[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan mahajan at mcs.anl.gov
Wed Feb 13 23:19:07 CST 2019
Minotaur daily test report
Wed Feb 13 22:57:02 CST 2019
petsc.mcs.anl.gov
Linux petsc 3.13.0-121-generic #170-Ubuntu SMP Wed Jun 14 09:04:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at  http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-95-gaf5f2ef
Summary
compiling build-base: OK.
make utest output for build-base: OK (41)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (41)
compiling build-base-static: OK.
make utest output for build-base-static: OK (41)
compiling build-filter: OK.
make utest output for build-filter: OK (41)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (41)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (41)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (44)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (44)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (44)
compiling build-osi: OK.
make utest output for build-osi: OK (41)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (41)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (41)
compiling build-ampl: OK.
make utest output for build-ampl: OK (60)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (60)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (60)
compiling build-all: OK.
make utest output for build-all: OK (71)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (71)
compiling build-all-static: OK.
make utest output for build-all-static: OK (71)
compiling build-all-manual: ERROR. bin/qg not built.
Errors:
Errors in build-all-debug:
/sandbox/mahajan/minotaur-test/src/base/ParBranchAndBound.cpp:1119:0: warning: ignoring #pragma omp single [-Wunknown-pragmas]
 #pragma omp single
In file included from /sandbox/mahajan/minotaur-test/src/base/ParQGBranchAndBound.cpp:30:0:
/sandbox/mahajan/minotaur-test/src/base/NodeProcessor.h:95:20: warning: ‘virtual void Minotaur::NodeProcessor::setCutManager(Minotaur::CutManager*)’ was hidden [-Woverloaded-virtual]
       virtual void setCutManager(CutManager *) {};
In file included from /sandbox/mahajan/minotaur-test/src/base/ParQGBranchAndBound.cpp:34:0:
/sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.h:96:10: warning:   by ‘void Minotaur::ParPCBProcessor::setCutManager(Minotaur::ParCutMan*)’ [-Woverloaded-virtual]
     void setCutManager(ParCutMan* cutman);
In file included from /sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.h:17:0,
                 from /sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.cpp:27:
In file included from /sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.cpp:27:0:
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp: In member function ‘void Minotaur::QGHandler::linearizeObj_()’:
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp:354:16: warning: unused variable ‘fType’ [-Wunused-variable]
   FunctionType fType;
                 from /sandbox/mahajan/minotaur-test/src/algorithms/McQG.cpp:40:
In file included from /sandbox/mahajan/minotaur-test/src/algorithms/McQG.cpp:40:0:
/sandbox/mahajan/minotaur-test/src/algorithms/McQG.cpp:347:13: warning: unused parameter ‘p’ [-Wunused-parameter]
 BrancherPtr createBrancher(EnvPtr env, ProblemPtr p, HandlerVector handlers,
: logger ok! OK (71)
==3752== Memcheck, a memory error detector
==3752== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==3752== Using Valgrind-3.10.1 and LibVEX; rerun with -h for copyright info
==3752== Command: ./unittest all
==3752==
: logger ok! ==3752== Conditional jump or move depends on uninitialised value(s)
==3752==    at 0x4EDE54: bqpd_ (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==3752==    by 0x4E6900: Minotaur::BqpdEngine::solve_(int, double&) (BqpdEngine.cpp:512)
==3752==    by 0x4E63A0: Minotaur::BqpdEngine::solve() (BqpdEngine.cpp:432)
==3752==    by 0x4D9E0D: AMPLBqpdUT::testNLP() (AMPLBqpdUT.cpp:57)
==3752==    by 0x4DB525: CppUnit::TestCaller<AMPLBqpdUT>::runTest() (TestCaller.h:166)
==3752==    by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==3752==    by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==3752==    by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==3752==    by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==3752==    by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==3752==    by 0x4E59952: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==3752==    by 0x4E5986D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==3752==
OK (71)
==3752==
==3752== HEAP SUMMARY:
==3752==     in use at exit: 0 bytes in 0 blocks
==3752==   total heap usage: 218,833 allocs, 218,833 frees, 1,089,067,843 bytes allocated
==3752==
==3752== All heap blocks were freed -- no leaks are possible
==3752==
==3752== For counts of detected and suppressed errors, rerun with: -v
==3752== Use --track-origins=yes to see where uninitialised values come from
==3752== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
Errors in build-all:
 #pragma omp single
/sandbox/mahajan/minotaur-test/src/base/PerspCon.cpp: In member function ‘bool Minotaur::PerspCon::boundBinVar(Minotaur::ConstraintPtr, Minotaur::VariablePtr&)’:
/sandbox/mahajan/minotaur-test/src/base/PerspCon.cpp:137:7: warning: ‘act’ may be used uninitialized in this function [-Wmaybe-uninitialized]
       if (act >= cu) {
   FunctionType fType;
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
   FunctionType fType;
g++: error: /sandbox/mahajan/minotaur-test/src/algorithms/qg.cpp: No such file or directory
Errors in build-all-static:
 #pragma omp single
       if (act >= cu) {
   FunctionType fType;
Errors in build-ampl-debug:
 #pragma omp single
   FunctionType fType;
: logger ok! OK (60)
Errors in build-ampl:
 #pragma omp single
       if (act >= cu) {
   FunctionType fType;
Errors in build-ampl-static:
 #pragma omp single
       if (act >= cu) {
   FunctionType fType;
Errors in build-base-debug:
 #pragma omp single
   FunctionType fType;
: logger ok! OK (41)
Errors in build-base:
 #pragma omp single
       if (act >= cu) {
   FunctionType fType;
Errors in build-base-static:
 #pragma omp single
       if (act >= cu) {
   FunctionType fType;
Errors in build-filter-debug:
 #pragma omp single
   FunctionType fType;
Errors in build-filter:
 #pragma omp single
       if (act >= cu) {
   FunctionType fType;
Errors in build-filter-static:
 #pragma omp single
       if (act >= cu) {
   FunctionType fType;
Errors in build-ipopt-debug:
 #pragma omp single
   FunctionType fType;
: logger ok! OK (44)
Errors in build-ipopt:
 #pragma omp single
       if (act >= cu) {
   FunctionType fType;
Errors in build-ipopt-static:
 #pragma omp single
       if (act >= cu) {
   FunctionType fType;
Errors in build-osi-debug:
 #pragma omp single
   FunctionType fType;
Errors in build-osi:
 #pragma omp single
       if (act >= cu) {
   FunctionType fType;
Errors in build-osi-static:
 #pragma omp single
       if (act >= cu) {
   FunctionType fType;
End of tests
More information about the Minotaur-dev mailing list
