactoryRegistry.cpp:135)
==19075==    by 0x45DE5D: main (unittest.cpp:42)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,068 of 3,576
==19075==    by 0x4625C8: CGraphUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x463952: CppUnit::TestSuiteFactory<CGraphUT>::makeTest() (TestSuiteFactory.h:20)
==19075==    by 0x4E59C81: CppUnit::TestFactoryRegistry::addTestToSuite(CppUnit::TestSuite*) (TestFactoryRegistry.cpp:149)
==19075==    by 0x4E59D00: CppUnit::TestFactoryRegistry::makeTest() (TestFactoryRegistry.cpp:136)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,069 of 3,576
==19075==    by 0x46869A: FunctionTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x46A66A: CppUnit::TestSuiteFactory<FunctionTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,070 of 3,576
==19075==    by 0x46F184: ProblemTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x46FB20: CppUnit::TestSuiteFactory<ProblemTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,071 of 3,576
==19075==    by 0x46FB3C: CppUnit::ConcretTestFixtureFactory<ProblemTest>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x46F33D: CppUnit::TestSuiteBuilderContext<ProblemTest>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x46E91A: ProblemTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (ProblemUT.h:40)
==19075==    by 0x46F1D2: ProblemTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,072 of 3,576
==19075==    by 0x46E9DA: ProblemTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (ProblemUT.h:41)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,073 of 3,576
==19075==    by 0x46EAA9: ProblemTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (ProblemUT.h:43)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,074 of 3,576
==19075==    by 0x46EB78: ProblemTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (ProblemUT.h:44)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,075 of 3,576
==19075==    by 0x46EC47: ProblemTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (ProblemUT.h:45)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,076 of 3,576
==19075==    by 0x46ED16: ProblemTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (ProblemUT.h:46)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,077 of 3,576
==19075==    by 0x46EDE5: ProblemTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (ProblemUT.h:47)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,078 of 3,576
==19075==    by 0x476D64: JacobianUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x477910: CppUnit::TestSuiteFactory<JacobianUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,079 of 3,576
==19075==    by 0x47CFF6: HessianOfLagUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,080 of 3,576
==19075==    by 0x480686: LapackTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x480B5C: CppUnit::TestSuiteFactory<LapackTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,081 of 3,576
==19075==    by 0x489E6C: LinearFunctionTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x48A7FE: CppUnit::TestSuiteFactory<LinearFunctionTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,082 of 3,576
==19075==    by 0x48A81A: CppUnit::ConcretTestFixtureFactory<LinearFunctionTest>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x489FBF: CppUnit::TestSuiteBuilderContext<LinearFunctionTest>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x489930: LinearFunctionTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LinearFunctionUT.h:33)
==19075==    by 0x489EBA: LinearFunctionTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,083 of 3,576
==19075==    by 0x489A12: LinearFunctionTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LinearFunctionUT.h:34)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,084 of 3,576
==19075==    by 0x489AF4: LinearFunctionTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LinearFunctionUT.h:35)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,085 of 3,576
==19075==    by 0x489BBD: LinearFunctionTest::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (LinearFunctionUT.h:36)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,086 of 3,576
==19075==    by 0x48B252: LoggerUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x48BA56: CppUnit::TestSuiteFactory<LoggerUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,087 of 3,576
==19075==    by 0x48D10E: ObjectiveUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x48DD96: CppUnit::TestSuiteFactory<ObjectiveUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,088 of 3,576
==19075==    by 0x490598: OperationsTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,089 of 3,576
==19075==    by 0x4944B6: PerspRefUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x494BA4: CppUnit::TestSuiteFactory<PerspRefUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,090 of 3,576
==19075==    by 0x49A230: PolyUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x49AE70: CppUnit::TestSuiteFactory<PolyUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,091 of 3,576
