[Minotaur-dev] minotaur daily test results
amahajan amahajan at iitb.ac.in
Sat Jun 17 12:13:12 CDT 2017
Minotaur daily test report
Sat Jun 17 22:37:02 IST 2017
origin.ieor.iitb.ac.in
Linux origin 4.9.0-2-amd64 #1 SMP Debian 4.9.13-1 (2017-02-27) x86_64 GNU/Linux
Detailed log available at  http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2-175-g4650ce2
ls: cannot access 'build-ampl/bin': No such file or directory
ls: cannot access 'build-ampl/lib': No such file or directory
ls: cannot access 'build-ampl/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-debug/bin': No such file or directory
ls: cannot access 'build-ampl-debug/lib': No such file or directory
ls: cannot access 'build-ampl-debug/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-static/bin': No such file or directory
ls: cannot access 'build-ampl-static/lib': No such file or directory
ls: cannot access 'build-ampl-static/include/minotaur/*': No such file or directory
ls: cannot access 'build-all/bin': No such file or directory
ls: cannot access 'build-all/lib': No such file or directory
ls: cannot access 'build-all/include/minotaur/*': No such file or directory
ls: cannot access 'build-all-debug/bin': No such file or directory
ls: cannot access 'build-all-debug/lib': No such file or directory
ls: cannot access 'build-all-debug/include/minotaur/*': No such file or directory
./daily-lnx-iit-test.sh: line 272: cd: build-all-debug/src/testing: No such file or directory
./daily-lnx-iit-test.sh: line 273: ../../../build-all-debug.out: Permission denied
./daily-lnx-iit-test.sh: line 47: ./scripts/build_with_externals: No such file or directory
./daily-lnx-iit-test.sh: line 50: cd: build-all-static: No such file or directory
ls: cannot access 'build-all-static/bin': No such file or directory
ls: cannot access 'build-all-static/lib': No such file or directory
ls: cannot access 'build-all-static/include/minotaur/*': No such file or directory
ssh: connect to host 10.119.2.10 port 22: No route to host
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(235) [sender=3.1.2]
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libmntrampl.a not built.
Errors:
Errors in build-all-debug:
CMake Error at CMakeLists.txt:203 (message):
   Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target 'install'.  Stop.
make: *** No rule to make target 'utest'.  Stop.
Errors in build-all:
Errors in build-all-manual:
Makefile:542: minotaur.d: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/ipopt-3.12.7/build/include: No such file or directory [-Wmissing-include-dirs]
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/clp-1.16.9/build/include: No such file or directory [-Wmissing-include-dirs]
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/asl-20161228: No such file or directory [-Wmissing-include-dirs]
/home/amahajan/tmp/minotaur-test/src/engines/OsiLP/OsiLPEngine.cpp:18:42: fatal error: coin/OsiClpSolverInterface.hpp: No such file or directory
 #include "coin/OsiClpSolverInterface.hpp"
compilation terminated.
make: *** [/home/amahajan/tmp/minotaur-test/src/engines/OsiLP/OsiLPEngine.o] Error 1
Errors in build-all-static:
Errors in build-ampl-debug:
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
Errors in build-base:
--2017-06-17 22:37:14--  http://www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz
Resolving www.mcs.anl.gov (www.mcs.anl.gov)... 140.221.6.95
Connecting to www.mcs.anl.gov (www.mcs.anl.gov)|140.221.6.95|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 32220716 (31M) [application/x-gzip]
Saving to: ‘minotaur-externals-0.2.tar.gz’
     0K .......... .......... .......... .......... ..........  0%  111K 4m44s
    50K .......... .......... .......... .......... ..........  0%  111K 4m43s
   100K .......... .......... .......... .......... ..........  0%  221K 3m56s
   150K .......... .......... .......... .......... ..........  0%  111K 4m7s
   200K .......... .......... .......... .......... ..........  0% 23.1M 3m18s
   250K .......... .......... .......... .......... ..........  0%  222K 3m8s
   300K .......... .......... .......... .......... ..........  1%  222K 3m1s
   350K .......... .......... .......... .......... ..........  1%  222K 2m55s
   400K .......... .......... .......... .......... ..........  1% 22.2M 2m36s
   450K .......... .......... .......... .......... ..........  1%  223K 2m34s
   500K .......... .......... .......... .......... ..........  1%  222K 2m32s
   550K .......... .......... .......... .......... ..........  1% 31.7M 2m20s
   600K .......... .......... .......... .......... ..........  2%  223K 2m19s
   650K .......... .......... .......... .......... ..........  2% 31.8M 2m9s
   700K .......... .......... .......... .......... ..........  2%  223K 2m10s
   750K .......... .......... .......... .......... ..........  2% 33.3M 2m1s
   800K .......... .......... .......... .......... ..........  2%  223K 2m2s
   850K .......... .......... .......... .......... ..........  2% 67.2M 1m55s
   900K .......... .......... .......... .......... ..........  3% 37.9M 1m49s
   950K .......... .......... .......... .......... ..........  3%  223K 1m50s
  1000K .......... .......... .......... .......... ..........  3% 2.53M 1m45s
  1050K .......... .......... .......... .......... ..........  3%  143M 1m40s
  1100K .......... .......... .......... .......... ..........  3%  179M 96s
  1150K .......... .......... .......... .......... ..........  3%  242K 97s
  1200K .......... .......... .......... .......... ..........  3% 2.60M 93s
  1250K .......... .......... .......... .......... ..........  4% 97.5M 90s
  1300K .......... .......... .......... .......... ..........  4%  243K 91s
  1350K .......... .......... .......... .......... ..........  4% 2.55M 88s
  1400K .......... .......... .......... .......... ..........  4%  150M 85s
  1450K .......... .......... .......... .......... ..........  4%  101M 82s
  1500K .......... .......... .......... .......... ..........  4%  243K 83s
  1550K .......... .......... .......... .......... ..........  5% 30.6M 80s
  1600K .......... .......... .......... .......... ..........  5% 2.73M 78s
  1650K .......... .......... .......... .......... ..........  5% 67.5M 76s
  1700K .......... .......... .......... .......... ..........  5%  243K 77s
  1750K .......... .......... .......... .......... ..........  5% 29.9M 75s
  1800K .......... .......... .......... .......... ..........  5% 2.71M 73s
  1850K .......... .......... .......... .......... ..........  6% 78.1M 71s
  1900K .......... .......... .......... .......... ..........  6% 96.0M 69s
  1950K .......... .......... .......... .......... ..........  6%  243K 70s
  2000K .......... .......... .......... .......... ..........  6% 42.7M 68s
  2050K .......... .......... .......... .......... ..........  6% 2.73M 67s
  2100K .......... .......... .......... .......... ..........  6% 62.6M 65s
  2150K .......... .......... .......... .......... ..........  6%  117M 63s
  2200K .......... .......... .......... .......... ..........  7%  243K 65s
  2250K .......... .......... .......... .......... ..........  7% 73.7M 63s
  2300K .......... .......... .......... .......... ..........  7% 2.71M 62s
  2350K .......... .......... .......... .......... ..........  7% 71.9M 60s
  2400K .......... .......... .......... .......... ..........  7%  108M 59s
  2450K .......... .......... .......... .......... ..........  7%  129M 58s
  2500K .......... .......... .......... .......... ..........  8%  243K 59s
  2550K .......... .......... .......... .......... ..........  8% 67.1M 58s
  2600K .......... .......... .......... .......... ..........  8% 2.74M 57s
  2650K .......... .......... .......... .......... ..........  8%  152M 56s
  2700K .......... .......... .......... .......... ..........  8% 69.9M 54s
