[Minotaur-dev] minotaur daily test results
amahajan
amahajan at iitb.ac.in
Sat Aug 4 12:14:39 CDT 2018
Minotaur daily test report
Sat Aug 4 22:37:01 IST 2018
origin.ieor.iitb.ac.in
Linux origin 4.9.0-6-amd64 #1 SMP Debian 4.9.82-1+deb9u3 (2018-03-02) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-63-gfee696e
ls: cannot access 'build-ampl/bin': No such file or directory
ls: cannot access 'build-ampl/lib': No such file or directory
ls: cannot access 'build-ampl/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-debug/bin': No such file or directory
ls: cannot access 'build-ampl-debug/lib': No such file or directory
ls: cannot access 'build-ampl-debug/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-static/bin': No such file or directory
ls: cannot access 'build-ampl-static/lib': No such file or directory
ls: cannot access 'build-ampl-static/include/minotaur/*': No such file or directory
ls: cannot access 'build-all/bin': No such file or directory
ls: cannot access 'build-all/lib': No such file or directory
ls: cannot access 'build-all/include/minotaur/*': No such file or directory
ls: cannot access 'build-all-debug/bin': No such file or directory
ls: cannot access 'build-all-debug/lib': No such file or directory
ls: cannot access 'build-all-debug/include/minotaur/*': No such file or directory
./daily-lnx-iit-test.sh: line 272: cd: build-all-debug/src/testing: No such file or directory
./daily-lnx-iit-test.sh: line 273: ../../../build-all-debug.out: Permission denied
./daily-lnx-iit-test.sh: line 47: ./scripts/build_with_externals: No such file or directory
./daily-lnx-iit-test.sh: line 50: cd: build-all-static: No such file or directory
ls: cannot access 'build-all-static/bin': No such file or directory
ls: cannot access 'build-all-static/lib': No such file or directory
ls: cannot access 'build-all-static/include/minotaur/*': No such file or directory
rsync: change_dir "/home/amahajan/tmp/minotaur-test/build-all/doxygen/html" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1196) [sender=3.1.2]
Summary
compiling build-base: OK.
make utest output for build-base: OK (41)
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libmntrampl.a not built.
Errors:
Errors in build-all-debug:
CMake Error at CMakeLists.txt:217 (message):
Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target 'install'. Stop.
make: *** No rule to make target 'utest'. Stop.
Errors in build-all:
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/ipopt-3.12.7/build/include: No such file or directory [-Wmissing-include-dirs]
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/clp-1.16.9/build/include: No such file or directory [-Wmissing-include-dirs]
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/asl-20161228: No such file or directory [-Wmissing-include-dirs]
/home/amahajan/tmp/minotaur-test/src/engines/OsiLP/OsiLPEngine.cpp:18:42: fatal error: coin/OsiClpSolverInterface.hpp: No such file or directory
#include "coin/OsiClpSolverInterface.hpp"
compilation terminated.
make: *** [/home/amahajan/tmp/minotaur-test/src/engines/OsiLP/OsiLPEngine.o] Error 1
Errors in build-all-static:
Errors in build-ampl-debug:
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
Errors in build-base:
--2018-08-04 22:37:05-- http://www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz
Resolving netmon.iitb.ac.in (netmon.iitb.ac.in)... 10.201.13.50
Connecting to netmon.iitb.ac.in (netmon.iitb.ac.in)|10.201.13.50|:80... connected.
Proxy request sent, awaiting response... 200 OK
Length: 32220716 (31M) [application/x-gzip]
Saving to: ‘minotaur-externals-0.2.tar.gz’
0K .......... .......... .......... .......... .......... 0% 72.1K 7m16s
50K .......... .......... .......... .......... .......... 0% 108K 6m3s
100K .......... .......... .......... .......... .......... 0% 215K 4m50s
150K .......... .......... .......... .......... .......... 0% 108K 4m49s
200K .......... .......... .......... .......... .......... 0% 215K 4m20s
250K .......... .......... .......... .......... .......... 0% 216K 4m0s
300K .......... .......... .......... .......... .......... 1% 216K 3m46s
350K .......... .......... .......... .......... .......... 1% 217K 3m36s
400K .......... .......... .......... .......... .......... 1% 216K 3m27s
450K .......... .......... .......... .......... .......... 1% 218K 3m20s
500K .......... .......... .......... .......... .......... 1% 11.0M 3m2s
550K .......... .......... .......... .......... .......... 1% 218K 2m59s
600K .......... .......... .......... .......... .......... 2% 217K 2m55s
650K .......... .......... .......... .......... .......... 2% 217K 2m53s
700K .......... .......... .......... .......... .......... 2% 217K 2m50s
750K .......... .......... .......... .......... .......... 2% 11.6M 2m40s
800K .......... .......... .......... .......... .......... 2% 217K 2m38s
850K .......... .......... .......... .......... .......... 2% 218K 2m37s
900K .......... .......... .......... .......... .......... 3% 217K 2m36s
950K .......... .......... .......... .......... .......... 3% 217K 2m35s
1000K .......... .......... .......... .......... .......... 3% 11.7M 2m27s
1050K .......... .......... .......... .......... .......... 3% 217K 2m27s
1100K .......... .......... .......... .......... .......... 3% 218K 2m26s
1150K .......... .......... .......... .......... .......... 3% 217K 2m26s
1200K .......... .......... .......... .......... .......... 3% 217K 2m25s
1250K .......... .......... .......... .......... .......... 4% 11.0M 2m20s
1300K .......... .......... .......... .......... .......... 4% 217K 2m19s
1350K .......... .......... .......... .......... .......... 4% 217K 2m19s
1400K .......... .......... .......... .......... .......... 4% 217K 2m19s
1450K .......... .......... .......... .......... .......... 4% 217K 2m19s
1500K .......... .......... .......... .......... .......... 4% 11.7M 2m14s
1550K .......... .......... .......... .......... .......... 5% 217K 2m14s
1600K .......... .......... .......... .......... .......... 5% 218K 2m14s
1650K .......... .......... .......... .......... .......... 5% 217K 2m14s
1700K .......... .......... .......... .......... .......... 5% 11.7M 2m10s
1750K .......... .......... .......... .......... .......... 5% 217K 2m10s
1800K .......... .......... .......... .......... .......... 5% 217K 2m10s
1850K .......... .......... .......... .......... .......... 6% 218K 2m10s
1900K .......... .......... .......... .......... .......... 6% 217K 2m10s
1950K .......... .......... .......... .......... .......... 6% 11.6M 2m6s
2000K .......... .......... .......... .......... .......... 6% 217K 2m6s
2050K .......... .......... .......... .......... .......... 6% 218K 2m6s
2100K .......... .......... .......... .......... .......... 6% 217K 2m6s
2150K .......... .......... .......... .......... .......... 6% 217K 2m6s
2200K .......... .......... .......... .......... .......... 7% 11.0M 2m3s
2250K .......... .......... .......... .......... .......... 7% 217K 2m3s
2300K .......... .......... .......... .......... .......... 7% 217K 2m3s
2350K .......... .......... .......... .......... .......... 7% 217K 2m3s
2400K .......... .......... .......... .......... .......... 7% 217K 2m3s
2450K .......... .......... .......... .......... .......... 7% 11.6M 2m1s
2500K .......... .......... .......... .......... .......... 8% 217K 2m1s
2550K .......... .......... .......... .......... .......... 8% 217K 2m1s
2600K .......... .......... .......... .......... .......... 8% 217K 2m1s
2650K .......... .......... .......... .......... .......... 8% 217K 2m1s
