[Minotaur-dev] minotaur daily test results
amahajan amahajan at iitb.ac.in
Wed Jan 30 11:14:05 CST 2019
Minotaur daily test report
Wed Jan 30 22:37:01 IST 2019
origin.ieor.iitb.ac.in
Linux origin 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64 GNU/Linux
Detailed log available at  http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-77-g7061c42
-- The CXX compiler identification is GNU 6.3.0
-- The C compiler identification is GNU 6.3.0
-- The Fortran compiler identification is GNU 6.3.0
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working Fortran compiler: /usr/bin/gfortran
-- Check for working Fortran compiler: /usr/bin/gfortran  -- works
-- Detecting Fortran compiler ABI info
-- Detecting Fortran compiler ABI info - done
-- Checking whether /usr/bin/gfortran supports Fortran 90
-- Checking whether /usr/bin/gfortran supports Fortran 90 -- yes
-- Detecting Fortran/C Interface
-- Detecting Fortran/C Interface - Found GLOBAL and MODULE mangling
-- Found Subversion: /usr/bin/svn (found version "1.9.5")
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29")
-- Minotaur config: Path to third-party =
-- Looking for getrusage
-- Looking for getrusage - found
-- Minotaur config: Is rusage available = 1
-- Minotaur config: checking git in = /home/amahajan/tmp/minotaur-test
-- Minotaur config: found .git in /home/amahajan/tmp/minotaur-test
-- Minotaur config: git version = v0.2.1-77-g7061c42
-- Minotaur config: pkg-config found.
-- Minotaur config: SPEW flag is OFF
-- Minotaur config: Searching for boost ...
-- Minotaur config: Using boost headers from /home/amahajan/tmp/minotaur-test/third-party/include
-- Minotaur config: Searching for bqpd ...
-- Minotaur config: BQPD_LIB_DIR_F is set to
-- Minotaur config: Link BQPD? No.
-- Minotaur config: Searching for Filter-SQP ...
-- Minotaur config: FILTER_LIB_DIR_F is set to
-- Minotaur config: Link Filter-SQP? No.
-- Minotaur config: Searching for Ipopt ...
-- Minotaur config: IPOPT_INC_DIR_F is set to
-- Minotaur config: IPOPT_LIB_DIR_F is set to
-- Minotaur config: Link IPOPT? No.
-- Minotaur config: Searching for OsiLP ...
-- Minotaur config: OSI_LIB_DIR_F is set to
-- Minotaur config: OSI_INC_DIR_F is set to
-- Minotaur config: Link OSI? No.
-- Minotaur config: Searching for CLP ...
-- Minotaur config: CLP_LIB_DIR_F is set to
-- Minotaur config: CLP_INC_DIR_F is set to
-- Minotaur config: Link CLP? No.
-- Minotaur config: Searching for Cplex ...
-- Minotaur config: CPX_INC_DIR is set to
-- Minotaur config: Link Cplex? No.
-- Minotaur config: Searching for Gurobi ...
-- Minotaur config: GRB_INC_DIR is set to
-- Minotaur config: Link Gurobi? No.
-- Minotaur config: Searching for Cbc ...
-- Minotaur config: CBC_INC_DIR_F is set to
-- Minotaur config: CBC_LIB_DIR_F is set to
-- Minotaur config: Link Cbc? No.
-- Minotaur config: Searching for qpOASES ...
-- Minotaur config: QPOASES_INC_DIR is set to
-- Minotaur config: QPOASES_LIB_DIR is set to
-- Minotaur config: Link qpOASES? No.
-- Minotaur config: Searching for ASL ...
-- Minotaur config: Link AMPL-ASL? No.
-- Minotaur config: Searching for cppunit ...
-- Minotaur config: found CPPUNIT library directory.
-- Minotaur config: Link CppUnit? Yes.
-- Minotaur config: rpath for installation is set to :/home/amahajan/tmp/minotaur-test/build-base/./lib
-- Configuring done
-- Generating done
-- Build files have been written to: /home/amahajan/tmp/minotaur-test/build-base
./daily-lnx-iit-test.sh: line 176: syntax error near unexpected token `5'
./daily-lnx-iit-test.sh: line 176: `exit(5)'
More information about the Minotaur-dev mailing list
