[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan mahajan at mcs.anl.gov
Wed May 31 23:08:11 CDT 2017
Minotaur daily test report
Wed May 31 22:57:01 CDT 2017
petsc.mcs.anl.gov
Linux petsc 3.13.0-111-generic #158-Ubuntu SMP Wed Feb 22 16:12:03 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at  http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2-150-gde69326
ls: cannot access build-ampl/bin: No such file or directory
ls: cannot access build-ampl/lib: No such file or directory
ls: cannot access build-ampl/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-debug/bin: No such file or directory
ls: cannot access build-ampl-debug/lib: No such file or directory
ls: cannot access build-ampl-debug/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-static/bin: No such file or directory
ls: cannot access build-ampl-static/lib: No such file or directory
ls: cannot access build-ampl-static/include/minotaur/*: No such file or directory
ls: cannot access build-all/bin: No such file or directory
ls: cannot access build-all/lib: No such file or directory
ls: cannot access build-all/include/minotaur/*: No such file or directory
ls: cannot access build-all-debug/bin: No such file or directory
ls: cannot access build-all-debug/lib: No such file or directory
ls: cannot access build-all-debug/include/minotaur/*: No such file or directory
ls: cannot access build-all-static/bin: No such file or directory
ls: cannot access build-all-static/lib: No such file or directory
ls: cannot access build-all-static/include/minotaur/*: No such file or directory
Summary
compiling build-base: OK.
make utest output for build-base: ERROR
compiling build-base-debug: OK.
make utest output for build-base-debug: ERROR
compiling build-base-static: OK.
make utest output for build-base-static: ERROR
compiling build-filter: OK.
make utest output for build-filter: ERROR
compiling build-filter-debug: OK.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: OK.
make utest output for build-filter-static: ERROR
compiling build-ipopt: OK.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libmntrampl.a not built.
Errors:
Errors in build-all-debug:
In file included from /usr/include/c++/4.8/cstdint:35:0,
                 from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/CoinTypes.hpp:15,
                 from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpMatrixBase.hpp:10,
                 from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpPackedMatrix.hpp:11,
                 from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpModel.hpp:19,
                 from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpSimplex.hpp:16,
                 from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/OsiClpSolverInterface.hpp:14,
                 from /sandbox/mahajan/minotaur-test/src/engines/OsiLP/OsiLPEngine.cpp:18:
/usr/include/c++/4.8/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
 #error This file requires compiler and library support for the \
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpSimplex.hpp:18:0,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpSolve.hpp:408:5: warning: "CLP_HAS_ABC" is not defined [-Wundef]
 #if CLP_HAS_ABC
In file included from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLHessian.h:17:0,
                 from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLHessian.cpp:19:
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/asl.h:956:44: warning: redundant redeclaration of ‘int Sprintf(char*, const char*, ...)’ in same scope [-Wredundant-decls]
  extern int Sprintf(char*, const char*, ...);
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/asl.h:24:0,
                 from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLHessian.h:17,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/stdio1.h:66:12: warning: previous declaration of ‘int Sprintf(char*, const char*, ...)’ [-Wredundant-decls]
 extern int Sprintf ANSI((char*, const char*, ...));
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:13:0,
                 from /sandbox/mahajan/minotaur-test/src/engines/Ipopt/IpoptEngine.cpp:18:
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpReferenced.hpp:215:8: warning: unused parameter ‘referencer’ [-Wunused-parameter]
   void ReferencedObject::AddRef(const Referencer* referencer) const
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpReferenced.hpp:227:8: warning: unused parameter ‘referencer’ [-Wunused-parameter]
   void ReferencedObject::ReleaseRef(const Referencer* referencer) const
In file included from /sandbox/mahajan/minotaur-test/src/engines/Ipopt/IpoptEngine.cpp:18:0:
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘n’ [-Wunused-parameter]