2700K .......... .......... .......... .......... .......... 8% 11.6M 1m58s
2750K .......... .......... .......... .......... .......... 8% 217K 1m58s
2800K .......... .......... .......... .......... .......... 9% 217K 1m58s
2850K .......... .......... .......... .......... .......... 9% 217K 1m58s
2900K .......... .......... .......... .......... .......... 9% 217K 1m58s
2950K .......... .......... .......... .......... .......... 9% 11.1M 1m56s
3000K .......... .......... .......... .......... .......... 9% 217K 1m56s
3050K .......... .......... .......... .......... .......... 9% 217K 1m56s
3100K .......... .......... .......... .......... .......... 10% 217K 1m56s
3150K .......... .......... .......... .......... .......... 10% 217K 1m56s
3200K .......... .......... .......... .......... .......... 10% 11.6M 1m54s
3250K .......... .......... .......... .......... .......... 10% 217K 1m54s
3300K .......... .......... .......... .......... .......... 10% 217K 1m55s
3350K .......... .......... .......... .......... .......... 10% 217K 1m55s
3400K .......... .......... .......... .......... .......... 10% 217K 1m55s
3450K .......... .......... .......... .......... .......... 11% 11.6M 1m53s
3500K .......... .......... .......... .......... .......... 11% 217K 1m53s
3550K .......... .......... .......... .......... .......... 11% 218K 1m53s
3600K .......... .......... .......... .......... .......... 11% 217K 1m53s
3650K .......... .......... .......... .......... .......... 11% 217K 1m53s
3700K .......... .......... .......... .......... .......... 11% 11.0M 1m51s
3750K .......... .......... .......... .......... .......... 12% 217K 1m51s
3800K .......... .......... .......... .......... .......... 12% 217K 1m51s
3850K .......... .......... .......... .......... .......... 12% 217K 1m51s
3900K .......... .......... .......... .......... .......... 12% 217K 1m51s
3950K .......... .......... .......... .......... .......... 12% 11.1M 1m50s
4000K .......... .......... .......... .......... .......... 12% 217K 1m50s
4050K .......... .......... .......... .......... .......... 13% 217K 1m50s
4100K .......... .......... .......... .......... .......... 13% 217K 1m50s
4150K .......... .......... .......... .......... .......... 13% 217K 1m50s
4200K .......... .......... .......... .......... .......... 13% 11.6M 1m48s
4250K .......... .......... .......... .......... .......... 13% 217K 1m48s
4300K .......... .......... .......... .......... .......... 13% 217K 1m48s
4350K .......... .......... .......... .......... .......... 13% 217K 1m48s
4400K .......... .......... .......... .......... .......... 14% 217K 1m48s
4450K .......... .......... .......... .......... .......... 14% 11.7M 1m47s
4500K .......... .......... .......... .......... .......... 14% 217K 1m47s
4550K .......... .......... .......... .......... .......... 14% 217K 1m47s
4600K .......... .......... .......... .......... .......... 14% 217K 1m47s
4650K .......... .......... .......... .......... .......... 14% 217K 1m47s
4700K .......... .......... .......... .......... .......... 15% 11.6M 1m45s
4750K .......... .......... .......... .......... .......... 15% 217K 1m45s
4800K .......... .......... .......... .......... .......... 15% 217K 1m45s
4850K .......... .......... .......... .......... .......... 15% 218K 1m45s
4900K .......... .......... .......... .......... .......... 15% 6.10M 1m44s
4950K .......... .......... .......... .......... .......... 15% 220K 1m44s
5000K .......... .......... .......... .......... .......... 16% 217K 1m44s
5050K .......... .......... .......... .......... .......... 16% 217K 1m44s
5100K .......... .......... .......... .......... .......... 16% 217K 1m44s
5150K .......... .......... .......... .......... .......... 16% 6.15M 1m43s
5200K .......... .......... .......... .......... .......... 16% 220K 1m43s
5250K .......... .......... .......... .......... .......... 16% 218K 1m43s
5300K .......... .......... .......... .......... .......... 17% 217K 1m43s
5350K .......... .......... .......... .......... .......... 17% 218K 1m43s
5400K .......... .......... .......... .......... .......... 17% 5.64M 1m42s
5450K .......... .......... .......... .......... .......... 17% 221K 1m42s
5500K .......... .......... .......... .......... .......... 17% 217K 1m42s
5550K .......... .......... .......... .......... .......... 17% 217K 1m41s
5600K .......... .......... .......... .......... .......... 17% 217K 1m41s
5650K .......... .......... .......... .......... .......... 18% 11.6M 1m40s
5700K .......... .......... .......... .......... .......... 18% 217K 1m40s
5750K .......... .......... .......... .......... .......... 18% 218K 1m40s
5800K .......... .......... .......... .......... .......... 18% 217K 1m40s
5850K .......... .......... .......... .......... .......... 18% 217K 1m40s
5900K .......... .......... .......... .......... .......... 18% 11.8M 99s
5950K .......... .......... .......... .......... .......... 19% 217K 99s
6000K .......... .......... .......... .......... .......... 19% 217K 99s
6050K .......... .......... .......... .......... .......... 19% 217K 99s
6100K .......... .......... .......... .......... .......... 19% 217K 99s
6150K .......... .......... .......... .......... .......... 19% 11.6M 98s
6200K .......... .......... .......... .......... .......... 19% 217K 98s
6250K .......... .......... .......... .......... .......... 20% 217K 98s
6300K .......... .......... .......... .......... .......... 20% 217K 98s
6350K .......... .......... .......... .......... .......... 20% 217K 98s
6400K .......... .......... .......... .......... .......... 20% 11.5M 97s
6450K .......... .......... .......... .......... .......... 20% 217K 97s
6500K .......... .......... .......... .......... .......... 20% 217K 97s
6550K .......... .......... .......... .......... .......... 20% 217K 97s
6600K .......... .......... .......... .......... .......... 21% 217K 97s
6650K .......... .......... .......... .......... .......... 21% 11.7M 96s
6700K .......... .......... .......... .......... .......... 21% 217K 96s
6750K .......... .......... .......... .......... .......... 21% 217K 96s
6800K .......... .......... .......... .......... .......... 21% 217K 96s
6850K .......... .......... .......... .......... .......... 21% 217K 96s
6900K .......... .......... .......... .......... .......... 22% 11.1M 95s
6950K .......... .......... .......... .......... .......... 22% 217K 95s
7000K .......... .......... .......... .......... .......... 22% 217K 95s
7050K .......... .......... .......... .......... .......... 22% 217K 94s
7100K .......... .......... .......... .......... .......... 22% 217K 94s
7150K .......... .......... .......... .......... .......... 22% 11.1M 94s
7200K .......... .......... .......... .......... .......... 23% 217K 93s
7250K .......... .......... .......... .......... .......... 23% 217K 93s
7300K .......... .......... .......... .......... .......... 23% 217K 93s
7350K .......... .......... .......... .......... .......... 23% 217K 93s
7400K .......... .......... .......... .......... .......... 23% 11.7M 92s
7450K .......... .......... .......... .......... .......... 23% 217K 92s
7500K .......... .......... .......... .......... .......... 23% 217K 92s
7550K .......... .......... .......... .......... .......... 24% 217K 92s
7600K .......... .......... .......... .......... .......... 24% 217K 92s
7650K .......... .......... .......... .......... .......... 24% 11.7M 91s
7700K .......... .......... .......... .......... .......... 24% 217K 91s
