[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan
mahajan at mcs.anl.gov
Sun Feb 10 23:08:49 CST 2019
Minotaur daily test report
Sun Feb 10 22:57:02 CST 2019
petsc.mcs.anl.gov
Linux petsc 3.13.0-121-generic #170-Ubuntu SMP Wed Jun 14 09:04:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-88-g9f11fe9
ls: cannot access build-ampl/bin: No such file or directory
ls: cannot access build-ampl/lib: No such file or directory
ls: cannot access build-ampl/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-debug/bin: No such file or directory
ls: cannot access build-ampl-debug/lib: No such file or directory
ls: cannot access build-ampl-debug/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-static/bin: No such file or directory
ls: cannot access build-ampl-static/lib: No such file or directory
ls: cannot access build-ampl-static/include/minotaur/*: No such file or directory
ls: cannot access build-all/bin: No such file or directory
ls: cannot access build-all/lib: No such file or directory
ls: cannot access build-all/include/minotaur/*: No such file or directory
ls: cannot access build-all-debug/bin: No such file or directory
ls: cannot access build-all-debug/lib: No such file or directory
ls: cannot access build-all-debug/include/minotaur/*: No such file or directory
ls: cannot access build-all-static/bin: No such file or directory
ls: cannot access build-all-static/lib: No such file or directory
ls: cannot access build-all-static/include/minotaur/*: No such file or directory
Summary
compiling build-base: ERROR. lib/libminotaur.so not built.
make utest output for build-base: ERROR
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. bin/qg not built.
Errors:
Errors in build-all-debug:
/sandbox/mahajan/minotaur-test/src/base/ParBranchAndBound.cpp:1119:0: warning: ignoring #pragma omp single [-Wunknown-pragmas]
#pragma omp single
In file included from /sandbox/mahajan/minotaur-test/src/base/ParQGBranchAndBound.cpp:30:0:
/sandbox/mahajan/minotaur-test/src/base/NodeProcessor.h:95:20: warning: ‘virtual void Minotaur::NodeProcessor::setCutManager(Minotaur::CutManager*)’ was hidden [-Woverloaded-virtual]
virtual void setCutManager(CutManager *) {};
In file included from /sandbox/mahajan/minotaur-test/src/base/ParQGBranchAndBound.cpp:34:0:
/sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.h:96:10: warning: by ‘void Minotaur::ParPCBProcessor::setCutManager(Minotaur::ParCutMan*)’ [-Woverloaded-virtual]
void setCutManager(ParCutMan* cutman);
/sandbox/mahajan/minotaur-test/src/base/ParQGBranchAndBound.cpp: In member function ‘void Minotaur::ParQGBranchAndBound::parsolve(Minotaur::ParNodeIncRelaxerPtr*, Minotaur::ParPCBProcessorPtr*, Minotaur::UInt)’:
/sandbox/mahajan/minotaur-test/src/base/ParQGBranchAndBound.cpp:406:40: warning: ISO C++ forbids variable length array ‘cutsIndex’ [-Wvla]
UInt cutsIndex[numThreads][numThreads];
/sandbox/mahajan/minotaur-test/src/base/ParQGBranchAndBound.cpp:407:26: warning: ISO C++ forbids variable length array ‘numCuts’ [-Wvla]
UInt numCuts[numThreads] = {0};
/sandbox/mahajan/minotaur-test/src/base/ParQGBranchAndBound.cpp:407:33: error: variable-sized object ‘numCuts’ may not be initialized
In file included from /sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.h:17:0,
from /sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.cpp:27:
In file included from /sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.cpp:27:0:
/sandbox/mahajan/minotaur-test/src/base/ParPCBProcessor.cpp:67:1: warning: unused parameter ‘numThreads’ [-Wunused-parameter]
ParPCBProcessor::ParPCBProcessor (EnvPtr env, EnginePtr engine,
make[2]: *** [src/base/CMakeFiles/minotaur.dir/ParQGBranchAndBound.o] Error 1
make[2]: *** Waiting for unfinished jobs....
/sandbox/mahajan/minotaur-test/src/base/ParReliabilityBrancher.cpp:164:11: warning: unused parameter ‘rel’ [-Wunused-parameter]
Branches ParReliabilityBrancher::findBranches(RelaxationPtr rel, NodePtr node,
/sandbox/mahajan/minotaur-test/src/base/ParReliabilityBrancher.cpp:164:11: warning: unused parameter ‘node’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/ParReliabilityBrancher.cpp:164:11: warning: unused parameter ‘sol’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/ParReliabilityBrancher.cpp:164:11: warning: unused parameter ‘s_pool’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/ParReliabilityBrancher.cpp:164:11: warning: unused parameter ‘br_status’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/ParReliabilityBrancher.cpp:164:11: warning: unused parameter ‘mods’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/src/base/ParReliabilityBrancher.cpp:374:6: warning: unused parameter ‘timesUp’ [-Wunused-parameter]
void ParReliabilityBrancher::getPCScore_(BrCandPtr cand, double *ch_down,
/sandbox/mahajan/minotaur-test/src/base/ParReliabilityBrancher.cpp:374:6: warning: unused parameter ‘timesDown’ [-Wunused-parameter]
make[1]: *** [src/base/CMakeFiles/minotaur.dir/all] Error 2
make: *** [all] Error 2
make[3]: *** [src/base/CMakeFiles/minotaur.dir/ParQGBranchAndBound.o] Error 1
make[2]: *** [src/base/CMakeFiles/minotaur.dir/all] Error 2
make[1]: *** [CMakeFiles/utest.dir/rule] Error 2
make: *** [utest] Error 2
valgrind: ./unittest: No such file or directory
Errors in build-all:
#pragma omp single
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
g++: error: /sandbox/mahajan/minotaur-test/src/algorithms/qg.cpp: No such file or directory
Errors in build-all-static:
#pragma omp single
Errors in build-ampl-debug:
#pragma omp single
Errors in build-ampl:
#pragma omp single
Errors in build-ampl-static:
#pragma omp single
Errors in build-base-debug:
#pragma omp single
Errors in build-base:
#pragma omp single
Errors in build-base-static:
#pragma omp single
Errors in build-filter-debug:
#pragma omp single
Errors in build-filter:
#pragma omp single
Errors in build-filter-static:
#pragma omp single
Errors in build-ipopt-debug:
#pragma omp single
Errors in build-ipopt:
#pragma omp single
Errors in build-ipopt-static:
#pragma omp single
Errors in build-osi-debug:
#pragma omp single
Errors in build-osi:
#pragma omp single
Errors in build-osi-static:
#pragma omp single
End of tests
More information about the Minotaur-dev
