[Minotaur-dev] [minotaur-solver/minotaur] 581c38: Another scheme for root linearization
Meenarli Sharma noreply at github.com
Tue Jun 18 06:08:39 CDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/minotaur-solver/minotaur
  Commit: 581c383cdc29d88dd309c4e901c7ee10d4619830
      https://github.com/minotaur-solver/minotaur/commit/581c383cdc29d88dd309c4e901c7ee10d4619830
  Author: meenarli <kukku.meenarli at gmail.com>
  Date:   2019-06-18 (Tue, 18 Jun 2019)
  Changed paths:
    M src/base/QGHandler.cpp
    M src/base/QGHandler.h
  Log Message:
  Commit: b2d1c2e5ccca4a1ff1e0c9741b568fc3f464aa44
      https://github.com/minotaur-solver/minotaur/commit/b2d1c2e5ccca4a1ff1e0c9741b568fc3f464aa44
  Changed paths:
    M src/algorithms/LSTOA.cpp
    M src/algorithms/OA.cpp
    M src/base/ActiveNodeStore.h
    M src/base/BndProcessor.h
    M src/base/BrCand.h
    M src/base/BrVarCand.cpp
    M src/base/Branch.h
    M src/base/BranchAndBound.cpp
    M src/base/BranchAndBound.h
    M src/base/Brancher.h
    M src/base/CGraph.h
    M src/base/ConBoundMod.h
    M src/base/Constraint.cpp
    M src/base/Constraint.h
    M src/base/Cut.cpp
    M src/base/Cut.h
    M src/base/CutInfo.h
    M src/base/CutMan2.cpp
    M src/base/CutMan2.h
    M src/base/CutManager.h
    M src/base/CutPool.h
    M src/base/CxQuadHandler.cpp
    M src/base/CxQuadHandler.h
    M src/base/CxUnivarHandler.h
    M src/base/Eigen.cpp
    M src/base/Eigen.h
    M src/base/Engine.h
    M src/base/FeasibilityPump.h
    M src/base/Function.cpp
    M src/base/Function.h
    M src/base/Gradient.h
    M src/base/Handler.h
    M src/base/HessianOfLag.h
    M src/base/Heuristic.h
    M src/base/IntVarHandler.h
    M src/base/KnapCovHandler.h
    M src/base/LGCIGenerator.h
    M src/base/LPRelaxation.h
    M src/base/LexicoBrancher.h
    M src/base/LinConMod.cpp
    M src/base/LinConMod.h
    M src/base/LinFeasPump.cpp
    M src/base/LinFeasPump.h
    M src/base/LinMods.h
    M src/base/LinearCut.h
    M src/base/LinearFunction.cpp
    M src/base/LinearFunction.h
    M src/base/LinearHandler.cpp
    M src/base/LinearHandler.h
    M src/base/MINLPDiving.h
    M src/base/MaxFreqBrancher.h
    M src/base/MaxVioBrancher.h
    M src/base/Modification.h
    M src/base/MsProcessor.h
    M src/base/MultilinearHandler.h
    M src/base/MultilinearTermsHandler.h
    M src/base/NLPMultiStart.h
    M src/base/NLPRelaxation.h
    M src/base/NlPresHandler.cpp
    M src/base/NlPresHandler.h
    M src/base/NlWriter.h
    M src/base/Node.cpp
    M src/base/Node.h
    M src/base/NodeFullRelaxer.cpp
    M src/base/NodeHeap.h
    M src/base/NodeIncRelaxer.cpp
    M src/base/NodeIncRelaxer.h
    M src/base/NodeProcessor.h
    M src/base/NodeRelaxer.h
    M src/base/NodeStack.h
    M src/base/NonlinearFunction.h
    M src/base/OAHandler.cpp
    M src/base/OAHandler.h
    M src/base/Objective.h
    M src/base/Option.h
    M src/base/PCBProcessor.h
    M src/base/ParBndProcessor.h
    M src/base/ParBranchAndBound.h
    M src/base/ParMINLPDiving.h