7750K .......... .......... .......... .......... .......... 24% 217K 91s
7800K .......... .......... .......... .......... .......... 24% 217K 91s
7850K .......... .......... .......... .......... .......... 25% 217K 91s
7900K .......... .......... .......... .......... .......... 25% 11.6M 90s
7950K .......... .......... .......... .......... .......... 25% 217K 90s
8000K .......... .......... .......... .......... .......... 25% 217K 90s
8050K .......... .......... .......... .......... .......... 25% 218K 90s
8100K .......... .......... .......... .......... .......... 25% 217K 90s
8150K .......... .......... .......... .......... .......... 26% 11.4M 89s
8200K .......... .......... .......... .......... .......... 26% 217K 89s
8250K .......... .......... .......... .......... .......... 26% 217K 89s
8300K .......... .......... .......... .......... .......... 26% 217K 89s
8350K .......... .......... .......... .......... .......... 26% 3.16M 88s
8400K .......... .......... .......... .......... .......... 26% 228K 88s
8450K .......... .......... .......... .......... .......... 27% 217K 88s
8500K .......... .......... .......... .......... .......... 27% 217K 88s
8550K .......... .......... .......... .......... .......... 27% 217K 88s
8600K .......... .......... .......... .......... .......... 27% 3.05M 87s
8650K .......... .......... .......... .......... .......... 27% 229K 87s
8700K .......... .......... .......... .......... .......... 27% 217K 87s
8750K .......... .......... .......... .......... .......... 27% 217K 87s
8800K .......... .......... .......... .......... .......... 28% 218K 87s
8850K .......... .......... .......... .......... .......... 28% 2.82M 86s
8900K .......... .......... .......... .......... .......... 28% 230K 86s
8950K .......... .......... .......... .......... .......... 28% 217K 86s
9000K .......... .......... .......... .......... .......... 28% 217K 86s
9050K .......... .......... .......... .......... .......... 28% 217K 86s
9100K .......... .......... .......... .......... .......... 29% 11.5M 85s
9150K .......... .......... .......... .......... .......... 29% 217K 85s
9200K .......... .......... .......... .......... .......... 29% 217K 85s
9250K .......... .......... .......... .......... .......... 29% 218K 85s
9300K .......... .......... .......... .......... .......... 29% 217K 85s
9350K .......... .......... .......... .......... .......... 29% 11.7M 84s
9400K .......... .......... .......... .......... .......... 30% 217K 84s
9450K .......... .......... .......... .......... .......... 30% 218K 84s
9500K .......... .......... .......... .......... .......... 30% 217K 84s
9550K .......... .......... .......... .......... .......... 30% 218K 84s
9600K .......... .......... .......... .......... .......... 30% 11.0M 83s
9650K .......... .......... .......... .......... .......... 30% 217K 83s
9700K .......... .......... .......... .......... .......... 30% 217K 83s
9750K .......... .......... .......... .......... .......... 31% 217K 83s
9800K .......... .......... .......... .......... .......... 31% 217K 83s
9850K .......... .......... .......... .......... .......... 31% 11.7M 82s
9900K .......... .......... .......... .......... .......... 31% 217K 82s
9950K .......... .......... .......... .......... .......... 31% 217K 82s
10000K .......... .......... .......... .......... .......... 31% 216K 82s
10050K .......... .......... .......... .......... .......... 32% 217K 82s
10100K .......... .......... .......... .......... .......... 32% 11.8M 81s
10150K .......... .......... .......... .......... .......... 32% 217K 81s
10200K .......... .......... .......... .......... .......... 32% 217K 81s
10250K .......... .......... .......... .......... .......... 32% 217K 81s
10300K .......... .......... .......... .......... .......... 32% 217K 81s
10350K .......... .......... .......... .......... .......... 33% 11.1M 80s
10400K .......... .......... .......... .......... .......... 33% 217K 80s
10450K .......... .......... .......... .......... .......... 33% 217K 80s
10500K .......... .......... .......... .......... .......... 33% 217K 80s
10550K .......... .......... .......... .......... .......... 33% 217K 80s
10600K .......... .......... .......... .......... .......... 33% 11.1M 79s
10650K .......... .......... .......... .......... .......... 34% 217K 79s
10700K .......... .......... .......... .......... .......... 34% 217K 79s
10750K .......... .......... .......... .......... .......... 34% 217K 79s
10800K .......... .......... .......... .......... .......... 34% 217K 79s
10850K .......... .......... .......... .......... .......... 34% 11.7M 78s
10900K .......... .......... .......... .......... .......... 34% 217K 78s
10950K .......... .......... .......... .......... .......... 34% 217K 78s
11000K .......... .......... .......... .......... .......... 35% 217K 78s
11050K .......... .......... .......... .......... .......... 35% 217K 78s
11100K .......... .......... .......... .......... .......... 35% 11.7M 77s
11150K .......... .......... .......... .......... .......... 35% 217K 77s
11200K .......... .......... .......... .......... .......... 35% 217K 77s
11250K .......... .......... .......... .......... .......... 35% 217K 77s
11300K .......... .......... .......... .......... .......... 36% 217K 77s
11350K .......... .......... .......... .......... .......... 36% 11.6M 76s
11400K .......... .......... .......... .......... .......... 36% 217K 76s
11450K .......... .......... .......... .......... .......... 36% 217K 76s
11500K .......... .......... .......... .......... .......... 36% 217K 76s
11550K .......... .......... .......... .......... .......... 36% 217K 76s
11600K .......... .......... .......... .......... .......... 37% 11.5M 75s
11650K .......... .......... .......... .......... .......... 37% 217K 75s
11700K .......... .......... .......... .......... .......... 37% 218K 75s
11750K .......... .......... .......... .......... .......... 37% 217K 75s
11800K .......... .......... .......... .......... .......... 37% 2.10M 74s
11850K .......... .......... .......... .......... .......... 37% 236K 74s
11900K .......... .......... .......... .......... .......... 37% 218K 74s
11950K .......... .......... .......... .......... .......... 38% 217K 74s
12000K .......... .......... .......... .......... .......... 38% 218K 74s
12050K .......... .......... .......... .......... .......... 38% 2.08M 73s
12100K .......... .......... .......... .......... .......... 38% 237K 73s
12150K .......... .......... .......... .......... .......... 38% 217K 73s
12200K .......... .......... .......... .......... .......... 38% 217K 73s
12250K .......... .......... .......... .......... .......... 39% 218K 73s
12300K .......... .......... .......... .......... .......... 39% 2.03M 72s
12350K .......... .......... .......... .......... .......... 39% 238K 72s
12400K .......... .......... .......... .......... .......... 39% 217K 72s
12450K .......... .......... .......... .......... .......... 39% 218K 72s
12500K .......... .......... .......... .......... .......... 39% 217K 72s
12550K .......... .......... .......... .......... .......... 40% 11.6M 71s
12600K .......... .......... .......... .......... .......... 40% 217K 71s
12650K .......... .......... .......... .......... .......... 40% 217K 71s
12700K .......... .......... .......... .......... .......... 40% 217K 71s
12750K .......... .......... .......... .......... .......... 40% 217K 71s
12800K .......... .......... .......... .......... .......... 40% 11.6M 70s
