[Minotaur-dev] minotaur daily test results
amahajan amahajan at iitb.ac.in
Sun Jul 29 12:14:34 CDT 2018
Minotaur daily test report
Sun Jul 29 22:37:01 IST 2018
origin.ieor.iitb.ac.in
Linux origin 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u2 (2017-06-26) x86_64 GNU/Linux
Detailed log available at  http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-63-gfee696e
ls: cannot access 'build-ampl/bin': No such file or directory
ls: cannot access 'build-ampl/lib': No such file or directory
ls: cannot access 'build-ampl/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-debug/bin': No such file or directory
ls: cannot access 'build-ampl-debug/lib': No such file or directory
ls: cannot access 'build-ampl-debug/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-static/bin': No such file or directory
ls: cannot access 'build-ampl-static/lib': No such file or directory
ls: cannot access 'build-ampl-static/include/minotaur/*': No such file or directory
ls: cannot access 'build-all/bin': No such file or directory
ls: cannot access 'build-all/lib': No such file or directory
ls: cannot access 'build-all/include/minotaur/*': No such file or directory
ls: cannot access 'build-all-debug/bin': No such file or directory
ls: cannot access 'build-all-debug/lib': No such file or directory
ls: cannot access 'build-all-debug/include/minotaur/*': No such file or directory
./daily-lnx-iit-test.sh: line 272: cd: build-all-debug/src/testing: No such file or directory
./daily-lnx-iit-test.sh: line 273: ../../../build-all-debug.out: Permission denied
./daily-lnx-iit-test.sh: line 47: ./scripts/build_with_externals: No such file or directory
./daily-lnx-iit-test.sh: line 50: cd: build-all-static: No such file or directory
ls: cannot access 'build-all-static/bin': No such file or directory
ls: cannot access 'build-all-static/lib': No such file or directory
ls: cannot access 'build-all-static/include/minotaur/*': No such file or directory
rsync: change_dir "/home/amahajan/tmp/minotaur-test/build-all/doxygen/html" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1196) [sender=3.1.2]
Summary
compiling build-base: OK.
make utest output for build-base: OK (41)
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libmntrampl.a not built.
Errors:
Errors in build-all-debug:
CMake Error at CMakeLists.txt:217 (message):
   Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target 'install'.  Stop.
make: *** No rule to make target 'utest'.  Stop.
Errors in build-all:
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/ipopt-3.12.7/build/include: No such file or directory [-Wmissing-include-dirs]
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/clp-1.16.9/build/include: No such file or directory [-Wmissing-include-dirs]
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/asl-20161228: No such file or directory [-Wmissing-include-dirs]
/home/amahajan/tmp/minotaur-test/src/engines/OsiLP/OsiLPEngine.cpp:18:42: fatal error: coin/OsiClpSolverInterface.hpp: No such file or directory
 #include "coin/OsiClpSolverInterface.hpp"
compilation terminated.
make: *** [/home/amahajan/tmp/minotaur-test/src/engines/OsiLP/OsiLPEngine.o] Error 1
Errors in build-all-static:
Errors in build-ampl-debug:
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
Errors in build-base:
--2018-07-29 22:37:10--  http://www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz
Resolving netmon.iitb.ac.in (netmon.iitb.ac.in)... 10.201.13.50
Connecting to netmon.iitb.ac.in (netmon.iitb.ac.in)|10.201.13.50|:80... connected.
Proxy request sent, awaiting response... 200 OK
Length: 32220716 (31M) [application/x-gzip]
Saving to: ‘minotaur-externals-0.2.tar.gz’
     0K .......... .......... .......... .......... ..........  0% 75.7K 6m55s
    50K .......... .......... .......... .......... ..........  0%  114K 5m45s
   100K .......... .......... .......... .......... ..........  0%  225K 4m36s
   150K .......... .......... .......... .......... ..........  0%  114K 4m35s
   200K .......... .......... .......... .......... ..........  0%  227K 4m7s
   250K .......... .......... .......... .......... ..........  0%  227K 3m49s
   300K .......... .......... .......... .......... ..........  1%  228K 3m35s
   350K .......... .......... .......... .......... ..........  1%  228K 3m25s
   400K .......... .......... .......... .......... ..........  1% 11.0M 3m2s
   450K .......... .......... .......... .......... ..........  1%  229K 2m57s
   500K .......... .......... .......... .......... ..........  1%  229K 2m53s
   550K .......... .......... .......... .......... ..........  1%  229K 2m50s
   600K .......... .......... .......... .......... ..........  2%  228K 2m47s
   650K .......... .......... .......... .......... ..........  2% 11.7M 2m35s
   700K .......... .......... .......... .......... ..........  2%  228K 2m33s
   750K .......... .......... .......... .......... ..........  2%  229K 2m32s
   800K .......... .......... .......... .......... ..........  2%  228K 2m31s
   850K .......... .......... .......... .......... ..........  2%  229K 2m29s
   900K .......... .......... .......... .......... ..........  3% 11.1M 2m21s
   950K .......... .......... .......... .......... ..........  3%  228K 2m21s
  1000K .......... .......... .......... .......... ..........  3%  228K 2m20s
  1050K .......... .......... .......... .......... ..........  3%  229K 2m20s
  1100K .......... .......... .......... .......... ..........  3%  228K 2m19s
  1150K .......... .......... .......... .......... ..........  3% 11.0M 2m13s
  1200K .......... .......... .......... .......... ..........  3%  228K 2m13s
  1250K .......... .......... .......... .......... ..........  4%  229K 2m13s
  1300K .......... .......... .......... .......... ..........  4%  229K 2m12s
  1350K .......... .......... .......... .......... ..........  4%  228K 2m12s
  1400K .......... .......... .......... .......... ..........  4% 11.8M 2m8s
  1450K .......... .......... .......... .......... ..........  4%  228K 2m7s
  1500K .......... .......... .......... .......... ..........  4%  228K 2m7s
  1550K .......... .......... .......... .......... ..........  5%  229K 2m7s
  1600K .......... .......... .......... .......... ..........  5%  229K 2m7s
  1650K .......... .......... .......... .......... ..........  5% 11.7M 2m3s
  1700K .......... .......... .......... .......... ..........  5%  228K 2m3s
  1750K .......... .......... .......... .......... ..........  5%  228K 2m3s
  1800K .......... .......... .......... .......... ..........  5%  228K 2m3s
  1850K .......... .......... .......... .......... ..........  6%  229K 2m3s
  1900K .......... .......... .......... .......... ..........  6% 11.6M 2m0s
  1950K .......... .......... .......... .......... ..........  6%  228K 2m0s
  2000K .......... .......... .......... .......... ..........  6%  228K 2m0s
  2050K .......... .......... .......... .......... ..........  6%  229K 2m0s
  2100K .......... .......... .......... .......... ..........  6%  228K 2m0s
  2150K .......... .......... .......... .......... ..........  6% 11.7M 1m57s
  2200K .......... .......... .......... .......... ..........  7%  228K 1m57s
  2250K .......... .......... .......... .......... ..........  7%  229K 1m57s
  2300K .......... .......... .......... .......... ..........  7%  228K 1m57s
  2350K .......... .......... .......... .......... ..........  7% 11.5M 1m55s
  2400K .......... .......... .......... .......... ..........  7%  228K 1m55s
  2450K .......... .......... .......... .......... ..........  7%  229K 1m55s
  2500K .......... .......... .......... .......... ..........  8%  228K 1m55s
  2550K .......... .......... .......... .......... ..........  8%  228K 1m55s
  2600K .......... .......... .......... .......... ..........  8% 11.5M 1m52s