     virtual bool get_var_con_metadata(Index n,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘var_string_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘var_integer_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘var_numeric_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘m’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘con_string_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘con_integer_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘con_numeric_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘obj_scaling’ [-Wunused-parameter]
     virtual bool get_scaling_parameters(Number& obj_scaling,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘use_x_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘n’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘x_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘use_g_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘m’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘g_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:132:18: warning: unused parameter ‘n’ [-Wunused-parameter]
     virtual bool get_variables_linearity(Index n, LinearityType* var_types)
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:132:18: warning: unused parameter ‘var_types’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:140:18: warning: unused parameter ‘m’ [-Wunused-parameter]
     virtual bool get_constraints_linearity(Index m, LinearityType* const_types)
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:140:18: warning: unused parameter ‘const_types’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:161:18: warning: unused parameter ‘warm_start_iterate’ [-Wunused-parameter]
     virtual bool get_warm_start_iterate(IteratesVector& warm_start_iterate)
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘n’ [-Wunused-parameter]
     virtual bool eval_h(Index n, const Number* x, bool new_x,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘x’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘new_x’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘obj_factor’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘m’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘lambda’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘new_lambda’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘nele_hess’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘iRow’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘jCol’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘values’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘n’ [-Wunused-parameter]
     virtual void finalize_metadata(Index n,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘var_string_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘var_integer_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘var_numeric_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘m’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘con_string_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘con_integer_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘con_numeric_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘mode’ [-Wunused-parameter]
     virtual bool intermediate_callback(AlgorithmMode mode,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘iter’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘obj_value’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘inf_pr’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘inf_du’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘mu’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘d_norm’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘regularization_size’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘alpha_du’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘alpha_pr’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘ls_trials’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘ip_data’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘ip_cq’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:272:18: warning: unused parameter ‘num_nonlin_vars’ [-Wunused-parameter]
     virtual bool get_list_of_nonlinear_variables(Index num_nonlin_vars,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:272:18: warning: unused parameter ‘pos_nonlin_vars’ [-Wunused-parameter]
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTaggedObject.hpp:15:0,
                 from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpVector.hpp:13,
                 from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:13,
                 from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpIpoptApplication.hpp:28,
                 from /sandbox/mahajan/minotaur-test/src/engines/Ipopt/IpoptEngine.cpp:19:
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpObserver.hpp:309:8: warning: unused parameter ‘notify_type’ [-Wunused-parameter]
   void Subject::AttachObserver(Observer::NotifyType notify_type, Observer* observer) const