12850K .......... .......... .......... .......... .......... 40% 217K 70s
12900K .......... .......... .......... .......... .......... 41% 218K 70s
12950K .......... .......... .......... .......... .......... 41% 217K 70s
13000K .......... .......... .......... .......... .......... 41% 217K 70s
13050K .......... .......... .......... .......... .......... 41% 11.0M 69s
13100K .......... .......... .......... .......... .......... 41% 217K 69s
13150K .......... .......... .......... .......... .......... 41% 217K 69s
13200K .......... .......... .......... .......... .......... 42% 218K 69s
13250K .......... .......... .......... .......... .......... 42% 217K 69s
13300K .......... .......... .......... .......... .......... 42% 11.7M 68s
13350K .......... .......... .......... .......... .......... 42% 217K 68s
13400K .......... .......... .......... .......... .......... 42% 218K 68s
13450K .......... .......... .......... .......... .......... 42% 217K 68s
13500K .......... .......... .......... .......... .......... 43% 217K 68s
13550K .......... .......... .......... .......... .......... 43% 11.0M 67s
13600K .......... .......... .......... .......... .......... 43% 217K 67s
13650K .......... .......... .......... .......... .......... 43% 217K 67s
13700K .......... .......... .......... .......... .......... 43% 217K 67s
13750K .......... .......... .......... .......... .......... 43% 218K 67s
13800K .......... .......... .......... .......... .......... 44% 11.0M 66s
13850K .......... .......... .......... .......... .......... 44% 217K 66s
13900K .......... .......... .......... .......... .......... 44% 217K 66s
13950K .......... .......... .......... .......... .......... 44% 218K 66s
14000K .......... .......... .......... .......... .......... 44% 217K 66s
14050K .......... .......... .......... .......... .......... 44% 11.6M 66s
14100K .......... .......... .......... .......... .......... 44% 217K 65s
14150K .......... .......... .......... .......... .......... 45% 217K 65s
14200K .......... .......... .......... .......... .......... 45% 217K 65s
14250K .......... .......... .......... .......... .......... 45% 217K 65s
14300K .......... .......... .......... .......... .......... 45% 11.7M 65s
14350K .......... .......... .......... .......... .......... 45% 217K 64s
14400K .......... .......... .......... .......... .......... 45% 217K 64s
14450K .......... .......... .......... .......... .......... 46% 217K 64s
14500K .......... .......... .......... .......... .......... 46% 217K 64s
14550K .......... .......... .......... .......... .......... 46% 11.8M 64s
14600K .......... .......... .......... .......... .......... 46% 218K 63s
14650K .......... .......... .......... .......... .......... 46% 217K 63s
14700K .......... .......... .......... .......... .......... 46% 217K 63s
14750K .......... .......... .......... .......... .......... 47% 217K 63s
14800K .......... .......... .......... .......... .......... 47% 11.7M 63s
14850K .......... .......... .......... .......... .......... 47% 217K 62s
14900K .......... .......... .......... .......... .......... 47% 217K 62s
14950K .......... .......... .......... .......... .......... 47% 217K 62s
15000K .......... .......... .......... .......... .......... 47% 1.88M 62s
15050K .......... .......... .......... .......... .......... 47% 240K 62s
15100K .......... .......... .......... .......... .......... 48% 217K 62s
15150K .......... .......... .......... .......... .......... 48% 217K 61s
15200K .......... .......... .......... .......... .......... 48% 217K 61s
15250K .......... .......... .......... .......... .......... 48% 1.87M 61s
15300K .......... .......... .......... .......... .......... 48% 240K 61s
15350K .......... .......... .......... .......... .......... 48% 218K 61s
15400K .......... .......... .......... .......... .......... 49% 216K 60s
15450K .......... .......... .......... .......... .......... 49% 218K 60s
15500K .......... .......... .......... .......... .......... 49% 1.86M 60s
15550K .......... .......... .......... .......... .......... 49% 240K 60s
15600K .......... .......... .......... .......... .......... 49% 217K 60s
15650K .......... .......... .......... .......... .......... 49% 217K 59s
15700K .......... .......... .......... .......... .......... 50% 217K 59s
15750K .......... .......... .......... .......... .......... 50% 9.60M 59s
15800K .......... .......... .......... .......... .......... 50% 217K 59s
15850K .......... .......... .......... .......... .......... 50% 218K 59s
15900K .......... .......... .......... .......... .......... 50% 217K 58s
15950K .......... .......... .......... .......... .......... 50% 217K 58s
16000K .......... .......... .......... .......... .......... 51% 8.40M 58s
16050K .......... .......... .......... .......... .......... 51% 217K 58s
16100K .......... .......... .......... .......... .......... 51% 219K 58s
16150K .......... .......... .......... .......... .......... 51% 217K 58s
16200K .......... .......... .......... .......... .......... 51% 217K 57s
16250K .......... .......... .......... .......... .......... 51% 7.94M 57s
16300K .......... .......... .......... .......... .......... 51% 217K 57s
16350K .......... .......... .......... .......... .......... 52% 220K 57s
16400K .......... .......... .......... .......... .......... 52% 217K 57s
16450K .......... .......... .......... .......... .......... 52% 217K 56s
16500K .......... .......... .......... .......... .......... 52% 7.67M 56s
16550K .......... .......... .......... .......... .......... 52% 217K 56s
16600K .......... .......... .......... .......... .......... 52% 219K 56s
16650K .......... .......... .......... .......... .......... 53% 217K 56s
16700K .......... .......... .......... .......... .......... 53% 217K 55s
16750K .......... .......... .......... .......... .......... 53% 7.15M 55s
16800K .......... .......... .......... .......... .......... 53% 217K 55s
16850K .......... .......... .......... .......... .......... 53% 220K 55s
16900K .......... .......... .......... .......... .......... 53% 217K 55s
16950K .......... .......... .......... .......... .......... 54% 217K 55s
17000K .......... .......... .......... .......... .......... 54% 6.97M 54s
17050K .......... .......... .......... .......... .......... 54% 220K 54s
17100K .......... .......... .......... .......... .......... 54% 217K 54s
17150K .......... .......... .......... .......... .......... 54% 218K 54s
17200K .......... .......... .......... .......... .......... 54% 217K 54s
17250K .......... .......... .......... .......... .......... 54% 7.01M 53s
17300K .......... .......... .......... .......... .......... 55% 217K 53s
17350K .......... .......... .......... .......... .......... 55% 219K 53s
17400K .......... .......... .......... .......... .......... 55% 218K 53s
17450K .......... .......... .......... .......... .......... 55% 217K 53s
17500K .......... .......... .......... .......... .......... 55% 7.86M 52s
17550K .......... .......... .......... .......... .......... 55% 217K 52s
17600K .......... .......... .......... .......... .......... 56% 219K 52s
17650K .......... .......... .......... .......... .......... 56% 217K 52s
17700K .......... .......... .......... .......... .......... 56% 217K 52s
17750K .......... .......... .......... .......... .......... 56% 7.80M 51s
17800K .......... .......... .......... .......... .......... 56% 218K 51s
17850K .......... .......... .......... .......... .......... 56% 218K 51s