  2650K .......... .......... .......... .......... ..........  8%  228K 1m53s
  2700K .......... .......... .......... .......... ..........  8%  229K 1m53s
  2750K .......... .......... .......... .......... ..........  8%  229K 1m53s
  2800K .......... .......... .......... .......... ..........  9%  228K 1m53s
  2850K .......... .......... .......... .......... ..........  9% 11.0M 1m51s
  2900K .......... .......... .......... .......... ..........  9%  229K 1m51s
  2950K .......... .......... .......... .......... ..........  9%  229K 1m51s
  3000K .......... .......... .......... .......... ..........  9%  228K 1m51s
  3050K .......... .......... .......... .......... ..........  9%  228K 1m51s
  3100K .......... .......... .......... .......... .......... 10% 11.6M 1m49s
  3150K .......... .......... .......... .......... .......... 10%  229K 1m49s
  3200K .......... .......... .......... .......... .......... 10%  228K 1m49s
  3250K .......... .......... .......... .......... .......... 10%  229K 1m49s
  3300K .......... .......... .......... .......... .......... 10%  229K 1m49s
  3350K .......... .......... .......... .......... .......... 10% 10.6M 1m47s
  3400K .......... .......... .......... .......... .......... 10%  228K 1m47s
  3450K .......... .......... .......... .......... .......... 11%  229K 1m47s
  3500K .......... .......... .......... .......... .......... 11%  228K 1m47s
  3550K .......... .......... .......... .......... .......... 11%  229K 1m47s
  3600K .......... .......... .......... .......... .......... 11% 11.0M 1m46s
  3650K .......... .......... .......... .......... .......... 11%  229K 1m46s
  3700K .......... .......... .......... .......... .......... 11%  228K 1m46s
  3750K .......... .......... .......... .......... .......... 12%  228K 1m46s
  3800K .......... .......... .......... .......... .......... 12%  228K 1m46s
  3850K .......... .......... .......... .......... .......... 12% 11.7M 1m44s
  3900K .......... .......... .......... .......... .......... 12%  228K 1m44s
  3950K .......... .......... .......... .......... .......... 12%  228K 1m44s
  4000K .......... .......... .......... .......... .......... 12%  228K 1m44s
  4050K .......... .......... .......... .......... .......... 13%  228K 1m44s
  4100K .......... .......... .......... .......... .......... 13% 11.1M 1m43s
  4150K .......... .......... .......... .......... .......... 13%  229K 1m43s
  4200K .......... .......... .......... .......... .......... 13%  229K 1m43s
  4250K .......... .......... .......... .......... .......... 13%  228K 1m43s
  4300K .......... .......... .......... .......... .......... 13%  229K 1m43s
  4350K .......... .......... .......... .......... .......... 13% 11.1M 1m41s
  4400K .......... .......... .......... .......... .......... 14%  229K 1m41s
  4450K .......... .......... .......... .......... .......... 14%  228K 1m41s
  4500K .......... .......... .......... .......... .......... 14%  228K 1m41s
  4550K .......... .......... .......... .......... .......... 14%  228K 1m41s
  4600K .......... .......... .......... .......... .......... 14% 11.0M 1m40s
  4650K .......... .......... .......... .......... .......... 14%  228K 1m40s
  4700K .......... .......... .......... .......... .......... 15%  229K 1m40s
  4750K .......... .......... .......... .......... .......... 15%  228K 1m40s
  4800K .......... .......... .......... .......... .......... 15%  228K 1m40s
  4850K .......... .......... .......... .......... .......... 15% 11.6M 99s
  4900K .......... .......... .......... .......... .......... 15%  228K 99s
  4950K .......... .......... .......... .......... .......... 15%  229K 99s
  5000K .......... .......... .......... .......... .......... 16%  228K 99s
  5050K .......... .......... .......... .......... .......... 16%  229K 99s
  5100K .......... .......... .......... .......... .......... 16% 11.0M 98s
  5150K .......... .......... .......... .......... .......... 16%  229K 98s
  5200K .......... .......... .......... .......... .......... 16%  229K 98s
  5250K .......... .......... .......... .......... .......... 16%  228K 98s
  5300K .......... .......... .......... .......... .......... 17%  228K 98s
  5350K .......... .......... .......... .......... .......... 17% 10.9M 97s
  5400K .......... .......... .......... .......... .......... 17%  229K 97s
  5450K .......... .......... .......... .......... .......... 17%  229K 97s
  5500K .......... .......... .......... .......... .......... 17%  229K 97s
  5550K .......... .......... .......... .......... .......... 17% 11.0M 96s
  5600K .......... .......... .......... .......... .......... 17%  229K 95s
  5650K .......... .......... .......... .......... .......... 18%  228K 95s
  5700K .......... .......... .......... .......... .......... 18%  228K 95s
  5750K .......... .......... .......... .......... .......... 18%  228K 95s
  5800K .......... .......... .......... .......... .......... 18% 11.6M 94s
  5850K .......... .......... .......... .......... .......... 18%  229K 94s
  5900K .......... .......... .......... .......... .......... 18%  229K 94s
  5950K .......... .......... .......... .......... .......... 19%  228K 94s
  6000K .......... .......... .......... .......... .......... 19%  228K 94s
  6050K .......... .......... .......... .......... .......... 19% 11.0M 93s
  6100K .......... .......... .......... .......... .......... 19%  228K 93s
  6150K .......... .......... .......... .......... .......... 19%  228K 93s
  6200K .......... .......... .......... .......... .......... 19%  228K 93s
  6250K .......... .......... .......... .......... .......... 20%  229K 93s
  6300K .......... .......... .......... .......... .......... 20% 11.6M 92s
  6350K .......... .......... .......... .......... .......... 20%  228K 92s
  6400K .......... .......... .......... .......... .......... 20%  229K 92s
  6450K .......... .......... .......... .......... .......... 20%  228K 92s
  6500K .......... .......... .......... .......... .......... 20%  228K 92s
  6550K .......... .......... .......... .......... .......... 20% 11.8M 91s
  6600K .......... .......... .......... .......... .......... 21%  229K 91s
  6650K .......... .......... .......... .......... .......... 21%  228K 91s
  6700K .......... .......... .......... .......... .......... 21%  228K 91s
  6750K .......... .......... .......... .......... .......... 21%  228K 91s
  6800K .......... .......... .......... .......... .......... 21% 11.6M 90s
  6850K .......... .......... .......... .......... .......... 21%  228K 90s
  6900K .......... .......... .......... .......... .......... 22%  229K 90s
  6950K .......... .......... .......... .......... .......... 22%  229K 90s
  7000K .......... .......... .......... .......... .......... 22%  229K 90s
  7050K .......... .......... .......... .......... .......... 22% 10.9M 89s
  7100K .......... .......... .......... .......... .......... 22%  229K 89s
  7150K .......... .......... .......... .......... .......... 22%  228K 89s
  7200K .......... .......... .......... .......... .......... 23%  229K 89s
  7250K .......... .......... .......... .......... .......... 23%  228K 89s
  7300K .......... .......... .......... .......... .......... 23% 11.7M 88s
  7350K .......... .......... .......... .......... .......... 23%  228K 88s
  7400K .......... .......... .......... .......... .......... 23%  229K 88s
  7450K .......... .......... .......... .......... .......... 23%  229K 88s
  7500K .......... .......... .......... .......... .......... 23%  228K 88s
  7550K .......... .......... .......... .......... .......... 24% 11.1M 87s
  7600K .......... .......... .......... .......... .......... 24%  229K 87s
  7650K .......... .......... .......... .......... .......... 24%  228K 87s
