[Minotaur-dev] minotaur daily test results
amahajan
amahajan at iitb.ac.in
Tue Aug 7 12:14:41 CDT 2018
Minotaur daily test report
Tue Aug 7 22:37:01 IST 2018
origin.ieor.iitb.ac.in
Linux origin 4.9.0-6-amd64 #1 SMP Debian 4.9.82-1+deb9u3 (2018-03-02) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-63-gfee696e
ls: cannot access 'build-ampl/bin': No such file or directory
ls: cannot access 'build-ampl/lib': No such file or directory
ls: cannot access 'build-ampl/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-debug/bin': No such file or directory
ls: cannot access 'build-ampl-debug/lib': No such file or directory
ls: cannot access 'build-ampl-debug/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-static/bin': No such file or directory
ls: cannot access 'build-ampl-static/lib': No such file or directory
ls: cannot access 'build-ampl-static/include/minotaur/*': No such file or directory
ls: cannot access 'build-all/bin': No such file or directory
ls: cannot access 'build-all/lib': No such file or directory
ls: cannot access 'build-all/include/minotaur/*': No such file or directory
ls: cannot access 'build-all-debug/bin': No such file or directory
ls: cannot access 'build-all-debug/lib': No such file or directory
ls: cannot access 'build-all-debug/include/minotaur/*': No such file or directory
./daily-lnx-iit-test.sh: line 272: cd: build-all-debug/src/testing: No such file or directory
./daily-lnx-iit-test.sh: line 273: ../../../build-all-debug.out: Permission denied
./daily-lnx-iit-test.sh: line 47: ./scripts/build_with_externals: No such file or directory
./daily-lnx-iit-test.sh: line 50: cd: build-all-static: No such file or directory
ls: cannot access 'build-all-static/bin': No such file or directory
ls: cannot access 'build-all-static/lib': No such file or directory
ls: cannot access 'build-all-static/include/minotaur/*': No such file or directory
rsync: change_dir "/home/amahajan/tmp/minotaur-test/build-all/doxygen/html" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1196) [sender=3.1.2]
Summary
compiling build-base: OK.
make utest output for build-base: OK (41)
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libmntrampl.a not built.
Errors:
Errors in build-all-debug:
CMake Error at CMakeLists.txt:217 (message):
Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target 'install'. Stop.
make: *** No rule to make target 'utest'. Stop.
Errors in build-all:
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/ipopt-3.12.7/build/include: No such file or directory [-Wmissing-include-dirs]
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/clp-1.16.9/build/include: No such file or directory [-Wmissing-include-dirs]
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/asl-20161228: No such file or directory [-Wmissing-include-dirs]
/home/amahajan/tmp/minotaur-test/src/engines/OsiLP/OsiLPEngine.cpp:18:42: fatal error: coin/OsiClpSolverInterface.hpp: No such file or directory
#include "coin/OsiClpSolverInterface.hpp"
compilation terminated.
make: *** [/home/amahajan/tmp/minotaur-test/src/engines/OsiLP/OsiLPEngine.o] Error 1
Errors in build-all-static:
Errors in build-ampl-debug:
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
Errors in build-base:
--2018-08-07 22:37:05-- http://www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz
Resolving netmon.iitb.ac.in (netmon.iitb.ac.in)... 10.201.13.50
Connecting to netmon.iitb.ac.in (netmon.iitb.ac.in)|10.201.13.50|:80... connected.
Proxy request sent, awaiting response... 200 OK
Length: 32220716 (31M) [application/x-gzip]
Saving to: ‘minotaur-externals-0.2.tar.gz’
0K .......... .......... .......... .......... .......... 0% 70.4K 7m26s
50K .......... .......... .......... .......... .......... 0% 105K 6m11s
100K .......... .......... .......... .......... .......... 0% 106K 5m46s
150K .......... .......... .......... .......... .......... 0% 210K 4m56s
200K .......... .......... .......... .......... .......... 0% 211K 4m26s
250K .......... .......... .......... .......... .......... 0% 211K 4m6s
300K .......... .......... .......... .......... .......... 1% 212K 3m51s
350K .......... .......... .......... .......... .......... 1% 11.0M 3m23s
400K .......... .......... .......... .......... .......... 1% 212K 3m16s
450K .......... .......... .......... .......... .......... 1% 212K 3m11s
500K .......... .......... .......... .......... .......... 1% 212K 3m6s
550K .......... .......... .......... .......... .......... 1% 213K 3m3s
600K .......... .......... .......... .......... .......... 2% 10.9M 2m49s
650K .......... .......... .......... .......... .......... 2% 212K 2m47s
700K .......... .......... .......... .......... .......... 2% 212K 2m45s
750K .......... .......... .......... .......... .......... 2% 213K 2m43s
800K .......... .......... .......... .......... .......... 2% 212K 2m42s
850K .......... .......... .......... .......... .......... 2% 10.9M 2m33s
900K .......... .......... .......... .......... .......... 3% 212K 2m32s
950K .......... .......... .......... .......... .......... 3% 213K 2m31s
1000K .......... .......... .......... .......... .......... 3% 212K 2m31s
1050K .......... .......... .......... .......... .......... 3% 212K 2m30s
1100K .......... .......... .......... .......... .......... 3% 11.6M 2m24s
1150K .......... .......... .......... .......... .......... 3% 212K 2m23s
1200K .......... .......... .......... .......... .......... 3% 212K 2m23s
1250K .......... .......... .......... .......... .......... 4% 212K 2m23s
1300K .......... .......... .......... .......... .......... 4% 213K 2m23s
1350K .......... .......... .......... .......... .......... 4% 10.9M 2m17s
1400K .......... .......... .......... .......... .......... 4% 212K 2m17s
1450K .......... .......... .......... .......... .......... 4% 212K 2m17s
1500K .......... .......... .......... .......... .......... 4% 212K 2m17s
1550K .......... .......... .......... .......... .......... 5% 212K 2m17s
1600K .......... .......... .......... .......... .......... 5% 11.7M 2m13s
1650K .......... .......... .......... .......... .......... 5% 212K 2m13s
1700K .......... .......... .......... .......... .......... 5% 212K 2m13s
1750K .......... .......... .......... .......... .......... 5% 212K 2m13s
1800K .......... .......... .......... .......... .......... 5% 213K 2m13s
1850K .......... .......... .......... .......... .......... 6% 9.08M 2m9s
1900K .......... .......... .......... .......... .......... 6% 212K 2m9s
1950K .......... .......... .......... .......... .......... 6% 213K 2m9s
2000K .......... .......... .......... .......... .......... 6% 212K 2m9s
2050K .......... .......... .......... .......... .......... 6% 213K 2m9s
2100K .......... .......... .......... .......... .......... 6% 9.50M 2m6s
2150K .......... .......... .......... .......... .......... 6% 213K 2m6s
2200K .......... .......... .......... .......... .......... 7% 212K 2m6s
2250K .......... .......... .......... .......... .......... 7% 212K 2m6s
2300K .......... .......... .......... .......... .......... 7% 212K 2m6s
2350K .......... .......... .......... .......... .......... 7% 11.0M 2m3s
2400K .......... .......... .......... .......... .......... 7% 212K 2m3s
2450K .......... .......... .......... .......... .......... 7% 212K 2m3s
2500K .......... .......... .......... .......... .......... 8% 212K 2m3s
2550K .......... .......... .......... .......... .......... 8% 213K 2m3s
2600K .......... .......... .......... .......... .......... 8% 10.9M 2m1s
2650K .......... .......... .......... .......... .......... 8% 212K 2m1s