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpObserver.hpp:329:8: warning: unused parameter ‘notify_type’ [-Wunused-parameter]
   void Subject::DetachObserver(Observer::NotifyType notify_type, Observer* observer) const
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpIpoptApplication.hpp:28:0,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:56:18: warning: unused parameter ‘options’ [-Wunused-parameter]
     virtual bool ProcessOptions(const OptionsList& options,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:56:18: warning: unused parameter ‘prefix’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:109:18: warning: unused parameter ‘warm_start_iterate’ [-Wunused-parameter]
     virtual bool GetWarmStartIterate(IteratesVector& warm_start_iterate)
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘status’ [-Wunused-parameter]
     virtual void FinalizeSolution(SolverReturn status,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘x’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘z_L’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘z_U’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘c’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘d’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘y_c’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘y_d’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘obj_value’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘ip_data’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘ip_cq’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘mode’ [-Wunused-parameter]
     virtual bool IntermediateCallBack(AlgorithmMode mode,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘iter’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘obj_value’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘inf_pr’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘inf_du’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘mu’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘d_norm’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘regularization_size’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘alpha_du’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘alpha_pr’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘ls_trials’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘ip_data’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘ip_cq’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘x_space’ [-Wunused-parameter]
     virtual void GetScalingParameters(
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘c_space’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘d_space’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘obj_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘x_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘c_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘d_scaling’ [-Wunused-parameter]
In file included from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLInterface.h:18:0,
                 from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLInterface.cpp:19:
                 from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLInterface.h:18,
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpModel.hpp:23:0,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/CoinFinite.hpp:19:14: warning: ‘COIN_INT_MAX’ defined but not used [-Wunused-variable]
 const int    COIN_INT_MAX = (std::numeric_limits<int>::max)();
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/CoinFinite.hpp:20:14: warning: ‘COIN_INT_MAX_AS_DOUBLE’ defined but not used [-Wunused-variable]
 const double COIN_INT_MAX_AS_DOUBLE = (std::numeric_limits<int>::max)();
make[2]: *** [src/engines/OsiLP/CMakeFiles/mntrosilp.dir/OsiLPEngine.cpp.o] Error 1
make[1]: *** [src/engines/OsiLP/CMakeFiles/mntrosilp.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpVector.hpp:14:0,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpCachedResults.hpp: In instantiation of ‘void Ipopt::DependentResult<T>::RecieveNotification(Ipopt::Observer::NotifyType, const Ipopt::Subject*) [with T = double]’:
/sandbox/mahajan/minotaur-test/src/engines/Ipopt/IpoptEngine.cpp:1126:1:   required from here
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpCachedResults.hpp:405:8: warning: unused parameter ‘subject’ [-Wunused-parameter]
   void DependentResult<T>::RecieveNotification(NotifyType notify_type, const Subject* subject)
In file included from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLNonlinearFunction.h:18:0,
                 from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLNonlinearFunction.cpp:17:
                 from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLNonlinearFunction.h:18,
                 from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLJacobian.cpp:18:
make: *** [all] Error 2
 #if CLP_HAS_ABC
make[3]: *** [src/engines/OsiLP/CMakeFiles/mntrosilp.dir/OsiLPEngine.cpp.o] Error 1