  7700K .......... .......... .......... .......... .......... 24%  228K 87s
  7750K .......... .......... .......... .......... .......... 24%  229K 87s
  7800K .......... .......... .......... .......... .......... 24% 11.0M 86s
  7850K .......... .......... .......... .......... .......... 25%  229K 86s
  7900K .......... .......... .......... .......... .......... 25%  228K 86s
  7950K .......... .......... .......... .......... .......... 25%  229K 86s
  8000K .......... .......... .......... .......... .......... 25%  228K 86s
  8050K .......... .......... .......... .......... .......... 25% 11.6M 85s
  8100K .......... .......... .......... .......... .......... 25%  229K 85s
  8150K .......... .......... .......... .......... .......... 26%  135K 85s
  8200K .......... .......... .......... .......... .......... 26% 83.5K 86s
  8250K .......... .......... .......... .......... .......... 26%  148M 86s
  8300K .......... .......... .......... .......... .......... 26%  171M 85s
  8350K .......... .......... .......... .......... .......... 26%  167M 84s
  8400K .......... .......... .......... .......... .......... 26%  389K 84s
  8450K .......... .......... .......... .......... .......... 27%  228K 84s
  8500K .......... .......... .......... .......... .......... 27%  229K 84s
  8550K .......... .......... .......... .......... .......... 27% 11.7M 83s
  8600K .......... .......... .......... .......... .......... 27%  228K 83s
  8650K .......... .......... .......... .......... .......... 27%  229K 83s
  8700K .......... .......... .......... .......... .......... 27%  229K 83s
  8750K .......... .......... .......... .......... .......... 27%  228K 83s
  8800K .......... .......... .......... .......... .......... 28% 11.7M 82s
  8850K .......... .......... .......... .......... .......... 28%  228K 82s
  8900K .......... .......... .......... .......... .......... 28%  229K 82s
  8950K .......... .......... .......... .......... .......... 28%  228K 82s
  9000K .......... .......... .......... .......... .......... 28% 11.6M 81s
  9050K .......... .......... .......... .......... .......... 28%  228K 81s
  9100K .......... .......... .......... .......... .......... 29%  229K 81s
  9150K .......... .......... .......... .......... .......... 29%  229K 81s
  9200K .......... .......... .......... .......... .......... 29%  228K 81s
  9250K .......... .......... .......... .......... .......... 29% 11.7M 80s
  9300K .......... .......... .......... .......... .......... 29%  228K 80s
  9350K .......... .......... .......... .......... .......... 29%  228K 80s
  9400K .......... .......... .......... .......... .......... 30%  229K 80s
  9450K .......... .......... .......... .......... .......... 30%  228K 80s
  9500K .......... .......... .......... .......... .......... 30% 11.0M 79s
  9550K .......... .......... .......... .......... .......... 30%  229K 79s
  9600K .......... .......... .......... .......... .......... 30%  228K 79s
  9650K .......... .......... .......... .......... .......... 30%  229K 79s
  9700K .......... .......... .......... .......... .......... 30%  228K 79s
  9750K .......... .......... .......... .......... .......... 31% 11.6M 78s
  9800K .......... .......... .......... .......... .......... 31%  228K 78s
  9850K .......... .......... .......... .......... .......... 31%  228K 78s
  9900K .......... .......... .......... .......... .......... 31%  229K 78s
  9950K .......... .......... .......... .......... .......... 31%  228K 78s
 10000K .......... .......... .......... .......... .......... 31% 11.7M 77s
 10050K .......... .......... .......... .......... .......... 32%  229K 77s
 10100K .......... .......... .......... .......... .......... 32%  229K 77s
 10150K .......... .......... .......... .......... .......... 32%  229K 77s
 10200K .......... .......... .......... .......... .......... 32%  229K 77s
 10250K .......... .......... .......... .......... .......... 32% 10.9M 76s
 10300K .......... .......... .......... .......... .......... 32%  229K 76s
 10350K .......... .......... .......... .......... .......... 33%  229K 76s
 10400K .......... .......... .......... .......... .......... 33%  229K 76s
 10450K .......... .......... .......... .......... .......... 33%  228K 76s
 10500K .......... .......... .......... .......... .......... 33% 11.8M 75s
 10550K .......... .......... .......... .......... .......... 33%  228K 75s
 10600K .......... .......... .......... .......... .......... 33%  228K 75s
 10650K .......... .......... .......... .......... .......... 34%  229K 75s
 10700K .......... .......... .......... .......... .......... 34%  229K 75s
 10750K .......... .......... .......... .......... .......... 34% 11.6M 74s
 10800K .......... .......... .......... .......... .......... 34%  229K 74s
 10850K .......... .......... .......... .......... .......... 34%  228K 74s
 10900K .......... .......... .......... .......... .......... 34%  228K 74s
 10950K .......... .......... .......... .......... .......... 34%  229K 74s
 11000K .......... .......... .......... .......... .......... 35% 11.0M 74s
 11050K .......... .......... .......... .......... .......... 35%  229K 73s
 11100K .......... .......... .......... .......... .......... 35%  229K 73s
 11150K .......... .......... .......... .......... .......... 35%  229K 73s
 11200K .......... .......... .......... .......... .......... 35%  228K 73s
 11250K .......... .......... .......... .......... .......... 35% 11.1M 73s
 11300K .......... .......... .......... .......... .......... 36%  228K 72s
 11350K .......... .......... .......... .......... .......... 36%  228K 72s
 11400K .......... .......... .......... .......... .......... 36%  229K 72s
 11450K .......... .......... .......... .......... .......... 36%  228K 72s
 11500K .......... .......... .......... .......... .......... 36% 11.6M 72s
 11550K .......... .......... .......... .......... .......... 36%  229K 72s
 11600K .......... .......... .......... .......... .......... 37%  229K 71s
 11650K .......... .......... .......... .......... .......... 37%  228K 71s
 11700K .......... .......... .......... .......... .......... 37%  229K 71s
 11750K .......... .......... .......... .......... .......... 37% 11.1M 71s
 11800K .......... .......... .......... .......... .......... 37%  229K 71s
 11850K .......... .......... .......... .......... .......... 37%  229K 71s
 11900K .......... .......... .......... .......... .......... 37%  228K 70s
 11950K .......... .......... .......... .......... .......... 38%  228K 70s
 12000K .......... .......... .......... .......... .......... 38% 11.8M 70s
 12050K .......... .......... .......... .......... .......... 38%  229K 70s
 12100K .......... .......... .......... .......... .......... 38%  228K 70s
 12150K .......... .......... .......... .......... .......... 38%  229K 69s
 12200K .......... .......... .......... .......... .......... 38% 11.7M 69s
 12250K .......... .......... .......... .......... .......... 39%  228K 69s
 12300K .......... .......... .......... .......... .......... 39%  228K 69s
 12350K .......... .......... .......... .......... .......... 39%  228K 69s
 12400K .......... .......... .......... .......... .......... 39%  229K 69s
 12450K .......... .......... .......... .......... .......... 39% 11.7M 68s
 12500K .......... .......... .......... .......... .......... 39%  229K 68s
 12550K .......... .......... .......... .......... .......... 40%  229K 68s
 12600K .......... .......... .......... .......... .......... 40%  228K 68s
 12650K .......... .......... .......... .......... .......... 40%  229K 68s
 12700K .......... .......... .......... .......... .......... 40% 11.0M 67s
 12750K .......... .......... .......... .......... .......... 40%  229K 67s