17900K .......... .......... .......... .......... .......... 57% 217K 51s
17950K .......... .......... .......... .......... .......... 57% 217K 51s
18000K .......... .......... .......... .......... .......... 57% 7.23M 50s
18050K .......... .......... .......... .......... .......... 57% 218K 50s
18100K .......... .......... .......... .......... .......... 57% 218K 50s
18150K .......... .......... .......... .......... .......... 57% 217K 50s
18200K .......... .......... .......... .......... .......... 57% 217K 50s
18250K .......... .......... .......... .......... .......... 58% 7.38M 49s
18300K .......... .......... .......... .......... .......... 58% 218K 49s
18350K .......... .......... .......... .......... .......... 58% 218K 49s
18400K .......... .......... .......... .......... .......... 58% 217K 49s
18450K .......... .......... .......... .......... .......... 58% 1.33M 49s
18500K .......... .......... .......... .......... .......... 58% 249K 48s
18550K .......... .......... .......... .......... .......... 59% 218K 48s
18600K .......... .......... .......... .......... .......... 59% 219K 48s
18650K .......... .......... .......... .......... .......... 59% 217K 48s
18700K .......... .......... .......... .......... .......... 59% 1.30M 48s
18750K .......... .......... .......... .......... .......... 59% 250K 48s
18800K .......... .......... .......... .......... .......... 59% 219K 47s
18850K .......... .......... .......... .......... .......... 60% 218K 47s
18900K .......... .......... .......... .......... .......... 60% 218K 47s
18950K .......... .......... .......... .......... .......... 60% 1.27M 47s
19000K .......... .......... .......... .......... .......... 60% 251K 47s
19050K .......... .......... .......... .......... .......... 60% 218K 46s
19100K .......... .......... .......... .......... .......... 60% 219K 46s
19150K .......... .......... .......... .......... .......... 61% 217K 46s
19200K .......... .......... .......... .......... .......... 61% 3.72M 46s
19250K .......... .......... .......... .......... .......... 61% 223K 46s
19300K .......... .......... .......... .......... .......... 61% 219K 45s
19350K .......... .......... .......... .......... .......... 61% 218K 45s
19400K .......... .......... .......... .......... .......... 61% 217K 45s
19450K .......... .......... .......... .......... .......... 61% 3.73M 45s
19500K .......... .......... .......... .......... .......... 62% 224K 45s
19550K .......... .......... .......... .......... .......... 62% 218K 45s
19600K .......... .......... .......... .......... .......... 62% 218K 44s
19650K .......... .......... .......... .......... .......... 62% 218K 44s
19700K .......... .......... .......... .......... .......... 62% 3.58M 44s
19750K .......... .......... .......... .......... .......... 62% 224K 44s
19800K .......... .......... .......... .......... .......... 63% 218K 44s
19850K .......... .......... .......... .......... .......... 63% 218K 43s
19900K .......... .......... .......... .......... .......... 63% 217K 43s
19950K .......... .......... .......... .......... .......... 63% 5.13M 43s
20000K .......... .......... .......... .......... .......... 63% 220K 43s
20050K .......... .......... .......... .......... .......... 63% 218K 43s
20100K .......... .......... .......... .......... .......... 64% 219K 42s
20150K .......... .......... .......... .......... .......... 64% 217K 42s
20200K .......... .......... .......... .......... .......... 64% 5.13M 42s
20250K .......... .......... .......... .......... .......... 64% 221K 42s
20300K .......... .......... .......... .......... .......... 64% 217K 42s
20350K .......... .......... .......... .......... .......... 64% 218K 42s
20400K .......... .......... .......... .......... .......... 64% 218K 41s
20450K .......... .......... .......... .......... .......... 65% 5.27M 41s
20500K .......... .......... .......... .......... .......... 65% 220K 41s
20550K .......... .......... .......... .......... .......... 65% 217K 41s
20600K .......... .......... .......... .......... .......... 65% 218K 41s
20650K .......... .......... .......... .......... .......... 65% 217K 40s
20700K .......... .......... .......... .......... .......... 65% 6.10M 40s
20750K .......... .......... .......... .......... .......... 66% 220K 40s
20800K .......... .......... .......... .......... .......... 66% 218K 40s
20850K .......... .......... .......... .......... .......... 66% 217K 40s
20900K .......... .......... .......... .......... .......... 66% 217K 39s
20950K .......... .......... .......... .......... .......... 66% 5.66M 39s
21000K .......... .......... .......... .......... .......... 66% 220K 39s
21050K .......... .......... .......... .......... .......... 67% 219K 39s
21100K .......... .......... .......... .......... .......... 67% 217K 39s
21150K .......... .......... .......... .......... .......... 67% 217K 39s
21200K .......... .......... .......... .......... .......... 67% 5.25M 38s
21250K .......... .......... .......... .......... .......... 67% 221K 38s
21300K .......... .......... .......... .......... .......... 67% 217K 38s
21350K .......... .......... .......... .......... .......... 68% 217K 38s
21400K .......... .......... .......... .......... .......... 68% 217K 38s
21450K .......... .......... .......... .......... .......... 68% 7.38M 37s
21500K .......... .......... .......... .......... .......... 68% 219K 37s
21550K .......... .......... .......... .......... .......... 68% 218K 37s
21600K .......... .......... .......... .......... .......... 68% 217K 37s
21650K .......... .......... .......... .......... .......... 68% 1.39M 37s
21700K .......... .......... .......... .......... .......... 69% 247K 36s
21750K .......... .......... .......... .......... .......... 69% 219K 36s
21800K .......... .......... .......... .......... .......... 69% 218K 36s
21850K .......... .......... .......... .......... .......... 69% 217K 36s
21900K .......... .......... .......... .......... .......... 69% 1.40M 36s
21950K .......... .......... .......... .......... .......... 69% 247K 35s
22000K .......... .......... .......... .......... .......... 70% 219K 35s
22050K .......... .......... .......... .......... .......... 70% 218K 35s
22100K .......... .......... .......... .......... .......... 70% 217K 35s
22150K .......... .......... .......... .......... .......... 70% 1.41M 35s
22200K .......... .......... .......... .......... .......... 70% 246K 34s
22250K .......... .......... .......... .......... .......... 70% 219K 34s
22300K .......... .......... .......... .......... .......... 71% 218K 34s
22350K .......... .......... .......... .......... .......... 71% 218K 34s
22400K .......... .......... .......... .......... .......... 71% 2.61M 34s
22450K .......... .......... .......... .......... .......... 71% 228K 34s
22500K .......... .......... .......... .......... .......... 71% 219K 33s
22550K .......... .......... .......... .......... .......... 71% 218K 33s
22600K .......... .......... .......... .......... .......... 71% 217K 33s
22650K .......... .......... .......... .......... .......... 72% 2.57M 33s
22700K .......... .......... .......... .......... .......... 72% 228K 33s
22750K .......... .......... .......... .......... .......... 72% 220K 32s
22800K .......... .......... .......... .......... .......... 72% 218K 32s
22850K .......... .......... .......... .......... .......... 72% 217K 32s
22900K .......... .......... .......... .......... .......... 72% 2.44M 32s