make[2]: *** [src/engines/OsiLP/CMakeFiles/mntrosilp.dir/all] Error 2
make[1]: *** [CMakeFiles/utest.dir/rule] Error 2
make: *** [utest] Error 2
 #if CLP_HAS_ABC
valgrind: ./unittest: No such file or directory
Errors in build-all:
 #if CLP_HAS_ABC
 #if CLP_HAS_ABC
 #if CLP_HAS_ABC
Errors in build-all-manual:
Makefile:542: minotaur.d: No such file or directory
 #if CLP_HAS_ABC
make: *** [/sandbox/mahajan/minotaur-test/src/engines/OsiLP/OsiLPEngine.o] Error 1
Errors in build-all-static:
 #if CLP_HAS_ABC
 #if CLP_HAS_ABC
 #if CLP_HAS_ABC
Errors in build-ampl-debug:
                 from /sandbox/mahajan/minotaur-test/src/algorithms/qg.cpp:17:
                 from /sandbox/mahajan/minotaur-test/src/algorithms/QPDive.cpp:43:
                 from /sandbox/mahajan/minotaur-test/src/algorithms/Glob.cpp:45:
                 from /sandbox/mahajan/minotaur-test/src/algorithms/McBnb.cpp:54:
                 from /sandbox/mahajan/minotaur-test/src/algorithms/Bnb.cpp:50:
                 from /sandbox/mahajan/minotaur-test/src/algorithms/MsBnb.cpp:52:
/usr/bin/ld: ../../../third-party-0.2.1-linux-x86_64/lib/amplsolver.a(f_read.o): unrecognized relocation (0x2a) in section `.text'
/usr/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
make[2]: *** [src/algorithms/qpd] Error 1
make[1]: *** [src/algorithms/CMakeFiles/qpd.dir/all] Error 2
make[2]: *** [src/algorithms/glob] Error 1
make[1]: *** [src/algorithms/CMakeFiles/glob.dir/all] Error 2
make[2]: *** [src/algorithms/qg] Error 1
make[1]: *** [src/algorithms/CMakeFiles/qg.dir/all] Error 2
make[2]: *** [src/algorithms/mcbnb] Error 1
make[1]: *** [src/algorithms/CMakeFiles/mcbnb.dir/all] Error 2
make[2]: *** [src/algorithms/bnb] Error 1
make[1]: *** [src/algorithms/CMakeFiles/bnb.dir/all] Error 2
make[2]: *** [src/algorithms/msbnb] Error 1
make[1]: *** [src/algorithms/CMakeFiles/msbnb.dir/all] Error 2
                 from /sandbox/mahajan/minotaur-test/src/testing/AMPLInstanceUT.h:18,
                 from /sandbox/mahajan/minotaur-test/src/testing/AMPLInstanceUT.cpp:8:
                 from /sandbox/mahajan/minotaur-test/src/testing/AMPLCGraphUT.h:18,
                 from /sandbox/mahajan/minotaur-test/src/testing/AMPLCGraphUT.cpp:8:
                 from /sandbox/mahajan/minotaur-test/src/testing/PolySolverUT.h:18,
                 from /sandbox/mahajan/minotaur-test/src/testing/PolySolverUT.cpp:10:
                 from /sandbox/mahajan/minotaur-test/src/testing/TransformerUT.h:18,
                 from /sandbox/mahajan/minotaur-test/src/testing/TransformerUT.cpp:8:
/usr/bin/ld: /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/lib/libcppunit.a(Asserter.o): unrecognized relocation (0x2a) in section `.text'
make[3]: *** [src/testing/unittest] Error 1
make[2]: *** [src/testing/CMakeFiles/unittest.dir/all] Error 2
Errors in build-ampl:
CMakeFiles/unittest.dir/LoggerUT.cpp.o: In function `CppUnit::TestSuiteFactory<LoggerUT>::makeTest()':
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x2c): undefined reference to `CppUnit::TestNamer::getFixtureName() const'
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x49): undefined reference to `CppUnit::TestSuite::TestSuite(std::string)'
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x195): undefined reference to `CppUnit::TestSuiteBuilderContextBase::getTestNameFor(std::string const&) const'
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x1bf): undefined reference to `CppUnit::TestCase::TestCase(std::string const&)'
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x24e): undefined reference to `CppUnit::TestSuiteBuilderContextBase::getTestNameFor(std::string const&) const'
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x278): undefined reference to `CppUnit::TestCase::TestCase(std::string const&)'
CMakeFiles/unittest.dir/LoggerUT.cpp.o: In function `_GLOBAL__sub_I__ZN8LoggerUT13testMsgStreamEv':
LoggerUT.cpp:(.text.startup+0x3d): undefined reference to `CppUnit::TestFactoryRegistry::getRegistry(std::string const&)'
LoggerUT.cpp:(.text.startup+0xa5): undefined reference to `CppUnit::TestFactoryRegistry::getRegistry(std::string const&)'
CMakeFiles/unittest.dir/LoggerUT.cpp.o:(.rodata._ZTVN7CppUnit10TestCallerI8LoggerUTEE[_ZTVN7CppUnit10TestCallerI8LoggerUTEE]+0x40): undefined reference to `CppUnit::TestCase::getName() const'
CMakeFiles/unittest.dir/LoggerUT.cpp.o:(.rodata._ZTVN7CppUnit10TestCallerI8LoggerUTEE[_ZTVN7CppUnit10TestCallerI8LoggerUTEE]+0x48): undefined reference to `CppUnit::Test::findTestPath(std::string const&, CppUnit::TestPath&) const'
CMakeFiles/unittest.dir/LoggerUT.cpp.o:(.rodata._ZTVN7CppUnit10TestCallerI8LoggerUTEE[_ZTVN7CppUnit10TestCallerI8LoggerUTEE]+0x58): undefined reference to `CppUnit::Test::findTest(std::string const&) const'
CMakeFiles/unittest.dir/LoggerUT.cpp.o:(.rodata._ZTVN7CppUnit10TestCallerI8LoggerUTEE[_ZTVN7CppUnit10TestCallerI8LoggerUTEE]+0x60): undefined reference to `CppUnit::Test::resolveTestPath(std::string const&) const'