 12800K .......... .......... .......... .......... .......... 40%  229K 67s
 12850K .......... .......... .......... .......... .......... 40%  228K 67s
 12900K .......... .......... .......... .......... .......... 41%  229K 67s
 12950K .......... .......... .......... .......... .......... 41% 11.5M 66s
 13000K .......... .......... .......... .......... .......... 41%  229K 66s
 13050K .......... .......... .......... .......... .......... 41%  229K 66s
 13100K .......... .......... .......... .......... .......... 41%  228K 66s
 13150K .......... .......... .......... .......... .......... 41%  228K 66s
 13200K .......... .......... .......... .......... .......... 42% 11.5M 65s
 13250K .......... .......... .......... .......... .......... 42%  228K 65s
 13300K .......... .......... .......... .......... .......... 42%  229K 65s
 13350K .......... .......... .......... .......... .......... 42%  228K 65s
 13400K .......... .......... .......... .......... .......... 42%  228K 65s
 13450K .......... .......... .......... .......... .......... 42% 11.0M 64s
 13500K .......... .......... .......... .......... .......... 43%  229K 64s
 13550K .......... .......... .......... .......... .......... 43%  229K 64s
 13600K .......... .......... .......... .......... .......... 43%  229K 64s
 13650K .......... .......... .......... .......... .......... 43%  228K 64s
 13700K .......... .......... .......... .......... .......... 43% 10.8M 63s
 13750K .......... .......... .......... .......... .......... 43%  229K 63s
 13800K .......... .......... .......... .......... .......... 44%  228K 63s
 13850K .......... .......... .......... .......... .......... 44%  229K 63s
 13900K .......... .......... .......... .......... .......... 44%  228K 63s
 13950K .......... .......... .......... .......... .......... 44% 11.6M 63s
 14000K .......... .......... .......... .......... .......... 44%  229K 62s
 14050K .......... .......... .......... .......... .......... 44%  229K 62s
 14100K .......... .......... .......... .......... .......... 44%  228K 62s
 14150K .......... .......... .......... .......... .......... 45%  229K 62s
 14200K .......... .......... .......... .......... .......... 45% 11.0M 62s
 14250K .......... .......... .......... .......... .......... 45%  229K 62s
 14300K .......... .......... .......... .......... .......... 45%  228K 61s
 14350K .......... .......... .......... .......... .......... 45%  229K 61s
 14400K .......... .......... .......... .......... .......... 45%  228K 61s
 14450K .......... .......... .......... .......... .......... 46% 11.6M 61s
 14500K .......... .......... .......... .......... .......... 46%  229K 61s
 14550K .......... .......... .......... .......... .......... 46%  228K 60s
 14600K .......... .......... .......... .......... .......... 46%  228K 60s
 14650K .......... .......... .......... .......... .......... 46%  229K 60s
 14700K .......... .......... .......... .......... .......... 46% 11.1M 60s
 14750K .......... .......... .......... .......... .......... 47%  229K 60s
 14800K .......... .......... .......... .......... .......... 47%  228K 60s
 14850K .......... .......... .......... .......... .......... 47%  228K 59s
 14900K .......... .......... .......... .......... .......... 47%  228K 59s
 14950K .......... .......... .......... .......... .......... 47% 11.6M 59s
 15000K .......... .......... .......... .......... .......... 47%  229K 59s
 15050K .......... .......... .......... .......... .......... 47%  228K 59s
 15100K .......... .......... .......... .......... .......... 48%  228K 58s
 15150K .......... .......... .......... .......... .......... 48%  229K 58s
 15200K .......... .......... .......... .......... .......... 48% 11.5M 58s
 15250K .......... .......... .......... .......... .......... 48%  228K 58s
 15300K .......... .......... .......... .......... .......... 48%  228K 58s
 15350K .......... .......... .......... .......... .......... 48%  229K 58s
 15400K .......... .......... .......... .......... .......... 49%  228K 57s
 15450K .......... .......... .......... .......... .......... 49% 11.6M 57s
 15500K .......... .......... .......... .......... .......... 49%  228K 57s
 15550K .......... .......... .......... .......... .......... 49%  228K 57s
 15600K .......... .......... .......... .......... .......... 49%  229K 57s
 15650K .......... .......... .......... .......... .......... 49% 11.7M 56s
 15700K .......... .......... .......... .......... .......... 50%  228K 56s
 15750K .......... .......... .......... .......... .......... 50%  228K 56s
 15800K .......... .......... .......... .......... .......... 50%  229K 56s
 15850K .......... .......... .......... .......... .......... 50%  228K 56s
 15900K .......... .......... .......... .......... .......... 50% 11.6M 55s
 15950K .......... .......... .......... .......... .......... 50%  229K 55s
 16000K .......... .......... .......... .......... .......... 51%  228K 55s
 16050K .......... .......... .......... .......... .......... 51%  228K 55s
 16100K .......... .......... .......... .......... .......... 51%  229K 55s
 16150K .......... .......... .......... .......... .......... 51% 10.8M 55s
 16200K .......... .......... .......... .......... .......... 51%  228K 54s
 16250K .......... .......... .......... .......... .......... 51%  228K 54s
 16300K .......... .......... .......... .......... .......... 51%  228K 54s
 16350K .......... .......... .......... .......... .......... 52%  229K 54s
 16400K .......... .......... .......... .......... .......... 52% 11.7M 54s
 16450K .......... .......... .......... .......... .......... 52%  228K 53s
 16500K .......... .......... .......... .......... .......... 52%  229K 53s
 16550K .......... .......... .......... .......... .......... 52%  228K 53s
 16600K .......... .......... .......... .......... .......... 52%  229K 53s
 16650K .......... .......... .......... .......... .......... 53% 11.5M 53s
 16700K .......... .......... .......... .......... .......... 53%  229K 53s
 16750K .......... .......... .......... .......... .......... 53%  228K 52s
 16800K .......... .......... .......... .......... .......... 53%  228K 52s
 16850K .......... .......... .......... .......... .......... 53%  229K 52s
 16900K .......... .......... .......... .......... .......... 53% 11.0M 52s
 16950K .......... .......... .......... .......... .......... 54%  228K 52s
 17000K .......... .......... .......... .......... .......... 54%  228K 52s
 17050K .......... .......... .......... .......... .......... 54%  228K 51s
 17100K .......... .......... .......... .......... .......... 54%  229K 51s
 17150K .......... .......... .......... .......... .......... 54% 11.5M 51s
 17200K .......... .......... .......... .......... .......... 54%  228K 51s
 17250K .......... .......... .......... .......... .......... 54%  228K 51s
 17300K .......... .......... .......... .......... .......... 55%  228K 50s
 17350K .......... .......... .......... .......... .......... 55%  229K 50s
 17400K .......... .......... .......... .......... .......... 55% 11.7M 50s
 17450K .......... .......... .......... .......... .......... 55%  228K 50s
 17500K .......... .......... .......... .......... .......... 55%  229K 50s
 17550K .......... .......... .......... .......... .......... 55%  228K 50s
 17600K .......... .......... .......... .......... .......... 56%  229K 49s
 17650K .......... .......... .......... .......... .......... 56% 11.0M 49s
 17700K .......... .......... .......... .......... .......... 56%  228K 49s
 17750K .......... .......... .......... .......... .......... 56%  229K 49s
 17800K .......... .......... .......... .......... .......... 56%  229K 49s
 17850K .......... .......... .......... .......... .......... 56%  228K 48s