2700K .......... .......... .......... .......... .......... 8% 212K 2m1s
2750K .......... .......... .......... .......... .......... 8% 212K 2m1s
2800K .......... .......... .......... .......... .......... 9% 213K 2m1s
2850K .......... .......... .......... .......... .......... 9% 9.32M 1m59s
2900K .......... .......... .......... .......... .......... 9% 212K 1m59s
2950K .......... .......... .......... .......... .......... 9% 212K 1m59s
3000K .......... .......... .......... .......... .......... 9% 212K 1m59s
3050K .......... .......... .......... .......... .......... 9% 213K 1m59s
3100K .......... .......... .......... .......... .......... 10% 9.82M 1m57s
3150K .......... .......... .......... .......... .......... 10% 212K 1m57s
3200K .......... .......... .......... .......... .......... 10% 212K 1m57s
3250K .......... .......... .......... .......... .......... 10% 212K 1m57s
3300K .......... .......... .......... .......... .......... 10% 10.9M 1m55s
3350K .......... .......... .......... .......... .......... 10% 213K 1m55s
3400K .......... .......... .......... .......... .......... 10% 212K 1m55s
3450K .......... .......... .......... .......... .......... 11% 212K 1m55s
3500K .......... .......... .......... .......... .......... 11% 212K 1m55s
3550K .......... .......... .......... .......... .......... 11% 9.11M 1m54s
3600K .......... .......... .......... .......... .......... 11% 213K 1m54s
3650K .......... .......... .......... .......... .......... 11% 212K 1m54s
3700K .......... .......... .......... .......... .......... 11% 213K 1m54s
3750K .......... .......... .......... .......... .......... 12% 212K 1m54s
3800K .......... .......... .......... .......... .......... 12% 8.14M 1m52s
3850K .......... .......... .......... .......... .......... 12% 214K 1m52s
3900K .......... .......... .......... .......... .......... 12% 212K 1m52s
3950K .......... .......... .......... .......... .......... 12% 212K 1m52s
4000K .......... .......... .......... .......... .......... 12% 212K 1m52s
4050K .......... .......... .......... .......... .......... 13% 7.98M 1m51s
4100K .......... .......... .......... .......... .......... 13% 214K 1m51s
4150K .......... .......... .......... .......... .......... 13% 212K 1m51s
4200K .......... .......... .......... .......... .......... 13% 212K 1m51s
4250K .......... .......... .......... .......... .......... 13% 212K 1m51s
4300K .......... .......... .......... .......... .......... 13% 7.93M 1m49s
4350K .......... .......... .......... .......... .......... 13% 214K 1m49s
4400K .......... .......... .......... .......... .......... 14% 212K 1m49s
4450K .......... .......... .......... .......... .......... 14% 212K 1m49s
4500K .......... .......... .......... .......... .......... 14% 212K 1m49s
4550K .......... .......... .......... .......... .......... 14% 7.59M 1m48s
4600K .......... .......... .......... .......... .......... 14% 214K 1m48s
4650K .......... .......... .......... .......... .......... 14% 212K 1m48s
4700K .......... .......... .......... .......... .......... 15% 213K 1m48s
4750K .......... .......... .......... .......... .......... 15% 213K 1m48s
4800K .......... .......... .......... .......... .......... 15% 7.58M 1m47s
4850K .......... .......... .......... .......... .......... 15% 214K 1m47s
4900K .......... .......... .......... .......... .......... 15% 212K 1m47s
4950K .......... .......... .......... .......... .......... 15% 212K 1m46s
5000K .......... .......... .......... .......... .......... 16% 212K 1m46s
5050K .......... .......... .......... .......... .......... 16% 7.34M 1m45s
5100K .......... .......... .......... .......... .......... 16% 214K 1m45s
5150K .......... .......... .......... .......... .......... 16% 213K 1m45s
5200K .......... .......... .......... .......... .......... 16% 212K 1m45s
5250K .......... .......... .......... .......... .......... 16% 212K 1m45s
5300K .......... .......... .......... .......... .......... 17% 8.06M 1m44s
5350K .......... .......... .......... .......... .......... 17% 214K 1m44s
5400K .......... .......... .......... .......... .......... 17% 212K 1m44s
5450K .......... .......... .......... .......... .......... 17% 213K 1m44s
5500K .......... .......... .......... .......... .......... 17% 212K 1m44s
5550K .......... .......... .......... .......... .......... 17% 10.3M 1m43s
5600K .......... .......... .......... .......... .......... 17% 212K 1m43s
5650K .......... .......... .......... .......... .......... 18% 212K 1m43s
5700K .......... .......... .......... .......... .......... 18% 213K 1m43s
5750K .......... .......... .......... .......... .......... 18% 212K 1m43s
5800K .......... .......... .......... .......... .......... 18% 9.88M 1m42s
5850K .......... .......... .......... .......... .......... 18% 212K 1m42s
5900K .......... .......... .......... .......... .......... 18% 212K 1m42s
5950K .......... .......... .......... .......... .......... 19% 213K 1m41s
6000K .......... .......... .......... .......... .......... 19% 212K 1m41s
6050K .......... .......... .......... .......... .......... 19% 9.89M 1m40s
6100K .......... .......... .......... .......... .......... 19% 210K 1m40s
6150K .......... .......... .......... .......... .......... 19% 212K 1m40s
6200K .......... .......... .......... .......... .......... 19% 215K 1m40s
6250K .......... .......... .......... .......... .......... 20% 212K 1m40s
6300K .......... .......... .......... .......... .......... 20% 7.19M 99s
6350K .......... .......... .......... .......... .......... 20% 212K 99s
6400K .......... .......... .......... .......... .......... 20% 212K 99s
6450K .......... .......... .......... .......... .......... 20% 214K 99s
6500K .......... .......... .......... .......... .......... 20% 212K 99s
6550K .......... .......... .......... .......... .......... 20% 5.40M 98s
6600K .......... .......... .......... .......... .......... 21% 213K 98s
6650K .......... .......... .......... .......... .......... 21% 216K 98s
6700K .......... .......... .......... .......... .......... 21% 212K 98s
6750K .......... .......... .......... .......... .......... 21% 4.44M 97s
6800K .......... .......... .......... .......... .......... 21% 215K 97s
6850K .......... .......... .......... .......... .......... 21% 213K 97s
6900K .......... .......... .......... .......... .......... 22% 216K 97s
6950K .......... .......... .......... .......... .......... 22% 212K 97s
7000K .......... .......... .......... .......... .......... 22% 4.38M 96s
7050K .......... .......... .......... .......... .......... 22% 215K 96s
7100K .......... .......... .......... .......... .......... 22% 213K 96s
7150K .......... .......... .......... .......... .......... 22% 215K 96s
7200K .......... .......... .......... .......... .......... 23% 213K 96s
7250K .......... .......... .......... .......... .......... 23% 3.85M 95s
7300K .......... .......... .......... .......... .......... 23% 216K 95s
7350K .......... .......... .......... .......... .......... 23% 212K 95s
7400K .......... .......... .......... .......... .......... 23% 216K 95s
7450K .......... .......... .......... .......... .......... 23% 212K 95s
7500K .......... .......... .......... .......... .......... 23% 4.48M 94s
7550K .......... .......... .......... .......... .......... 24% 213K 94s
7600K .......... .......... .......... .......... .......... 24% 212K 94s
7650K .......... .......... .......... .......... .......... 24% 218K 94s
7700K .......... .......... .......... .......... .......... 24% 212K 93s