/usr/binmake[1]: /*** [src/algorithms/CMakeFiles/qpd.dir/all] Error 2ld
: ../make[1]: .*** Waiting for unfinished jobs.....
//usrusr//binbin//ldld::  ....//....//....//thirdthird--partyparty--0.2.10.2.1--linuxlinux--x86_64x86_64//liblib//amplsolver.aamplsolver.a((f_read.of_read.o))::  unrecognizedunrecognized  relocationrelocation  ((0x2a0x2a))  inin  sectionsection  ``..texttext''
//usrusr//binbin//ldld::  finalfinal  linklink  failedfailed::  BadBad  valuevalue
Errors in build-ampl-static:
Errors in build-base-debug:
Errors in build-base:
--2017-05-31 22:57:03--  http://www.mcs.anl.gov/research/projects/minotaur/dist/third-party-0.2.1-linux-x86_64.tar.gz
Resolving www.mcs.anl.gov (www.mcs.anl.gov)... 140.221.6.95
Connecting to www.mcs.anl.gov (www.mcs.anl.gov)|140.221.6.95|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 12156146 (12M) [application/x-gzip]
Saving to: ‘third-party-0.2.1-linux-x86_64.tar.gz’
     0K .......... .......... .......... .......... ..........  0% 35.1M 0s
    50K .......... .......... .......... .......... ..........  0% 39.2M 0s
   100K .......... .......... .......... .......... ..........  1% 49.9M 0s
   150K .......... .......... .......... .......... ..........  1% 4.25M 1s
   200K .......... .......... .......... .......... ..........  2% 43.9M 1s
   250K .......... .......... .......... .......... ..........  2% 45.2M 1s
   300K .......... .......... .......... .......... ..........  2% 55.9M 1s
   350K .......... .......... .......... .......... ..........  3% 8.86M 1s
   400K .......... .......... .......... .......... ..........  3% 55.2M 1s
   450K .......... .......... .......... .......... ..........  4% 79.8M 1s
   500K .......... .......... .......... .......... ..........  4% 3.24M 1s
   550K .......... .......... .......... .......... ..........  5% 58.6M 1s
   600K .......... .......... .......... .......... ..........  5% 64.8M 1s
   650K .......... .......... .......... .......... ..........  5% 75.1M 1s
   700K .......... .......... .......... .......... ..........  6% 30.6M 1s
   750K .......... .......... .......... .......... ..........  6% 90.9M 1s
   800K .......... .......... .......... .......... ..........  7% 1.07M 1s
   850K .......... .......... .......... .......... ..........  7%  123M 1s
   900K .......... .......... .......... .......... ..........  8% 87.2M 1s
   950K .......... .......... .......... .......... ..........  8% 83.9M 1s
  1000K .......... .......... .......... .......... ..........  8% 80.8M 1s
  1050K .......... .......... .......... .......... ..........  9% 73.3M 1s
  1100K .......... .......... .......... .......... ..........  9%  128M 1s
  1150K .......... .......... .......... .......... .......... 10% 88.5M 1s
  1200K .......... .......... .......... .......... .......... 10%  120M 1s
  1250K .......... .......... .......... .......... .......... 10%  111M 1s
  1300K .......... .......... .......... .......... .......... 11% 1.86M 1s
  1350K .......... .......... .......... .......... .......... 11% 57.9M 1s
  1400K .......... .......... .......... .......... .......... 12%  118M 1s
  1450K .......... .......... .......... .......... .......... 12%  133M 1s
  1500K .......... .......... .......... .......... .......... 13%  103M 1s
  1550K .......... .......... .......... .......... .......... 13%  109M 1s
  1600K .......... .......... .......... .......... .......... 13% 3.17M 1s
  1650K .......... .......... .......... .......... .......... 14% 95.3M 1s
  1700K .......... .......... .......... .......... .......... 14% 99.1M 1s
  1750K .......... .......... .......... .......... .......... 15%  107M 1s
  1800K .......... .......... .......... .......... .......... 15% 66.7M 1s
  1850K .......... .......... .......... .......... .......... 16%  114M 1s
  1900K .......... .......... .......... .......... .......... 16% 96.8M 1s
  1950K .......... .......... .......... .......... .......... 16% 60.9M 1s
  2000K .......... .......... .......... .......... .......... 17%  126M 1s
  2050K .......... .......... .......... .......... .......... 17%  119M 1s
  2100K .......... .......... .......... .......... .......... 18%  108M 1s
  2150K .......... .......... .......... .......... .......... 18%  121M 1s
  2200K .......... .......... .......... .......... .......... 18%  112M 1s
  2250K .......... .......... .......... .......... .......... 19%  113M 1s
  2300K .......... .......... .......... .......... .......... 19%  104M 1s
  2350K .......... .......... .......... .......... .......... 20%  121M 1s
  2400K .......... .......... .......... .......... .......... 20%  105M 1s
  2450K .......... .......... .......... .......... .......... 21%  118M 1s
  2500K .......... .......... .......... .......... .......... 21% 2.41M 1s