 17900K .......... .......... .......... .......... .......... 57% 11.6M 48s
 17950K .......... .......... .......... .......... .......... 57%  229K 48s
 18000K .......... .......... .......... .......... .......... 57%  228K 48s
 18050K .......... .......... .......... .......... .......... 57%  229K 48s
 18100K .......... .......... .......... .......... .......... 57%  228K 48s
 18150K .......... .......... .......... .......... .......... 57% 11.5M 47s
 18200K .......... .......... .......... .......... .......... 57%  229K 47s
 18250K .......... .......... .......... .......... .......... 58%  229K 47s
 18300K .......... .......... .......... .......... .......... 58%  228K 47s
 18350K .......... .......... .......... .......... .......... 58%  229K 47s
 18400K .......... .......... .......... .......... .......... 58% 11.1M 46s
 18450K .......... .......... .......... .......... .......... 58%  229K 46s
 18500K .......... .......... .......... .......... .......... 58%  228K 46s
 18550K .......... .......... .......... .......... .......... 59%  228K 46s
 18600K .......... .......... .......... .......... .......... 59%  228K 46s
 18650K .......... .......... .......... .......... .......... 59% 11.6M 45s
 18700K .......... .......... .......... .......... .......... 59%  228K 45s
 18750K .......... .......... .......... .......... .......... 59%  228K 45s
 18800K .......... .......... .......... .......... .......... 59%  229K 45s
 18850K .......... .......... .......... .......... .......... 60%  228K 45s
 18900K .......... .......... .......... .......... .......... 60% 11.0M 45s
 18950K .......... .......... .......... .......... .......... 60%  229K 44s
 19000K .......... .......... .......... .......... .......... 60%  229K 44s
 19050K .......... .......... .......... .......... .......... 60%  228K 44s
 19100K .......... .......... .......... .......... .......... 60% 1.17M 44s
 19150K .......... .......... .......... .......... .......... 61%  275K 44s
 19200K .......... .......... .......... .......... .......... 61%  228K 44s
 19250K .......... .......... .......... .......... .......... 61%  229K 43s
 19300K .......... .......... .......... .......... .......... 61%  228K 43s
 19350K .......... .......... .......... .......... .......... 61% 1.16M 43s
 19400K .......... .......... .......... .......... .......... 61%  277K 43s
 19450K .......... .......... .......... .......... .......... 61%  229K 43s
 19500K .......... .......... .......... .......... .......... 62%  228K 42s
 19550K .......... .......... .......... .......... .......... 62%  229K 42s
 19600K .......... .......... .......... .......... .......... 62% 1.13M 42s
 19650K .......... .......... .......... .......... .......... 62%  277K 42s
 19700K .......... .......... .......... .......... .......... 62%  228K 42s
 19750K .......... .......... .......... .......... .......... 62%  229K 42s
 19800K .......... .......... .......... .......... .......... 63%  229K 41s
 19850K .......... .......... .......... .......... .......... 63% 1.18M 41s
 19900K .......... .......... .......... .......... .......... 63%  275K 41s
 19950K .......... .......... .......... .......... .......... 63%  228K 41s
 20000K .......... .......... .......... .......... .......... 63%  228K 41s
 20050K .......... .......... .......... .......... .......... 63%  229K 41s
 20100K .......... .......... .......... .......... .......... 64% 1.19M 40s
 20150K .......... .......... .......... .......... .......... 64%  274K 40s
 20200K .......... .......... .......... .......... .......... 64%  228K 40s
 20250K .......... .......... .......... .......... .......... 64%  229K 40s
 20300K .......... .......... .......... .......... .......... 64%  229K 40s
 20350K .......... .......... .......... .......... .......... 64% 1.16M 39s
 20400K .......... .......... .......... .......... .......... 64%  276K 39s
 20450K .......... .......... .......... .......... .......... 65%  228K 39s
 20500K .......... .......... .......... .......... .......... 65%  229K 39s
 20550K .......... .......... .......... .......... .......... 65%  228K 39s
 20600K .......... .......... .......... .......... .......... 65% 11.7M 38s
 20650K .......... .......... .......... .......... .......... 65%  229K 38s
 20700K .......... .......... .......... .......... .......... 65%  229K 38s
 20750K .......... .......... .......... .......... .......... 66%  228K 38s
 20800K .......... .......... .......... .......... .......... 66%  228K 38s
 20850K .......... .......... .......... .......... .......... 66% 11.0M 38s
 20900K .......... .......... .......... .......... .......... 66%  229K 37s
 20950K .......... .......... .......... .......... .......... 66%  228K 37s
 21000K .......... .......... .......... .......... .......... 66%  228K 37s
 21050K .......... .......... .......... .......... .......... 67%  229K 37s
 21100K .......... .......... .......... .......... .......... 67% 11.7M 37s
 21150K .......... .......... .......... .......... .......... 67%  229K 37s
 21200K .......... .......... .......... .......... .......... 67%  228K 36s
 21250K .......... .......... .......... .......... .......... 67%  229K 36s
 21300K .......... .......... .......... .......... .......... 67%  228K 36s
 21350K .......... .......... .......... .......... .......... 68% 10.9M 36s
 21400K .......... .......... .......... .......... .......... 68%  229K 36s
 21450K .......... .......... .......... .......... .......... 68%  229K 35s
 21500K .......... .......... .......... .......... .......... 68%  228K 35s
 21550K .......... .......... .......... .......... .......... 68%  229K 35s
 21600K .......... .......... .......... .......... .......... 68% 11.0M 35s
 21650K .......... .......... .......... .......... .......... 68%  229K 35s
 21700K .......... .......... .......... .......... .......... 69%  229K 35s
 21750K .......... .......... .......... .......... .......... 69%  228K 34s
 21800K .......... .......... .......... .......... .......... 69%  229K 34s
 21850K .......... .......... .......... .......... .......... 69% 11.0M 34s
 21900K .......... .......... .......... .......... .......... 69%  228K 34s
 21950K .......... .......... .......... .......... .......... 69%  228K 34s
 22000K .......... .......... .......... .......... .......... 70%  228K 34s
 22050K .......... .......... .......... .......... .......... 70%  229K 33s
 22100K .......... .......... .......... .......... .......... 70% 11.5M 33s
 22150K .......... .......... .......... .......... .......... 70%  228K 33s
 22200K .......... .......... .......... .......... .......... 70%  228K 33s
 22250K .......... .......... .......... .......... .......... 70%  228K 33s
 22300K .......... .......... .......... .......... .......... 71% 1.05M 32s
 22350K .......... .......... .......... .......... .......... 71%  283K 32s
 22400K .......... .......... .......... .......... .......... 71%  228K 32s
 22450K .......... .......... .......... .......... .......... 71%  229K 32s
 22500K .......... .......... .......... .......... .......... 71%  228K 32s
 22550K .......... .......... .......... .......... .......... 71% 1.03M 32s
 22600K .......... .......... .......... .......... .......... 71%  284K 31s
 22650K .......... .......... .......... .......... .......... 72%  229K 31s
 22700K .......... .......... .......... .......... .......... 72%  229K 31s
 22750K .......... .......... .......... .......... .......... 72%  228K 31s
 22800K .......... .......... .......... .......... .......... 72% 1.02M 31s
 22850K .......... .......... .......... .......... .......... 72%  285K 30s
 22900K .......... .......... .......... .......... .......... 72%  229K 30s
 22950K .......... .......... .......... .......... .......... 73%  229K 30s