7750K .......... .......... .......... .......... .......... 24% 4.71M 93s
7800K .......... .......... .......... .......... .......... 24% 212K 93s
7850K .......... .......... .......... .......... .......... 25% 213K 93s
7900K .......... .......... .......... .......... .......... 25% 217K 92s
7950K .......... .......... .......... .......... .......... 25% 212K 92s
8000K .......... .......... .......... .......... .......... 25% 4.66M 92s
8050K .......... .......... .......... .......... .......... 25% 213K 92s
8100K .......... .......... .......... .......... .......... 25% 213K 91s
8150K .......... .......... .......... .......... .......... 26% 216K 91s
8200K .......... .......... .......... .......... .......... 26% 213K 91s
8250K .......... .......... .......... .......... .......... 26% 5.20M 91s
8300K .......... .......... .......... .......... .......... 26% 212K 90s
8350K .......... .......... .......... .......... .......... 26% 213K 90s
8400K .......... .......... .......... .......... .......... 26% 216K 90s
8450K .......... .......... .......... .......... .......... 27% 213K 90s
8500K .......... .......... .......... .......... .......... 27% 5.25M 89s
8550K .......... .......... .......... .......... .......... 27% 213K 89s
8600K .......... .......... .......... .......... .......... 27% 213K 89s
8650K .......... .......... .......... .......... .......... 27% 216K 89s
8700K .......... .......... .......... .......... .......... 27% 213K 89s
8750K .......... .......... .......... .......... .......... 27% 5.41M 88s
8800K .......... .......... .......... .......... .......... 28% 213K 88s
8850K .......... .......... .......... .......... .......... 28% 212K 88s
8900K .......... .......... .......... .......... .......... 28% 216K 88s
8950K .......... .......... .......... .......... .......... 28% 213K 88s
9000K .......... .......... .......... .......... .......... 28% 5.60M 87s
9050K .......... .......... .......... .......... .......... 28% 212K 87s
9100K .......... .......... .......... .......... .......... 29% 213K 87s
9150K .......... .......... .......... .......... .......... 29% 216K 87s
9200K .......... .......... .......... .......... .......... 29% 211K 87s
9250K .......... .......... .......... .......... .......... 29% 6.79M 86s
9300K .......... .......... .......... .......... .......... 29% 212K 86s
9350K .......... .......... .......... .......... .......... 29% 210K 86s
9400K .......... .......... .......... .......... .......... 30% 217K 86s
9450K .......... .......... .......... .......... .......... 30% 212K 86s
9500K .......... .......... .......... .......... .......... 30% 6.12M 85s
9550K .......... .......... .......... .......... .......... 30% 213K 85s
9600K .......... .......... .......... .......... .......... 30% 213K 85s
9650K .......... .......... .......... .......... .......... 30% 213K 85s
9700K .......... .......... .......... .......... .......... 30% 213K 85s
9750K .......... .......... .......... .......... .......... 31% 6.67M 84s
9800K .......... .......... .......... .......... .......... 31% 212K 84s
9850K .......... .......... .......... .......... .......... 31% 215K 84s
9900K .......... .......... .......... .......... .......... 31% 212K 84s
9950K .......... .......... .......... .......... .......... 31% 3.12M 83s
10000K .......... .......... .......... .......... .......... 31% 220K 83s
10050K .......... .......... .......... .......... .......... 32% 212K 83s
10100K .......... .......... .......... .......... .......... 32% 215K 83s
10150K .......... .......... .......... .......... .......... 32% 212K 83s
10200K .......... .......... .......... .......... .......... 32% 3.04M 82s
10250K .......... .......... .......... .......... .......... 32% 220K 82s
10300K .......... .......... .......... .......... .......... 32% 213K 82s
10350K .......... .......... .......... .......... .......... 33% 215K 82s
10400K .......... .......... .......... .......... .......... 33% 213K 82s
10450K .......... .......... .......... .......... .......... 33% 2.89M 81s
10500K .......... .......... .......... .......... .......... 33% 221K 81s
10550K .......... .......... .......... .......... .......... 33% 212K 81s
10600K .......... .......... .......... .......... .......... 33% 215K 81s
10650K .......... .......... .......... .......... .......... 34% 212K 81s
10700K .......... .......... .......... .......... .......... 34% 6.96M 80s
10750K .......... .......... .......... .......... .......... 34% 212K 80s
10800K .......... .......... .......... .......... .......... 34% 212K 80s
10850K .......... .......... .......... .......... .......... 34% 214K 80s
10900K .......... .......... .......... .......... .......... 34% 212K 80s
10950K .......... .......... .......... .......... .......... 34% 8.13M 79s
11000K .......... .......... .......... .......... .......... 35% 212K 79s
11050K .......... .......... .......... .......... .......... 35% 213K 79s
11100K .......... .......... .......... .......... .......... 35% 213K 79s
11150K .......... .......... .......... .......... .......... 35% 212K 79s
11200K .......... .......... .......... .......... .......... 35% 9.19M 78s
11250K .......... .......... .......... .......... .......... 35% 212K 78s
11300K .......... .......... .......... .......... .......... 36% 212K 78s
11350K .......... .......... .......... .......... .......... 36% 213K 78s
11400K .......... .......... .......... .......... .......... 36% 213K 78s
11450K .......... .......... .......... .......... .......... 36% 9.67M 77s
11500K .......... .......... .......... .......... .......... 36% 212K 77s
11550K .......... .......... .......... .......... .......... 36% 213K 77s
11600K .......... .......... .......... .......... .......... 37% 212K 77s
11650K .......... .......... .......... .......... .......... 37% 212K 77s
11700K .......... .......... .......... .......... .......... 37% 11.7M 76s
11750K .......... .......... .......... .......... .......... 37% 212K 76s
11800K .......... .......... .......... .......... .......... 37% 212K 76s
11850K .......... .......... .......... .......... .......... 37% 212K 76s
11900K .......... .......... .......... .......... .......... 37% 212K 76s
11950K .......... .......... .......... .......... .......... 38% 11.1M 75s
12000K .......... .......... .......... .......... .......... 38% 212K 75s
12050K .......... .......... .......... .......... .......... 38% 213K 75s
12100K .......... .......... .......... .......... .......... 38% 212K 75s
12150K .......... .......... .......... .......... .......... 38% 212K 75s
12200K .......... .......... .......... .......... .......... 38% 11.1M 74s
12250K .......... .......... .......... .......... .......... 39% 212K 74s
12300K .......... .......... .......... .......... .......... 39% 212K 74s
12350K .......... .......... .......... .......... .......... 39% 212K 74s
12400K .......... .......... .......... .......... .......... 39% 212K 74s
12450K .......... .......... .......... .......... .......... 39% 11.7M 73s
12500K .......... .......... .......... .......... .......... 39% 212K 73s
12550K .......... .......... .......... .......... .......... 40% 212K 73s
12600K .......... .......... .......... .......... .......... 40% 212K 73s
12650K .......... .......... .......... .......... .......... 40% 212K 73s
12700K .......... .......... .......... .......... .......... 40% 11.0M 72s
12750K .......... .......... .......... .......... .......... 40% 212K 72s
12800K .......... .......... .......... .......... .......... 40% 213K 72s