==19075==    by 0x4A8BE0: QuadraticFunctionTest::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4AA910: CppUnit::TestSuiteFactory<QuadraticFunctionTest>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,092 of 3,576
==19075==    by 0x4ABD3A: TimerUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4AC210: CppUnit::TestSuiteFactory<TimerUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,093 of 3,576
==19075==    by 0x4AF816: NLPBnbUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4B48A2: CppUnit::TestSuiteFactory<NLPBnbUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,094 of 3,576
==19075==    by 0x4B674A: IpoptEngineUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,095 of 3,576
==19075==    by 0x4B7FF2: CppUnit::ConcretTestFixtureFactory<IpoptEngineUT>::makeFixture() (TestFixtureFactory.h:41)
==19075==    by 0x4B6B01: CppUnit::TestSuiteBuilderContext<IpoptEngineUT>::makeFixture() const (TestSuiteBuilderContext.h:118)
==19075==    by 0x4B657F: IpoptEngineUT::addTestsToSuite(CppUnit::TestSuiteBuilderContextBase&) (IpoptEngineUT.h:33)
==19075==    by 0x4B6798: IpoptEngineUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,096 of 3,576
==19075==    by 0x4C4F22: AMPLInstanceUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,097 of 3,576
==19075==    by 0x4D60F6: AMPLCGraphUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4D662C: CppUnit::TestSuiteFactory<AMPLCGraphUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,098 of 3,576
==19075==    by 0x4D7492: PolySolverUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4D799A: CppUnit::TestSuiteFactory<PolySolverUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,099 of 3,576
==19075==    by 0x4D906A: TransformerUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,100 of 3,576
==19075==    by 0x4DA924: AMPLBqpdUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DB390: CppUnit::TestSuiteFactory<AMPLBqpdUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,101 of 3,576
==19075==    by 0x4DCE5C: AMPLFilterSQPUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DD5D4: CppUnit::TestSuiteFactory<AMPLFilterSQPUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,102 of 3,576
==19075==    by 0x4DE712: AMPLIpoptUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DEBE8: CppUnit::TestSuiteFactory<AMPLIpoptUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,103 of 3,576
==19075==    by 0x4E3652: AMPLOsiUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4E406C: CppUnit::TestSuiteFactory<AMPLOsiUT>::makeTest() (TestSuiteFactory.h:20)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,104 of 3,576
==19075==    by 0x719B3F1: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:285)
==19075==    by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==19075==    by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==19075==    by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==19075==    by 0x4E59952: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==19075==    by 0x4E5986D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,105 of 3,576
==19075==    by 0x719B541: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:289)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,106 of 3,576
==19075==    by 0x719B691: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:294)
==19075==    by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,107 of 3,576
==19075==    at 0x4C2B0E0: operator new(unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==19075==    by 0x719B7E1: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:299)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,108 of 3,576
==19075==    by 0x719B931: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:303)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,109 of 3,576
==19075==    by 0x719BA81: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:308)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,110 of 3,576
==19075==    by 0x719BBD1: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:313)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,111 of 3,576
==19075==    by 0x719BD21: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:318)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,112 of 3,576
==19075==    by 0x719BE71: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:323)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,113 of 3,576
==19075==    by 0x719BFC1: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:329)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,114 of 3,576
==19075==    by 0x719C111: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:334)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,115 of 3,576
==19075==    by 0x719C261: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:339)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,116 of 3,576
==19075==    by 0x719C3D8: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:347)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,117 of 3,576