  2550K .......... .......... .......... .......... .......... 21%  105M 1s
  2600K .......... .......... .......... .......... .......... 22% 37.2M 1s
  2650K .......... .......... .......... .......... .......... 22%  139M 1s
  2700K .......... .......... .......... .......... .......... 23%  105M 1s
  2750K .......... .......... .......... .......... .......... 23% 3.21M 1s
  2800K .......... .......... .......... .......... .......... 24%  107M 1s
  2850K .......... .......... .......... .......... .......... 24% 78.2M 1s
  2900K .......... .......... .......... .......... .......... 24%  114M 1s
  2950K .......... .......... .......... .......... .......... 25%  101M 1s
  3000K .......... .......... .......... .......... .......... 25%  113M 1s
  3050K .......... .......... .......... .......... .......... 26%  117M 1s
  3100K .......... .......... .......... .......... .......... 26% 97.1M 1s
  3150K .......... .......... .......... .......... .......... 26%  141M 1s
  3200K .......... .......... .......... .......... .......... 27% 90.7M 1s
  3250K .......... .......... .......... .......... .......... 27%  134M 0s
  3300K .......... .......... .......... .......... .......... 28%  110M 0s
  3350K .......... .......... .......... .......... .......... 28%  112M 0s
  3400K .......... .......... .......... .......... .......... 29%  111M 0s
  3450K .......... .......... .......... .......... .......... 29%  107M 0s
  3500K .......... .......... .......... .......... .......... 29%  114M 0s
  3550K .......... .......... .......... .......... .......... 30%  105M 0s
  3600K .......... .......... .......... .......... .......... 30%  127M 0s
  3650K .......... .......... .......... .......... .......... 31%  112M 0s
  3700K .......... .......... .......... .......... .......... 31%  107M 0s
  3750K .......... .......... .......... .......... .......... 32% 98.9M 0s
  3800K .......... .......... .......... .......... .......... 32%  122M 0s
  3850K .......... .......... .......... .......... .......... 32%  118M 0s
  3900K .......... .......... .......... .......... .......... 33%  119M 0s
  3950K .......... .......... .......... .......... .......... 33% 97.4M 0s
  4000K .......... .......... .......... .......... .......... 34%  131M 0s
  4050K .......... .......... .......... .......... .......... 34%  101M 0s
  4100K .......... .......... .......... .......... .......... 34%  114M 0s
  4150K .......... .......... .......... .......... .......... 35%  116M 0s
  4200K .......... .......... .......... .......... .......... 35%  118M 0s
  4250K .......... .......... .......... .......... .......... 36%  108M 0s
  4300K .......... .......... .......... .......... .......... 36%  116M 0s
  4350K .......... .......... .......... .......... .......... 37%  105M 0s
  4400K .......... .......... .......... .......... .......... 37%  107M 0s
  4450K .......... .......... .......... .......... .......... 37%  122M 0s
  4500K .......... .......... .......... .......... .......... 38%  111M 0s
  4550K .......... .......... .......... .......... .......... 38%  116M 0s
  4600K .......... .......... .......... .......... .......... 39%  110M 0s
  4650K .......... .......... .......... .......... .......... 39%  122M 0s
  4700K .......... .......... .......... .......... .......... 40%  102M 0s
  4750K .......... .......... .......... .......... .......... 40%  124M 0s
  4800K .......... .......... .......... .......... .......... 40%  110M 0s
  4850K .......... .......... .......... .......... .......... 41%  101M 0s
  4900K .......... .......... .......... .......... .......... 41%  112M 0s
  4950K .......... .......... .......... .......... .......... 42%  110M 0s
  5000K .......... .......... .......... .......... .......... 42%  116M 0s
  5050K .......... .......... .......... .......... .......... 42%  117M 0s
  5100K .......... .......... .......... .......... .......... 43%  129M 0s
  5150K .......... .......... .......... .......... .......... 43%  102M 0s
  5200K .......... .......... .......... .......... .......... 44%  118M 0s
  5250K .......... .......... .......... .......... .......... 44%  109M 0s
  5300K .......... .......... .......... .......... .......... 45%  112M 0s
  5350K .......... .......... .......... .......... .......... 45%  102M 0s
  5400K .......... .......... .......... .......... .......... 45%  130M 0s
  5450K .......... .......... .......... .......... .......... 46%  101M 0s
  5500K .......... .......... .......... .......... .......... 46%  107M 0s
  5550K .......... .......... .......... .......... .......... 47%  130M 0s
  5600K .......... .......... .......... .......... .......... 47%  111M 0s
  5650K .......... .......... .......... .......... .......... 48%  113M 0s
  5700K .......... .......... .......... .......... .......... 48%  106M 0s
