[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan mahajan at mcs.anl.gov
Wed Apr 4 23:01:05 CDT 2018
Minotaur daily test report
Wed Apr  4 22:57:01 CDT 2018
petsc.mcs.anl.gov
Linux petsc 3.13.0-121-generic #170-Ubuntu SMP Wed Jun 14 09:04:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at  http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-58-g89a7335
ls: cannot access build-ampl/bin: No such file or directory
ls: cannot access build-ampl/lib: No such file or directory
ls: cannot access build-ampl/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-debug/bin: No such file or directory
ls: cannot access build-ampl-debug/lib: No such file or directory
ls: cannot access build-ampl-debug/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-static/bin: No such file or directory
ls: cannot access build-ampl-static/lib: No such file or directory
ls: cannot access build-ampl-static/include/minotaur/*: No such file or directory
ls: cannot access build-all/bin: No such file or directory
ls: cannot access build-all/lib: No such file or directory
ls: cannot access build-all/include/minotaur/*: No such file or directory
ls: cannot access build-all-debug/bin: No such file or directory
ls: cannot access build-all-debug/lib: No such file or directory
ls: cannot access build-all-debug/include/minotaur/*: No such file or directory
ls: cannot access build-all-static/bin: No such file or directory
ls: cannot access build-all-static/lib: No such file or directory
ls: cannot access build-all-static/include/minotaur/*: No such file or directory
rsync: change_dir "/sandbox/mahajan/minotaur-test/build-all/doxygen/html" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1183) [sender=3.1.0]
Summary
compiling build-base: ERROR. lib/libminotaur.so not built.
make utest output for build-base: ERROR
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libminotaur.a not built.
Errors:
Errors in build-all-debug:
CMake Error at src/base/CMakeLists.txt:247 (add_library):
  Cannot find source file:
    ConBoundMod.cpp
  Tried extensions .c .C .c++ .cc .cpp .cxx .m .M .mm .h .hh .h++ .hm .hpp
  .hxx .in .txx
make: *** No rule to make target `install'.  Stop.
make: *** No rule to make target `utest'.  Stop.
valgrind: ./unittest: No such file or directory
Errors in build-all:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
/sandbox/mahajan/minotaur-test/src/base/QGHandler.cpp:24:25: fatal error: ConBoundMod.h: No such file or directory
 #include "ConBoundMod.h"
compilation terminated.
make: *** [depend] Error 1
Errors in build-all-static:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-ampl-debug:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-ampl:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-ampl-static:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-base-debug:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-base:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-base-static:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-filter-debug:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-filter:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-filter-static:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-ipopt-debug:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-ipopt:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-ipopt-static:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-osi-debug:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-osi:
    ConBoundMod.cpp
  .hxx .in .txx
Errors in build-osi-static:
    ConBoundMod.cpp
  .hxx .in .txx
End of tests
Wed Apr  4 23:01:04 CDT 2018
More information about the Minotaur-dev mailing list
