[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan mahajan at mcs.anl.gov
Sat Mar 25 23:09:56 CDT 2017
Minotaur daily test report
Sat Mar 25 22:57:02 CDT 2017
petsc.mcs.anl.gov
Linux petsc 3.13.0-111-generic #158-Ubuntu SMP Wed Feb 22 16:12:03 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at  http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2-136-g3033e2b
ls: cannot access build-all/bin: No such file or directory
ls: cannot access build-all/lib: No such file or directory
ls: cannot access build-all/include/minotaur/*: No such file or directory
ls: cannot access build-all-debug/bin: No such file or directory
ls: cannot access build-all-debug/lib: No such file or directory
ls: cannot access build-all-debug/include/minotaur/*: No such file or directory
./daily-lnx-test.sh: line 270: cd: build-all-debug/src/testing: No such file or directory
./daily-lnx-test.sh: line 271: ../../../build-all-debug.out: Permission denied
./daily-lnx-test.sh: line 47: ./scripts/build_with_externals: No such file or directory
./daily-lnx-test.sh: line 50: cd: build-all-static: No such file or directory
ls: cannot access build-all-static/bin: No such file or directory
ls: cannot access build-all-static/lib: No such file or directory
ls: cannot access build-all-static/include/minotaur/*: No such file or directory
rsync: change_dir "/sandbox/mahajan/minotaur-test/build-all/doxygen/html" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1183) [sender=3.1.0]
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (39)
compiling build-base-static: OK.
make utest output for build-base-static: OK (39)
compiling build-filter: OK.
make utest output for build-filter: OK (39)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (39)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (39)
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: OK.
make utest output for build-osi: OK (39)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (39)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (39)
compiling build-ampl: OK.
make utest output for build-ampl: OK (58)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (58)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (58)
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libmntrampl.a not built.
Errors:
Errors in build-all-debug:
CMake Error at CMakeLists.txt:321 (message):
   Minotaur config: /sandbox/mahajan/minotaur-test/minotaur-externals/ipopt-3.12.3/build/include/coin/IpIpoptApplication.hpp not found.
make: *** No rule to make target `install'.  Stop.
make: *** No rule to make target `utest'.  Stop.
Errors in build-all:
Errors in build-all-manual:
Makefile:542: minotaur.d: No such file or directory
/sandbox/mahajan/minotaur-test/src/engines/Ipopt/IpoptEngine.cpp:18:27: fatal error: coin/IpTNLP.hpp: No such file or directory
 #include "coin/IpTNLP.hpp"
compilation terminated.
make: *** [/sandbox/mahajan/minotaur-test/src/engines/Ipopt/IpoptEngine.o] Error 1
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (58)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (39)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
More information about the Minotaur-dev mailing list