  2750K .......... .......... .......... .......... ..........  8%  101M 53s
  2800K .......... .......... .......... .......... ..........  9% 93.3M 52s
  2850K .......... .......... .......... .......... ..........  9%  243K 53s
  2900K .......... .......... .......... .......... ..........  9% 71.9M 52s
  2950K .......... .......... .......... .......... ..........  9% 46.3M 51s
  3000K .......... .......... .......... .......... ..........  9% 2.85M 51s
  3050K .......... .......... .......... .......... ..........  9% 97.8M 50s
  3100K .......... .......... .......... .......... .......... 10%  101M 49s
  3150K .......... .......... .......... .......... .......... 10% 97.3M 48s
  3200K .......... .......... .......... .......... .......... 10% 1.78M 48s
  3250K .......... .......... .......... .......... .......... 10%  280K 48s
  3300K .......... .......... .......... .......... .......... 10%  103M 47s
  3350K .......... .......... .......... .......... .......... 10% 2.76M 47s
  3400K .......... .......... .......... .......... .......... 10% 95.5M 46s
  3450K .......... .......... .......... .......... .......... 11% 99.3M 45s
  3500K .......... .......... .......... .......... .......... 11%  128M 45s
  3550K .......... .......... .......... .......... .......... 11%  103M 44s
  3600K .......... .......... .......... .......... .......... 11% 1.76M 43s
  3650K .......... .......... .......... .......... .......... 11%  280K 44s
  3700K .......... .......... .......... .......... .......... 11%  130M 43s
  3750K .......... .......... .......... .......... .......... 12% 2.81M 43s
  3800K .......... .......... .......... .......... .......... 12% 91.1M 42s
  3850K .......... .......... .......... .......... .......... 12%  100M 42s
  3900K .......... .......... .......... .......... .......... 12%  109M 41s
  3950K .......... .......... .......... .......... .......... 12%  127M 40s
  4000K .......... .......... .......... .......... .......... 12% 44.6M 40s
  4050K .......... .......... .......... .......... .......... 13%  244K 41s
  4100K .......... .......... .......... .......... .......... 13% 67.5M 40s
  4150K .......... .......... .......... .......... .......... 13% 80.7M 40s
  4200K .......... .......... .......... .......... .......... 13% 2.88M 39s
  4250K .......... .......... .......... .......... .......... 13%  108M 39s
  4300K .......... .......... .......... .......... .......... 13% 90.8M 38s
  4350K .......... .......... .......... .......... .......... 13% 95.3M 38s
  4400K .......... .......... .......... .......... .......... 14% 67.3M 37s
  4450K .......... .......... .......... .......... .......... 14%  107M 37s
  4500K .......... .......... .......... .......... .......... 14%  244K 37s
  4550K .......... .......... .......... .......... .......... 14% 82.8M 37s
  4600K .......... .......... .......... .......... .......... 14% 95.4M 36s
  4650K .......... .......... .......... .......... .......... 14% 73.9M 36s
  4700K .......... .......... .......... .......... .......... 15% 2.93M 36s
  4750K .......... .......... .......... .......... .......... 15% 92.9M 35s
  4800K .......... .......... .......... .......... .......... 15% 95.6M 35s
  4850K .......... .......... .......... .......... .......... 15% 95.0M 34s
  4900K .......... .......... .......... .......... .......... 15% 96.7M 34s
  4950K .......... .......... .......... .......... .......... 15% 77.6M 34s
  5000K .......... .......... .......... .......... .......... 16%  244K 34s
  5050K .......... .......... .......... .......... .......... 16% 66.7M 34s
  5100K .......... .......... .......... .......... .......... 16% 95.6M 33s
  5150K .......... .......... .......... .......... .......... 16%  144M 33s
  5200K .......... .......... .......... .......... .......... 16% 2.94M 33s
  5250K .......... .......... .......... .......... .......... 16% 68.8M 32s
  5300K .......... .......... .......... .......... .......... 17% 98.9M 32s
  5350K .......... .......... .......... .......... .......... 17% 84.9M 32s
  5400K .......... .......... .......... .......... .......... 17%  100M 31s
  5450K .......... .......... .......... .......... .......... 17%  110M 31s
  5500K .......... .......... .......... .......... .......... 17% 70.7M 31s
  5550K .......... .......... .......... .......... .......... 17%  245K 31s
  5600K .......... .......... .......... .......... .......... 17% 51.3M 31s
  5650K .......... .......... .......... .......... .......... 18% 93.4M 31s
  5700K .......... .......... .......... .......... .......... 18% 92.0M 30s
  5750K .......... .......... .......... .......... .......... 18% 3.02M 30s
  5800K .......... .......... .......... .......... .......... 18% 72.3M 30s
  5850K .......... .......... .......... .......... .......... 18%  104M 29s
  5900K .......... .......... .......... .......... .......... 18% 94.1M 29s
  5950K .......... .......... .......... .......... .......... 19% 56.0M 29s
  6000K .......... .......... .......... .......... .......... 19%  146M 29s
  6050K .......... .......... .......... .......... .......... 19% 97.0M 28s
  6100K .......... .......... .......... .......... .......... 19% 1.84M 28s
  6150K .......... .......... .......... .......... .......... 19%  280K 29s
  6200K .......... .......... .......... .......... .......... 19% 59.5M 28s
  6250K .......... .......... .......... .......... .......... 20% 98.5M 28s
  6300K .......... .......... .......... .......... .......... 20%  132M 28s
  6350K .......... .......... .......... .......... .......... 20% 3.05M 28s
  6400K .......... .......... .......... .......... .......... 20% 64.1M 27s
  6450K .......... .......... .......... .......... .......... 20%  101M 27s
  6500K .......... .......... .......... .......... .......... 20%  100M 27s
  6550K .......... .......... .......... .......... .......... 20% 89.1M 26s
  6600K .......... .......... .......... .......... .......... 21% 90.7M 26s
  6650K .......... .......... .......... .......... .......... 21%  106M 26s
  6700K .......... .......... .......... .......... .......... 21% 67.5M 26s
  6750K .......... .......... .......... .......... .......... 21%  245K 26s
  6800K .......... .......... .......... .......... .......... 21% 72.5M 26s
  6850K .......... .......... .......... .......... .......... 21% 79.1M 26s
  6900K .......... .......... .......... .......... .......... 22% 95.1M 26s
  6950K .......... .......... .......... .......... .......... 22%  105M 25s
  7000K .......... .......... .......... .......... .......... 22% 3.01M 25s
  7050K .......... .......... .......... .......... .......... 22%  101M 25s
  7100K .......... .......... .......... .......... .......... 22%  112M 25s
  7150K .......... .......... .......... .......... .......... 22%  124M 24s
  7200K .......... .......... .......... .......... .......... 23% 99.5M 24s
  7250K .......... .......... .......... .......... .......... 23%  152M 24s
  7300K .......... .......... .......... .......... .......... 23%  107M 24s
  7350K .......... .......... .......... .......... .......... 23%  104M 24s
  7400K .......... .......... .......... .......... .......... 23% 1.87M 23s
  7450K .......... .......... .......... .......... .......... 23%  280K 24s
  7500K .......... .......... .......... .......... .......... 23% 66.5M 24s
  7550K .......... .......... .......... .......... .......... 24% 83.1M 23s
  7600K .......... .......... .......... .......... .......... 24% 76.0M 23s
  7650K .......... .......... .......... .......... .......... 24% 20.6M 23s
  7700K .......... .......... .......... .......... .......... 24% 3.48M 23s
  7750K .......... .......... .......... .......... .......... 24% 80.4M 23s
  7800K .......... .......... .......... .......... .......... 24%  124M 22s
