[Minotaur-dev] minotaur daily test results
amahajan
amahajan at iitb.ac.in
Wed Dec 13 11:17:30 CST 2017
Minotaur daily test report
Wed Dec 13 22:37:01 IST 2017
origin.ieor.iitb.ac.in
Linux origin 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u2 (2017-06-26) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-21-g9ee29f9
ls: cannot access 'build-ampl/bin': No such file or directory
ls: cannot access 'build-ampl/lib': No such file or directory
ls: cannot access 'build-ampl/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-debug/bin': No such file or directory
ls: cannot access 'build-ampl-debug/lib': No such file or directory
ls: cannot access 'build-ampl-debug/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-static/bin': No such file or directory
ls: cannot access 'build-ampl-static/lib': No such file or directory
ls: cannot access 'build-ampl-static/include/minotaur/*': No such file or directory
Summary
compiling build-base: ERROR. lib/libminotaur.so not built.
make utest output for build-base: ERROR
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: OK.
make utest output for build-all: OK (71)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (71)
compiling build-all-static: OK.
make utest output for build-all-static: OK (71)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
: logger ok! OK (71)
==24481== Memcheck, a memory error detector
==24481== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==24481== Using Valgrind-3.12.0.SVN and LibVEX; rerun with -h for copyright info
==24481== Command: ./unittest all
==24481==
: logger ok! ==24481== Conditional jump or move depends on uninitialised value(s)
==24481== at 0x208814: bqpd_ (in /home/amahajan/tmp/minotaur-test/build-all-debug/src/testing/unittest)
==24481== by 0x200EC7: Minotaur::BqpdEngine::solve_(int, double&) (BqpdEngine.cpp:512)
==24481== by 0x20099C: Minotaur::BqpdEngine::solve() (BqpdEngine.cpp:432)
==24481== by 0x1F4244: AMPLBqpdUT::testNLP() (AMPLBqpdUT.cpp:57)
==24481== by 0x1F59B5: CppUnit::TestCaller<AMPLBqpdUT>::runTest() (TestCaller.h:166)
==24481== by 0x4E5AB81: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==24481== by 0x4E5197F: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==24481== by 0x4E57F74: operator() (ProtectorChain.cpp:20)
==24481== by 0x4E57F74: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==24481== by 0x4E6047B: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (TestResult.cpp:181)
==24481== by 0x4E5A9CF: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==24481== by 0x4E5AE52: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==24481== by 0x4E5AD6D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==24481==
OK (71)
==24481==
==24481== HEAP SUMMARY:
==24481== in use at exit: 0 bytes in 0 blocks
==24481== total heap usage: 173,239 allocs, 173,239 frees, 888,656,153 bytes allocated
==24481==
==24481== All heap blocks were freed -- no leaks are possible
==24481==
==24481== For counts of detected and suppressed errors, rerun with: -v
==24481== Use --track-origins=yes to see where uninitialised values come from
==24481== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:543: minotaur.d: No such file or directory
Errors in build-all-static:
Errors in build-ampl-debug:
CMake Error at CMakeLists.txt:246 (message):
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-ampl-debug//lib not found.
make: *** No rule to make target 'install'. Stop.
make: *** No rule to make target 'utest'. Stop.
Errors in build-ampl:
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-ampl//lib not found.
Errors in build-ampl-static:
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-ampl-static//lib not found.
Errors in build-base-debug:
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-base-debug//lib not found.
Errors in build-base:
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-base//lib not found.
Errors in build-base-static:
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-base-static//lib not found.
Errors in build-filter-debug:
CMake Error at CMakeLists.txt:331 (message):
Minotaur config: /home/amahajan/tmp/minotaur-test/build-filter-debug//include/coin/IpIpoptApplication.hpp not found.
Errors in build-filter:
Minotaur config: /home/amahajan/tmp/minotaur-test/build-filter//include/coin/IpIpoptApplication.hpp not found.
Errors in build-filter-static:
Minotaur config: /home/amahajan/tmp/minotaur-test/build-filter-static//include/coin/IpIpoptApplication.hpp not found.
Errors in build-ipopt-debug:
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-ipopt-debug//lib not found.
Errors in build-ipopt:
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-ipopt//lib not found.
Errors in build-ipopt-static:
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-ipopt-static//lib not found.
Errors in build-osi-debug:
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-osi-debug//lib not found.
Errors in build-osi:
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-osi//lib not found.
Errors in build-osi-static:
Minotaur config: BQPD_LIB_DIR_F /home/amahajan/tmp/minotaur-test/build-osi-static//lib not found.
End of tests
Wed Dec 13 22:47:30 IST 2017
More information about the Minotaur-dev