22950K .......... .......... .......... .......... .......... 73% 229K 32s
23000K .......... .......... .......... .......... .......... 73% 220K 31s
23050K .......... .......... .......... .......... .......... 73% 218K 31s
23100K .......... .......... .......... .......... .......... 73% 217K 31s
23150K .......... .......... .......... .......... .......... 73% 5.17M 31s
23200K .......... .......... .......... .......... .......... 73% 218K 31s
23250K .......... .......... .......... .......... .......... 74% 220K 31s
23300K .......... .......... .......... .......... .......... 74% 218K 30s
23350K .......... .......... .......... .......... .......... 74% 217K 30s
23400K .......... .......... .......... .......... .......... 74% 5.26M 30s
23450K .......... .......... .......... .......... .......... 74% 218K 30s
23500K .......... .......... .......... .......... .......... 74% 220K 30s
23550K .......... .......... .......... .......... .......... 75% 218K 29s
23600K .......... .......... .......... .......... .......... 75% 218K 29s
23650K .......... .......... .......... .......... .......... 75% 5.00M 29s
23700K .......... .......... .......... .......... .......... 75% 218K 29s
23750K .......... .......... .......... .......... .......... 75% 220K 29s
23800K .......... .......... .......... .......... .......... 75% 218K 29s
23850K .......... .......... .......... .......... .......... 75% 218K 28s
23900K .......... .......... .......... .......... .......... 76% 5.22M 28s
23950K .......... .......... .......... .......... .......... 76% 218K 28s
24000K .......... .......... .......... .......... .......... 76% 220K 28s
24050K .......... .......... .......... .......... .......... 76% 219K 28s
24100K .......... .......... .......... .......... .......... 76% 217K 27s
24150K .......... .......... .......... .......... .......... 76% 5.03M 27s
24200K .......... .......... .......... .......... .......... 77% 218K 27s
24250K .......... .......... .......... .......... .......... 77% 220K 27s
24300K .......... .......... .......... .......... .......... 77% 218K 27s
24350K .......... .......... .......... .......... .......... 77% 217K 26s
24400K .......... .......... .......... .......... .......... 77% 4.84M 26s
24450K .......... .......... .......... .......... .......... 77% 221K 26s
24500K .......... .......... .......... .......... .......... 78% 217K 26s
24550K .......... .......... .......... .......... .......... 78% 219K 26s
24600K .......... .......... .......... .......... .......... 78% 218K 26s
24650K .......... .......... .......... .......... .......... 78% 4.52M 25s
24700K .......... .......... .......... .......... .......... 78% 222K 25s
24750K .......... .......... .......... .......... .......... 78% 218K 25s
24800K .......... .......... .......... .......... .......... 78% 219K 25s
24850K .......... .......... .......... .......... .......... 79% 217K 25s
24900K .......... .......... .......... .......... .......... 79% 6.01M 24s
24950K .......... .......... .......... .......... .......... 79% 218K 24s
25000K .......... .......... .......... .......... .......... 79% 219K 24s
25050K .......... .......... .......... .......... .......... 79% 218K 24s
25100K .......... .......... .......... .......... .......... 79% 1.43M 24s
25150K .......... .......... .......... .......... .......... 80% 245K 23s
25200K .......... .......... .......... .......... .......... 80% 217K 23s
25250K .......... .......... .......... .......... .......... 80% 219K 23s
25300K .......... .......... .......... .......... .......... 80% 218K 23s
25350K .......... .......... .......... .......... .......... 80% 1.44M 23s
25400K .......... .......... .......... .......... .......... 80% 244K 22s
25450K .......... .......... .......... .......... .......... 81% 217K 22s
25500K .......... .......... .......... .......... .......... 81% 220K 22s
25550K .......... .......... .......... .......... .......... 81% 218K 22s
25600K .......... .......... .......... .......... .......... 81% 1.44M 22s
25650K .......... .......... .......... .......... .......... 81% 245K 22s
25700K .......... .......... .......... .......... .......... 81% 217K 21s
25750K .......... .......... .......... .......... .......... 81% 220K 21s
25800K .......... .......... .......... .......... .......... 82% 217K 21s
25850K .......... .......... .......... .......... .......... 82% 2.08M 21s
25900K .......... .......... .......... .......... .......... 82% 234K 21s
25950K .......... .......... .......... .......... .......... 82% 220K 20s
26000K .......... .......... .......... .......... .......... 82% 217K 20s
26050K .......... .......... .......... .......... .......... 82% 217K 20s
26100K .......... .......... .......... .......... .......... 83% 2.07M 20s
26150K .......... .......... .......... .......... .......... 83% 234K 20s
26200K .......... .......... .......... .......... .......... 83% 220K 19s
26250K .......... .......... .......... .......... .......... 83% 217K 19s
26300K .......... .......... .......... .......... .......... 83% 217K 19s
26350K .......... .......... .......... .......... .......... 83% 2.05M 19s
26400K .......... .......... .......... .......... .......... 84% 235K 19s
26450K .......... .......... .......... .......... .......... 84% 219K 19s
26500K .......... .......... .......... .......... .......... 84% 217K 18s
26550K .......... .......... .......... .......... .......... 84% 217K 18s
26600K .......... .......... .......... .......... .......... 84% 4.37M 18s
26650K .......... .......... .......... .......... .......... 84% 222K 18s
26700K .......... .......... .......... .......... .......... 85% 219K 18s
26750K .......... .......... .......... .......... .......... 85% 217K 17s
26800K .......... .......... .......... .......... .......... 85% 217K 17s
26850K .......... .......... .......... .......... .......... 85% 4.79M 17s
26900K .......... .......... .......... .......... .......... 85% 221K 17s
26950K .......... .......... .......... .......... .......... 85% 219K 17s
27000K .......... .......... .......... .......... .......... 85% 217K 16s
27050K .......... .......... .......... .......... .......... 86% 218K 16s
27100K .......... .......... .......... .......... .......... 86% 4.47M 16s
27150K .......... .......... .......... .......... .......... 86% 222K 16s
27200K .......... .......... .......... .......... .......... 86% 219K 16s
27250K .......... .......... .......... .......... .......... 86% 217K 16s
27300K .......... .......... .......... .......... .......... 86% 217K 15s
27350K .......... .......... .......... .......... .......... 87% 4.71M 15s
27400K .......... .......... .......... .......... .......... 87% 220K 15s
27450K .......... .......... .......... .......... .......... 87% 220K 15s
27500K .......... .......... .......... .......... .......... 87% 217K 15s
27550K .......... .......... .......... .......... .......... 87% 217K 14s
27600K .......... .......... .......... .......... .......... 87% 4.46M 14s
27650K .......... .......... .......... .......... .......... 88% 221K 14s
27700K .......... .......... .......... .......... .......... 88% 220K 14s
27750K .......... .......... .......... .......... .......... 88% 217K 14s
27800K .......... .......... .......... .......... .......... 88% 217K 14s
27850K .......... .......... .......... .......... .......... 88% 4.22M 13s
27900K .......... .......... .......... .......... .......... 88% 221K 13s
27950K .......... .......... .......... .......... .......... 88% 221K 13s