  7850K .......... .......... .......... .......... .......... 25%  127M 22s
  7900K .......... .......... .......... .......... .......... 25%  107M 22s
  7950K .......... .......... .......... .......... .......... 25%  122M 22s
  8000K .......... .......... .......... .......... .......... 25%  107M 22s
  8050K .......... .......... .......... .......... .......... 25%  110M 22s
  8100K .......... .......... .......... .......... .......... 25% 36.9M 21s
  8150K .......... .......... .......... .......... .......... 26%  246K 22s
  8200K .......... .......... .......... .......... .......... 26% 68.2M 22s
  8250K .......... .......... .......... .......... .......... 26%  112M 21s
  8300K .......... .......... .......... .......... .......... 26% 99.0M 21s
  8350K .......... .......... .......... .......... .......... 26%  123M 21s
  8400K .......... .......... .......... .......... .......... 26% 29.7M 21s
  8450K .......... .......... .......... .......... .......... 27% 26.3M 21s
  8500K .......... .......... .......... .......... .......... 27% 3.76M 21s
  8550K .......... .......... .......... .......... .......... 27% 72.2M 20s
  8600K .......... .......... .......... .......... .......... 27%  128M 20s
  8650K .......... .......... .......... .......... .......... 27%  102M 20s
  8700K .......... .......... .......... .......... .......... 27%  105M 20s
  8750K .......... .......... .......... .......... .......... 27%  137M 20s
  8800K .......... .......... .......... .......... .......... 28%  109M 20s
  8850K .......... .......... .......... .......... .......... 28%  110M 20s
  8900K .......... .......... .......... .......... .......... 28%  128M 19s
  8950K .......... .......... .......... .......... .......... 28%  107M 19s
  9000K .......... .......... .......... .......... .......... 28% 1.94M 19s
  9050K .......... .......... .......... .......... .......... 28%  281K 19s
  9100K .......... .......... .......... .......... .......... 29% 71.4M 19s
  9150K .......... .......... .......... .......... .......... 29% 84.6M 19s
  9200K .......... .......... .......... .......... .......... 29%  116M 19s
  9250K .......... .......... .......... .......... .......... 29%  127M 19s
  9300K .......... .......... .......... .......... .......... 29% 84.1M 19s
  9350K .......... .......... .......... .......... .......... 29% 25.2M 19s
  9400K .......... .......... .......... .......... .......... 30% 3.56M 18s
  9450K .......... .......... .......... .......... .......... 30%  123M 18s
  9500K .......... .......... .......... .......... .......... 30%  109M 18s
  9550K .......... .......... .......... .......... .......... 30% 95.1M 18s
  9600K .......... .......... .......... .......... .......... 30%  123M 18s
  9650K .......... .......... .......... .......... .......... 30% 77.1M 18s
  9700K .......... .......... .......... .......... .......... 30% 91.3M 18s
  9750K .......... .......... .......... .......... .......... 31% 99.9M 18s
  9800K .......... .......... .......... .......... .......... 31%  153M 17s
  9850K .......... .......... .......... .......... .......... 31% 90.4M 17s
  9900K .......... .......... .......... .......... .......... 31% 77.7M 17s
  9950K .......... .......... .......... .......... .......... 31%  108M 17s
 10000K .......... .......... .......... .......... .......... 31% 1.97M 17s
 10050K .......... .......... .......... .......... .......... 32%  281K 17s
 10100K .......... .......... .......... .......... .......... 32% 71.5M 17s
 10150K .......... .......... .......... .......... .......... 32% 94.2M 17s
 10200K .......... .......... .......... .......... .......... 32%  148M 17s
 10250K .......... .......... .......... .......... .......... 32%  101M 17s
 10300K .......... .......... .......... .......... .......... 32% 72.8M 17s
 10350K .......... .......... .......... .......... .......... 33% 24.6M 16s
 10400K .......... .......... .......... .......... .......... 33% 3.68M 16s
 10450K .......... .......... .......... .......... .......... 33%  101M 16s
 10500K .......... .......... .......... .......... .......... 33%  128M 16s
 10550K .......... .......... .......... .......... .......... 33%  125M 16s
 10600K .......... .......... .......... .......... .......... 33%  115M 16s
 10650K .......... .......... .......... .......... .......... 34% 97.6M 16s
 10700K .......... .......... .......... .......... .......... 34%  102M 16s
 10750K .......... .......... .......... .......... .......... 34% 64.3M 16s
 10800K .......... .......... .......... .......... .......... 34% 73.1M 16s
 10850K .......... .......... .......... .......... .......... 34%  106M 15s
 10900K .......... .......... .......... .......... .......... 34%  123M 15s
 10950K .......... .......... .......... .......... .......... 34%  125M 15s
 11000K .......... .......... .......... .......... .......... 35%  104M 15s
 11050K .......... .......... .......... .......... .......... 35% 98.5M 15s
 11100K .......... .......... .......... .......... .......... 35% 2.00M 15s
 11150K .......... .......... .......... .......... .......... 35%  282K 15s
 11200K .......... .......... .......... .......... .......... 35% 80.5M 15s
 11250K .......... .......... .......... .......... .......... 35%  108M 15s
 11300K .......... .......... .......... .......... .......... 36% 89.0M 15s
 11350K .......... .......... .......... .......... .......... 36%  128M 15s
 11400K .......... .......... .......... .......... .......... 36% 83.1M 15s
 11450K .......... .......... .......... .......... .......... 36% 66.1M 15s
 11500K .......... .......... .......... .......... .......... 36% 22.6M 14s
 11550K .......... .......... .......... .......... .......... 36% 3.95M 14s
 11600K .......... .......... .......... .......... .......... 37%  111M 14s
 11650K .......... .......... .......... .......... .......... 37%  125M 14s
 11700K .......... .......... .......... .......... .......... 37%  114M 14s
 11750K .......... .......... .......... .......... .......... 37%  112M 14s
 11800K .......... .......... .......... .......... .......... 37%  109M 14s
 11850K .......... .......... .......... .......... .......... 37%  120M 14s
 11900K .......... .......... .......... .......... .......... 37% 66.0M 14s
 11950K .......... .......... .......... .......... .......... 38% 91.1M 14s
 12000K .......... .......... .......... .......... .......... 38%  120M 14s
 12050K .......... .......... .......... .......... .......... 38%  111M 13s
 12100K .......... .......... .......... .......... .......... 38%  102M 13s
 12150K .......... .......... .......... .......... .......... 38%  116M 13s
 12200K .......... .......... .......... .......... .......... 38%  122M 13s
 12250K .......... .......... .......... .......... .......... 39% 33.5M 13s
 12300K .......... .......... .......... .......... .......... 39% 2.00M 13s
 12350K .......... .......... .......... .......... .......... 39%  283K 13s
 12400K .......... .......... .......... .......... .......... 39% 97.2M 13s
 12450K .......... .......... .......... .......... .......... 39%  123M 13s
 12500K .......... .......... .......... .......... .......... 39% 56.8M 13s
 12550K .......... .......... .......... .......... .......... 40%  114M 13s
 12600K .......... .......... .......... .......... .......... 40%  105M 13s
 12650K .......... .......... .......... .......... .......... 40% 50.9M 13s
 12700K .......... .......... .......... .......... .......... 40% 39.1M 13s
 12750K .......... .......... .......... .......... .......... 40% 56.3M 13s
 12800K .......... .......... .......... .......... .......... 40% 4.14M 12s
 12850K .......... .......... .......... .......... .......... 40%  126M 12s
 12900K .......... .......... .......... .......... .......... 41%  119M 12s