 23000K .......... .......... .......... .......... .......... 73%  228K 30s
 23050K .......... .......... .......... .......... .......... 73% 1.01M 30s
 23100K .......... .......... .......... .......... .......... 73%  286K 30s
 23150K .......... .......... .......... .......... .......... 73%  229K 29s
 23200K .......... .......... .......... .......... .......... 73%  228K 29s
 23250K .......... .......... .......... .......... .......... 74%  228K 29s
 23300K .......... .......... .......... .......... .......... 74% 1024K 29s
 23350K .......... .......... .......... .......... .......... 74%  287K 29s
 23400K .......... .......... .......... .......... .......... 74%  229K 28s
 23450K .......... .......... .......... .......... .......... 74%  229K 28s
 23500K .......... .......... .......... .......... .......... 74%  229K 28s
 23550K .......... .......... .......... .......... .......... 75% 1004K 28s
 23600K .......... .......... .......... .......... .......... 75%  288K 28s
 23650K .......... .......... .......... .......... .......... 75%  228K 28s
 23700K .......... .......... .......... .......... .......... 75%  229K 27s
 23750K .......... .......... .......... .......... .......... 75%  228K 27s
 23800K .......... .......... .......... .......... .......... 75% 11.1M 27s
 23850K .......... .......... .......... .......... .......... 75%  229K 27s
 23900K .......... .......... .......... .......... .......... 76%  228K 27s
 23950K .......... .......... .......... .......... .......... 76%  229K 27s
 24000K .......... .......... .......... .......... .......... 76%  228K 26s
 24050K .......... .......... .......... .......... .......... 76% 11.3M 26s
 24100K .......... .......... .......... .......... .......... 76%  228K 26s
 24150K .......... .......... .......... .......... .......... 76%  228K 26s
 24200K .......... .......... .......... .......... .......... 77%  228K 26s
 24250K .......... .......... .......... .......... .......... 77%  229K 25s
 24300K .......... .......... .......... .......... .......... 77% 10.8M 25s
 24350K .......... .......... .......... .......... .......... 77%  229K 25s
 24400K .......... .......... .......... .......... .......... 77%  228K 25s
 24450K .......... .......... .......... .......... .......... 77%  229K 25s
 24500K .......... .......... .......... .......... .......... 78%  228K 25s
 24550K .......... .......... .......... .......... .......... 78% 10.9M 24s
 24600K .......... .......... .......... .......... .......... 78%  228K 24s
 24650K .......... .......... .......... .......... .......... 78%  228K 24s
 24700K .......... .......... .......... .......... .......... 78%  229K 24s
 24750K .......... .......... .......... .......... .......... 78%  228K 24s
 24800K .......... .......... .......... .......... .......... 78% 11.5M 23s
 24850K .......... .......... .......... .......... .......... 79%  228K 23s
 24900K .......... .......... .......... .......... .......... 79%  229K 23s
 24950K .......... .......... .......... .......... .......... 79%  229K 23s
 25000K .......... .......... .......... .......... .......... 79%  228K 23s
 25050K .......... .......... .......... .......... .......... 79% 11.0M 23s
 25100K .......... .......... .......... .......... .......... 79%  229K 22s
 25150K .......... .......... .......... .......... .......... 80%  229K 22s
 25200K .......... .......... .......... .......... .......... 80%  228K 22s
 25250K .......... .......... .......... .......... .......... 80%  228K 22s
 25300K .......... .......... .......... .......... .......... 80% 11.0M 22s
 25350K .......... .......... .......... .......... .......... 80%  228K 22s
 25400K .......... .......... .......... .......... .......... 80%  229K 21s
 25450K .......... .......... .......... .......... .......... 81%  229K 21s
 25500K .......... .......... .......... .......... .......... 81%  228K 21s
 25550K .......... .......... .......... .......... .......... 81% 11.5M 21s
 25600K .......... .......... .......... .......... .......... 81%  228K 21s
 25650K .......... .......... .......... .......... .......... 81%  229K 20s
 25700K .......... .......... .......... .......... .......... 81%  229K 20s
 25750K .......... .......... .......... .......... .......... 81%  885K 20s
 25800K .......... .......... .......... .......... .......... 82%  300K 20s
 25850K .......... .......... .......... .......... .......... 82%  229K 20s
 25900K .......... .......... .......... .......... .......... 82%  229K 20s
 25950K .......... .......... .......... .......... .......... 82%  229K 19s
 26000K .......... .......... .......... .......... .......... 82%  867K 19s
 26050K .......... .......... .......... .......... .......... 82%  301K 19s
 26100K .......... .......... .......... .......... .......... 83%  228K 19s
 26150K .......... .......... .......... .......... .......... 83%  229K 19s
 26200K .......... .......... .......... .......... .......... 83%  229K 19s
 26250K .......... .......... .......... .......... .......... 83%  849K 18s
 26300K .......... .......... .......... .......... .......... 83%  303K 18s
 26350K .......... .......... .......... .......... .......... 83%  229K 18s
 26400K .......... .......... .......... .......... .......... 84%  228K 18s
 26450K .......... .......... .......... .......... .......... 84%  229K 18s
 26500K .......... .......... .......... .......... .......... 84%  863K 17s
 26550K .......... .......... .......... .......... .......... 84%  302K 17s
 26600K .......... .......... .......... .......... .......... 84%  228K 17s
 26650K .......... .......... .......... .......... .......... 84%  228K 17s
 26700K .......... .......... .......... .......... .......... 85%  229K 17s
 26750K .......... .......... .......... .......... .......... 85%  850K 17s
 26800K .......... .......... .......... .......... .......... 85%  303K 16s
 26850K .......... .......... .......... .......... .......... 85%  228K 16s
 26900K .......... .......... .......... .......... .......... 85%  229K 16s
 26950K .......... .......... .......... .......... .......... 85%  229K 16s
 27000K .......... .......... .......... .......... .......... 85%  844K 16s
 27050K .......... .......... .......... .......... .......... 86%  304K 15s
 27100K .......... .......... .......... .......... .......... 86%  229K 15s
 27150K .......... .......... .......... .......... .......... 86%  228K 15s
 27200K .......... .......... .......... .......... .......... 86%  229K 15s
 27250K .......... .......... .......... .......... .......... 86% 11.0M 15s
 27300K .......... .......... .......... .......... .......... 86%  228K 15s
 27350K .......... .......... .......... .......... .......... 87%  229K 14s
 27400K .......... .......... .......... .......... .......... 87%  229K 14s
 27450K .......... .......... .......... .......... .......... 87%  228K 14s
 27500K .......... .......... .......... .......... .......... 87% 11.5M 14s
 27550K .......... .......... .......... .......... .......... 87%  228K 14s
 27600K .......... .......... .......... .......... .......... 87%  228K 14s
 27650K .......... .......... .......... .......... .......... 88%  228K 13s
 27700K .......... .......... .......... .......... .......... 88%  228K 13s
 27750K .......... .......... .......... .......... .......... 88% 11.1M 13s
 27800K .......... .......... .......... .......... .......... 88%  228K 13s
 27850K .......... .......... .......... .......... .......... 88%  228K 13s
 27900K .......... .......... .......... .......... .......... 88%  229K 12s
 27950K .......... .......... .......... .......... .......... 88%  229K 12s
 28000K .......... .......... .......... .......... .......... 89% 11.7M 12s
 28050K .......... .......... .......... .......... .......... 89%  228K 12s