    M src/base/ParNodeIncRelaxer.cpp
    M src/base/ParNodeIncRelaxer.h
    M src/base/ParPCBProcessor.cpp
    M src/base/ParPCBProcessor.h
    M src/base/ParQGBranchAndBound.cpp
    M src/base/ParQGBranchAndBound.h
    M src/base/ParQGHandler.cpp
    M src/base/ParQGHandler.h
    M src/base/ParReliabilityBrancher.h
    M src/base/ParTreeManager.cpp
    M src/base/ParTreeManager.h
    M src/base/PerspCutGenerator.h
    M src/base/PerspCutHandler.h
    M src/base/PolynomialFunction.cpp
    M src/base/PolynomialFunction.h
    M src/base/PreAuxVars.h
    M src/base/PreDelVars.h
    M src/base/PreSubstVars.h
    M src/base/Presolver.cpp
    M src/base/Presolver.h
    M src/base/Problem.h
    M src/base/ProblemSize.h
    M src/base/QGAdvHandler.h
    M src/base/QPDProcessor.cpp
    M src/base/QPDProcessor.h
    M src/base/QPDRelaxer.cpp
    M src/base/QPDRelaxer.h
    M src/base/QuadHandler.h
    M src/base/QuadraticFunction.cpp
    M src/base/QuadraticFunction.h
    M src/base/RCHandler.h
    M src/base/RandomBrancher.h
    M src/base/Relaxation.h
    M src/base/ReliabilityBrancher.h
    M src/base/SOS1Handler.cpp
    M src/base/SOS1Handler.h
    M src/base/SOS2Handler.h
    M src/base/STOAHandler.cpp
    M src/base/STOAHandler.h
    M src/base/SecantMod.cpp
    M src/base/SecantMod.h
    M src/base/SimpleTransformer.cpp
    M src/base/SimpleTransformer.h
    M src/base/Solution.h
    M src/base/SolutionPool.h
    M src/base/TransPoly.cpp
    M src/base/TransPoly.h
    M src/base/TransSep.h
    M src/base/Transformer.cpp
    M src/base/Transformer.h
    M src/base/TreeManager.cpp
    M src/base/TreeManager.h
    M src/base/Types.h
    M src/base/UnambRelBrancher.h
    M src/base/VarBoundMod.h
    M src/base/WarmStart.h
    M src/base/YEqCGs.h
    M src/base/YEqLFs.h
    M src/base/YEqMonomial.h
    M src/base/YEqUCGs.h
    M src/engines/Bqpd/BqpdEngine.cpp
    M src/engines/Bqpd/BqpdEngine.h
    M src/engines/Cbc/CbcEngine.cpp
    M src/engines/Cbc/CbcEngine.h
    M src/engines/Cplex/CplexMILPEngine.h
    M src/engines/EngineFactory.cpp
    M src/engines/FilterSQP/FilterSQPEngine.cpp
    M src/engines/FilterSQP/FilterSQPEngine.h
    M src/engines/Ipopt/IpoptEngine.cpp
    M src/engines/Ipopt/IpoptEngine.h
    M src/engines/OsiLP/OsiLPEngine.cpp
    M src/engines/OsiLP/OsiLPEngine.h
    M src/engines/qpOASES/qpOASESEngine.h
    M src/interfaces/ampl/AMPLInterface.cpp
    M src/interfaces/ampl/AMPLInterface.h
    M src/interfaces/ampl/AMPLNonlinearFunction.h
    M src/testing/HessianOfLagUT.cpp
    M src/testing/IpoptEngineUT.h
    M src/testing/JacobianUT.cpp
    M src/testing/LinearFunctionUT.cpp
    M src/testing/NLPBnbUT.h
    M src/testing/ObjectiveUT.h
    M src/testing/PolyUT.cpp
    M src/testing/QuadraticFunctionUT.cpp
  Log Message:
  Merge branch 'master' of https://github.com/minotaur-solver/minotaur
Compare: https://github.com/minotaur-solver/minotaur/compare/0b09ad807883...b2d1c2e5ccca
More information about the Minotaur-dev mailing list