==19075==    by 0x719C55A: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:352)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,118 of 3,576
==19075==    by 0x719C6DC: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:356)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,119 of 3,576
==19075==    by 0x719C85E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:361)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,120 of 3,576
==19075==    by 0x719C9E0: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:366)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,121 of 3,576
==19075==    by 0x719CB62: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:372)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,122 of 3,576
==19075==    by 0x719CCE4: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:377)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,123 of 3,576
==19075==    by 0x719CE66: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:382)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,124 of 3,576
==19075==    by 0x719CFE8: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:387)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,125 of 3,576
==19075==    by 0x719D16A: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:392)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,126 of 3,576
==19075==    by 0x719D2DA: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:396)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,127 of 3,576
==19075==    by 0x719D44A: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:400)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,128 of 3,576
==19075==    by 0x72DC35E: Minotaur::TreeManager::TreeManager(boost::shared_ptr<Minotaur::Environment>) (TreeManager.cpp:55)
==19075==    by 0x7130306: Minotaur::BranchAndBound::BranchAndBound(boost::shared_ptr<Minotaur::Environment>, boost::shared_ptr<Minotaur::Problem>) (BranchAndBound.cpp:68)
==19075==    by 0x4ADE17: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:304)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,129 of 3,576
==19075==    by 0x5A38FDD: Ipopt::IpoptApplication::IpoptApplication(bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are still reachable in loss record 1,130 of 3,576
==19075==    by 0x57C282B: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:313)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,131 of 3,576
==19075==    by 0x7888248: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7889970: char* std::string::_S_construct<char const*>(char const*, char const*, std::allocator<char> const&, std::forward_iterator_tag) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7889D87: std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x717FD54: __static_initialization_and_destruction_0(int, int) (CxQuadHandler.cpp:52)
==19075==    by 0x717FDB6: _GLOBAL__sub_I_CxQuadHandler.cpp (CxQuadHandler.cpp:1204)
==19075==    by 0x40101D9: call_init.part.0 (dl-init.c:78)
==19075==    by 0x40102C2: call_init (dl-init.c:36)
==19075==    by 0x40102C2: _dl_init (dl-init.c:126)
==19075==    by 0x4001299: ??? (in /lib/x86_64-linux-gnu/ld-2.19.so)
==19075==    by 0x1: ???
==19075==    by 0xFFF000E22: ???
==19075==    by 0xFFF000E2D: ???
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,132 of 3,576
==19075==    by 0x71AF5FE: __static_initialization_and_destruction_0(int, int) (IntVarHandler.cpp:34)
==19075==    by 0x71AF660: _GLOBAL__sub_I_IntVarHandler.cpp (IntVarHandler.cpp:243)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,133 of 3,576
==19075==    by 0x71DA484: __static_initialization_and_destruction_0(int, int) (LinearHandler.cpp:46)
==19075==    by 0x71DA4E6: _GLOBAL__sub_I_LinearHandler.cpp (LinearHandler.cpp:1635)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,134 of 3,576
==19075==    by 0x721434E: __static_initialization_and_destruction_0(int, int) (NlPresHandler.cpp:41)
==19075==    by 0x72143B0: _GLOBAL__sub_I_NlPresHandler.cpp (NlPresHandler.cpp:974)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,135 of 3,576
==19075==    by 0x6D3F2CD: __static_initialization_and_destruction_0(int, int) (AMPLInterface.cpp:45)
==19075==    by 0x6D3F32F: _GLOBAL__sub_I_AMPLInterface.cpp (AMPLInterface.cpp:2577)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,136 of 3,576
==19075==    by 0x4DC996: __static_initialization_and_destruction_0(int, int) (AMPLFilterSQPUT.cpp:17)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,137 of 3,576
==19075==    by 0x4E6300F: CppUnit::TypeInfoHelper::getClassName(std::type_info const&) (TypeInfoHelper.cpp:33)
==19075==    by 0x4E5AA44: CppUnit::TestNamer::TestNamer(std::type_info const&) (TestNamer.cpp:12)
==19075==    by 0x4DCAAA: AMPLFilterSQPUT::getTestNamer__() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==    by 0x4DCE20: AMPLFilterSQPUT::suite() (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,138 of 3,576
==19075==    by 0x48BD74: ObjectiveUT::setUp() (ObjectiveUT.cpp:24)
