[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan
mahajan at mcs.anl.gov
Sat Sep 22 22:59:01 CDT 2018
Minotaur daily test report
Sat Sep 22 22:57:01 CDT 2018
petsc.mcs.anl.gov
Linux petsc 3.13.0-121-generic #170-Ubuntu SMP Wed Jun 14 09:04:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-66-geb87a30
ls: cannot access build-ampl/bin: No such file or directory
ls: cannot access build-ampl/lib: No such file or directory
ls: cannot access build-ampl/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-debug/bin: No such file or directory
ls: cannot access build-ampl-debug/lib: No such file or directory
ls: cannot access build-ampl-debug/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-static/bin: No such file or directory
ls: cannot access build-ampl-static/lib: No such file or directory
ls: cannot access build-ampl-static/include/minotaur/*: No such file or directory
ls: cannot access build-all/bin: No such file or directory
ls: cannot access build-all/lib: No such file or directory
ls: cannot access build-all/include/minotaur/*: No such file or directory
ls: cannot access build-all-debug/bin: No such file or directory
ls: cannot access build-all-debug/lib: No such file or directory
ls: cannot access build-all-debug/include/minotaur/*: No such file or directory
./daily-lnx-test.sh: line 270: cd: build-all-debug/src/testing: No such file or directory
./daily-lnx-test.sh: line 271: ../../../build-all-debug.out: Permission denied
./daily-lnx-test.sh: line 47: ./scripts/build_with_externals: No such file or directory
./daily-lnx-test.sh: line 50: cd: build-all-static: No such file or directory
ls: cannot access build-all-static/bin: No such file or directory
ls: cannot access build-all-static/lib: No such file or directory
ls: cannot access build-all-static/include/minotaur/*: No such file or directory
rsync: change_dir "/sandbox/mahajan/minotaur-test/build-all/doxygen/html" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1183) [sender=3.1.0]
Summary
compiling build-base: ERROR. lib/libminotaur.so not built.
make utest output for build-base: ERROR
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libmntrampl.a not built.
Errors:
Errors in build-all-debug:
CMake Error at CMakeLists.txt:217 (message):
Minotaur config: /sandbox/mahajan/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target `install'. Stop.
make: *** No rule to make target `utest'. Stop.
Errors in build-all:
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
cc1plus: warning: /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.7/build/include: No such file or directory [enabled by default]
cc1plus: warning: /sandbox/mahajan/minotaur-test/minotaur-externals/clp-1.16.9/build/include: No such file or directory [enabled by default]
cc1plus: warning: /sandbox/mahajan/minotaur-test/minotaur-externals/asl-20161228: No such file or directory [enabled by default]
/sandbox/mahajan/minotaur-test/src/engines/OsiLP/OsiLPEngine.cpp:18:42: fatal error: coin/OsiClpSolverInterface.hpp: No such file or directory
#include "coin/OsiClpSolverInterface.hpp"
compilation terminated.
make: *** [/sandbox/mahajan/minotaur-test/src/engines/OsiLP/OsiLPEngine.o] Error 1
Errors in build-all-static:
Errors in build-ampl-debug:
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
Errors in build-base:
--2018-09-22 22:57:04-- http://www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz
Resolving www.mcs.anl.gov (www.mcs.anl.gov)... 140.221.6.95
Connecting to www.mcs.anl.gov (www.mcs.anl.gov)|140.221.6.95|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz [following]
--2018-09-22 22:57:04-- https://www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz
Connecting to www.mcs.anl.gov (www.mcs.anl.gov)|140.221.6.95|:443... connected.
ERROR: cannot verify www.mcs.anl.gov's certificate, issued by ‘/C=US/O=Entrust, Inc./OU=See www.entrust.net/legal-terms/OU=(c) 2012 Entrust, Inc. - for authorized use only/CN=Entrust Certification Authority - L1K’:
Unable to locally verify the issuer's authority.
To connect to www.mcs.anl.gov insecurely, use `--no-check-certificate'.
tar (child): minotaur-externals-0.2.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 129: cd: minotaur-externals/clp-1.16.9: No such file or directory
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 132: ../configure: No such file or directory
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 150: cd: minotaur-externals/bqpd-3: No such file or directory
make: *** No targets specified and no makefile found. Stop.
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 160: cd: minotaur-externals/filter-102/src: No such file or directory
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 170: cd: minotaur-externals/asl-20161228: No such file or directory
chmod: cannot access ‘configurehere’: No such file or directory
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 172: ./configurehere: No such file or directory
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 177: cd: minotaur-externals/cppunit-1.13.2: No such file or directory
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 184: ../../configure: No such file or directory
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 191: cd: minotaur-externals/clp-1.16.9/build: No such file or directory
make: *** No rule to make target `distclean'. Stop.
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 196: cd: minotaur-externals//build: No such file or directory
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 201: cd: minotaur-externals/bqpd-3: No such file or directory
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 206: cd: minotaur-externals/filter-102: No such file or directory
/sandbox/mahajan/minotaur-test/scripts/build_externals: line 211: cd: minotaur-externals/cppunit-1.13.2/build/tmp: No such file or directory
Minotaur config: /sandbox/mahajan/minotaur-test/minotaur-externals/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
More information about the Minotaur-dev