  5750K .......... .......... .......... .......... .......... 48%  111M 0s
  5800K .......... .......... .......... .......... .......... 49%  106M 0s
  5850K .......... .......... .......... .......... .......... 49%  114M 0s
  5900K .......... .......... .......... .......... .......... 50%  113M 0s
  5950K .......... .......... .......... .......... .......... 50%  110M 0s
  6000K .......... .......... .......... .......... .......... 50%  116M 0s
  6050K .......... .......... .......... .......... .......... 51%  118M 0s
  6100K .......... .......... .......... .......... .......... 51%  113M 0s
  6150K .......... .......... .......... .......... .......... 52%  113M 0s
  6200K .......... .......... .......... .......... .......... 52%  120M 0s
  6250K .......... .......... .......... .......... .......... 53%  101M 0s
  6300K .......... .......... .......... .......... .......... 53%  111M 0s
  6350K .......... .......... .......... .......... .......... 53%  111M 0s
  6400K .......... .......... .......... .......... .......... 54%  126M 0s
  6450K .......... .......... .......... .......... .......... 54%  108M 0s
  6500K .......... .......... .......... .......... .......... 55%  114M 0s
  6550K .......... .......... .......... .......... .......... 55%  110M 0s
  6600K .......... .......... .......... .......... .......... 56%  122M 0s
  6650K .......... .......... .......... .......... .......... 56%  111M 0s
  6700K .......... .......... .......... .......... .......... 56%  102M 0s
  6750K .......... .......... .......... .......... .......... 57%  112M 0s
  6800K .......... .......... .......... .......... .......... 57%  122M 0s
  6850K .......... .......... .......... .......... .......... 58%  102M 0s
  6900K .......... .......... .......... .......... .......... 58% 9.57M 0s
  6950K .......... .......... .......... .......... .......... 58%  127M 0s
  7000K .......... .......... .......... .......... .......... 59%  110M 0s
  7050K .......... .......... .......... .......... .......... 59%  105M 0s
  7100K .......... .......... .......... .......... .......... 60%  119M 0s
  7150K .......... .......... .......... .......... .......... 60%  107M 0s
  7200K .......... .......... .......... .......... .......... 61%  125M 0s
  7250K .......... .......... .......... .......... .......... 61%  106M 0s
  7300K .......... .......... .......... .......... .......... 61%  106M 0s
  7350K .......... .......... .......... .......... .......... 62%  129M 0s
  7400K .......... .......... .......... .......... .......... 62%  107M 0s
  7450K .......... .......... .......... .......... .......... 63%  114M 0s
  7500K .......... .......... .......... .......... .......... 63%  104M 0s
  7550K .......... .......... .......... .......... .......... 64%  126M 0s
  7600K .......... .......... .......... .......... .......... 64%  101M 0s
  7650K .......... .......... .......... .......... .......... 64%  119M 0s
  7700K .......... .......... .......... .......... .......... 65%  114M 0s
  7750K .......... .......... .......... .......... .......... 65%  114M 0s
  7800K .......... .......... .......... .......... .......... 66%  101M 0s
  7850K .......... .......... .......... .......... .......... 66%  129M 0s
  7900K .......... .......... .......... .......... .......... 66% 98.6M 0s
  7950K .......... .......... .......... .......... .......... 67% 14.7M 0s
  8000K .......... .......... .......... .......... .......... 67%  180M 0s
  8050K .......... .......... .......... .......... .......... 68%  172M 0s
  8100K .......... .......... .......... .......... .......... 68%  176M 0s
  8150K .......... .......... .......... .......... .......... 69%  205M 0s
  8200K .......... .......... .......... .......... .......... 69%  207M 0s
  8250K .......... .......... .......... .......... .......... 69%  201M 0s
  8300K .......... .......... .......... .......... .......... 70%  176M 0s
  8350K .......... .......... .......... .......... .......... 70% 80.3M 0s
  8400K .......... .......... .......... .......... .......... 71% 86.7M 0s
  8450K .......... .......... .......... .......... .......... 71%  119M 0s
  8500K .......... .......... .......... .......... .......... 72% 87.3M 0s
  8550K .......... .......... .......... .......... .......... 72% 94.9M 0s
  8600K .......... .......... .......... .......... .......... 72%  145M 0s
  8650K .......... .......... .......... .......... .......... 73%  125M 0s
  8700K .......... .......... .......... .......... .......... 73% 97.7M 0s
  8750K .......... .......... .......... .......... .......... 74%  113M 0s
  8800K .......... .......... .......... .......... .......... 74%  105M 0s
  8850K .......... .......... .......... .......... .......... 74%  126M 0s
  8900K .......... .......... .......... .......... .......... 75%  108M 0s