 28100K .......... .......... .......... .......... .......... 89%  229K 12s
 28150K .......... .......... .......... .......... .......... 89%  228K 12s
 28200K .......... .......... .......... .......... .......... 89%  229K 11s
 28250K .......... .......... .......... .......... .......... 89% 11.5M 11s
 28300K .......... .......... .......... .......... .......... 90%  229K 11s
 28350K .......... .......... .......... .......... .......... 90%  229K 11s
 28400K .......... .......... .......... .......... .......... 90%  229K 11s
 28450K .......... .......... .......... .......... .......... 90%  228K 11s
 28500K .......... .......... .......... .......... .......... 90% 11.8M 10s
 28550K .......... .......... .......... .......... .......... 90%  229K 10s
 28600K .......... .......... .......... .......... .......... 91%  228K 10s
 28650K .......... .......... .......... .......... .......... 91%  228K 10s
 28700K .......... .......... .......... .......... .......... 91%  229K 10s
 28750K .......... .......... .......... .......... .......... 91% 11.6M 9s
 28800K .......... .......... .......... .......... .......... 91%  228K 9s
 28850K .......... .......... .......... .......... .......... 91%  229K 9s
 28900K .......... .......... .......... .......... .......... 92%  228K 9s
 28950K .......... .......... .......... .......... .......... 92%  769K 9s
 29000K .......... .......... .......... .......... .......... 92%  317K 9s
 29050K .......... .......... .......... .......... .......... 92%  229K 8s
 29100K .......... .......... .......... .......... .......... 92%  229K 8s
 29150K .......... .......... .......... .......... .......... 92%  228K 8s
 29200K .......... .......... .......... .......... .......... 92%  771K 8s
 29250K .......... .......... .......... .......... .......... 93%  317K 8s
 29300K .......... .......... .......... .......... .......... 93%  229K 7s
 29350K .......... .......... .......... .......... .......... 93%  229K 7s
 29400K .......... .......... .......... .......... .......... 93%  229K 7s
 29450K .......... .......... .......... .......... .......... 93%  763K 7s
 29500K .......... .......... .......... .......... .......... 93%  316K 7s
 29550K .......... .......... .......... .......... .......... 94%  229K 7s
 29600K .......... .......... .......... .......... .......... 94%  229K 6s
 29650K .......... .......... .......... .......... .......... 94%  228K 6s
 29700K .......... .......... .......... .......... .......... 94%  763K 6s
 29750K .......... .......... .......... .......... .......... 94%  317K 6s
 29800K .......... .......... .......... .......... .......... 94%  229K 6s
 29850K .......... .......... .......... .......... .......... 95%  229K 6s
 29900K .......... .......... .......... .......... .......... 95%  229K 5s
 29950K .......... .......... .......... .......... .......... 95%  763K 5s
 30000K .......... .......... .......... .......... .......... 95%  318K 5s
 30050K .......... .......... .......... .......... .......... 95%  229K 5s
 30100K .......... .......... .......... .......... .......... 95%  228K 5s
 30150K .......... .......... .......... .......... .......... 95%  229K 4s
 30200K .......... .......... .......... .......... .......... 96%  747K 4s
 30250K .......... .......... .......... .......... .......... 96%  319K 4s
 30300K .......... .......... .......... .......... .......... 96%  229K 4s
 30350K .......... .......... .......... .......... .......... 96%  228K 4s
 30400K .......... .......... .......... .......... .......... 96%  229K 4s
 30450K .......... .......... .......... .......... .......... 96% 11.6M 3s
 30500K .......... .......... .......... .......... .......... 97%  229K 3s
 30550K .......... .......... .......... .......... .......... 97%  229K 3s
 30600K .......... .......... .......... .......... .......... 97%  229K 3s
 30650K .......... .......... .......... .......... .......... 97%  228K 3s
 30700K .......... .......... .......... .......... .......... 97% 11.7M 3s
 30750K .......... .......... .......... .......... .......... 97%  229K 2s
 30800K .......... .......... .......... .......... .......... 98%  229K 2s
 30850K .......... .......... .......... .......... .......... 98%  228K 2s
 30900K .......... .......... .......... .......... .......... 98%  229K 2s
 30950K .......... .......... .......... .......... .......... 98% 11.0M 2s
 31000K .......... .......... .......... .......... .......... 98%  229K 1s
 31050K .......... .......... .......... .......... .......... 98%  229K 1s
 31100K .......... .......... .......... .......... .......... 98%  228K 1s
 31150K .......... .......... .......... .......... .......... 99%  228K 1s
 31200K .......... .......... .......... .......... .......... 99% 11.6M 1s
 31250K .......... .......... .......... .......... .......... 99%  229K 1s
 31300K .......... .......... .......... .......... .......... 99%  229K 0s
 31350K .......... .......... .......... .......... .......... 99%  229K 0s
 31400K .......... .......... .......... .......... .......... 99%  228K 0s
 31450K .......... .....                                      100% 13.1M=1m51s
2018-07-29 22:39:03 (282 KB/s) - ‘minotaur-externals-0.2.tar.gz’ saved [32220716/32220716]
configure: WARNING: Cannot find C-function for checking NaN.
configure: WARNING: No solver available, examples will not work.
../../../CoinUtils/src/CoinFactorization2.cpp: In member function 'int CoinFactorization::factorDense()':
../../../CoinUtils/src/CoinFactorization2.cpp:520:75: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
   newSize += (numberDense_+1)/(sizeof(CoinFactorizationDouble)/sizeof(int));
../../../CoinUtils/src/CoinFactorization2.cpp:521:81: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
   newSize += 2*((numberDense_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinFactorization2.cpp:522:78: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
   newSize += ((numberRows_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinLpIO.cpp: In member function 'void CoinLpIO::readLp(FILE*)':
../../../CoinUtils/src/CoinLpIO.cpp:2268:24: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
       int length=strlen(buff);
../../../CoinUtils/src/CoinLpIO.cpp:2320:24: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
       int length=strlen(next+1);
../../../CoinUtils/src/CoinStructuredModel.cpp: In member function 'int CoinStructuredModel::decompose(const CoinPackedMatrix&, const double*, const double*, const double*, const double*, const double*, int, int, int*, double)':
../../../CoinUtils/src/CoinStructuredModel.cpp:761:10: warning: variable 'goodDW' set but not used [-Wunused-but-set-variable]
     bool goodDW=true;
../../../CoinUtils/src/CoinStructuredModel.cpp:1343:10: warning: variable 'goodBenders' set but not used [-Wunused-but-set-variable]
     bool goodBenders=true;
../../../CoinUtils/src/CoinMpsIO.cpp: In member function 'int CoinMpsIO::readConicMps(const char*, int*&, int*&, int*&, int&)':
../../../CoinUtils/src/CoinMpsIO.cpp:5814:3: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
   if ( cardReader_->whichSection (  ) == COIN_NAME_SECTION )
../../../CoinUtils/src/CoinMpsIO.cpp:5816:5: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
     if ( cardReader_->whichSection (  ) == COIN_CONIC_SECTION ) {
../../../CoinUtils/src/CoinPresolveDual.cpp: In static member function 'static const CoinPresolveAction* remove_dual_action::presolve(CoinPresolveMatrix*, const CoinPresolveAction*)':
../../../CoinUtils/src/CoinPresolveDual.cpp:236:20: warning: unused variable 'lb' [-Wunused-variable]
       const double lb = clo[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:237:20: warning: unused variable 'ub' [-Wunused-variable]
