[Minotaur-dev] [minotaur-solver/minotaur] 5b1641: Logger & some more shared_ptr changed to raw point...
Vinay Chourasiya
noreply at github.com
Fri Jun 7 07:06:45 CDT 2019
Branch: refs/heads/master
Home: https://github.com/minotaur-solver/minotaur
Commit: 5b1641e2d573a2ea24fc444d6e3abfd62c5362c1
https://github.com/minotaur-solver/minotaur/commit/5b1641e2d573a2ea24fc444d6e3abfd62c5362c1
Author: Vinay Chourasiya <vinayi.chourasia5 at gmail.com>
Date: 2019-06-07 (Fri, 07 Jun 2019)
Changed paths:
M src/base/KnapCovHandler.h
M src/base/Logger.h
M src/base/OAHandler.cpp
M src/base/ParQGBranchAndBound.cpp
M src/base/RCHandler.cpp
M src/base/RCHandler.h
M src/base/Types.h
Log Message:
Logger & some more shared_ptr changed to raw pointer and some more
change in RCHandler
Commit: 817175d24c895051d1cc3e732f251f7ef7d883d8
https://github.com/minotaur-solver/minotaur/commit/817175d24c895051d1cc3e732f251f7ef7d883d8
Changed paths:
M CMakeLists.txt
M scripts/daily-lnx-iit-test.sh
M src/algorithms/Bnb.cpp
M src/algorithms/CMakeLists.txt
A src/algorithms/LSTOA.cpp
M src/algorithms/McBnb.cpp
M src/algorithms/McQG.cpp
M src/algorithms/OA.cpp
M src/algorithms/QG.cpp
M src/base/BrCand.cpp
M src/base/BrCand.h
M src/base/Branch.cpp
M src/base/Branch.h
M src/base/BranchAndBound.cpp
M src/base/BranchAndBound.h
M src/base/CMakeLists.txt
M src/base/Constraint.cpp
M src/base/Constraint.h
M src/base/Environment.cpp
M src/base/Function.cpp
M src/base/Function.h
M src/base/IntVarHandler.cpp
M src/base/MILPEngine.h
M src/base/Node.cpp
M src/base/Node.h
M src/base/NodeProcessor.h
M src/base/OAHandler.h
M src/base/Objective.cpp
M src/base/Objective.h
M src/base/PCBProcessor.cpp
M src/base/ParBranchAndBound.cpp
A src/base/ParMINLPDiving.cpp
A src/base/ParMINLPDiving.h
M src/base/ParQGHandler.cpp
M src/base/ParQGHandler.h
M src/base/ParTreeManager.cpp
M src/base/PerspCutHandler.cpp
M src/base/PerspCutHandler.h
M src/base/Presolver.cpp
M src/base/Problem.cpp
M src/base/Problem.h
M src/base/QGAdvHandler.cpp
M src/base/QGHandler.cpp
M src/base/QGHandler.h
R src/base/QGHandlerPDE.cpp
R src/base/QGHandlerPDE.h
M src/base/ReliabilityBrancher.cpp
M src/base/ReliabilityBrancher.h
A src/base/STOAHandler.cpp
A src/base/STOAHandler.h
M src/base/SolutionPool.cpp
M src/base/SolutionPool.h
M src/base/Timer.h
A src/base/UnambRelBrancher.cpp
A src/base/UnambRelBrancher.h
M src/base/Variable.cpp
M src/base/Variable.h
M src/engines/CMakeLists.txt
M src/engines/Cbc/CbcEngine.cpp
M src/engines/Cbc/CbcEngine.h
A src/engines/Cplex/CMakeLists.txt
A src/engines/Cplex/CplexMILPEngine.cpp
A src/engines/Cplex/CplexMILPEngine.h
M src/engines/EngineFactory.cpp
Log Message:
Merge branch 'master' of https://github.com/minotaur-solver/minotaur
Compare: https://github.com/minotaur-solver/minotaur/compare/ed9ecbf5fe7d...817175d24c89
More information about the Minotaur-dev