  8950K .......... .......... .......... .......... .......... 75%  108M 0s
  9000K .......... .......... .......... .......... .......... 76%  120M 0s
  9050K .......... .......... .......... .......... .......... 76%  104M 0s
  9100K .......... .......... .......... .......... .......... 77%  115M 0s
  9150K .......... .......... .......... .......... .......... 77%  108M 0s
  9200K .......... .......... .......... .......... .......... 77%  129M 0s
  9250K .......... .......... .......... .......... .......... 78%  101M 0s
  9300K .......... .......... .......... .......... .......... 78%  110M 0s
  9350K .......... .......... .......... .......... .......... 79%  128M 0s
  9400K .......... .......... .......... .......... .......... 79%  105M 0s
  9450K .......... .......... .......... .......... .......... 80%  122M 0s
  9500K .......... .......... .......... .......... .......... 80%  107M 0s
  9550K .......... .......... .......... .......... .......... 80%  106M 0s
  9600K .......... .......... .......... .......... .......... 81%  127M 0s
  9650K .......... .......... .......... .......... .......... 81%  110M 0s
  9700K .......... .......... .......... .......... .......... 82% 98.0M 0s
  9750K .......... .......... .......... .......... .......... 82%  122M 0s
  9800K .......... .......... .......... .......... .......... 82%  112M 0s
  9850K .......... .......... .......... .......... .......... 83%  114M 0s
  9900K .......... .......... .......... .......... .......... 83%  123M 0s
  9950K .......... .......... .......... .......... .......... 84%  107M 0s
 10000K .......... .......... .......... .......... .......... 84%  114M 0s
 10050K .......... .......... .......... .......... .......... 85% 7.21M 0s
 10100K .......... .......... .......... .......... .......... 85%  114M 0s
 10150K .......... .......... .......... .......... .......... 85%  111M 0s
 10200K .......... .......... .......... .......... .......... 86%  114M 0s
 10250K .......... .......... .......... .......... .......... 86%  111M 0s
 10300K .......... .......... .......... .......... .......... 87%  102M 0s
 10350K .......... .......... .......... .......... .......... 87%  123M 0s
 10400K .......... .......... .......... .......... .......... 88%  110M 0s
 10450K .......... .......... .......... .......... .......... 88%  113M 0s
 10500K .......... .......... .......... .......... .......... 88%  104M 0s
 10550K .......... .......... .......... .......... .......... 89%  108M 0s
 10600K .......... .......... .......... .......... .......... 89%  112M 0s
 10650K .......... .......... .......... .......... .......... 90%  131M 0s
 10700K .......... .......... .......... .......... .......... 90%  101M 0s
 10750K .......... .......... .......... .......... .......... 90%  117M 0s
 10800K .......... .......... .......... .......... .......... 91%  106M 0s
 10850K .......... .......... .......... .......... .......... 91%  118M 0s
 10900K .......... .......... .......... .......... .......... 92%  127M 0s
 10950K .......... .......... .......... .......... .......... 92% 9.96M 0s
 11000K .......... .......... .......... .......... .......... 93%  111M 0s
 11050K .......... .......... .......... .......... .......... 93% 43.1M 0s
 11100K .......... .......... .......... .......... .......... 93%  141M 0s
 11150K .......... .......... .......... .......... .......... 94%  104M 0s
 11200K .......... .......... .......... .......... .......... 94%  108M 0s
 11250K .......... .......... .......... .......... .......... 95%  109M 0s
 11300K .......... .......... .......... .......... .......... 95%  114M 0s
 11350K .......... .......... .......... .......... .......... 96%  118M 0s
 11400K .......... .......... .......... .......... .......... 96%  112M 0s
 11450K .......... .......... .......... .......... .......... 96%  107M 0s
 11500K .......... .......... .......... .......... .......... 97%  118M 0s
 11550K .......... .......... .......... .......... .......... 97%  104M 0s
 11600K .......... .......... .......... .......... .......... 98%  106M 0s
 11650K .......... .......... .......... .......... .......... 98%  136M 0s
 11700K .......... .......... .......... .......... .......... 98%  103M 0s
 11750K .......... .......... .......... .......... .......... 99%  112M 0s
 11800K .......... .......... .......... .......... .......... 99%  112M 0s
 11850K .......... .......... .                               100%  148M=0.3s
2017-05-31 22:57:03 (41.0 MB/s) - ‘third-party-0.2.1-linux-x86_64.tar.gz’ saved [12156146/12156146]
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
 #if CLP_HAS_ABC
 #if CLP_HAS_ABC
 #if CLP_HAS_ABC
Errors in build-osi:
 #if CLP_HAS_ABC
 #if CLP_HAS_ABC
 #if CLP_HAS_ABC
Errors in build-osi-static:
 #if CLP_HAS_ABC
 #if CLP_HAS_ABC
 #if CLP_HAS_ABC
End of tests
More information about the Minotaur-dev mailing list