       const double ub = cup[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:642:13: warning: unused variable 'no_clb' [-Wunused-variable]
  const bool no_clb = (active[j]&5)==0 ;
../../../CoinUtils/src/CoinRational.cpp: In member function 'bool CoinRational::nearestRational_(double, double, long int)':
../../../CoinUtils/src/CoinRational.cpp:30:27: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
       double mediant = (a + c)/(double(b + d));
../../../CoinUtils/src/CoinRational.cpp:60:30: warning: conversion to 'long int' from 'double' may alter its value [-Wfloat-conversion]
    numerator_ += labs(intpart) * denominator_;
../../../CoinUtils/src/CoinRational.cpp:64:22: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
    return fabs(val - numerator_/double(denominator_)) <= maxdelta;
../../../CoinUtils/src/CoinWarmStartBasis.cpp: In member function 'bool CoinWarmStartBasis::fixFullBasis()':
../../../CoinUtils/src/CoinWarmStartBasis.cpp:494:7: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
       if (status==CoinWarmStartBasis::basic)
../../../CoinUtils/src/CoinWarmStartBasis.cpp:496:2: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
  numberBasic--;
In file included from ../../../../Osi/src/Osi/OsiColCut.cpp:10:0:
../../../../Osi/src/Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
../../../../Osi/src/Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
     if ( cutUbs.isExistingIndex(colIndx) )
../../../../Osi/src/Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
       if ( newLb > newUb )
../../../../Osi/src/Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
     if ( cutLbs.isExistingIndex(colIndx) )
../../../../Osi/src/Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
       if ( newUb < newLb )
In file included from ../../../../Osi/src/Osi/OsiCuts.hpp:14:0,
                 from ../../../../Osi/src/Osi/OsiCuts.cpp:13:
                 from ../../../../Osi/src/Osi/OsiRowCutDebugger.hpp:16,
                 from ../../../../Osi/src/Osi/OsiRowCutDebugger.cpp:19:
                 from ../../../../Osi/src/Osi/OsiSolverInterface.cpp:21:
../../../../Osi/src/Osi/OsiSolverInterface.cpp: In member function 'int OsiSolverInterface::differentModel(OsiSolverInterface&, bool)':
../../../../Osi/src/Osi/OsiSolverInterface.cpp:1880:8: warning: unused variable 'gotHint' [-Wunused-variable]
   bool gotHint = (getHintParam(OsiDoReducePrint,takeHint,strength));
libtool: install: warning: relinking `libOsi.la'
In file included from ../../../../Osi/src/OsiCommonTest/OsiColCutTest.cpp:13:0:
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
In file included from ../../../../Osi/src/OsiCommonTest/../Osi/OsiCuts.hpp:14:0,
                 from ../../../../Osi/src/OsiCommonTest/OsiCutsTest.cpp:9:
                 from ../../../../Osi/src/OsiCommonTest/../Osi/OsiRowCutDebugger.hpp:16,
                 from ../../../../Osi/src/OsiCommonTest/OsiRowCutDebuggerTest.cpp:9:
                 from ../../../../Osi/src/OsiCommonTest/OsiSolverInterfaceTest.cpp:84:
libtool: install: warning: relinking `libOsiCommonTests.la'
mkdir: cannot create directory '.libs': File exists
../../../Clp/src/ClpPlusMinusOneMatrix.cpp:459:13: warning: 'doPlusOnes' defined but not used [-Wunused-variable]
 static bool doPlusOnes=true;
../../../Clp/src/ClpSimplex.cpp: In member function 'int ClpSimplex::fathom(void*)':
../../../Clp/src/ClpSimplex.cpp:11081:15: warning: unused variable 'statusWeights' [-Wunused-variable]
           int statusWeights = fastDual2(info);
../../../Clp/src/ClpSimplexOther.cpp: In member function 'int ClpSimplexOther::setInDual(ClpSimplex*)':
../../../Clp/src/ClpSimplexOther.cpp:1313:12: warning: unused variable 'statusD' [-Wunused-variable]
     Status statusD = dualProblem->getRowStatus(iColumn);
../../../Clp/src/ClpSimplexOther.cpp:1314:12: warning: unused variable 'statusDJ' [-Wunused-variable]
     Status statusDJ = dualProblem->getColumnStatus(jColumn);
../../../Clp/src/ClpSimplexOther.cpp:1352:12: warning: unused variable 'statusD' [-Wunused-variable]
     Status statusD = dualProblem->getColumnStatus(iRow);
../../../Clp/src/ClpSolve.cpp: In member function 'int ClpSimplex::solveBenders(CoinStructuredModel*, ClpSolve&)':
../../../Clp/src/ClpSolve.cpp:7272:9: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
         if (saveLower[i] < -1.0e20);
../../../Clp/src/ClpSolve.cpp:7273:4: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
    solution[i]=0.0;
../../../Clp/src/ClpSolver.cpp: In function 'void statistics(ClpSimplex*, ClpSimplex*)':
../../../Clp/src/ClpSolver.cpp:3756:10: warning: variable 'numberWritten' set but not used [-Wunused-but-set-variable]
   size_t numberWritten;
libtool: install: warning: relinking `libClp.la'
libtool: install: warning: relinking `libClpSolver.la'
In file included from /home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiCuts.hpp:14:0,
                 from ../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:33:
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::initialSolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:148:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::resolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:843:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
   bool gotHint = (getHintParam(OsiDoInBranchAndCut,takeHint,strength));
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'int OsiClpSolverInterface::infeasibleOtherWay(char*)':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9986:24: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
    whichWay[iColumn] *=2;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9991:24: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9841:7: warning: unused variable 'iRow' [-Wunused-variable]
   int iRow,iColumn;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9859:17: warning: unused variable 'objective' [-Wunused-variable]
   const double *objective = getObjCoefficients() ;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9860:10: warning: unused variable 'direction' [-Wunused-variable]
   double direction = getObjSense();
libtool: install: warning: relinking `libOsiClp.la'
filteraux.f:105:24:
      .                  0.D0,.false.)
                        1
Warning: Rank mismatch in argument ‘w’ at (1) (rank-1 and scalar)
ar: creating libfiltersqp.a
ar: `u' modifier ignored since `D' is the default (see `U')
ar: creating amplsolver.a
../../../../src/cppunit/Protector.cpp: In member function 'void CppUnit::Protector::reportError(const CppUnit::ProtectorContext&, const CppUnit::Exception&) const':
../../../../src/cppunit/Protector.cpp:24:8: warning: 'template<class> class std::auto_ptr' is deprecated [-Wdeprecated-declarations]
   std::auto_ptr<Exception> actualError( error.clone() );
In file included from /usr/include/c++/6/memory:81:0,
                 from ../../../../src/cppunit/Protector.cpp:6:
/usr/include/c++/6/bits/unique_ptr.h:49:28: note: declared here
   template<typename> class auto_ptr;
../../../../src/cppunit/Protector.cpp: In member function 'void CppUnit::Protector::reportFailure(const CppUnit::ProtectorContext&, const CppUnit::Exception&) const':
../../../../src/cppunit/Protector.cpp:45:8: warning: 'template<class> class std::auto_ptr' is deprecated [-Wdeprecated-declarations]
   std::auto_ptr<Exception> actualFailure( failure.clone() );
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 196: cd: minotaur-externals//build: No such file or directory
make: *** No rule to make target 'distclean'.  Stop.
: logger ok! OK (41)
Errors in build-base-static:
CMake Error at CMakeLists.txt:217 (message):
   Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target 'install'.  Stop.
make: *** No rule to make target 'utest'.  Stop.
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Sun Jul 29 22:44:34 IST 2018
More information about the Minotaur-dev mailing list