12850K .......... .......... .......... .......... .......... 40% 212K 72s
12900K .......... .......... .......... .......... .......... 41% 212K 72s
12950K .......... .......... .......... .......... .......... 41% 11.1M 71s
13000K .......... .......... .......... .......... .......... 41% 212K 71s
13050K .......... .......... .......... .......... .......... 41% 212K 71s
13100K .......... .......... .......... .......... .......... 41% 211K 71s
13150K .......... .......... .......... .......... .......... 41% 212K 71s
13200K .......... .......... .......... .......... .......... 42% 11.7M 70s
13250K .......... .......... .......... .......... .......... 42% 212K 70s
13300K .......... .......... .......... .......... .......... 42% 212K 70s
13350K .......... .......... .......... .......... .......... 42% 213K 70s
13400K .......... .......... .......... .......... .......... 42% 2.19M 69s
13450K .......... .......... .......... .......... .......... 42% 230K 69s
13500K .......... .......... .......... .......... .......... 43% 212K 69s
13550K .......... .......... .......... .......... .......... 43% 212K 69s
13600K .......... .......... .......... .......... .......... 43% 212K 69s
13650K .......... .......... .......... .......... .......... 43% 2.10M 68s
13700K .......... .......... .......... .......... .......... 43% 231K 68s
13750K .......... .......... .......... .......... .......... 43% 212K 68s
13800K .......... .......... .......... .......... .......... 44% 212K 68s
13850K .......... .......... .......... .......... .......... 44% 212K 68s
13900K .......... .......... .......... .......... .......... 44% 2.00M 67s
13950K .......... .......... .......... .......... .......... 44% 232K 67s
14000K .......... .......... .......... .......... .......... 44% 212K 67s
14050K .......... .......... .......... .......... .......... 44% 212K 67s
14100K .......... .......... .......... .......... .......... 44% 212K 67s
14150K .......... .......... .......... .......... .......... 45% 11.6M 66s
14200K .......... .......... .......... .......... .......... 45% 212K 66s
14250K .......... .......... .......... .......... .......... 45% 212K 66s
14300K .......... .......... .......... .......... .......... 45% 212K 66s
14350K .......... .......... .......... .......... .......... 45% 212K 66s
14400K .......... .......... .......... .......... .......... 45% 11.5M 66s
14450K .......... .......... .......... .......... .......... 46% 210K 65s
14500K .......... .......... .......... .......... .......... 46% 214K 65s
14550K .......... .......... .......... .......... .......... 46% 212K 65s
14600K .......... .......... .......... .......... .......... 46% 212K 65s
14650K .......... .......... .......... .......... .......... 46% 11.6M 65s
14700K .......... .......... .......... .......... .......... 46% 212K 64s
14750K .......... .......... .......... .......... .......... 47% 212K 64s
14800K .......... .......... .......... .......... .......... 47% 212K 64s
14850K .......... .......... .......... .......... .......... 47% 212K 64s
14900K .......... .......... .......... .......... .......... 47% 11.1M 64s
14950K .......... .......... .......... .......... .......... 47% 212K 63s
15000K .......... .......... .......... .......... .......... 47% 212K 63s
15050K .......... .......... .......... .......... .......... 47% 212K 63s
15100K .......... .......... .......... .......... .......... 48% 212K 63s
15150K .......... .......... .......... .......... .......... 48% 11.7M 63s
15200K .......... .......... .......... .......... .......... 48% 212K 62s
15250K .......... .......... .......... .......... .......... 48% 213K 62s
15300K .......... .......... .......... .......... .......... 48% 212K 62s
15350K .......... .......... .......... .......... .......... 48% 212K 62s
15400K .......... .......... .......... .......... .......... 49% 11.0M 62s
15450K .......... .......... .......... .......... .......... 49% 212K 61s
15500K .......... .......... .......... .......... .......... 49% 212K 61s
15550K .......... .......... .......... .......... .......... 49% 212K 61s
15600K .......... .......... .......... .......... .......... 49% 212K 61s
15650K .......... .......... .......... .......... .......... 49% 11.1M 61s
15700K .......... .......... .......... .......... .......... 50% 212K 60s
15750K .......... .......... .......... .......... .......... 50% 212K 60s
15800K .......... .......... .......... .......... .......... 50% 213K 60s
15850K .......... .......... .......... .......... .......... 50% 212K 60s
15900K .......... .......... .......... .......... .......... 50% 11.0M 60s
15950K .......... .......... .......... .......... .......... 50% 212K 59s
16000K .......... .......... .......... .......... .......... 51% 212K 59s
16050K .......... .......... .......... .......... .......... 51% 212K 59s
16100K .......... .......... .......... .......... .......... 51% 212K 59s
16150K .......... .......... .......... .......... .......... 51% 11.7M 59s
16200K .......... .......... .......... .......... .......... 51% 212K 59s
16250K .......... .......... .......... .......... .......... 51% 212K 58s
16300K .......... .......... .......... .......... .......... 51% 212K 58s
16350K .......... .......... .......... .......... .......... 52% 212K 58s
16400K .......... .......... .......... .......... .......... 52% 11.1M 58s
16450K .......... .......... .......... .......... .......... 52% 212K 58s
16500K .......... .......... .......... .......... .......... 52% 213K 57s
16550K .......... .......... .......... .......... .......... 52% 212K 57s
16600K .......... .......... .......... .......... .......... 52% 1.47M 57s
16650K .......... .......... .......... .......... .......... 53% 242K 57s
16700K .......... .......... .......... .......... .......... 53% 212K 57s
16750K .......... .......... .......... .......... .......... 53% 212K 56s
16800K .......... .......... .......... .......... .......... 53% 212K 56s
16850K .......... .......... .......... .......... .......... 53% 1.44M 56s
16900K .......... .......... .......... .......... .......... 53% 243K 56s
16950K .......... .......... .......... .......... .......... 54% 212K 56s
17000K .......... .......... .......... .......... .......... 54% 212K 55s
17050K .......... .......... .......... .......... .......... 54% 213K 55s
17100K .......... .......... .......... .......... .......... 54% 1.36M 55s
17150K .......... .......... .......... .......... .......... 54% 245K 55s
17200K .......... .......... .......... .......... .......... 54% 213K 55s
17250K .......... .......... .......... .......... .......... 54% 213K 54s
17300K .......... .......... .......... .......... .......... 55% 212K 54s
17350K .......... .......... .......... .......... .......... 55% 1.38M 54s
17400K .......... .......... .......... .......... .......... 55% 244K 54s
17450K .......... .......... .......... .......... .......... 55% 212K 54s
17500K .......... .......... .......... .......... .......... 55% 212K 53s
17550K .......... .......... .......... .......... .......... 55% 212K 53s
17600K .......... .......... .......... .......... .......... 56% 11.7M 53s
17650K .......... .......... .......... .......... .......... 56% 212K 53s
17700K .......... .......... .......... .......... .......... 56% 213K 53s
17750K .......... .......... .......... .......... .......... 56% 212K 53s
17800K .......... .......... .......... .......... .......... 56% 212K 52s
17850K .......... .......... .......... .......... .......... 56% 10.9M 52s
