[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan
mahajan at mcs.anl.gov
Sun Nov 18 23:18:51 CST 2018
Minotaur daily test report
Sun Nov 18 22:57:01 CST 2018
petsc.mcs.anl.gov
Linux petsc 3.13.0-121-generic #170-Ubuntu SMP Wed Jun 14 09:04:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-66-geb87a30
Summary
compiling build-base: OK.
make utest output for build-base: OK (41)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (41)
compiling build-base-static: OK.
make utest output for build-base-static: OK (41)
compiling build-filter: OK.
make utest output for build-filter: OK (41)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (41)
compiling build-filter-static: OK.
make utest output for build-filter-static: ERROR
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (44)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (44)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (44)
compiling build-osi: OK.
make utest output for build-osi: OK (41)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (41)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (41)
compiling build-ampl: OK.
make utest output for build-ampl: OK (60)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (60)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (60)
compiling build-all: OK.
make utest output for build-all: OK (71)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (71)
compiling build-all-static: OK.
make utest output for build-all-static: OK (71)
compiling build-all-manual: ERROR. bin/bnb not built.
Errors:
Errors in build-all-debug:
: logger ok! OK (71)
==30667== Memcheck, a memory error detector
==30667== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==30667== Using Valgrind-3.10.1 and LibVEX; rerun with -h for copyright info
==30667== Command: ./unittest all
==30667==
: logger ok! ==30667== Conditional jump or move depends on uninitialised value(s)
==30667== at 0x4EE7A4: bqpd_ (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==30667== by 0x4E72A0: Minotaur::BqpdEngine::solve_(int, double&) (BqpdEngine.cpp:512)
==30667== by 0x4E6D40: Minotaur::BqpdEngine::solve() (BqpdEngine.cpp:432)
==30667== by 0x4DA339: AMPLBqpdUT::testNLP() (AMPLBqpdUT.cpp:57)
==30667== by 0x4DBAA5: CppUnit::TestCaller<AMPLBqpdUT>::runTest() (TestCaller.h:166)
==30667== by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==30667== by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==30667== by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==30667== by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==30667== by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==30667== by 0x4E59952: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==30667== by 0x4E5986D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==30667==
OK (71)
==30667==
==30667== HEAP SUMMARY:
==30667== in use at exit: 0 bytes in 0 blocks
==30667== total heap usage: 221,418 allocs, 221,418 frees, 1,089,183,704 bytes allocated
==30667==
==30667== All heap blocks were freed -- no leaks are possible
==30667==
==30667== For counts of detected and suppressed errors, rerun with: -v
==30667== Use --track-origins=yes to see where uninitialised values come from
==30667== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
./lib/libminotaur.a(QGHandler.o): In function `Minotaur::QGHandler::fixCons_(boost::shared_ptr<Minotaur::Constraint const>)':
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp:330: undefined reference to `Minotaur::ConBoundMod::ConBoundMod(boost::shared_ptr<Minotaur::Constraint>, Minotaur::BoundType, double)'
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp:332: undefined reference to `Minotaur::ConBoundMod::ConBoundMod(boost::shared_ptr<Minotaur::Constraint>, Minotaur::BoundType, double)'
collect2: error: ld returned 1 exit status
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (60)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (41)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
: logger ok! TimerUT.cpp:36:Assertion
Test name: TimerUT::testSleep
assertion failed
- Expression: time_used <= 0.001
Failures !!!
Run: 41 Failure total: 1 Failures: 1 Errors: 0
make[3]: *** [CMakeFiles/utest] Error 1
make[2]: *** [CMakeFiles/utest.dir/all] Error 2
make[1]: *** [CMakeFiles/utest.dir/rule] Error 2
make: *** [utest] Error 2
Errors in build-ipopt-debug:
: logger ok! OK (44)
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
More information about the Minotaur-dev
