[Minotaur-dev] minotaur daily test results
amahajan
amahajan at iitb.ac.in
Fri Mar 16 12:33:41 CDT 2018
Minotaur daily test report
Fri Mar 16 22:37:01 IST 2018
origin.ieor.iitb.ac.in
Linux origin 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u2 (2017-06-26) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-51-g7e72f13
Summary
compiling build-base: OK.
make utest output for build-base: OK (41)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (41)
compiling build-base-static: OK.
make utest output for build-base-static: OK (41)
compiling build-filter: OK.
make utest output for build-filter: OK (41)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (41)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (41)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (44)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (44)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (44)
compiling build-osi: OK.
make utest output for build-osi: OK (41)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (41)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (41)
compiling build-ampl: OK.
make utest output for build-ampl: OK (60)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (60)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (60)
compiling build-all: OK.
make utest output for build-all: OK (71)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (71)
compiling build-all-static: OK.
make utest output for build-all-static: OK (71)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
: logger ok! OK (71)
==6573== Memcheck, a memory error detector
==6573== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==6573== Using Valgrind-3.12.0.SVN and LibVEX; rerun with -h for copyright info
==6573== Command: ./unittest all
==6573==
: logger ok! ==6573== Conditional jump or move depends on uninitialised value(s)
==6573== at 0x208904: bqpd_ (in /home/amahajan/tmp/minotaur-test/build-all-debug/src/testing/unittest)
==6573== by 0x200FB7: Minotaur::BqpdEngine::solve_(int, double&) (BqpdEngine.cpp:512)
==6573== by 0x200A8C: Minotaur::BqpdEngine::solve() (BqpdEngine.cpp:432)
==6573== by 0x1F4334: AMPLBqpdUT::testNLP() (AMPLBqpdUT.cpp:57)
==6573== by 0x1F5AA5: CppUnit::TestCaller<AMPLBqpdUT>::runTest() (TestCaller.h:166)
==6573== by 0x4E5AB81: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==6573== by 0x4E5197F: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==6573== by 0x4E57F74: operator() (ProtectorChain.cpp:20)
==6573== by 0x4E57F74: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==6573== by 0x4E6047B: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (TestResult.cpp:181)
==6573== by 0x4E5A9CF: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==6573== by 0x4E5AE52: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==6573== by 0x4E5AD6D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==6573==
OK (71)
==6573==
==6573== HEAP SUMMARY:
==6573== in use at exit: 0 bytes in 0 blocks
==6573== total heap usage: 173,733 allocs, 173,733 frees, 888,681,205 bytes allocated
==6573==
==6573== All heap blocks were freed -- no leaks are possible
==6573==
==6573== For counts of detected and suppressed errors, rerun with: -v
==6573== Use --track-origins=yes to see where uninitialised values come from
==6573== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (60)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (41)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
: logger ok! OK (44)
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Fri Mar 16 23:03:41 IST 2018
More information about the Minotaur-dev