17900K .......... .......... .......... .......... .......... 57% 213K 52s
17950K .......... .......... .......... .......... .......... 57% 212K 52s
18000K .......... .......... .......... .......... .......... 57% 212K 52s
18050K .......... .......... .......... .......... .......... 57% 212K 51s
18100K .......... .......... .......... .......... .......... 57% 10.3M 51s
18150K .......... .......... .......... .......... .......... 57% 213K 51s
18200K .......... .......... .......... .......... .......... 57% 212K 51s
18250K .......... .......... .......... .......... .......... 58% 213K 51s
18300K .......... .......... .......... .......... .......... 58% 212K 50s
18350K .......... .......... .......... .......... .......... 58% 11.7M 50s
18400K .......... .......... .......... .......... .......... 58% 212K 50s
18450K .......... .......... .......... .......... .......... 58% 212K 50s
18500K .......... .......... .......... .......... .......... 58% 212K 50s
18550K .......... .......... .......... .......... .......... 59% 213K 49s
18600K .......... .......... .......... .......... .......... 59% 11.1M 49s
18650K .......... .......... .......... .......... .......... 59% 212K 49s
18700K .......... .......... .......... .......... .......... 59% 212K 49s
18750K .......... .......... .......... .......... .......... 59% 212K 49s
18800K .......... .......... .......... .......... .......... 59% 212K 48s
18850K .......... .......... .......... .......... .......... 60% 10.9M 48s
18900K .......... .......... .......... .......... .......... 60% 212K 48s
18950K .......... .......... .......... .......... .......... 60% 212K 48s
19000K .......... .......... .......... .......... .......... 60% 212K 48s
19050K .......... .......... .......... .......... .......... 60% 212K 48s
19100K .......... .......... .......... .......... .......... 60% 11.7M 47s
19150K .......... .......... .......... .......... .......... 61% 212K 47s
19200K .......... .......... .......... .......... .......... 61% 212K 47s
19250K .......... .......... .......... .......... .......... 61% 212K 47s
19300K .......... .......... .......... .......... .......... 61% 212K 47s
19350K .......... .......... .......... .......... .......... 61% 11.1M 46s
19400K .......... .......... .......... .......... .......... 61% 212K 46s
19450K .......... .......... .......... .......... .......... 61% 212K 46s
19500K .......... .......... .......... .......... .......... 62% 213K 46s
19550K .......... .......... .......... .......... .......... 62% 212K 46s
19600K .......... .......... .......... .......... .......... 62% 11.7M 45s
19650K .......... .......... .......... .......... .......... 62% 212K 45s
19700K .......... .......... .......... .......... .......... 62% 212K 45s
19750K .......... .......... .......... .......... .......... 62% 212K 45s
19800K .......... .......... .......... .......... .......... 63% 212K 45s
19850K .......... .......... .......... .......... .......... 63% 11.8M 44s
19900K .......... .......... .......... .......... .......... 63% 212K 44s
19950K .......... .......... .......... .......... .......... 63% 212K 44s
20000K .......... .......... .......... .......... .......... 63% 212K 44s
20050K .......... .......... .......... .......... .......... 63% 1.28M 44s
20100K .......... .......... .......... .......... .......... 64% 249K 43s
20150K .......... .......... .......... .......... .......... 64% 212K 43s
20200K .......... .......... .......... .......... .......... 64% 212K 43s
20250K .......... .......... .......... .......... .......... 64% 212K 43s
20300K .......... .......... .......... .......... .......... 64% 1.27M 43s
20350K .......... .......... .......... .......... .......... 64% 246K 42s
20400K .......... .......... .......... .......... .......... 64% 214K 42s
20450K .......... .......... .......... .......... .......... 65% 212K 42s
20500K .......... .......... .......... .......... .......... 65% 212K 42s
20550K .......... .......... .......... .......... .......... 65% 1.28M 42s
20600K .......... .......... .......... .......... .......... 65% 246K 41s
20650K .......... .......... .......... .......... .......... 65% 213K 41s
20700K .......... .......... .......... .......... .......... 65% 213K 41s
20750K .......... .......... .......... .......... .......... 66% 212K 41s
20800K .......... .......... .......... .......... .......... 66% 4.75M 41s
20850K .......... .......... .......... .......... .......... 66% 216K 40s
20900K .......... .......... .......... .......... .......... 66% 214K 40s
20950K .......... .......... .......... .......... .......... 66% 212K 40s
21000K .......... .......... .......... .......... .......... 66% 212K 40s
21050K .......... .......... .......... .......... .......... 67% 3.81M 40s
21100K .......... .......... .......... .......... .......... 67% 216K 39s
21150K .......... .......... .......... .......... .......... 67% 215K 39s
21200K .......... .......... .......... .......... .......... 67% 213K 39s
21250K .......... .......... .......... .......... .......... 67% 213K 39s
21300K .......... .......... .......... .......... .......... 67% 4.08M 39s
21350K .......... .......... .......... .......... .......... 68% 216K 39s
21400K .......... .......... .......... .......... .......... 68% 216K 38s
21450K .......... .......... .......... .......... .......... 68% 212K 38s
21500K .......... .......... .......... .......... .......... 68% 212K 38s
21550K .......... .......... .......... .......... .......... 68% 5.74M 38s
21600K .......... .......... .......... .......... .......... 68% 212K 38s
21650K .......... .......... .......... .......... .......... 68% 216K 37s
21700K .......... .......... .......... .......... .......... 69% 212K 37s
21750K .......... .......... .......... .......... .......... 69% 212K 37s
21800K .......... .......... .......... .......... .......... 69% 4.06M 37s
21850K .......... .......... .......... .......... .......... 69% 212K 37s
21900K .......... .......... .......... .......... .......... 69% 220K 36s
21950K .......... .......... .......... .......... .......... 69% 213K 36s
22000K .......... .......... .......... .......... .......... 70% 212K 36s
22050K .......... .......... .......... .......... .......... 70% 3.82M 36s
22100K .......... .......... .......... .......... .......... 70% 212K 36s
22150K .......... .......... .......... .......... .......... 70% 220K 35s
22200K .......... .......... .......... .......... .......... 70% 213K 35s
22250K .......... .......... .......... .......... .......... 70% 213K 35s
22300K .......... .......... .......... .......... .......... 71% 3.39M 35s
22350K .......... .......... .......... .......... .......... 71% 212K 35s
22400K .......... .......... .......... .......... .......... 71% 222K 35s
22450K .......... .......... .......... .......... .......... 71% 213K 34s
22500K .......... .......... .......... .......... .......... 71% 212K 34s
22550K .......... .......... .......... .......... .......... 71% 3.34M 34s
22600K .......... .......... .......... .......... .......... 71% 212K 34s
22650K .......... .......... .......... .......... .......... 72% 222K 34s
22700K .......... .......... .......... .......... .......... 72% 212K 33s
22750K .......... .......... .......... .......... .......... 72% 212K 33s
22800K .......... .......... .......... .......... .......... 72% 3.17M 33s
22850K .......... .......... .......... .......... .......... 72% 220K 33s
22900K .......... .......... .......... .......... .......... 72% 215K 33s
22950K .......... .......... .......... .......... .......... 73% 212K 32s