28000K .......... .......... .......... .......... .......... 89% 217K 13s
28050K .......... .......... .......... .......... .......... 89% 217K 13s
28100K .......... .......... .......... .......... .......... 89% 5.84M 12s
28150K .......... .......... .......... .......... .......... 89% 217K 12s
28200K .......... .......... .......... .......... .......... 89% 222K 12s
28250K .......... .......... .......... .......... .......... 89% 218K 12s
28300K .......... .......... .......... .......... .......... 90% 217K 12s
28350K .......... .......... .......... .......... .......... 90% 5.45M 11s
28400K .......... .......... .......... .......... .......... 90% 217K 11s
28450K .......... .......... .......... .......... .......... 90% 222K 11s
28500K .......... .......... .......... .......... .......... 90% 218K 11s
28550K .......... .......... .......... .......... .......... 90% 1.70M 11s
28600K .......... .......... .......... .......... .......... 91% 237K 11s
28650K .......... .......... .......... .......... .......... 91% 217K 10s
28700K .......... .......... .......... .......... .......... 91% 223K 10s
28750K .......... .......... .......... .......... .......... 91% 217K 10s
28800K .......... .......... .......... .......... .......... 91% 1.72M 10s
28850K .......... .......... .......... .......... .......... 91% 236K 10s
28900K .......... .......... .......... .......... .......... 92% 218K 9s
28950K .......... .......... .......... .......... .......... 92% 222K 9s
29000K .......... .......... .......... .......... .......... 92% 217K 9s
29050K .......... .......... .......... .......... .......... 92% 1.74M 9s
29100K .......... .......... .......... .......... .......... 92% 236K 9s
29150K .......... .......... .......... .......... .......... 92% 217K 8s
29200K .......... .......... .......... .......... .......... 92% 223K 8s
29250K .......... .......... .......... .......... .......... 93% 217K 8s
29300K .......... .......... .......... .......... .......... 93% 1.77M 8s
29350K .......... .......... .......... .......... .......... 93% 236K 8s
29400K .......... .......... .......... .......... .......... 93% 222K 8s
29450K .......... .......... .......... .......... .......... 93% 217K 7s
29500K .......... .......... .......... .......... .......... 93% 217K 7s
29550K .......... .......... .......... .......... .......... 94% 1.72M 7s
29600K .......... .......... .......... .......... .......... 94% 236K 7s
29650K .......... .......... .......... .......... .......... 94% 223K 7s
29700K .......... .......... .......... .......... .......... 94% 217K 6s
29750K .......... .......... .......... .......... .......... 94% 218K 6s
29800K .......... .......... .......... .......... .......... 94% 1.72M 6s
29850K .......... .......... .......... .......... .......... 95% 236K 6s
29900K .......... .......... .......... .......... .......... 95% 222K 6s
29950K .......... .......... .......... .......... .......... 95% 218K 5s
30000K .......... .......... .......... .......... .......... 95% 217K 5s
30050K .......... .......... .......... .......... .......... 95% 3.01M 5s
30100K .......... .......... .......... .......... .......... 95% 222K 5s
30150K .......... .......... .......... .......... .......... 95% 224K 5s
30200K .......... .......... .......... .......... .......... 96% 217K 5s
30250K .......... .......... .......... .......... .......... 96% 218K 4s
30300K .......... .......... .......... .......... .......... 96% 2.84M 4s
30350K .......... .......... .......... .......... .......... 96% 222K 4s
30400K .......... .......... .......... .......... .......... 96% 225K 4s
30450K .......... .......... .......... .......... .......... 96% 217K 4s
30500K .......... .......... .......... .......... .......... 97% 217K 3s
30550K .......... .......... .......... .......... .......... 97% 2.84M 3s
30600K .......... .......... .......... .......... .......... 97% 222K 3s
30650K .......... .......... .......... .......... .......... 97% 225K 3s
30700K .......... .......... .......... .......... .......... 97% 218K 3s
30750K .......... .......... .......... .......... .......... 97% 217K 2s
30800K .......... .......... .......... .......... .......... 98% 2.71M 2s
30850K .......... .......... .......... .......... .......... 98% 221K 2s
30900K .......... .......... .......... .......... .......... 98% 226K 2s
30950K .......... .......... .......... .......... .......... 98% 218K 2s
31000K .......... .......... .......... .......... .......... 98% 217K 2s
31050K .......... .......... .......... .......... .......... 98% 2.65M 1s
31100K .......... .......... .......... .......... .......... 98% 222K 1s
31150K .......... .......... .......... .......... .......... 99% 226K 1s
31200K .......... .......... .......... .......... .......... 99% 218K 1s
31250K .......... .......... .......... .......... .......... 99% 217K 1s
31300K .......... .......... .......... .......... .......... 99% 2.64M 0s
31350K .......... .......... .......... .......... .......... 99% 222K 0s
31400K .......... .......... .......... .......... .......... 99% 225K 0s
31450K .......... ..... 100% 1.57M=1m57s
2018-08-04 22:39:04 (268 KB/s) - ‘minotaur-externals-0.2.tar.gz’ saved [32220716/32220716]
configure: WARNING: Cannot find C-function for checking NaN.
configure: WARNING: No solver available, examples will not work.
../../../CoinUtils/src/CoinFactorization2.cpp: In member function 'int CoinFactorization::factorDense()':
../../../CoinUtils/src/CoinFactorization2.cpp:520:75: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += (numberDense_+1)/(sizeof(CoinFactorizationDouble)/sizeof(int));
../../../CoinUtils/src/CoinFactorization2.cpp:521:81: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += 2*((numberDense_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinFactorization2.cpp:522:78: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += ((numberRows_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinLpIO.cpp: In member function 'void CoinLpIO::readLp(FILE*)':
../../../CoinUtils/src/CoinLpIO.cpp:2268:24: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
int length=strlen(buff);
../../../CoinUtils/src/CoinLpIO.cpp:2320:24: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
int length=strlen(next+1);
../../../CoinUtils/src/CoinStructuredModel.cpp: In member function 'int CoinStructuredModel::decompose(const CoinPackedMatrix&, const double*, const double*, const double*, const double*, const double*, int, int, int*, double)':
../../../CoinUtils/src/CoinStructuredModel.cpp:761:10: warning: variable 'goodDW' set but not used [-Wunused-but-set-variable]
bool goodDW=true;
../../../CoinUtils/src/CoinStructuredModel.cpp:1343:10: warning: variable 'goodBenders' set but not used [-Wunused-but-set-variable]
bool goodBenders=true;
../../../CoinUtils/src/CoinMpsIO.cpp: In member function 'int CoinMpsIO::readConicMps(const char*, int*&, int*&, int*&, int&)':
../../../CoinUtils/src/CoinMpsIO.cpp:5814:3: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if ( cardReader_->whichSection ( ) == COIN_NAME_SECTION )
../../../CoinUtils/src/CoinMpsIO.cpp:5816:5: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
if ( cardReader_->whichSection ( ) == COIN_CONIC_SECTION ) {
../../../CoinUtils/src/CoinPresolveDual.cpp: In static member function 'static const CoinPresolveAction* remove_dual_action::presolve(CoinPresolveMatrix*, const CoinPresolveAction*)':
../../../CoinUtils/src/CoinPresolveDual.cpp:236:20: warning: unused variable 'lb' [-Wunused-variable]
