[Minotaur-dev] minotaur daily test results
amahajan
amahajan at iitb.ac.in
Mon Aug 5 12:38:54 CDT 2019
Minotaur daily test report
Mon Aug 5 22:37:01 IST 2019
origin.ieor.iitb.ac.in
Linux origin 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-342-g77c189d
rsync: mkdir "/home/amahajan/webpage/minotaur/nightly/origin/html" failed: No such file or directory (2)
rsync error: error in file IO (code 11) at main.c(675) [Receiver=3.1.2]
mkdir: cannot create directory ‘/home/amahajan/misc/web/minotaur/nightly/origin’: No such file or directory
mkdir: cannot create directory ‘/home/amahajan/misc/web/minotaur/nightly/origin/build-log’: No such file or directory
cp: failed to access '/home/amahajan/misc/web/minotaur/nightly/origin/build-log/': No such file or directory
./daily-lnx-iit-test.sh: line 478: cd: /home/amahajan/misc/web/minotaur/nightly/origin: No such file or directory
tar: build-log: Cannot stat: No such file or directory
tar: Exiting with failure status due to previous errors
rsync: change_dir "/home/amahajan/misc/web/minotaur/nightly/origin" failed: No such file or directory (2)
rsync: mkdir "/home/amahajan/webpage/minotaur/nightly/origin" failed: No such file or directory (2)
Summary
build-base: OK, all binaries compiled.
build-base: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-base-debug: OK, all binaries compiled.
build-base-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-base-static-debug: OK, all binaries compiled.
build-base-static-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-base-static: OK, all binaries compiled.
build-base-static: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-filter: OK, all binaries compiled.
build-filter: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-filter-debug: OK, all binaries compiled.
build-filter-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-filter-static-debug: OK, all binaries compiled.
build-filter-static-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-filter-static: OK, all binaries compiled.
build-filter-static: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-ipopt: OK, all binaries compiled.
build-ipopt: 0 errors and 1 warnings in compiling, utest output: OK (44)
build-ipopt-debug: OK, all binaries compiled.
build-ipopt-debug: 0 errors and 1 warnings in compiling, utest output: OK (44)
build-ipopt-static-debug: OK, all binaries compiled.
build-ipopt-static-debug: 0 errors and 1 warnings in compiling, utest output: OK (44)
build-ipopt-static: OK, all binaries compiled.
build-ipopt-static: 0 errors and 1 warnings in compiling, utest output: OK (44)
build-osi: OK, all binaries compiled.
build-osi: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-osi-debug: OK, all binaries compiled.
build-osi-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-osi-static-debug: OK, all binaries compiled.
build-osi-static-debug: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-osi-static: OK, all binaries compiled.
build-osi-static: 0 errors and 0 warnings in compiling, utest output: OK (41)
build-cbc: OK, all binaries compiled.
build-cbc: 0 errors and 4 warnings in compiling, utest output: OK (41)
build-cbc-debug: OK, all binaries compiled.
build-cbc-debug: 0 errors and 4 warnings in compiling, utest output: OK (41)
build-cbc-static-debug: OK, all binaries compiled.
build-cbc-static-debug: 0 errors and 4 warnings in compiling, utest output: OK (41)
build-cbc-static: OK, all binaries compiled.
build-cbc-static: 0 errors and 4 warnings in compiling, utest output: OK (41)
build-ampl: OK, all binaries compiled.
build-ampl: 0 errors and 0 warnings in compiling, utest output: OK (60)
build-ampl-debug: OK, all binaries compiled.
build-ampl-debug: 0 errors and 0 warnings in compiling, utest output: OK (60)
build-ampl-static-debug: OK, all binaries compiled.
build-ampl-static-debug: 0 errors and 0 warnings in compiling, utest output: OK (60)
build-ampl-static: OK, all binaries compiled.
build-ampl-static: 0 errors and 0 warnings in compiling, utest output: OK (60)
build-all: OK, all binaries compiled.
build-all: 0 errors and 7 warnings in compiling, utest output: OK (72)
build-all-debug: OK, all binaries compiled.
build-all-debug: 0 errors and 7 warnings in compiling, utest output: OK (72)
Valgrind:
==12272== LEAK SUMMARY:
==12272== definitely lost: 0 bytes in 0 blocks
==12272== indirectly lost: 0 bytes in 0 blocks
==12272== possibly lost: 0 bytes in 0 blocks
==12272== still reachable: 8 bytes in 1 blocks
==12272== suppressed: 0 bytes in 0 blocks
build-all-static-debug: OK, all binaries compiled.
build-all-static-debug: 0 errors and 7 warnings in compiling, utest output: OK (72)
build-all-static: OK, all binaries compiled.
build-all-static: 0 errors and 7 warnings in compiling, utest output: OK (72)
build-all-static-spew: OK, all binaries compiled.
build-all-static-spew: 0 errors and 8 warnings in compiling, utest output: OK (72)
build-all-manual: OK, all binaries compiled.
build-all-manual: utest ERROR
build-all-manual: 0 errors and 49 warnings in compiling, utest output:
Mon Aug 5 23:08:54 IST 2019
More information about the Minotaur-dev
