[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan mahajan at mcs.anl.gov
Mon Aug 7 23:17:45 CDT 2017
Minotaur daily test report
Mon Aug  7 22:57:02 CDT 2017
petsc.mcs.anl.gov
Linux petsc 3.13.0-121-generic #170-Ubuntu SMP Wed Jun 14 09:04:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at  http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2-175-g4650ce2
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (39)
compiling build-base-static: OK.
make utest output for build-base-static: OK (39)
compiling build-filter: OK.
make utest output for build-filter: OK (39)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (39)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (39)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (42)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (42)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (42)
compiling build-osi: OK.
make utest output for build-osi: OK (39)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (39)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (39)
compiling build-ampl: OK.
make utest output for build-ampl: OK (58)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (58)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (58)
compiling build-all: OK.
make utest output for build-all: OK (69)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (69)
compiling build-all-static: OK.
make utest output for build-all-static: OK (69)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
: logger ok! OK (69)
==22132== Memcheck, a memory error detector
==22132== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==22132== Using Valgrind-3.10.1 and LibVEX; rerun with -h for copyright info
==22132== Command: ./unittest all
==22132==
: logger ok! ==22132== Conditional jump or move depends on uninitialised value(s)
==22132==    at 0x4E6EE4: bqpd_ (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==22132==    by 0x4DF9E2: Minotaur::BqpdEngine::solve_(int, double&) (BqpdEngine.cpp:512)
==22132==    by 0x4DF482: Minotaur::BqpdEngine::solve() (BqpdEngine.cpp:432)
==22132==    by 0x4D2A7B: AMPLBqpdUT::testNLP() (AMPLBqpdUT.cpp:57)
==22132==    by 0x4D41E7: CppUnit::TestCaller<AMPLBqpdUT>::runTest() (TestCaller.h:166)
==22132==    by 0x4E59601: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==22132==    by 0x4E500FF: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==22132==    by 0x4E56B1C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==22132==    by 0x4E5F1A9: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==22132==    by 0x4E59309: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==22132==    by 0x4E59952: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==22132==    by 0x4E5986D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==22132==
OK (69)
==22132==
==22132== HEAP SUMMARY:
==22132==     in use at exit: 0 bytes in 0 blocks
==22132==   total heap usage: 220,488 allocs, 220,488 frees, 1,089,117,119 bytes allocated
==22132==
==22132== All heap blocks were freed -- no leaks are possible
==22132==
==22132== For counts of detected and suppressed errors, rerun with: -v
==22132== Use --track-origins=yes to see where uninitialised values come from
==22132== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:542: minotaur.d: No such file or directory
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (58)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (39)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
: logger ok! OK (42)
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
More information about the Minotaur-dev mailing list
