[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan mahajan at mcs.anl.gov
Fri Dec 8 23:07:11 CST 2017
Minotaur daily test report
Fri Dec  8 22:57:01 CST 2017
petsc.mcs.anl.gov
Linux petsc 3.13.0-121-generic #170-Ubuntu SMP Wed Jun 14 09:04:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at  http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-10-g8ab398c
ls: cannot access build-ampl/bin: No such file or directory
ls: cannot access build-ampl/lib: No such file or directory
ls: cannot access build-ampl/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-debug/bin: No such file or directory
ls: cannot access build-ampl-debug/lib: No such file or directory
ls: cannot access build-ampl-debug/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-static/bin: No such file or directory
ls: cannot access build-ampl-static/lib: No such file or directory
ls: cannot access build-ampl-static/include/minotaur/*: No such file or directory
Summary
compiling build-base: ERROR. lib/libminotaur.so not built.
make utest output for build-base: ERROR
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: OK.
make utest output for build-all: OK (71)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (71)
compiling build-all-static: OK.
make utest output for build-all-static: OK (71)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
: logger ok! OK (71)
==28657== Memcheck, a memory error detector
==28657== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==28657== Using Valgrind-3.10.1 and LibVEX; rerun with -h for copyright info
==28657== Command: ./unittest all
==28657==
: logger ok! ==28657== Conditional jump or move depends on uninitialised value(s)
==28657==    at 0x4EE734: bqpd_ (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==28657==    by 0x4E7230: Minotaur::BqpdEngine::solve_(int, double&) (BqpdEngine.cpp:512)
==28657==    by 0x4E6CD0: Minotaur::BqpdEngine::solve() (BqpdEngine.cpp:432)
==28657==    by 0x4DA2C9: AMPLBqpdUT::testNLP() (AMPLBqpdUT.cpp:57)
==28657==    by 0x4DBA35: CppUnit::TestCaller<AMPLBqpdUT>::runTest() (TestCaller.h:166)
==28657==    by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==28657==    by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==28657==    by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==28657==    by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==28657==    by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==28657==    by 0x4E59952: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==28657==    by 0x4E5986D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==28657==
OK (71)
==28657==
==28657== HEAP SUMMARY:
==28657==     in use at exit: 0 bytes in 0 blocks
==28657==   total heap usage: 220,791 allocs, 220,791 frees, 1,089,158,113 bytes allocated
==28657==
==28657== All heap blocks were freed -- no leaks are possible
==28657==
==28657== For counts of detected and suppressed errors, rerun with: -v
==28657== Use --track-origins=yes to see where uninitialised values come from
==28657== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:543: minotaur.d: No such file or directory
Errors in build-all-static:
Errors in build-ampl-debug:
CMake Error at CMakeLists.txt:246 (message):
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-ampl-debug//lib not found.
make: *** No rule to make target `install'.  Stop.
make: *** No rule to make target `utest'.  Stop.
Errors in build-ampl:
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-ampl//lib not found.
Errors in build-ampl-static:
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-ampl-static//lib not found.
Errors in build-base-debug:
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-base-debug//lib not found.
Errors in build-base:
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-base//lib not found.
Errors in build-base-static:
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-base-static//lib not found.
Errors in build-filter-debug:
CMake Error at CMakeLists.txt:331 (message):
   Minotaur config: /sandbox/mahajan/minotaur-test/build-filter-debug//include/coin/IpIpoptApplication.hpp not found.
Errors in build-filter:
   Minotaur config: /sandbox/mahajan/minotaur-test/build-filter//include/coin/IpIpoptApplication.hpp not found.
Errors in build-filter-static:
   Minotaur config: /sandbox/mahajan/minotaur-test/build-filter-static//include/coin/IpIpoptApplication.hpp not found.
Errors in build-ipopt-debug:
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-ipopt-debug//lib not found.
Errors in build-ipopt:
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-ipopt//lib not found.
Errors in build-ipopt-static:
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-ipopt-static//lib not found.
Errors in build-osi-debug:
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-osi-debug//lib not found.
Errors in build-osi:
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-osi//lib not found.
Errors in build-osi-static:
   Minotaur config:  BQPD_LIB_DIR_F /sandbox/mahajan/minotaur-test/build-osi-static//lib not found.
End of tests
More information about the Minotaur-dev mailing list