==19075==    by 0x48DF58: CppUnit::TestCaller<ObjectiveUT>::setUp() (TestCaller.h:177)
==19075==    by 0x4E59286: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:87)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,139 of 3,576
==19075==    by 0x78883D5: std::string::_M_mutate(unsigned long, unsigned long, unsigned long) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7888545: std::string::_M_leak_hard() (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x788860A: std::string::operator[](unsigned long) (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==19075==    by 0x7225600: Minotaur::toLowerCase(std::string&) (Operations.cpp:374)
==19075==    by 0x7226E0B: Minotaur::Option<bool>::Option(std::string const&, std::string const&, bool, bool) (Option.cpp:32)
==19075==    by 0x719741E: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:57)
==19075==    by 0x7197213: Minotaur::Environment::Environment() (Environment.cpp:36)
==19075==    by 0x4ADB29: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:293)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,140 of 3,576
==19075==    by 0x7197560: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:62)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,141 of 3,576
==19075==    by 0x71980B2: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:102)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,142 of 3,576
==19075==    by 0x7199390: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:164)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,143 of 3,576
==19075==    by 0x71999DA: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:186)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,144 of 3,576
==19075==    by 0x72269E4: Minotaur::Option<int>::Option(std::string const&, std::string const&, bool, int) (Option.cpp:32)
==19075==    by 0x719AF0A: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:264)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,145 of 3,576
==19075==    by 0x7227239: Minotaur::Option<double>::Option(std::string const&, std::string const&, bool, double) (Option.cpp:32)
==19075==    by 0x719C27B: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:341)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,146 of 3,576
==19075==    by 0x5A44B9D: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A336AD: Ipopt::RegisterOptions_Interfaces(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,147 of 3,576
==19075==    by 0x5A453FC: Ipopt::TNLPAdapter::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,148 of 3,576
==19075==    by 0x5A7A6A9: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8264D: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x4B4A37: CppUnit::TestCaller<NLPBnbUT>::runTest() (TestCaller.h:166)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,149 of 3,576
==19075==    by 0x5A8A536: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A8269F: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,150 of 3,576
==19075==    by 0x5A8A5FF: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,151 of 3,576
==19075==    by 0x5A8ABF4: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,152 of 3,576
==19075==    by 0x5A8AD92: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x57C26E9: Minotaur::IpoptEngine::IpoptEngine(boost::shared_ptr<Minotaur::Environment>) (IpoptEngine.cpp:300)
==19075==    by 0x507AE4F: Minotaur::EngineFactory::getNLPEngine() (EngineFactory.cpp:119)
==19075==    by 0x4AE092: NLPBnbUT::testNLPBnb1() (NLPBnbUT.cpp:314)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,153 of 3,576
==19075==    by 0x5AE72F1: Ipopt::OptimalityErrorConvergenceCheck::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A829D9: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,154 of 3,576
==19075==    by 0x5AE74DD: Ipopt::OptimalityErrorConvergenceCheck::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,155 of 3,576
==19075==    by 0x5B16399: Ipopt::RestoIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82CFA: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,156 of 3,576
==19075==    by 0x5B3B4F8: Ipopt::Ma57TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31ACE: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,157 of 3,576
==19075==    by 0x5B40EAF: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31C21: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,158 of 3,576
==19075==    by 0x5B41459: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,159 of 3,576
==19075==    by 0x5B4171B: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,160 of 3,576
==19075==    by 0x5B41F0E: Ipopt::Ma97SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 40 bytes in 1 blocks are possibly lost in loss record 1,161 of 3,576
==19075==    by 0x5B50E8C: Ipopt::MumpsSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31C92: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,162 of 3,576
==19075==    by 0x71C2D68: __static_initialization_and_destruction_0(int, int) (LexicoBrancher.cpp:33)
==19075==    by 0x71C2DCA: _GLOBAL__sub_I_LexicoBrancher.cpp (LexicoBrancher.cpp:157)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,163 of 3,576
==19075==    by 0x72B30CE: __static_initialization_and_destruction_0(int, int) (RandomBrancher.cpp:33)
==19075==    by 0x72B3130: _GLOBAL__sub_I_RandomBrancher.cpp (RandomBrancher.cpp:163)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,164 of 3,576
==19075==    by 0x489726: __static_initialization_and_destruction_0(int, int) (LinearFunctionUT.cpp:21)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,165 of 3,576
==19075==    by 0x7199898: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:182)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,166 of 3,576
==19075==    by 0x719A8D9: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:243)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,167 of 3,576
==19075==    by 0x719B6C0: Minotaur::Environment::createDefaultOptions_() (Environment.cpp:296)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,168 of 3,576
==19075==    by 0x5A34575: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,169 of 3,576
==19075==    by 0x5A34800: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,170 of 3,576
==19075==    by 0x5A34B5C: Ipopt::IpoptApplication::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,171 of 3,576
==19075==    by 0x5A920C1: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A825FB: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,172 of 3,576
==19075==    by 0x5A92168: Ipopt::DefaultIterateInitializer::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,173 of 3,576
==19075==    by 0x5A795CE: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A39098: Ipopt::IpoptApplication::IpoptApplication(bool, bool) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,174 of 3,576
==19075==    by 0x5A7A360: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,175 of 3,576
==19075==    by 0x5A7A3E7: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,176 of 3,576
==19075==    by 0x5A7A5E5: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A35800: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,177 of 3,576
==19075==    by 0x5A7A8F9: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,178 of 3,576
==19075==    by 0x5A7A915: Ipopt::AlgorithmBuilder::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,179 of 3,576
==19075==    by 0x5A89DEE: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,180 of 3,576
==19075==    by 0x5A89F24: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,181 of 3,576
==19075==    by 0x5A8B423: Ipopt::BacktrackingLineSearch::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,182 of 3,576
==19075==    by 0x5AA4BB3: Ipopt::IpoptAlgorithm::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82865: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,183 of 3,576
==19075==    by 0x5AEA4EF: Ipopt::OrigIpoptNLP::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,184 of 3,576
==19075==    by 0x5B03D8F: Ipopt::PDSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82AC4: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,185 of 3,576
==19075==    by 0x5A82AE1: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,186 of 3,576
==19075==    by 0x5A82B33: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,187 of 3,576
==19075==    by 0x5B01CB9: Ipopt::PDPerturbationHandler::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A82B60: Ipopt::RegisterOptions_Algorithm(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,188 of 3,576
==19075==    by 0x5B01D6B: Ipopt::PDPerturbationHandler::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,189 of 3,576
==19075==    by 0x5B0C65F: Ipopt::QualityFunctionMuOracle::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,190 of 3,576
==19075==    by 0x5A6F5FC: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A6D312: Ipopt::RegisterOptions_CGPenalty(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A35808: Ipopt::IpoptApplication::RegisterAllIpoptOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,191 of 3,576
==19075==    by 0x5A6F6AC: Ipopt::CGSearchDirCalculator::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,192 of 3,576
==19075==    by 0x5A68344: Ipopt::CGPenaltyLSAcceptor::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5A6D34B: Ipopt::RegisterOptions_CGPenalty(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,193 of 3,576
==19075==    by 0x5B3B2B3: Ipopt::Ma57TSolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,194 of 3,576
==19075==    by 0x5B491DC: Ipopt::Ma77SolverInterface::RegisterOptions(Ipopt::SmartPtr<Ipopt::RegisteredOptions>) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==    by 0x5B31B3F: Ipopt::RegisterOptions_LinearSolvers(Ipopt::SmartPtr<Ipopt::RegisteredOptions> const&) (in /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/lib/libipopt.so.1.10.7)
==19075==
==19075== 41 bytes in 1 blocks are possibly lost in loss record 1,195 of 3,576
