[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan
mahajan at mcs.anl.gov
Thu Jan 24 23:18:49 CST 2019
Minotaur daily test report
Thu Jan 24 22:57:02 CST 2019
petsc.mcs.anl.gov
Linux petsc 3.13.0-121-generic #170-Ubuntu SMP Wed Jun 14 09:04:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-73-g72004dd
Summary
compiling build-base: OK.
make utest output for build-base: OK (41)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (41)
compiling build-base-static: OK.
make utest output for build-base-static: OK (41)
compiling build-filter: OK.
make utest output for build-filter: OK (41)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (41)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (41)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (44)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (44)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (44)
compiling build-osi: OK.
make utest output for build-osi: OK (41)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (41)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (41)
compiling build-ampl: OK.
make utest output for build-ampl: OK (60)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (60)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (60)
compiling build-all: OK.
make utest output for build-all: OK (71)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (71)
compiling build-all-static: OK.
make utest output for build-all-static: OK (71)
compiling build-all-manual: ERROR. bin/bnb not built.
Errors:
Errors in build-all-debug:
In file included from /sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:20:0:
/sandbox/mahajan/minotaur-test/src/base/RCHandler.h:97:8: warning: unused parameter ‘out’ [-Wunused-parameter]
void writeStats(std::ostream &out) const{}
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp: In member function ‘virtual void Minotaur::RCHandler::separate(Minotaur::ConstSolutionPtr, Minotaur::NodePtr, Minotaur::RelaxationPtr, Minotaur::CutManager*, Minotaur::SolutionPoolPtr, Minotaur::ModVector&, Minotaur::ModVector&, bool*, Minotaur::SeparationStatus*)’:
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:49:16: warning: unused variable ‘v_type’ [-Wunused-variable]
VariableType v_type;
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:51:17: warning: unused variable ‘x’ [-Wunused-variable]
const double *x = sol->getPrimal();
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp: At global scope:
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:40:6: warning: unused parameter ‘node’ [-Wunused-parameter]
void RCHandler::separate(ConstSolutionPtr sol, NodePtr node,
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:40:6: warning: unused parameter ‘cutman’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:40:6: warning: unused parameter ‘p_mods’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:40:6: warning: unused parameter ‘sol_found’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:40:6: warning: unused parameter ‘status’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:110:6: warning: unused parameter ‘node’ [-Wunused-parameter]
void RCHandler::relaxNodeInc(NodePtr node, RelaxationPtr rel, bool *is_inf){}
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:110:6: warning: unused parameter ‘rel’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:110:6: warning: unused parameter ‘is_inf’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:112:6: warning: unused parameter ‘node’ [-Wunused-parameter]
void RCHandler::relaxNodeFull(NodePtr node, RelaxationPtr rel, bool *is_inf){}
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:112:6: warning: unused parameter ‘rel’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:112:6: warning: unused parameter ‘is_inf’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:114:6: warning: unused parameter ‘rel’ [-Wunused-parameter]
void RCHandler::relaxInitInc(RelaxationPtr rel, bool *is_inf){}
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:114:6: warning: unused parameter ‘is_inf’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp: In member function ‘virtual bool Minotaur::RCHandler::isFeasible(Minotaur::ConstSolutionPtr, Minotaur::RelaxationPtr, bool&, double&)’:
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:119:58: warning: no return statement in function returning non-void [-Wreturn-type]
bool & should_prune, double &inf_meas){}
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:118:6: warning: unused parameter ‘sol’ [-Wunused-parameter]
bool RCHandler::isFeasible(ConstSolutionPtr sol, RelaxationPtr relaxation,
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:118:6: warning: unused parameter ‘relaxation’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:118:6: warning: unused parameter ‘should_prune’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:118:6: warning: unused parameter ‘inf_meas’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:131:6: warning: unused parameter ‘rel’ [-Wunused-parameter]
void RCHandler::relaxInitFull(RelaxationPtr rel, bool *is_inf){}
/sandbox/mahajan/minotaur-test/src/base/RCHandler.cpp:131:6: warning: unused parameter ‘is_inf’ [-Wunused-parameter]
In file included from /sandbox/mahajan/minotaur-test/src/algorithms/qg.cpp:51:0:
: logger ok! OK (71)
==9413== Memcheck, a memory error detector
==9413== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==9413== Using Valgrind-3.10.1 and LibVEX; rerun with -h for copyright info
==9413== Command: ./unittest all
==9413==
: logger ok! ==9413== Conditional jump or move depends on uninitialised value(s)
==9413== at 0x4EE7A4: bqpd_ (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==9413== by 0x4E72A0: Minotaur::BqpdEngine::solve_(int, double&) (BqpdEngine.cpp:512)
==9413== by 0x4E6D40: Minotaur::BqpdEngine::solve() (BqpdEngine.cpp:432)
==9413== by 0x4DA339: AMPLBqpdUT::testNLP() (AMPLBqpdUT.cpp:57)
==9413== by 0x4DBAA5: CppUnit::TestCaller<AMPLBqpdUT>::runTest() (TestCaller.h:166)
==9413== by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==9413== by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==9413== by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==9413== by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==9413== by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==9413== by 0x4E59952: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==9413== by 0x4E5986D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==9413==
OK (71)
==9413==
==9413== HEAP SUMMARY:
==9413== in use at exit: 0 bytes in 0 blocks
==9413== total heap usage: 221,617 allocs, 221,617 frees, 1,089,192,089 bytes allocated
==9413==
==9413== All heap blocks were freed -- no leaks are possible
==9413==
==9413== For counts of detected and suppressed errors, rerun with: -v
==9413== Use --track-origins=yes to see where uninitialised values come from
==9413== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
./lib/libminotaur.a(QGHandler.o): In function `Minotaur::QGHandler::fixCons_(boost::shared_ptr<Minotaur::Constraint const>)':
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp:330: undefined reference to `Minotaur::ConBoundMod::ConBoundMod(boost::shared_ptr<Minotaur::Constraint>, Minotaur::BoundType, double)'
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp:332: undefined reference to `Minotaur::ConBoundMod::ConBoundMod(boost::shared_ptr<Minotaur::Constraint>, Minotaur::BoundType, double)'
collect2: error: ld returned 1 exit status
/sandbox/mahajan/minotaur-test/src/algorithms/qg.cpp:51:23: fatal error: RCHandler.h: No such file or directory
#include "RCHandler.h"
compilation terminated.
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (60)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (41)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
: logger ok! OK (44)
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
More information about the Minotaur-dev