const double lb = clo[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:237:20: warning: unused variable 'ub' [-Wunused-variable]
const double ub = cup[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:642:13: warning: unused variable 'no_clb' [-Wunused-variable]
const bool no_clb = (active[j]&5)==0 ;
../../../CoinUtils/src/CoinRational.cpp: In member function 'bool CoinRational::nearestRational_(double, double, long int)':
../../../CoinUtils/src/CoinRational.cpp:30:27: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
double mediant = (a + c)/(double(b + d));
../../../CoinUtils/src/CoinRational.cpp:60:30: warning: conversion to 'long int' from 'double' may alter its value [-Wfloat-conversion]
numerator_ += labs(intpart) * denominator_;
../../../CoinUtils/src/CoinRational.cpp:64:22: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
return fabs(val - numerator_/double(denominator_)) <= maxdelta;
../../../CoinUtils/src/CoinWarmStartBasis.cpp: In member function 'bool CoinWarmStartBasis::fixFullBasis()':
../../../CoinUtils/src/CoinWarmStartBasis.cpp:494:7: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if (status==CoinWarmStartBasis::basic)
../../../CoinUtils/src/CoinWarmStartBasis.cpp:496:2: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
numberBasic--;
mkdir: cannot create directory '.libs': File exists
In file included from ../../../../Osi/src/Osi/OsiColCut.cpp:10:0:
../../../../Osi/src/Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
../../../../Osi/src/Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if ( cutUbs.isExistingIndex(colIndx) )
../../../../Osi/src/Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
if ( newLb > newUb )
../../../../Osi/src/Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if ( cutLbs.isExistingIndex(colIndx) )
../../../../Osi/src/Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
if ( newUb < newLb )
In file included from ../../../../Osi/src/Osi/OsiCuts.hpp:14:0,
from ../../../../Osi/src/Osi/OsiCuts.cpp:13:
from ../../../../Osi/src/Osi/OsiRowCutDebugger.hpp:16,
from ../../../../Osi/src/Osi/OsiRowCutDebugger.cpp:19:
from ../../../../Osi/src/Osi/OsiSolverInterface.cpp:21:
../../../../Osi/src/Osi/OsiSolverInterface.cpp: In member function 'int OsiSolverInterface::differentModel(OsiSolverInterface&, bool)':
../../../../Osi/src/Osi/OsiSolverInterface.cpp:1880:8: warning: unused variable 'gotHint' [-Wunused-variable]
bool gotHint = (getHintParam(OsiDoReducePrint,takeHint,strength));
libtool: install: warning: relinking `libOsi.la'
In file included from ../../../../Osi/src/OsiCommonTest/../Osi/OsiCuts.hpp:14:0,
from ../../../../Osi/src/OsiCommonTest/OsiCutsTest.cpp:9:
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
from ../../../../Osi/src/OsiCommonTest/../Osi/OsiRowCutDebugger.hpp:16,
from ../../../../Osi/src/OsiCommonTest/OsiRowCutDebuggerTest.cpp:9:
In file included from ../../../../Osi/src/OsiCommonTest/OsiColCutTest.cpp:13:0:
from ../../../../Osi/src/OsiCommonTest/OsiSolverInterfaceTest.cpp:84:
libtool: install: warning: relinking `libOsiCommonTests.la'
../../../Clp/src/ClpPlusMinusOneMatrix.cpp:459:13: warning: 'doPlusOnes' defined but not used [-Wunused-variable]
static bool doPlusOnes=true;
../../../Clp/src/ClpSimplex.cpp: In member function 'int ClpSimplex::fathom(void*)':
../../../Clp/src/ClpSimplex.cpp:11081:15: warning: unused variable 'statusWeights' [-Wunused-variable]
int statusWeights = fastDual2(info);
../../../Clp/src/ClpSimplexOther.cpp: In member function 'int ClpSimplexOther::setInDual(ClpSimplex*)':
../../../Clp/src/ClpSimplexOther.cpp:1313:12: warning: unused variable 'statusD' [-Wunused-variable]
Status statusD = dualProblem->getRowStatus(iColumn);
../../../Clp/src/ClpSimplexOther.cpp:1314:12: warning: unused variable 'statusDJ' [-Wunused-variable]
Status statusDJ = dualProblem->getColumnStatus(jColumn);
../../../Clp/src/ClpSimplexOther.cpp:1352:12: warning: unused variable 'statusD' [-Wunused-variable]
Status statusD = dualProblem->getColumnStatus(iRow);
../../../Clp/src/ClpSolve.cpp: In member function 'int ClpSimplex::solveBenders(CoinStructuredModel*, ClpSolve&)':
../../../Clp/src/ClpSolve.cpp:7272:9: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if (saveLower[i] < -1.0e20);
../../../Clp/src/ClpSolve.cpp:7273:4: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
solution[i]=0.0;
../../../Clp/src/ClpSolver.cpp: In function 'void statistics(ClpSimplex*, ClpSimplex*)':
../../../Clp/src/ClpSolver.cpp:3756:10: warning: variable 'numberWritten' set but not used [-Wunused-but-set-variable]
size_t numberWritten;
libtool: install: warning: relinking `libClp.la'
libtool: install: warning: relinking `libClpSolver.la'
In file included from /home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiCuts.hpp:14:0,
from ../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:33:
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::initialSolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:148:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::resolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:843:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
bool gotHint = (getHintParam(OsiDoInBranchAndCut,takeHint,strength));
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'int OsiClpSolverInterface::infeasibleOtherWay(char*)':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9986:24: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
whichWay[iColumn] *=2;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9991:24: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9841:7: warning: unused variable 'iRow' [-Wunused-variable]
int iRow,iColumn;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9859:17: warning: unused variable 'objective' [-Wunused-variable]
const double *objective = getObjCoefficients() ;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9860:10: warning: unused variable 'direction' [-Wunused-variable]
double direction = getObjSense();
libtool: install: warning: relinking `libOsiClp.la'
filteraux.f:105:24:
. 0.D0,.false.)
1
Warning: Rank mismatch in argument ‘w’ at (1) (rank-1 and scalar)
ar: creating libfiltersqp.a
ar: `u' modifier ignored since `D' is the default (see `U')
ar: creating amplsolver.a
../../../../src/cppunit/Protector.cpp: In member function 'void CppUnit::Protector::reportError(const CppUnit::ProtectorContext&, const CppUnit::Exception&) const':
../../../../src/cppunit/Protector.cpp:24:8: warning: 'template<class> class std::auto_ptr' is deprecated [-Wdeprecated-declarations]
std::auto_ptr<Exception> actualError( error.clone() );
In file included from /usr/include/c++/6/memory:81:0,
from ../../../../src/cppunit/Protector.cpp:6:
/usr/include/c++/6/bits/unique_ptr.h:49:28: note: declared here
template<typename> class auto_ptr;
../../../../src/cppunit/Protector.cpp: In member function 'void CppUnit::Protector::reportFailure(const CppUnit::ProtectorContext&, const CppUnit::Exception&) const':
../../../../src/cppunit/Protector.cpp:45:8: warning: 'template<class> class std::auto_ptr' is deprecated [-Wdeprecated-declarations]
std::auto_ptr<Exception> actualFailure( failure.clone() );
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 196: cd: minotaur-externals//build: No such file or directory
make: *** No rule to make target 'distclean'. Stop.
: logger ok! OK (41)
Errors in build-base-static:
CMake Error at CMakeLists.txt:217 (message):
Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target 'install'. Stop.
make: *** No rule to make target 'utest'. Stop.
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Sat Aug 4 22:44:39 IST 2018
More information about the Minotaur-dev