23000K .......... .......... .......... .......... .......... 73% 212K 32s
23050K .......... .......... .......... .......... .......... 73% 3.03M 32s
23100K .......... .......... .......... .......... .......... 73% 220K 32s
23150K .......... .......... .......... .......... .......... 73% 216K 32s
23200K .......... .......... .......... .......... .......... 73% 213K 31s
23250K .......... .......... .......... .......... .......... 74% 213K 31s
23300K .......... .......... .......... .......... .......... 74% 2.83M 31s
23350K .......... .......... .......... .......... .......... 74% 220K 31s
23400K .......... .......... .......... .......... .......... 74% 216K 31s
23450K .......... .......... .......... .......... .......... 74% 213K 30s
23500K .......... .......... .......... .......... .......... 74% 1.15M 30s
23550K .......... .......... .......... .......... .......... 75% 237K 30s
23600K .......... .......... .......... .......... .......... 75% 220K 30s
23650K .......... .......... .......... .......... .......... 75% 217K 30s
23700K .......... .......... .......... .......... .......... 75% 213K 30s
23750K .......... .......... .......... .......... .......... 75% 1.13M 29s
23800K .......... .......... .......... .......... .......... 75% 237K 29s
23850K .......... .......... .......... .......... .......... 75% 221K 29s
23900K .......... .......... .......... .......... .......... 76% 217K 29s
23950K .......... .......... .......... .......... .......... 76% 212K 29s
24000K .......... .......... .......... .......... .......... 76% 1.13M 28s
24050K .......... .......... .......... .......... .......... 76% 237K 28s
24100K .......... .......... .......... .......... .......... 76% 220K 28s
24150K .......... .......... .......... .......... .......... 76% 218K 28s
24200K .......... .......... .......... .......... .......... 77% 212K 28s
24250K .......... .......... .......... .......... .......... 77% 2.09M 27s
24300K .......... .......... .......... .......... .......... 77% 216K 27s
24350K .......... .......... .......... .......... .......... 77% 221K 27s
24400K .......... .......... .......... .......... .......... 77% 217K 27s
24450K .......... .......... .......... .......... .......... 77% 212K 27s
24500K .......... .......... .......... .......... .......... 78% 2.04M 26s
24550K .......... .......... .......... .......... .......... 78% 217K 26s
24600K .......... .......... .......... .......... .......... 78% 221K 26s
24650K .......... .......... .......... .......... .......... 78% 218K 26s
24700K .......... .......... .......... .......... .......... 78% 213K 26s
24750K .......... .......... .......... .......... .......... 78% 1.95M 25s
24800K .......... .......... .......... .......... .......... 78% 217K 25s
24850K .......... .......... .......... .......... .......... 79% 221K 25s
24900K .......... .......... .......... .......... .......... 79% 218K 25s
24950K .......... .......... .......... .......... .......... 79% 212K 25s
25000K .......... .......... .......... .......... .......... 79% 2.37M 24s
25050K .......... .......... .......... .......... .......... 79% 212K 24s
25100K .......... .......... .......... .......... .......... 79% 222K 24s
25150K .......... .......... .......... .......... .......... 80% 217K 24s
25200K .......... .......... .......... .......... .......... 80% 213K 24s
25250K .......... .......... .......... .......... .......... 80% 2.45M 24s
25300K .......... .......... .......... .......... .......... 80% 212K 23s
25350K .......... .......... .......... .......... .......... 80% 222K 23s
25400K .......... .......... .......... .......... .......... 80% 217K 23s
25450K .......... .......... .......... .......... .......... 81% 212K 23s
25500K .......... .......... .......... .......... .......... 81% 2.46M 23s
25550K .......... .......... .......... .......... .......... 81% 212K 22s
25600K .......... .......... .......... .......... .......... 81% 222K 22s
25650K .......... .......... .......... .......... .......... 81% 217K 22s
25700K .......... .......... .......... .......... .......... 81% 213K 22s
25750K .......... .......... .......... .......... .......... 81% 2.42M 22s
25800K .......... .......... .......... .......... .......... 82% 213K 21s
25850K .......... .......... .......... .......... .......... 82% 222K 21s
25900K .......... .......... .......... .......... .......... 82% 216K 21s
25950K .......... .......... .......... .......... .......... 82% 213K 21s
26000K .......... .......... .......... .......... .......... 82% 2.46M 21s
26050K .......... .......... .......... .......... .......... 82% 222K 20s
26100K .......... .......... .......... .......... .......... 83% 213K 20s
26150K .......... .......... .......... .......... .......... 83% 216K 20s
26200K .......... .......... .......... .......... .......... 83% 213K 20s
26250K .......... .......... .......... .......... .......... 83% 2.40M 20s
26300K .......... .......... .......... .......... .......... 83% 223K 20s
26350K .......... .......... .......... .......... .......... 83% 213K 19s
26400K .......... .......... .......... .......... .......... 84% 216K 19s
26450K .......... .......... .......... .......... .......... 84% 212K 19s
26500K .......... .......... .......... .......... .......... 84% 2.48M 19s
26550K .......... .......... .......... .......... .......... 84% 222K 19s
26600K .......... .......... .......... .......... .......... 84% 216K 18s
26650K .......... .......... .......... .......... .......... 84% 213K 18s
26700K .......... .......... .......... .......... .......... 85% 1.01M 18s
26750K .......... .......... .......... .......... .......... 85% 241K 18s
26800K .......... .......... .......... .......... .......... 85% 223K 18s
26850K .......... .......... .......... .......... .......... 85% 215K 17s
26900K .......... .......... .......... .......... .......... 85% 214K 17s
26950K .......... .......... .......... .......... .......... 85% 1005K 17s
27000K .......... .......... .......... .......... .......... 85% 242K 17s
27050K .......... .......... .......... .......... .......... 86% 223K 17s
27100K .......... .......... .......... .......... .......... 86% 215K 16s
27150K .......... .......... .......... .......... .......... 86% 213K 16s
27200K .......... .......... .......... .......... .......... 86% 1001K 16s
27250K .......... .......... .......... .......... .......... 86% 244K 16s
27300K .......... .......... .......... .......... .......... 86% 221K 16s
27350K .......... .......... .......... .......... .......... 87% 217K 16s
27400K .......... .......... .......... .......... .......... 87% 213K 15s
27450K .......... .......... .......... .......... .......... 87% 1.57M 15s
27500K .......... .......... .......... .......... .......... 87% 223K 15s
27550K .......... .......... .......... .......... .......... 87% 221K 15s
27600K .......... .......... .......... .......... .......... 87% 218K 15s
27650K .......... .......... .......... .......... .......... 88% 212K 14s
27700K .......... .......... .......... .......... .......... 88% 1.55M 14s
27750K .......... .......... .......... .......... .......... 88% 224K 14s
27800K .......... .......... .......... .......... .......... 88% 221K 14s
27850K .......... .......... .......... .......... .......... 88% 217K 14s
27900K .......... .......... .......... .......... .......... 88% 212K 13s
27950K .......... .......... .......... .......... .......... 88% 1.55M 13s
28000K .......... .......... .......... .......... .......... 89% 224K 13s
28050K .......... .......... .......... .......... .......... 89% 222K 13s
28100K .......... .......... .......... .......... .......... 89% 217K 13s
28150K .......... .......... .......... .......... .......... 89% 212K 12s
28200K .......... .......... .......... .......... .......... 89% 2.43M 12s
28250K .......... .......... .......... .......... .......... 89% 212K 12s
28300K .......... .......... .......... .......... .......... 90% 222K 12s
28350K .......... .......... .......... .......... .......... 90% 217K 12s
28400K .......... .......... .......... .......... .......... 90% 212K 12s
28450K .......... .......... .......... .......... .......... 90% 2.47M 11s
28500K .......... .......... .......... .......... .......... 90% 212K 11s
28550K .......... .......... .......... .......... .......... 90% 223K 11s
28600K .......... .......... .......... .......... .......... 91% 216K 11s
28650K .......... .......... .......... .......... .......... 91% 213K 11s
28700K .......... .......... .......... .......... .......... 91% 2.41M 10s
28750K .......... .......... .......... .......... .......... 91% 213K 10s
28800K .......... .......... .......... .......... .......... 91% 223K 10s
28850K .......... .......... .......... .......... .......... 91% 216K 10s
28900K .......... .......... .......... .......... .......... 92% 212K 10s
28950K .......... .......... .......... .......... .......... 92% 2.45M 9s
29000K .......... .......... .......... .......... .......... 92% 212K 9s
29050K .......... .......... .......... .......... .......... 92% 222K 9s
29100K .......... .......... .......... .......... .......... 92% 216K 9s
29150K .......... .......... .......... .......... .......... 92% 212K 9s
29200K .......... .......... .......... .......... .......... 92% 2.48M 8s
29250K .......... .......... .......... .......... .......... 93% 212K 8s
29300K .......... .......... .......... .......... .......... 93% 225K 8s
29350K .......... .......... .......... .......... .......... 93% 209K 8s
29400K .......... .......... .......... .......... .......... 93% 216K 8s
29450K .......... .......... .......... .......... .......... 93% 2.86M 7s
29500K .......... .......... .......... .......... .......... 93% 222K 7s
29550K .......... .......... .......... .......... .......... 94% 212K 7s
29600K .......... .......... .......... .......... .......... 94% 214K 7s
29650K .......... .......... .......... .......... .......... 94% 213K 7s
29700K .......... .......... .......... .......... .......... 94% 2.88M 7s
29750K .......... .......... .......... .......... .......... 94% 222K 6s
29800K .......... .......... .......... .......... .......... 94% 212K 6s
29850K .......... .......... .......... .......... .......... 95% 215K 6s
29900K .......... .......... .......... .......... .......... 95% 211K 6s
29950K .......... .......... .......... .......... .......... 95% 2.79M 6s
30000K .......... .......... .......... .......... .......... 95% 224K 5s
30050K .......... .......... .......... .......... .......... 95% 213K 5s
30100K .......... .......... .......... .......... .......... 95% 213K 5s
30150K .......... .......... .......... .......... .......... 95% 970K 5s
30200K .......... .......... .......... .......... .......... 96% 251K 5s
30250K .......... .......... .......... .......... .......... 96% 221K 4s
30300K .......... .......... .......... .......... .......... 96% 213K 4s
30350K .......... .......... .......... .......... .......... 96% 213K 4s
30400K .......... .......... .......... .......... .......... 96% 983K 4s
30450K .......... .......... .......... .......... .......... 96% 251K 4s
30500K .......... .......... .......... .......... .......... 97% 221K 3s
30550K .......... .......... .......... .......... .......... 97% 212K 3s
30600K .......... .......... .......... .......... .......... 97% 214K 3s
30650K .......... .......... .......... .......... .......... 97% 970K 3s
30700K .......... .......... .......... .......... .......... 97% 252K 3s
30750K .......... .......... .......... .......... .......... 97% 220K 3s
30800K .......... .......... .......... .......... .......... 98% 213K 2s
30850K .......... .......... .......... .......... .......... 98% 212K 2s
30900K .......... .......... .......... .......... .......... 98% 1.39M 2s
30950K .......... .......... .......... .......... .......... 98% 233K 2s
31000K .......... .......... .......... .......... .......... 98% 220K 2s
31050K .......... .......... .......... .......... .......... 98% 213K 1s
31100K .......... .......... .......... .......... .......... 98% 212K 1s
31150K .......... .......... .......... .......... .......... 99% 1.41M 1s
31200K .......... .......... .......... .......... .......... 99% 234K 1s
31250K .......... .......... .......... .......... .......... 99% 220K 1s
31300K .......... .......... .......... .......... .......... 99% 213K 0s
31350K .......... .......... .......... .......... .......... 99% 212K 0s
31400K .......... .......... .......... .......... .......... 99% 1.37M 0s
31450K .......... ..... 100% 77.4K=2m0s
2018-08-07 22:39:07 (262 KB/s) - ‘minotaur-externals-0.2.tar.gz’ saved [32220716/32220716]
configure: WARNING: Cannot find C-function for checking NaN.
configure: WARNING: No solver available, examples will not work.
mkdir: mkdir: cannot create directory '.libs'cannot create directory '.libs': File exists: File exists
mkdir: cannot create directory '.libs': File exists
../../../CoinUtils/src/CoinFactorization2.cpp: In member function 'int CoinFactorization::factorDense()':
../../../CoinUtils/src/CoinFactorization2.cpp:520:75: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += (numberDense_+1)/(sizeof(CoinFactorizationDouble)/sizeof(int));
../../../CoinUtils/src/CoinFactorization2.cpp:521:81: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += 2*((numberDense_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinFactorization2.cpp:522:78: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += ((numberRows_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinLpIO.cpp: In member function 'void CoinLpIO::readLp(FILE*)':
../../../CoinUtils/src/CoinLpIO.cpp:2268:24: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
int length=strlen(buff);
../../../CoinUtils/src/CoinLpIO.cpp:2320:24: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
int length=strlen(next+1);
../../../CoinUtils/src/CoinStructuredModel.cpp: In member function 'int CoinStructuredModel::decompose(const CoinPackedMatrix&, const double*, const double*, const double*, const double*, const double*, int, int, int*, double)':
../../../CoinUtils/src/CoinStructuredModel.cpp:761:10: warning: variable 'goodDW' set but not used [-Wunused-but-set-variable]
bool goodDW=true;
../../../CoinUtils/src/CoinStructuredModel.cpp:1343:10: warning: variable 'goodBenders' set but not used [-Wunused-but-set-variable]
bool goodBenders=true;
../../../CoinUtils/src/CoinMpsIO.cpp: In member function 'int CoinMpsIO::readConicMps(const char*, int*&, int*&, int*&, int&)':
../../../CoinUtils/src/CoinMpsIO.cpp:5814:3: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if ( cardReader_->whichSection ( ) == COIN_NAME_SECTION )
../../../CoinUtils/src/CoinMpsIO.cpp:5816:5: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
if ( cardReader_->whichSection ( ) == COIN_CONIC_SECTION ) {
../../../CoinUtils/src/CoinPresolveDual.cpp: In static member function 'static const CoinPresolveAction* remove_dual_action::presolve(CoinPresolveMatrix*, const CoinPresolveAction*)':
../../../CoinUtils/src/CoinPresolveDual.cpp:236:20: warning: unused variable 'lb' [-Wunused-variable]
const double lb = clo[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:237:20: warning: unused variable 'ub' [-Wunused-variable]
const double ub = cup[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:642:13: warning: unused variable 'no_clb' [-Wunused-variable]
const bool no_clb = (active[j]&5)==0 ;
../../../CoinUtils/src/CoinRational.cpp: In member function 'bool CoinRational::nearestRational_(double, double, long int)':
../../../CoinUtils/src/CoinRational.cpp:30:27: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
double mediant = (a + c)/(double(b + d));
../../../CoinUtils/src/CoinRational.cpp:60:30: warning: conversion to 'long int' from 'double' may alter its value [-Wfloat-conversion]
numerator_ += labs(intpart) * denominator_;
../../../CoinUtils/src/CoinRational.cpp:64:22: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
return fabs(val - numerator_/double(denominator_)) <= maxdelta;
../../../CoinUtils/src/CoinWarmStartBasis.cpp: In member function 'bool CoinWarmStartBasis::fixFullBasis()':
../../../CoinUtils/src/CoinWarmStartBasis.cpp:494:7: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if (status==CoinWarmStartBasis::basic)
../../../CoinUtils/src/CoinWarmStartBasis.cpp:496:2: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
numberBasic--;
In file included from ../../../../Osi/src/Osi/OsiColCut.cpp:10:0:
../../../../Osi/src/Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
../../../../Osi/src/Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if ( cutUbs.isExistingIndex(colIndx) )
../../../../Osi/src/Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
if ( newLb > newUb )
../../../../Osi/src/Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if ( cutLbs.isExistingIndex(colIndx) )
../../../../Osi/src/Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
if ( newUb < newLb )
In file included from ../../../../Osi/src/Osi/OsiCuts.hpp:14:0,
from ../../../../Osi/src/Osi/OsiCuts.cpp:13:
from ../../../../Osi/src/Osi/OsiRowCutDebugger.hpp:16,
from ../../../../Osi/src/Osi/OsiRowCutDebugger.cpp:19:
from ../../../../Osi/src/Osi/OsiSolverInterface.cpp:21:
../../../../Osi/src/Osi/OsiSolverInterface.cpp: In member function 'int OsiSolverInterface::differentModel(OsiSolverInterface&, bool)':
../../../../Osi/src/Osi/OsiSolverInterface.cpp:1880:8: warning: unused variable 'gotHint' [-Wunused-variable]
bool gotHint = (getHintParam(OsiDoReducePrint,takeHint,strength));
libtool: install: warning: relinking `libOsi.la'
In file included from ../../../../Osi/src/OsiCommonTest/OsiColCutTest.cpp:13:0:
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
In file included from ../../../../Osi/src/OsiCommonTest/../Osi/OsiCuts.hpp:14:0,
from ../../../../Osi/src/OsiCommonTest/../Osi/OsiRowCutDebugger.hpp:16,
from ../../../../Osi/src/OsiCommonTest/OsiRowCutDebuggerTest.cpp:9:
from ../../../../Osi/src/OsiCommonTest/OsiCutsTest.cpp:9:
from ../../../../Osi/src/OsiCommonTest/OsiSolverInterfaceTest.cpp:84:
libtool: install: warning: relinking `libOsiCommonTests.la'
../../../Clp/src/ClpPlusMinusOneMatrix.cpp:459:13: warning: 'doPlusOnes' defined but not used [-Wunused-variable]
static bool doPlusOnes=true;
../../../Clp/src/ClpSimplex.cpp: In member function 'int ClpSimplex::fathom(void*)':
../../../Clp/src/ClpSimplex.cpp:11081:15: warning: unused variable 'statusWeights' [-Wunused-variable]
int statusWeights = fastDual2(info);
../../../Clp/src/ClpSimplexOther.cpp: In member function 'int ClpSimplexOther::setInDual(ClpSimplex*)':
../../../Clp/src/ClpSimplexOther.cpp:1313:12: warning: unused variable 'statusD' [-Wunused-variable]
Status statusD = dualProblem->getRowStatus(iColumn);
../../../Clp/src/ClpSimplexOther.cpp:1314:12: warning: unused variable 'statusDJ' [-Wunused-variable]
Status statusDJ = dualProblem->getColumnStatus(jColumn);
../../../Clp/src/ClpSimplexOther.cpp:1352:12: warning: unused variable 'statusD' [-Wunused-variable]
Status statusD = dualProblem->getColumnStatus(iRow);
../../../Clp/src/ClpSolve.cpp: In member function 'int ClpSimplex::solveBenders(CoinStructuredModel*, ClpSolve&)':
../../../Clp/src/ClpSolve.cpp:7272:9: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if (saveLower[i] < -1.0e20);
../../../Clp/src/ClpSolve.cpp:7273:4: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
solution[i]=0.0;
../../../Clp/src/ClpSolver.cpp: In function 'void statistics(ClpSimplex*, ClpSimplex*)':
../../../Clp/src/ClpSolver.cpp:3756:10: warning: variable 'numberWritten' set but not used [-Wunused-but-set-variable]
size_t numberWritten;
libtool: install: warning: relinking `libClp.la'
libtool: install: warning: relinking `libClpSolver.la'
In file included from /home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiCuts.hpp:14:0,
from ../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:33:
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::initialSolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:148:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::resolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:843:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
bool gotHint = (getHintParam(OsiDoInBranchAndCut,takeHint,strength));
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'int OsiClpSolverInterface::infeasibleOtherWay(char*)':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9986:24: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
whichWay[iColumn] *=2;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9991:24: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9841:7: warning: unused variable 'iRow' [-Wunused-variable]
int iRow,iColumn;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9859:17: warning: unused variable 'objective' [-Wunused-variable]
const double *objective = getObjCoefficients() ;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9860:10: warning: unused variable 'direction' [-Wunused-variable]
double direction = getObjSense();
libtool: install: warning: relinking `libOsiClp.la'
filteraux.f:105:24:
. 0.D0,.false.)
1
Warning: Rank mismatch in argument ‘w’ at (1) (rank-1 and scalar)
ar: creating libfiltersqp.a
ar: `u' modifier ignored since `D' is the default (see `U')
ar: creating amplsolver.a
../../../../src/cppunit/Protector.cpp: In member function 'void CppUnit::Protector::reportError(const CppUnit::ProtectorContext&, const CppUnit::Exception&) const':
../../../../src/cppunit/Protector.cpp:24:8: warning: 'template<class> class std::auto_ptr' is deprecated [-Wdeprecated-declarations]
std::auto_ptr<Exception> actualError( error.clone() );
In file included from /usr/include/c++/6/memory:81:0,
from ../../../../src/cppunit/Protector.cpp:6:
/usr/include/c++/6/bits/unique_ptr.h:49:28: note: declared here
template<typename> class auto_ptr;
../../../../src/cppunit/Protector.cpp: In member function 'void CppUnit::Protector::reportFailure(const CppUnit::ProtectorContext&, const CppUnit::Exception&) const':
../../../../src/cppunit/Protector.cpp:45:8: warning: 'template<class> class std::auto_ptr' is deprecated [-Wdeprecated-declarations]
std::auto_ptr<Exception> actualFailure( failure.clone() );
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 196: cd: minotaur-externals//build: No such file or directory
make: *** No rule to make target 'distclean'. Stop.
: logger ok! OK (41)
Errors in build-base-static:
CMake Error at CMakeLists.txt:217 (message):
Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target 'install'. Stop.
make: *** No rule to make target 'utest'. Stop.
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Tue Aug 7 22:44:41 IST 2018
More information about the Minotaur-dev
