[Minotaur-dev] minotaur daily test results
amahajan amahajan at iitb.ac.in
Mon May 7 12:15:41 CDT 2018
Minotaur daily test report
Mon May  7 22:37:01 IST 2018
origin.ieor.iitb.ac.in
Linux origin 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u2 (2017-06-26) x86_64 GNU/Linux
Detailed log available at  http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-62-g5589c94
ls: cannot access 'build-ampl/bin': No such file or directory
ls: cannot access 'build-ampl/lib': No such file or directory
ls: cannot access 'build-ampl/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-debug/bin': No such file or directory
ls: cannot access 'build-ampl-debug/lib': No such file or directory
ls: cannot access 'build-ampl-debug/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-static/bin': No such file or directory
ls: cannot access 'build-ampl-static/lib': No such file or directory
ls: cannot access 'build-ampl-static/include/minotaur/*': No such file or directory
ls: cannot access 'build-all/bin': No such file or directory
ls: cannot access 'build-all/lib': No such file or directory
ls: cannot access 'build-all/include/minotaur/*': No such file or directory
ls: cannot access 'build-all-debug/bin': No such file or directory
ls: cannot access 'build-all-debug/lib': No such file or directory
ls: cannot access 'build-all-debug/include/minotaur/*': No such file or directory
./daily-lnx-iit-test.sh: line 272: cd: build-all-debug/src/testing: No such file or directory
./daily-lnx-iit-test.sh: line 273: ../../../build-all-debug.out: Permission denied
./daily-lnx-iit-test.sh: line 47: ./scripts/build_with_externals: No such file or directory
./daily-lnx-iit-test.sh: line 50: cd: build-all-static: No such file or directory
ls: cannot access 'build-all-static/bin': No such file or directory
ls: cannot access 'build-all-static/lib': No such file or directory
ls: cannot access 'build-all-static/include/minotaur/*': No such file or directory
rsync: change_dir "/home/amahajan/tmp/minotaur-test/build-all/doxygen/html" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1196) [sender=3.1.2]
Summary
compiling build-base: OK.
make utest output for build-base: OK (41)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (41)
compiling build-base-static: OK.
make utest output for build-base-static: OK (41)
compiling build-filter: OK.
make utest output for build-filter: OK (41)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (41)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (41)
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libmntrampl.a not built.
Errors:
Errors in build-all-debug:
CMake Error at CMakeLists.txt:335 (message):
   Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/ipopt-3.12.7/build/include/coin/IpIpoptApplication.hpp not found.
make: *** No rule to make target 'install'.  Stop.
make: *** No rule to make target 'utest'.  Stop.
Errors in build-all:
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/ipopt-3.12.7/build/include: No such file or directory [-Wmissing-include-dirs]
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/clp-1.16.9/build/include: No such file or directory [-Wmissing-include-dirs]
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/asl-20161228: No such file or directory [-Wmissing-include-dirs]
In file included from /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/smart_ptr/shared_ptr.hpp:28:0,
                 from /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/Types.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/base/Brancher.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/BndProcessor.cpp:15:
/home/amahajan/tmp/minotaur-test/minotaur-externals/boost/smart_ptr/detail/shared_count.hpp:395:33: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
     explicit shared_count( std::auto_ptr<Y> & r ): pi_( new sp_counted_impl_p<Y>( r.get() ) )
In file included from /usr/include/c++/6/memory:81:0,
                 from /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/config/no_tr1/memory.hpp:21,
                 from /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/smart_ptr/shared_ptr.hpp:23,
/usr/include/c++/6/bits/unique_ptr.h:49:28: note: declared here
   template<typename> class auto_ptr;
In file included from /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp:17:0,
/home/amahajan/tmp/minotaur-test/minotaur-externals/boost/smart_ptr/shared_ptr.hpp:242:65: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
 template< class T, class R > struct sp_enable_if_auto_ptr< std::auto_ptr< T >, R >
/home/amahajan/tmp/minotaur-test/minotaur-externals/boost/smart_ptr/shared_ptr.hpp:441:31: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
     explicit shared_ptr( std::auto_ptr<Y> & r ): px(r.get()), pn()
/home/amahajan/tmp/minotaur-test/minotaur-externals/boost/smart_ptr/shared_ptr.hpp:454:22: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
     shared_ptr( std::auto_ptr<Y> && r ): px(r.get()), pn()
/home/amahajan/tmp/minotaur-test/minotaur-externals/boost/smart_ptr/shared_ptr.hpp:520:34: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
     shared_ptr & operator=( std::auto_ptr<Y> & r )
/home/amahajan/tmp/minotaur-test/minotaur-externals/boost/smart_ptr/shared_ptr.hpp:529:34: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
     shared_ptr & operator=( std::auto_ptr<Y> && r )
/home/amahajan/tmp/minotaur-test/minotaur-externals/boost/smart_ptr/shared_ptr.hpp: In member function ‘boost::shared_ptr<T>& boost::shared_ptr<T>::operator=(std::auto_ptr<_Up>&&)’:
/home/amahajan/tmp/minotaur-test/minotaur-externals/boost/smart_ptr/shared_ptr.hpp:531:38: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
         this_type( static_cast< std::auto_ptr<Y> && >( r ) ).swap( *this );
                 from /home/amahajan/tmp/minotaur-test/src/base/BrCand.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/Branch.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/BranchAndBound.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/base/BranchAndBound.cpp:17:
In file included from /usr/include/c++/6/bits/locale_conv.h:41:0,
                 from /usr/include/c++/6/locale:43,
                 from /usr/include/c++/6/iomanip:43,
                 from /home/amahajan/tmp/minotaur-test/src/base/BranchAndBound.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/Brancher.cpp:13:
                 from /home/amahajan/tmp/minotaur-test/src/base/BrCand.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/BrVarCand.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/BrVarCand.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/LinearFunction.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/Chol.h:11,
                 from /home/amahajan/tmp/minotaur-test/src/base/Chol.cpp:8:
                 from /home/amahajan/tmp/minotaur-test/src/base/CGraph.h:20,
                 from /home/amahajan/tmp/minotaur-test/src/base/CGraph.cpp:21:
                 from /home/amahajan/tmp/minotaur-test/src/base/CNode.h:19,
                 from /home/amahajan/tmp/minotaur-test/src/base/CNode.cpp:21:
                 from /home/amahajan/tmp/minotaur-test/src/base/Constraint.h:18,
                 from /home/amahajan/tmp/minotaur-test/src/base/Constraint.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/Cut.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/Cut.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/Function.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/base/CutInfo.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/Environment.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/base/CutMan1.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/Branch.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/CxQuadHandler.cpp:29:
                 from /home/amahajan/tmp/minotaur-test/src/base/CxQuadHandler.cpp:26:
                 from /home/amahajan/tmp/minotaur-test/src/base/CxUnivarHandler.cpp:20:
                 from /home/amahajan/tmp/minotaur-test/src/base/CxUnivarHandler.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/Eigen.h:18,
                 from /home/amahajan/tmp/minotaur-test/src/base/Eigen.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/Engine.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/base/Engine.cpp:9:
                 from /home/amahajan/tmp/minotaur-test/src/base/Environment.cpp:20:
                 from /home/amahajan/tmp/minotaur-test/src/base/FeasibilityPump.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/Function.cpp:12:
                 from /home/amahajan/tmp/minotaur-test/src/base/HessianOfLag.cpp:20:
                 from /home/amahajan/tmp/minotaur-test/src/base/Logger.h:34,
                 from /home/amahajan/tmp/minotaur-test/src/base/Interrupt.h:26,
                 from /home/amahajan/tmp/minotaur-test/src/base/Interrupt.cpp:11:
                 from /home/amahajan/tmp/minotaur-test/src/base/IntVarHandler.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/Jacobian.cpp:10:
                 from /home/amahajan/tmp/minotaur-test/src/base/Modification.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/LPRelaxation.h:11,
                 from /home/amahajan/tmp/minotaur-test/src/base/LPRelaxation.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/base/LexicoBrancher.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/LinBil.cpp:21:
                 from /home/amahajan/tmp/minotaur-test/src/base/LinBil.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/LinConMod.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/LinearCut.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/LinearFunction.cpp:12:
                 from /home/amahajan/tmp/minotaur-test/src/base/LinearHandler.cpp:20:
                 from /home/amahajan/tmp/minotaur-test/src/base/LinearHandler.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/LinFeasPump.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/LinConMod.h:18,
                 from /home/amahajan/tmp/minotaur-test/src/base/LinMods.h:18,
                 from /home/amahajan/tmp/minotaur-test/src/base/LinMods.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/Logger.cpp:10:
                 from /home/amahajan/tmp/minotaur-test/src/base/MaxFreqBrancher.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/MaxFreqBrancher.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/MaxVioBrancher.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/MaxVioBrancher.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/MINLPDiving.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/MINLPDiving.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/MsProcessor.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/Problem.h:18,
                 from /home/amahajan/tmp/minotaur-test/src/base/Relaxation.h:18,
                 from /home/amahajan/tmp/minotaur-test/src/base/NLPRelaxation.h:11,
                 from /home/amahajan/tmp/minotaur-test/src/base/NLPRelaxation.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/NlPresHandler.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/NlPresHandler.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/NLPMultiStart.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/NlWriter.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/NlWriter.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/Node.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/NodeFullRelaxer.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/Node.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/NodeHeap.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/NodeIncRelaxer.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/NodeProcessor.h:18,