 12950K .......... .......... .......... .......... .......... 41%  110M 12s
 13000K .......... .......... .......... .......... .......... 41%  108M 12s
 13050K .......... .......... .......... .......... .......... 41%  124M 12s
 13100K .......... .......... .......... .......... .......... 41%  106M 12s
 13150K .......... .......... .......... .......... .......... 41%  109M 12s
 13200K .......... .......... .......... .......... .......... 42%  109M 12s
 13250K .......... .......... .......... .......... .......... 42%  122M 12s
 13300K .......... .......... .......... .......... .......... 42%  106M 12s
 13350K .......... .......... .......... .......... .......... 42%  109M 12s
 13400K .......... .......... .......... .......... .......... 42%  122M 12s
 13450K .......... .......... .......... .......... .......... 42%  108M 11s
 13500K .......... .......... .......... .......... .......... 43%  110M 11s
 13550K .......... .......... .......... .......... .......... 43%  123M 11s
 13600K .......... .......... .......... .......... .......... 43%  105M 11s
 13650K .......... .......... .......... .......... .......... 43% 66.4M 11s
 13700K .......... .......... .......... .......... .......... 43% 2.07M 11s
 13750K .......... .......... .......... .......... .......... 43%  283K 11s
 13800K .......... .......... .......... .......... .......... 44% 79.3M 11s
 13850K .......... .......... .......... .......... .......... 44%  129M 11s
 13900K .......... .......... .......... .......... .......... 44% 60.7M 11s
 13950K .......... .......... .......... .......... .......... 44% 94.8M 11s
 14000K .......... .......... .......... .......... .......... 44%  132M 11s
 14050K .......... .......... .......... .......... .......... 44%  115M 11s
 14100K .......... .......... .......... .......... .......... 44%  117M 11s
 14150K .......... .......... .......... .......... .......... 45% 53.6M 11s
 14200K .......... .......... .......... .......... .......... 45% 37.3M 11s
 14250K .......... .......... .......... .......... .......... 45% 60.9M 11s
 14300K .......... .......... .......... .......... .......... 45% 4.35M 11s
 14350K .......... .......... .......... .......... .......... 45% 98.8M 10s
 14400K .......... .......... .......... .......... .......... 45%  151M 10s
 14450K .......... .......... .......... .......... .......... 46% 91.2M 10s
 14500K .......... .......... .......... .......... .......... 46%  131M 10s
 14550K .......... .......... .......... .......... .......... 46%  106M 10s
 14600K .......... .......... .......... .......... .......... 46%  144M 10s
 14650K .......... .......... .......... .......... .......... 46%  106M 10s
 14700K .......... .......... .......... .......... .......... 46%  107M 10s
 14750K .......... .......... .......... .......... .......... 47%  127M 10s
 14800K .......... .......... .......... .......... .......... 47%  109M 10s
 14850K .......... .......... .......... .......... .......... 47%  105M 10s
 14900K .......... .......... .......... .......... .......... 47% 60.9M 10s
 14950K .......... .......... .......... .......... .......... 47%  106M 10s
 15000K .......... .......... .......... .......... .......... 47%  108M 10s
 15050K .......... .......... .......... .......... .......... 47%  130M 10s
 15100K .......... .......... .......... .......... .......... 48%  106M 10s
 15150K .......... .......... .......... .......... .......... 48%  106M 9s
 15200K .......... .......... .......... .......... .......... 48%  108M 9s
 15250K .......... .......... .......... .......... .......... 48%  129M 9s
 15300K .......... .......... .......... .......... .......... 48%  116M 9s
 15350K .......... .......... .......... .......... .......... 48%  108M 9s
 15400K .......... .......... .......... .......... .......... 49% 2.24M 9s
 15450K .......... .......... .......... .......... .......... 49% 41.5M 9s
 15500K .......... .......... .......... .......... .......... 49%  284K 9s
 15550K .......... .......... .......... .......... .......... 49% 91.0M 9s
 15600K .......... .......... .......... .......... .......... 49% 68.1M 9s
 15650K .......... .......... .......... .......... .......... 49% 82.1M 9s
 15700K .......... .......... .......... .......... .......... 50%  131M 9s
 15750K .......... .......... .......... .......... .......... 50%  108M 9s
 15800K .......... .......... .......... .......... .......... 50%  126M 9s
 15850K .......... .......... .......... .......... .......... 50%  107M 9s
 15900K .......... .......... .......... .......... .......... 50% 72.2M 9s
 15950K .......... .......... .......... .......... .......... 50% 45.4M 9s
 16000K .......... .......... .......... .......... .......... 51% 82.5M 9s
 16050K .......... .......... .......... .......... .......... 51% 4.27M 9s
 16100K .......... .......... .......... .......... .......... 51% 80.3M 9s
 16150K .......... .......... .......... .......... .......... 51%  105M 9s
 16200K .......... .......... .......... .......... .......... 51%  105M 8s
 16250K .......... .......... .......... .......... .......... 51%  102M 8s
 16300K .......... .......... .......... .......... .......... 51%  111M 8s
 16350K .......... .......... .......... .......... .......... 52%  131M 8s
 16400K .......... .......... .......... .......... .......... 52%  122M 8s
 16450K .......... .......... .......... .......... .......... 52%  104M 8s
 16500K .......... .......... .......... .......... .......... 52%  111M 8s
 16550K .......... .......... .......... .......... .......... 52%  109M 8s
 16600K .......... .......... .......... .......... .......... 52%  129M 8s
 16650K .......... .......... .......... .......... .......... 53%  107M 8s
 16700K .......... .......... .......... .......... .......... 53%  106M 8s
 16750K .......... .......... .......... .......... .......... 53% 97.2M 8s
 16800K .......... .......... .......... .......... .......... 53%  106M 8s
 16850K .......... .......... .......... .......... .......... 53%  130M 8s
 16900K .......... .......... .......... .......... .......... 53%  104M 8s
 16950K .......... .......... .......... .......... .......... 54% 19.8M 8s
 17000K .......... .......... .......... .......... .......... 54%  108M 8s
 17050K .......... .......... .......... .......... .......... 54%  129M 8s
 17100K .......... .......... .......... .......... .......... 54%  106M 8s
 17150K .......... .......... .......... .......... .......... 54%  104M 8s
 17200K .......... .......... .......... .......... .......... 54%  110M 7s
 17250K .......... .......... .......... .......... .......... 54% 2.47M 7s
 17300K .......... .......... .......... .......... .......... 55% 46.8M 7s
 17350K .......... .......... .......... .......... .......... 55%  285K 7s
 17400K .......... .......... .......... .......... .......... 55%  141M 7s
 17450K .......... .......... .......... .......... .......... 55% 72.8M 7s
 17500K .......... .......... .......... .......... .......... 55% 79.9M 7s
 17550K .......... .......... .......... .......... .......... 55% 96.8M 7s
 17600K .......... .......... .......... .......... .......... 56%  121M 7s
 17650K .......... .......... .......... .......... .......... 56%  101M 7s
 17700K .......... .......... .......... .......... .......... 56%  140M 7s
 17750K .......... .......... .......... .......... .......... 56% 94.4M 7s
 17800K .......... .......... .......... .......... .......... 56% 95.0M 7s
 17850K .......... .......... .......... .......... .......... 56% 43.3M 7s
 17900K .......... .......... .......... .......... .......... 57% 85.7M 7s
 17950K .......... .......... .......... .......... .......... 57% 4.38M 7s
 18000K .......... .......... .......... .......... .......... 57% 82.5M 7s
 18050K .......... .......... .......... .......... .......... 57%  104M 7s
 18100K .......... .......... .......... .......... .......... 57% 96.9M 7s
 18150K .......... .......... .......... .......... .......... 57%  136M 7s
 18200K .......... .......... .......... .......... .......... 57%  109M 7s
 18250K .......... .......... .......... .......... .......... 58%  137M 7s
 18300K .......... .......... .......... .......... .......... 58%  101M 7s
 18350K .......... .......... .......... .......... .......... 58%  132M 7s
 18400K .......... .......... .......... .......... .......... 58%  108M 7s
 18450K .......... .......... .......... .......... .......... 58%  108M 7s
 18500K .......... .......... .......... .......... .......... 58%  107M 6s
 18550K .......... .......... .......... .......... .......... 59%  129M 6s
 18600K .......... .......... .......... .......... .......... 59%  106M 6s
 18650K .......... .......... .......... .......... .......... 59%  107M 6s
 18700K .......... .......... .......... .......... .......... 59%  108M 6s
 18750K .......... .......... .......... .......... .......... 59% 20.9M 6s
 18800K .......... .......... .......... .......... .......... 59%  105M 6s
 18850K .......... .......... .......... .......... .......... 60%  126M 6s
 18900K .......... .......... .......... .......... .......... 60%  109M 6s
 18950K .......... .......... .......... .......... .......... 60%  106M 6s
 19000K .......... .......... .......... .......... .......... 60% 13.8M 6s
 19050K .......... .......... .......... .......... .......... 60%  106M 6s
 19100K .......... .......... .......... .......... .......... 60%  106M 6s
 19150K .......... .......... .......... .......... .......... 61%  107M 6s
 19200K .......... .......... .......... .......... .......... 61% 3.01M 6s
 19250K .......... .......... .......... .......... .......... 61% 36.9M 6s
 19300K .......... .......... .......... .......... .......... 61%  285K 6s
 19350K .......... .......... .......... .......... .......... 61% 85.4M 6s
 19400K .......... .......... .......... .......... .......... 61% 97.9M 6s
 19450K .......... .......... .......... .......... .......... 61%  126M 6s
 19500K .......... .......... .......... .......... .......... 62%  104M 6s
 19550K .......... .......... .......... .......... .......... 62% 88.3M 6s
 19600K .......... .......... .......... .......... .......... 62%  101M 6s
 19650K .......... .......... .......... .......... .......... 62%  124M 6s
 19700K .......... .......... .......... .......... .......... 62%  108M 6s
 19750K .......... .......... .......... .......... .......... 62%  105M 6s
 19800K .......... .......... .......... .......... .......... 63%  109M 6s
 19850K .......... .......... .......... .......... .......... 63% 53.8M 6s
 19900K .......... .......... .......... .......... .......... 63%  110M 5s
 19950K .......... .......... .......... .......... .......... 63% 4.41M 5s
 20000K .......... .......... .......... .......... .......... 63% 49.0M 5s
 20050K .......... .......... .......... .......... .......... 63%  127M 5s
 20100K .......... .......... .......... .......... .......... 64%  141M 5s
 20150K .......... .......... .......... .......... .......... 64%  103M 5s
 20200K .......... .......... .......... .......... .......... 64%  100M 5s
 20250K .......... .......... .......... .......... .......... 64%  112M 5s
 20300K .......... .......... .......... .......... .......... 64%  146M 5s
 20350K .......... .......... .......... .......... .......... 64%  105M 5s
 20400K .......... .......... .......... .......... .......... 64%  108M 5s
 20450K .......... .......... .......... .......... .......... 65% 97.4M 5s
 20500K .......... .......... .......... .......... .......... 65%  138M 5s
 20550K .......... .......... .......... .......... .......... 65%  110M 5s
 20600K .......... .......... .......... .......... .......... 65%  107M 5s
 20650K .......... .......... .......... .......... .......... 65%  126M 5s
 20700K .......... .......... .......... .......... .......... 65%  108M 5s
 20750K .......... .......... .......... .......... .......... 66% 50.8M 5s
 20800K .......... .......... .......... .......... .......... 66% 30.6M 5s
 20850K .......... .......... .......... .......... .......... 66% 86.7M 5s
 20900K .......... .......... .......... .......... .......... 66%  108M 5s
 20950K .......... .......... .......... .......... .......... 66% 97.4M 5s
 21000K .......... .......... .......... .......... .......... 66%  144M 5s
 21050K .......... .......... .......... .......... .......... 67% 16.7M 5s
 21100K .......... .......... .......... .......... .......... 67% 74.4M 5s
 21150K .......... .......... .......... .......... .......... 67%  108M 5s
 21200K .......... .......... .......... .......... .......... 67%  109M 5s
 21250K .......... .......... .......... .......... .......... 67% 88.3M 5s
 21300K .......... .......... .......... .......... .......... 67% 3.05M 5s
 21350K .......... .......... .......... .......... .......... 68% 32.2M 4s
 21400K .......... .......... .......... .......... .......... 68%  286K 5s
 21450K .......... .......... .......... .......... .......... 68% 82.8M 5s
 21500K .......... .......... .......... .......... .......... 68% 88.8M 4s
 21550K .......... .......... .......... .......... .......... 68%  131M 4s
 21600K .......... .......... .......... .......... .......... 68% 97.5M 4s
 21650K .......... .......... .......... .......... .......... 68% 82.4M 4s
 21700K .......... .......... .......... .......... .......... 69%  114M 4s
 21750K .......... .......... .......... .......... .......... 69%  145M 4s
 21800K .......... .......... .......... .......... .......... 69% 97.6M 4s
 21850K .......... .......... .......... .......... .......... 69%  120M 4s
 21900K .......... .......... .......... .......... .......... 69%  108M 4s
 21950K .......... .......... .......... .......... .......... 69% 97.6M 4s
 22000K .......... .......... .......... .......... .......... 70% 97.7M 4s
 22050K .......... .......... .......... .......... .......... 70% 51.6M 4s
 22100K .......... .......... .......... .......... .......... 70% 4.50M 4s
 22150K .......... .......... .......... .......... .......... 70%  120M 4s
 22200K .......... .......... .......... .......... .......... 70%  100M 4s
 22250K .......... .......... .......... .......... .......... 70% 36.5M 4s
 22300K .......... .......... .......... .......... .......... 71%  123M 4s
 22350K .......... .......... .......... .......... .......... 71%  112M 4s
 22400K .......... .......... .......... .......... .......... 71%  121M 4s
 22450K .......... .......... .......... .......... .......... 71%  110M 4s
 22500K .......... .......... .......... .......... .......... 71% 65.2M 4s
 22550K .......... .......... .......... .......... .......... 71%  128M 4s
 22600K .......... .......... .......... .......... .......... 71%  112M 4s
 22650K .......... .......... .......... .......... .......... 72%  106M 4s
 22700K .......... .......... .......... .......... .......... 72%  128M 4s
 22750K .......... .......... .......... .......... .......... 72%  110M 4s
 22800K .......... .......... .......... .......... .......... 72%  107M 4s
 22850K .......... .......... .......... .......... .......... 72%  123M 4s
 22900K .......... .......... .......... .......... .......... 72%  108M 4s
 22950K .......... .......... .......... .......... .......... 73%  110M 4s
 23000K .......... .......... .......... .......... .......... 73%  118M 4s
 23050K .......... .......... .......... .......... .......... 73% 73.2M 4s
 23100K .......... .......... .......... .......... .......... 73%  111M 4s
 23150K .......... .......... .......... .......... .......... 73%  118M 3s
 23200K .......... .......... .......... .......... .......... 73%  110M 3s
 23250K .......... .......... .......... .......... .......... 74%  110M 3s
 23300K .......... .......... .......... .......... .......... 74% 17.2M 3s
 23350K .......... .......... .......... .......... .......... 74% 79.6M 3s
 23400K .......... .......... .......... .......... .......... 74%  128M 3s
 23450K .......... .......... .......... .......... .......... 74%  107M 3s
 23500K .......... .......... .......... .......... .......... 74% 3.07M 3s
 23550K .......... .......... .......... .......... .......... 75% 57.4M 3s
 23600K .......... .......... .......... .......... .......... 75% 38.1M 3s
 23650K .......... .......... .......... .......... .......... 75%  286K 3s
 23700K .......... .......... .......... .......... .......... 75%  126M 3s
 23750K .......... .......... .......... .......... .......... 75% 81.8M 3s
 23800K .......... .......... .......... .......... .......... 75%  104M 3s
 23850K .......... .......... .......... .......... .......... 75%  130M 3s
 23900K .......... .......... .......... .......... .......... 76%  118M 3s
 23950K .......... .......... .......... .......... .......... 76% 97.2M 3s
 24000K .......... .......... .......... .......... .......... 76%  126M 3s
 24050K .......... .......... .......... .......... .......... 76%  110M 3s
 24100K .......... .......... .......... .......... .......... 76%  127M 3s
 24150K .......... .......... .......... .......... .......... 76%  106M 3s
 24200K .......... .......... .......... .......... .......... 77%  105M 3s
 24250K .......... .......... .......... .......... .......... 77%  111M 3s
 24300K .......... .......... .......... .......... .......... 77%  127M 3s
 24350K .......... .......... .......... .......... .......... 77% 30.6M 3s
 24400K .......... .......... .......... .......... .......... 77% 4.88M 3s
 24450K .......... .......... .......... .......... .......... 77%  104M 3s
 24500K .......... .......... .......... .......... .......... 78% 98.6M 3s
 24550K .......... .......... .......... .......... .......... 78% 48.6M 3s
 24600K .......... .......... .......... .......... .......... 78% 95.3M 3s
 24650K .......... .......... .......... .......... .......... 78%  108M 3s
 24700K .......... .......... .......... .......... .......... 78%  144M 3s
 24750K .......... .......... .......... .......... .......... 78%  108M 3s
 24800K .......... .......... .......... .......... .......... 78%  106M 3s
 24850K .......... .......... .......... .......... .......... 79% 96.6M 3s
 24900K .......... .......... .......... .......... .......... 79%  144M 3s
 24950K .......... .......... .......... .......... .......... 79%  108M 3s
 25000K .......... .......... .......... .......... .......... 79%  107M 3s
 25050K .......... .......... .......... .......... .......... 79%  127M 3s
 25100K .......... .......... .......... .......... .......... 79%  107M 3s
 25150K .......... .......... .......... .......... .......... 80%  105M 2s
 25200K .......... .......... .......... .......... .......... 80%  109M 2s
 25250K .......... .......... .......... .......... .......... 80%  129M 2s
 25300K .......... .......... .......... .......... .......... 80%  104M 2s
 25350K .......... .......... .......... .......... .......... 80%  108M 2s
 25400K .......... .......... .......... .......... .......... 80%  107M 2s
 25450K .......... .......... .......... .......... .......... 81%  126M 2s
 25500K .......... .......... .......... .......... .......... 81%  108M 2s
 25550K .......... .......... .......... .......... .......... 81%  105M 2s
 25600K .......... .......... .......... .......... .......... 81%  109M 2s
 25650K .......... .......... .......... .......... .......... 81%  149M 2s
 25700K .......... .......... .......... .......... .......... 81% 94.7M 2s
 25750K .......... .......... .......... .......... .......... 81%  107M 2s
 25800K .......... .......... .......... .......... .......... 82%  109M 2s
 25850K .......... .......... .......... .......... .......... 82% 50.3M 2s
 25900K .......... .......... .......... .......... .......... 82% 60.9M 2s
 25950K .......... .......... .......... .......... .......... 82%  105M 2s
 26000K .......... .......... .......... .......... .......... 82% 92.6M 2s
 26050K .......... .......... .......... .......... .......... 82%  153M 2s
 26100K .......... .......... .......... .......... .......... 83%  122M 2s
 26150K .......... .......... .......... .......... .......... 83% 3.15M 2s
 26200K .......... .......... .......... .......... .......... 83% 36.2M 2s
 26250K .......... .......... .......... .......... .......... 83%  286K 2s
 26300K .......... .......... .......... .......... .......... 83%  112M 2s
 26350K .......... .......... .......... .......... .......... 83% 68.9M 2s
 26400K .......... .......... .......... .......... .......... 84%  117M 2s
 26450K .......... .......... .......... .......... .......... 84%  115M 2s
 26500K .......... .......... .......... .......... .......... 84%  105M 2s
 26550K .......... .......... .......... .......... .......... 84%  119M 2s
 26600K .......... .......... .......... .......... .......... 84% 96.0M 2s
 26650K .......... .......... .......... .......... .......... 84% 84.5M 2s
 26700K .......... .......... .......... .......... .......... 85%  140M 2s
 26750K .......... .......... .......... .......... .......... 85% 99.0M 2s
 26800K .......... .......... .......... .......... .......... 85%  102M 2s
 26850K .......... .......... .......... .......... .......... 85%  141M 2s
 26900K .......... .......... .......... .......... .......... 85% 95.2M 2s
 26950K .......... .......... .......... .......... .......... 85%  130M 2s
 27000K .......... .......... .......... .......... .......... 85% 53.1M 2s
 27050K .......... .......... .......... .......... .......... 86% 67.1M 2s
 27100K .......... .......... .......... .......... .......... 86% 4.93M 2s
 27150K .......... .......... .......... .......... .......... 86%  123M 2s
 27200K .......... .......... .......... .......... .......... 86% 60.6M 2s
 27250K .......... .......... .......... .......... .......... 86% 90.7M 2s
 27300K .......... .......... .......... .......... .......... 86% 96.9M 2s
 27350K .......... .......... .......... .......... .......... 87%  104M 2s
 27400K .......... .......... .......... .......... .......... 87% 55.8M 1s
 27450K .......... .......... .......... .......... .......... 87%  108M 1s
 27500K .......... .......... .......... .......... .......... 87%  128M 1s
 27550K .......... .......... .......... .......... .......... 87%  105M 1s
 27600K .......... .......... .......... .......... .......... 87%  106M 1s
 27650K .......... .......... .......... .......... .......... 88%  109M 1s
 27700K .......... .......... .......... .......... .......... 88% 81.6M 1s
 27750K .......... .......... .......... .......... .......... 88%  106M 1s
 27800K .......... .......... .......... .......... .......... 88%  107M 1s
 27850K .......... .......... .......... .......... .......... 88%  143M 1s
 27900K .......... .......... .......... .......... .......... 88%  106M 1s
 27950K .......... .......... .......... .......... .......... 88%  109M 1s
 28000K .......... .......... .......... .......... .......... 89%  129M 1s
 28050K .......... .......... .......... .......... .......... 89%  104M 1s
 28100K .......... .......... .......... .......... .......... 89%  108M 1s
 28150K .......... .......... .......... .......... .......... 89%  106M 1s
 28200K .......... .......... .......... .......... .......... 89%  129M 1s
 28250K .......... .......... .......... .......... .......... 89%  107M 1s
 28300K .......... .......... .......... .......... .......... 90%  107M 1s
 28350K .......... .......... .......... .......... .......... 90%  107M 1s
 28400K .......... .......... .......... .......... .......... 90%  127M 1s
 28450K .......... .......... .......... .......... .......... 90%  108M 1s
 28500K .......... .......... .......... .......... .......... 90%  105M 1s
 28550K .......... .......... .......... .......... .......... 90%  109M 1s
 28600K .......... .......... .......... .......... .......... 91%  140M 1s
 28650K .......... .......... .......... .......... .......... 91%  107M 1s
 28700K .......... .......... .......... .......... .......... 91% 98.1M 1s
 28750K .......... .......... .......... .......... .......... 91%  107M 1s
 28800K .......... .......... .......... .......... .......... 91%  145M 1s
 28850K .......... .......... .......... .......... .......... 91%  107M 1s
 28900K .......... .......... .......... .......... .......... 92% 3.28M 1s
 28950K .......... .......... .......... .......... .......... 92% 56.8M 1s
 29000K .......... .......... .......... .......... .......... 92% 68.7M 1s
 29050K .......... .......... .......... .......... .......... 92%  286K 1s
 29100K .......... .......... .......... .......... .......... 92% 76.2M 1s
 29150K .......... .......... .......... .......... .......... 92% 22.9M 1s
 29200K .......... .......... .......... .......... .......... 92%  119M 1s
 29250K .......... .......... .......... .......... .......... 93%  102M 1s
 29300K .......... .......... .......... .......... .......... 93%  142M 1s
 29350K .......... .......... .......... .......... .......... 93%  110M 1s
 29400K .......... .......... .......... .......... .......... 93%  108M 1s
 29450K .......... .......... .......... .......... .......... 93%  108M 1s
 29500K .......... .......... .......... .......... .......... 93%  142M 1s
 29550K .......... .......... .......... .......... .......... 94%  106M 1s
 29600K .......... .......... .......... .......... .......... 94%  110M 1s
 29650K .......... .......... .......... .......... .......... 94%  126M 1s
 29700K .......... .......... .......... .......... .......... 94%  106M 1s
 29750K .......... .......... .......... .......... .......... 94%  107M 1s
 29800K .......... .......... .......... .......... .......... 94%  109M 1s
 29850K .......... .......... .......... .......... .......... 95%  124M 1s
 29900K .......... .......... .......... .......... .......... 95%  109M 1s
 29950K .......... .......... .......... .......... .......... 95% 5.61M 1s
 30000K .......... .......... .......... .......... .......... 95%  110M 0s
 30050K .......... .......... .......... .......... .......... 95% 80.7M 0s
 30100K .......... .......... .......... .......... .......... 95% 67.9M 0s
 30150K .......... .......... .......... .......... .......... 95%  101M 0s
 30200K .......... .......... .......... .......... .......... 96% 94.6M 0s
 30250K .......... .......... .......... .......... .......... 96%  130M 0s
 30300K .......... .......... .......... .......... .......... 96% 76.3M 0s
 30350K .......... .......... .......... .......... .......... 96% 97.0M 0s
 30400K .......... .......... .......... .......... .......... 96%  127M 0s
 30450K .......... .......... .......... .......... .......... 96%  107M 0s
 30500K .......... .......... .......... .......... .......... 97%  107M 0s
 30550K .......... .......... .......... .......... .......... 97%  107M 0s
 30600K .......... .......... .......... .......... .......... 97% 82.7M 0s
 30650K .......... .......... .......... .......... .......... 97%  106M 0s
 30700K .......... .......... .......... .......... .......... 97%  108M 0s
 30750K .......... .......... .......... .......... .......... 97% 19.0M 0s
 30800K .......... .......... .......... .......... .......... 98%  108M 0s
 30850K .......... .......... .......... .......... .......... 98% 97.3M 0s
 30900K .......... .......... .......... .......... .......... 98%  144M 0s
 30950K .......... .......... .......... .......... .......... 98%  106M 0s
 31000K .......... .......... .......... .......... .......... 98%  108M 0s
 31050K .......... .......... .......... .......... .......... 98%  128M 0s
 31100K .......... .......... .......... .......... .......... 98%  108M 0s
 31150K .......... .......... .......... .......... .......... 99%  105M 0s
 31200K .......... .......... .......... .......... .......... 99%  106M 0s
 31250K .......... .......... .......... .......... .......... 99%  131M 0s
 31300K .......... .......... .......... .......... .......... 99%  104M 0s
 31350K .......... .......... .......... .......... .......... 99%  108M 0s
 31400K .......... .......... .......... .......... .......... 99%  108M 0s
 31450K .......... .....                                      100%  149M=10s
2017-06-17 22:37:25 (2.95 MB/s) - ‘minotaur-externals-0.2.tar.gz’ saved [32220716/32220716]
configure: WARNING: Cannot find C-function for checking NaN.
configure: WARNING: No solver available, examples will not work.
mkdir: cannot create directory '.libs': File exists
../../../CoinUtils/src/CoinFactorization2.cpp: In member function 'int CoinFactorization::factorDense()':
../../../CoinUtils/src/CoinFactorization2.cpp:520:75: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
   newSize += (numberDense_+1)/(sizeof(CoinFactorizationDouble)/sizeof(int));
../../../CoinUtils/src/CoinFactorization2.cpp:521:81: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
   newSize += 2*((numberDense_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinFactorization2.cpp:522:78: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
   newSize += ((numberRows_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinLpIO.cpp: In member function 'void CoinLpIO::readLp(FILE*)':
../../../CoinUtils/src/CoinLpIO.cpp:2268:24: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
       int length=strlen(buff);
../../../CoinUtils/src/CoinLpIO.cpp:2320:24: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
       int length=strlen(next+1);
../../../CoinUtils/src/CoinStructuredModel.cpp: In member function 'int CoinStructuredModel::decompose(const CoinPackedMatrix&, const double*, const double*, const double*, const double*, const double*, int, int, int*, double)':
../../../CoinUtils/src/CoinStructuredModel.cpp:761:10: warning: variable 'goodDW' set but not used [-Wunused-but-set-variable]
     bool goodDW=true;
../../../CoinUtils/src/CoinStructuredModel.cpp:1343:10: warning: variable 'goodBenders' set but not used [-Wunused-but-set-variable]
     bool goodBenders=true;
../../../CoinUtils/src/CoinMpsIO.cpp: In member function 'int CoinMpsIO::readConicMps(const char*, int*&, int*&, int*&, int&)':
../../../CoinUtils/src/CoinMpsIO.cpp:5814:3: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
   if ( cardReader_->whichSection (  ) == COIN_NAME_SECTION )
../../../CoinUtils/src/CoinMpsIO.cpp:5816:5: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
     if ( cardReader_->whichSection (  ) == COIN_CONIC_SECTION ) {
../../../CoinUtils/src/CoinPresolveDual.cpp: In static member function 'static const CoinPresolveAction* remove_dual_action::presolve(CoinPresolveMatrix*, const CoinPresolveAction*)':
../../../CoinUtils/src/CoinPresolveDual.cpp:236:20: warning: unused variable 'lb' [-Wunused-variable]
       const double lb = clo[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:237:20: warning: unused variable 'ub' [-Wunused-variable]
       const double ub = cup[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:642:13: warning: unused variable 'no_clb' [-Wunused-variable]
  const bool no_clb = (active[j]&5)==0 ;
../../../CoinUtils/src/CoinRational.cpp: In member function 'bool CoinRational::nearestRational_(double, double, long int)':
../../../CoinUtils/src/CoinRational.cpp:30:27: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
       double mediant = (a + c)/(double(b + d));
../../../CoinUtils/src/CoinRational.cpp:60:30: warning: conversion to 'long int' from 'double' may alter its value [-Wfloat-conversion]
    numerator_ += labs(intpart) * denominator_;
../../../CoinUtils/src/CoinRational.cpp:64:22: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
    return fabs(val - numerator_/double(denominator_)) <= maxdelta;
../../../CoinUtils/src/CoinWarmStartBasis.cpp: In member function 'bool CoinWarmStartBasis::fixFullBasis()':
../../../CoinUtils/src/CoinWarmStartBasis.cpp:494:7: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
       if (status==CoinWarmStartBasis::basic)
../../../CoinUtils/src/CoinWarmStartBasis.cpp:496:2: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
  numberBasic--;
In file included from ../../../../Osi/src/Osi/OsiColCut.cpp:10:0:
../../../../Osi/src/Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
../../../../Osi/src/Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
     if ( cutUbs.isExistingIndex(colIndx) )
../../../../Osi/src/Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
       if ( newLb > newUb )
../../../../Osi/src/Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
     if ( cutLbs.isExistingIndex(colIndx) )
../../../../Osi/src/Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
       if ( newUb < newLb )
In file included from ../../../../Osi/src/Osi/OsiCuts.hpp:14:0,
                 from ../../../../Osi/src/Osi/OsiCuts.cpp:13:
                 from ../../../../Osi/src/Osi/OsiRowCutDebugger.hpp:16,
                 from ../../../../Osi/src/Osi/OsiRowCutDebugger.cpp:19:
                 from ../../../../Osi/src/Osi/OsiSolverInterface.cpp:21:
../../../../Osi/src/Osi/OsiSolverInterface.cpp: In member function 'int OsiSolverInterface::differentModel(OsiSolverInterface&, bool)':
../../../../Osi/src/Osi/OsiSolverInterface.cpp:1880:8: warning: unused variable 'gotHint' [-Wunused-variable]
   bool gotHint = (getHintParam(OsiDoReducePrint,takeHint,strength));
libtool: install: warning: relinking `libOsi.la'
In file included from ../../../../Osi/src/OsiCommonTest/OsiColCutTest.cpp:13:0:
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
../../../../Osi/src/OsiCommonTest/../Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
In file included from ../../../../Osi/src/OsiCommonTest/../Osi/OsiCuts.hpp:14:0,
                 from ../../../../Osi/src/OsiCommonTest/OsiCutsTest.cpp:9:
                 from ../../../../Osi/src/OsiCommonTest/../Osi/OsiRowCutDebugger.hpp:16,
                 from ../../../../Osi/src/OsiCommonTest/OsiRowCutDebuggerTest.cpp:9:
                 from ../../../../Osi/src/OsiCommonTest/OsiSolverInterfaceTest.cpp:84:
libtool: install: warning: relinking `libOsiCommonTests.la'
../../../Clp/src/ClpPlusMinusOneMatrix.cpp:459:13: warning: 'doPlusOnes' defined but not used [-Wunused-variable]
 static bool doPlusOnes=true;
../../../Clp/src/ClpSimplex.cpp: In member function 'int ClpSimplex::fathom(void*)':
../../../Clp/src/ClpSimplex.cpp:11081:15: warning: unused variable 'statusWeights' [-Wunused-variable]
           int statusWeights = fastDual2(info);
../../../Clp/src/ClpSimplexOther.cpp: In member function 'int ClpSimplexOther::setInDual(ClpSimplex*)':
../../../Clp/src/ClpSimplexOther.cpp:1313:12: warning: unused variable 'statusD' [-Wunused-variable]
     Status statusD = dualProblem->getRowStatus(iColumn);
../../../Clp/src/ClpSimplexOther.cpp:1314:12: warning: unused variable 'statusDJ' [-Wunused-variable]
     Status statusDJ = dualProblem->getColumnStatus(jColumn);
../../../Clp/src/ClpSimplexOther.cpp:1352:12: warning: unused variable 'statusD' [-Wunused-variable]
     Status statusD = dualProblem->getColumnStatus(iRow);
../../../Clp/src/ClpSolve.cpp: In member function 'int ClpSimplex::solveBenders(CoinStructuredModel*, ClpSolve&)':
../../../Clp/src/ClpSolve.cpp:7272:9: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
         if (saveLower[i] < -1.0e20);
../../../Clp/src/ClpSolve.cpp:7273:4: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
    solution[i]=0.0;
../../../Clp/src/ClpSolver.cpp: In function 'void statistics(ClpSimplex*, ClpSimplex*)':
../../../Clp/src/ClpSolver.cpp:3756:10: warning: variable 'numberWritten' set but not used [-Wunused-but-set-variable]
   size_t numberWritten;
libtool: install: warning: relinking `libClp.la'
libtool: install: warning: relinking `libClpSolver.la'
In file included from /home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiCuts.hpp:14:0,
                 from ../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:33:
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp: In member function 'virtual bool OsiColCut::infeasible(const OsiSolverInterface&) const':
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:304:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:306:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:315:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
/home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/clp-1.16.9/Osi/src/Osi/OsiColCut.hpp:317:7: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::initialSolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:148:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::resolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:843:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
   bool gotHint = (getHintParam(OsiDoInBranchAndCut,takeHint,strength));
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'int OsiClpSolverInterface::infeasibleOtherWay(char*)':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9986:24: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
    whichWay[iColumn] *=2;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9991:24: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9841:7: warning: unused variable 'iRow' [-Wunused-variable]
   int iRow,iColumn;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9859:17: warning: unused variable 'objective' [-Wunused-variable]
   const double *objective = getObjCoefficients() ;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9860:10: warning: unused variable 'direction' [-Wunused-variable]
   double direction = getObjSense();
libtool: install: warning: relinking `libOsiClp.la'
filteraux.f:105:24:
      .                  0.D0,.false.)
                        1
Warning: Rank mismatch in argument ‘w’ at (1) (rank-1 and scalar)
ar: creating libfiltersqp.a
ar: `u' modifier ignored since `D' is the default (see `U')
ar: creating amplsolver.a
../../../../src/cppunit/Protector.cpp: In member function 'void CppUnit::Protector::reportError(const CppUnit::ProtectorContext&, const CppUnit::Exception&) const':
../../../../src/cppunit/Protector.cpp:24:8: warning: 'template<class> class std::auto_ptr' is deprecated [-Wdeprecated-declarations]
   std::auto_ptr<Exception> actualError( error.clone() );
In file included from /usr/include/c++/6/memory:81:0,
                 from ../../../../src/cppunit/Protector.cpp:6:
/usr/include/c++/6/bits/unique_ptr.h:49:28: note: declared here
   template<typename> class auto_ptr;
../../../../src/cppunit/Protector.cpp: In member function 'void CppUnit::Protector::reportFailure(const CppUnit::ProtectorContext&, const CppUnit::Exception&) const':
../../../../src/cppunit/Protector.cpp:45:8: warning: 'template<class> class std::auto_ptr' is deprecated [-Wdeprecated-declarations]
   std::auto_ptr<Exception> actualFailure( failure.clone() );
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 189: cd: minotaur-externals//build: No such file or directory
make: *** No rule to make target 'distclean'.  Stop.
: logger ok! OK (39)
Errors in build-base-static:
CMake Error at CMakeLists.txt:203 (message):
   Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target 'install'.  Stop.
make: *** No rule to make target 'utest'.  Stop.
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Sat Jun 17 22:43:12 IST 2017
More information about the Minotaur-dev mailing list
