[Minotaur-dev] minotaur daily test results
amahajan amahajan at iitb.ac.in
Sun Jan 15 11:24:46 CST 2017
Minotaur daily test report
Sun Jan 15 22:37:01 IST 2017
origin.ieor.iitb.ac.in
Linux origin 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux
Detailed log available at  http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2-133-g168b2dd
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (39)
compiling build-base-static: OK.
make utest output for build-base-static: OK (39)
compiling build-filter: OK.
make utest output for build-filter: OK (39)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (39)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (39)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (42)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (42)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (42)
compiling build-osi: OK.
make utest output for build-osi: OK (39)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (39)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (39)
compiling build-ampl: OK.
make utest output for build-ampl: OK (58)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (58)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (58)
compiling build-all: OK.
make utest output for build-all: OK (69)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (69)
compiling build-all-static: OK.
make utest output for build-all-static: OK (69)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
: logger ok! OK (69)
==25665== Memcheck, a memory error detector
==25665== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==25665== Using Valgrind-3.10.0 and LibVEX; rerun with -h for copyright info
==25665== Command: ./unittest all
==25665==
==25665==
==25665== HEAP SUMMARY:
==25665==     in use at exit: 0 bytes in 0 blocks
==25665==   total heap usage: 171,585 allocs, 171,585 frees, 888,067,750 bytes allocated
==25665==
==25665== All heap blocks were freed -- no leaks are possible
==25665==
==25665== For counts of detected and suppressed errors, rerun with: -v
==25665== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:542: minotaur.d: No such file or directory
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (58)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (39)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
: logger ok! OK (42)
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Sun Jan 15 22:54:46 IST 2017
More information about the Minotaur-dev mailing list