                 from /home/amahajan/tmp/minotaur-test/src/base/NodeProcessor.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/base/NodeStack.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/NonlinearFunction.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/base/NonlinearFunction.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/Objective.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/Operations.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/base/Operations.cpp:21:
                 from /home/amahajan/tmp/minotaur-test/src/base/Operations.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/Option.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/Option.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/PCBProcessor.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/base/Option.h:19,
                 from /home/amahajan/tmp/minotaur-test/src/base/PerspCon.cpp:20:
                 from /home/amahajan/tmp/minotaur-test/src/base/PerspCutGenerator.h:22,
                 from /home/amahajan/tmp/minotaur-test/src/base/PerspCutGenerator.cpp:22:
                 from /home/amahajan/tmp/minotaur-test/src/base/PerspCutGenerator.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/Handler.h:18,
                 from /home/amahajan/tmp/minotaur-test/src/base/PerspCutHandler.h:18,
                 from /home/amahajan/tmp/minotaur-test/src/base/PerspCutHandler.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/PerspCutHandler.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/PolynomialFunction.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/PreMod.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/base/PreAuxVars.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/PreAuxVars.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/PreDelVars.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/PreDelVars.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/PreSubstVars.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/PreSubstVars.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/Presolver.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/base/Problem.cpp:20:
                 from /home/amahajan/tmp/minotaur-test/src/base/Problem.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/QGHandler.cpp:23:
                 from /home/amahajan/tmp/minotaur-test/src/base/QGHandler.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/QPDRelaxer.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/base/QPDProcessor.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/QPDProcessor.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/base/QuadHandler.cpp:22:
                 from /home/amahajan/tmp/minotaur-test/src/base/QuadHandler.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/HessianOfLag.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/QuadraticFunction.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/QuadraticFunction.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/base/RandomBrancher.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/Relaxation.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/ReliabilityBrancher.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/ReliabilityBrancher.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/SecantMod.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/SimpleCutMan.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/SimpleTransformer.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/Solution.cpp:20:
                 from /home/amahajan/tmp/minotaur-test/src/base/Solution.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/SolutionPool.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/SOS.cpp:20:
                 from /home/amahajan/tmp/minotaur-test/src/base/SOS.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/base/SOS1Handler.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/SOS1Handler.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/SOS2Handler.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/SOS2Handler.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/SOSBrCand.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/SOSBrCand.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/base/Transformer.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/TransPoly.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/TransSep.cpp:19:
                 from /home/amahajan/tmp/minotaur-test/src/base/TreeManager.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/Types.cpp:16:
                 from /home/amahajan/tmp/minotaur-test/src/base/VarBoundMod.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/Variable.h:21,
                 from /home/amahajan/tmp/minotaur-test/src/base/Variable.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/YEqCGs.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/YEqLFs.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/PolynomialFunction.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/YEqMonomial.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/YEqUCGs.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/YEqVars.cpp:19:
                 from ./include/minotaur/Types.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/engines/EngineFactory.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/engines/EngineFactory.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/engines/Bqpd/BqpdEngine.h:15,
                 from /home/amahajan/tmp/minotaur-test/src/engines/Bqpd/BqpdEngine.cpp:25:
                 from /home/amahajan/tmp/minotaur-test/src/engines/Bqpd/BqpdEngine.cpp:20:
                 from ./include/minotaur/Constraint.h:18,
                 from /home/amahajan/tmp/minotaur-test/src/engines/FilterSQP/FilterSQPEngine.cpp:21:
                 from /home/amahajan/tmp/minotaur-test/src/engines/FilterSQP/FilterSQPEngine.cpp:18:
/home/amahajan/tmp/minotaur-test/src/engines/OsiLP/OsiLPEngine.cpp:18:42: fatal error: coin/OsiClpSolverInterface.hpp: No such file or directory
 #include "coin/OsiClpSolverInterface.hpp"
compilation terminated.
make: *** [/home/amahajan/tmp/minotaur-test/src/engines/OsiLP/OsiLPEngine.o] Error 1
Errors in build-all-static:
Errors in build-ampl-debug:
CMake Error at CMakeLists.txt:817 (message):
   Minotaur config:  /home/amahajan/tmp/minotaur-test/minotaur-externals/asl-20161228/asl.h not found.
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
                 from /home/amahajan/tmp/minotaur-test/src/base/ConBoundMod.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/KnapsackList.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/CoverCutGenerator.h:23,
                 from /home/amahajan/tmp/minotaur-test/src/base/CoverCutGenerator.cpp:28:
                 from /home/amahajan/tmp/minotaur-test/src/base/Cut.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/base/CutMan2.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/KnapsackList.cpp:13:
                 from /home/amahajan/tmp/minotaur-test/src/base/KnapCovHandler.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/base/KnapCovHandler.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/LGCIGenerator.h:24,
                 from /home/amahajan/tmp/minotaur-test/src/base/LGCIGenerator.cpp:29:
                 from /home/amahajan/tmp/minotaur-test/src/base/MultilinearTermsHandler.cpp:18:
                 from /home/amahajan/tmp/minotaur-test/src/base/ParBndProcessor.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/ParTreeManager.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/base/ParNodeIncRelaxer.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/base/ParBranchAndBound.cpp:21:
                 from /home/amahajan/tmp/minotaur-test/src/base/ParBranchAndBound.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/ProbStructure.h:19,
                 from /home/amahajan/tmp/minotaur-test/src/base/ProbStructure.cpp:12:
                 from /home/amahajan/tmp/minotaur-test/src/base/QGHandlerPDE.cpp:23:
                 from /home/amahajan/tmp/minotaur-test/src/base/QGHandlerPDE.cpp:17:
                 from /home/amahajan/tmp/minotaur-test/src/testing/CGraphUT.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/testing/CGraphUT.cpp:10:
                 from /home/amahajan/tmp/minotaur-test/minotaur-externals/cppunit-1.13.2/build/include/cppunit/extensions/HelperMacros.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/testing/CGraphUT.h:14,
                 from /home/amahajan/tmp/minotaur-test/src/testing/EnvironmentUT.h:22,
                 from /home/amahajan/tmp/minotaur-test/src/testing/EnvironmentUT.cpp:15:
                 from /home/amahajan/tmp/minotaur-test/src/testing/EnvironmentUT.h:20,
                 from /home/amahajan/tmp/minotaur-test/src/testing/FunctionUT.h:19,
                 from /home/amahajan/tmp/minotaur-test/src/testing/FunctionUT.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/testing/FunctionUT.h:17,
                 from /home/amahajan/tmp/minotaur-test/src/testing/ProblemUT.cpp:14:
                 from /home/amahajan/tmp/minotaur-test/src/base/Jacobian.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/testing/JacobianUT.cpp:10:
                 from /home/amahajan/tmp/minotaur-test/src/testing/HessianOfLagUT.cpp:10:
                 from /home/amahajan/tmp/minotaur-test/src/testing/LapackUT.h:18,
                 from /home/amahajan/tmp/minotaur-test/src/testing/LapackUT.cpp:10:
                 from /home/amahajan/tmp/minotaur-test/src/testing/LapackUT.h:16,
                 from /home/amahajan/tmp/minotaur-test/src/testing/LinearFunctionUT.cpp:14:
