[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan
mahajan at mcs.anl.gov
Sun Apr 30 23:07:46 CDT 2017
Minotaur daily test report
Sun Apr 30 22:57:01 CDT 2017
petsc.mcs.anl.gov
Linux petsc 3.13.0-111-generic #158-Ubuntu SMP Wed Feb 22 16:12:03 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2-150-gde69326
ls: cannot access build-ampl/bin: No such file or directory
ls: cannot access build-ampl/lib: No such file or directory
ls: cannot access build-ampl/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-debug/bin: No such file or directory
ls: cannot access build-ampl-debug/lib: No such file or directory
ls: cannot access build-ampl-debug/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-static/bin: No such file or directory
ls: cannot access build-ampl-static/lib: No such file or directory
ls: cannot access build-ampl-static/include/minotaur/*: No such file or directory
ls: cannot access build-all/bin: No such file or directory
ls: cannot access build-all/lib: No such file or directory
ls: cannot access build-all/include/minotaur/*: No such file or directory
ls: cannot access build-all-debug/bin: No such file or directory
ls: cannot access build-all-debug/lib: No such file or directory
ls: cannot access build-all-debug/include/minotaur/*: No such file or directory
ls: cannot access build-all-static/bin: No such file or directory
ls: cannot access build-all-static/lib: No such file or directory
ls: cannot access build-all-static/include/minotaur/*: No such file or directory
Summary
compiling build-base: OK.
make utest output for build-base: ERROR
compiling build-base-debug: OK.
make utest output for build-base-debug: ERROR
compiling build-base-static: OK.
make utest output for build-base-static: ERROR
compiling build-filter: OK.
make utest output for build-filter: ERROR
compiling build-filter-debug: OK.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: OK.
make utest output for build-filter-static: ERROR
compiling build-ipopt: OK.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libmntrampl.a not built.
Errors:
Errors in build-all-debug:
In file included from /usr/include/c++/4.8/cstdint:35:0,
from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/CoinTypes.hpp:15,
from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpMatrixBase.hpp:10,
from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpPackedMatrix.hpp:11,
from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpModel.hpp:19,
from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpSimplex.hpp:16,
from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/OsiClpSolverInterface.hpp:14,
from /sandbox/mahajan/minotaur-test/src/engines/OsiLP/OsiLPEngine.cpp:18:
/usr/include/c++/4.8/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
#error This file requires compiler and library support for the \
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpSimplex.hpp:18:0,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpSolve.hpp:408:5: warning: "CLP_HAS_ABC" is not defined [-Wundef]
#if CLP_HAS_ABC
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:13:0,
from /sandbox/mahajan/minotaur-test/src/engines/Ipopt/IpoptEngine.cpp:18:
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpReferenced.hpp:215:8: warning: unused parameter ‘referencer’ [-Wunused-parameter]
void ReferencedObject::AddRef(const Referencer* referencer) const
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpReferenced.hpp:227:8: warning: unused parameter ‘referencer’ [-Wunused-parameter]
void ReferencedObject::ReleaseRef(const Referencer* referencer) const
In file included from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLHessian.h:17:0,
from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLHessian.cpp:19:
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/asl.h:956:44: warning: redundant redeclaration of ‘int Sprintf(char*, const char*, ...)’ in same scope [-Wredundant-decls]
extern int Sprintf(char*, const char*, ...);
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/asl.h:24:0,
from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLHessian.h:17,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/stdio1.h:66:12: warning: previous declaration of ‘int Sprintf(char*, const char*, ...)’ [-Wredundant-decls]
extern int Sprintf ANSI((char*, const char*, ...));
In file included from /sandbox/mahajan/minotaur-test/src/engines/Ipopt/IpoptEngine.cpp:18:0:
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘n’ [-Wunused-parameter]
virtual bool get_var_con_metadata(Index n,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘var_string_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘var_integer_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘var_numeric_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘m’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘con_string_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘con_integer_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:90:18: warning: unused parameter ‘con_numeric_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘obj_scaling’ [-Wunused-parameter]
virtual bool get_scaling_parameters(Number& obj_scaling,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘use_x_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘n’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘x_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘use_g_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘m’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:119:18: warning: unused parameter ‘g_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:132:18: warning: unused parameter ‘n’ [-Wunused-parameter]
virtual bool get_variables_linearity(Index n, LinearityType* var_types)
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:132:18: warning: unused parameter ‘var_types’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:140:18: warning: unused parameter ‘m’ [-Wunused-parameter]
virtual bool get_constraints_linearity(Index m, LinearityType* const_types)
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:140:18: warning: unused parameter ‘const_types’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:161:18: warning: unused parameter ‘warm_start_iterate’ [-Wunused-parameter]
virtual bool get_warm_start_iterate(IteratesVector& warm_start_iterate)
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘n’ [-Wunused-parameter]
virtual bool eval_h(Index n, const Number* x, bool new_x,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘x’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘new_x’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘obj_factor’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘m’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘lambda’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘new_lambda’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘nele_hess’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘iRow’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘jCol’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:196:18: warning: unused parameter ‘values’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘n’ [-Wunused-parameter]
virtual void finalize_metadata(Index n,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘var_string_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘var_integer_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘var_numeric_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘m’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘con_string_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘con_integer_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:226:18: warning: unused parameter ‘con_numeric_md’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘mode’ [-Wunused-parameter]
virtual bool intermediate_callback(AlgorithmMode mode,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘iter’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘obj_value’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘inf_pr’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘inf_du’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘mu’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘d_norm’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘regularization_size’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘alpha_du’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘alpha_pr’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘ls_trials’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘ip_data’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:240:18: warning: unused parameter ‘ip_cq’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:272:18: warning: unused parameter ‘num_nonlin_vars’ [-Wunused-parameter]
virtual bool get_list_of_nonlinear_variables(Index num_nonlin_vars,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTNLP.hpp:272:18: warning: unused parameter ‘pos_nonlin_vars’ [-Wunused-parameter]
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpTaggedObject.hpp:15:0,
from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpVector.hpp:13,
from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:13,
from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpIpoptApplication.hpp:28,
from /sandbox/mahajan/minotaur-test/src/engines/Ipopt/IpoptEngine.cpp:19:
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpObserver.hpp:309:8: warning: unused parameter ‘notify_type’ [-Wunused-parameter]
void Subject::AttachObserver(Observer::NotifyType notify_type, Observer* observer) const
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpObserver.hpp:329:8: warning: unused parameter ‘notify_type’ [-Wunused-parameter]
void Subject::DetachObserver(Observer::NotifyType notify_type, Observer* observer) const
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpIpoptApplication.hpp:28:0,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:56:18: warning: unused parameter ‘options’ [-Wunused-parameter]
virtual bool ProcessOptions(const OptionsList& options,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:56:18: warning: unused parameter ‘prefix’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:109:18: warning: unused parameter ‘warm_start_iterate’ [-Wunused-parameter]
virtual bool GetWarmStartIterate(IteratesVector& warm_start_iterate)
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘status’ [-Wunused-parameter]
virtual void FinalizeSolution(SolverReturn status,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘x’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘z_L’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘z_U’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘c’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘d’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘y_c’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘y_d’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘obj_value’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘ip_data’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:145:18: warning: unused parameter ‘ip_cq’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘mode’ [-Wunused-parameter]
virtual bool IntermediateCallBack(AlgorithmMode mode,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘iter’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘obj_value’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘inf_pr’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘inf_du’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘mu’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘d_norm’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘regularization_size’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘alpha_du’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘alpha_pr’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘ls_trials’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘ip_data’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:170:18: warning: unused parameter ‘ip_cq’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘x_space’ [-Wunused-parameter]
virtual void GetScalingParameters(
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘c_space’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘d_space’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘obj_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘x_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘c_scaling’ [-Wunused-parameter]
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpNLP.hpp:188:18: warning: unused parameter ‘d_scaling’ [-Wunused-parameter]
In file included from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLInterface.h:18:0,
from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLInterface.cpp:19:
from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLInterface.h:18,
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/ClpModel.hpp:23:0,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/CoinFinite.hpp:19:14: warning: ‘COIN_INT_MAX’ defined but not used [-Wunused-variable]
const int COIN_INT_MAX = (std::numeric_limits<int>::max)();
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/CoinFinite.hpp:20:14: warning: ‘COIN_INT_MAX_AS_DOUBLE’ defined but not used [-Wunused-variable]
const double COIN_INT_MAX_AS_DOUBLE = (std::numeric_limits<int>::max)();
make[2]: *** [src/engines/OsiLP/CMakeFiles/mntrosilp.dir/OsiLPEngine.cpp.o] Error 1
make[1]: *** [src/engines/OsiLP/CMakeFiles/mntrosilp.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
In file included from /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpVector.hpp:14:0,
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpCachedResults.hpp: In instantiation of ‘void Ipopt::DependentResult<T>::RecieveNotification(Ipopt::Observer::NotifyType, const Ipopt::Subject*) [with T = double]’:
/sandbox/mahajan/minotaur-test/src/engines/Ipopt/IpoptEngine.cpp:1126:1: required from here
/sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/include/coin/IpCachedResults.hpp:405:8: warning: unused parameter ‘subject’ [-Wunused-parameter]
void DependentResult<T>::RecieveNotification(NotifyType notify_type, const Subject* subject)
In file included from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLNonlinearFunction.h:18:0,
from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLNonlinearFunction.cpp:17:
from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLNonlinearFunction.h:18,
from /sandbox/mahajan/minotaur-test/src/interfaces/ampl/AMPLJacobian.cpp:18:
make: *** [all] Error 2
#if CLP_HAS_ABC
make[3]: *** [src/engines/OsiLP/CMakeFiles/mntrosilp.dir/OsiLPEngine.cpp.o] Error 1
make[2]: *** [src/engines/OsiLP/CMakeFiles/mntrosilp.dir/all] Error 2
make[1]: *** [CMakeFiles/utest.dir/rule] Error 2
make: *** [utest] Error 2
#if CLP_HAS_ABC
valgrind: ./unittest: No such file or directory
Errors in build-all:
#if CLP_HAS_ABC
#if CLP_HAS_ABC
#if CLP_HAS_ABC
Errors in build-all-manual:
Makefile:542: minotaur.d: No such file or directory
#if CLP_HAS_ABC
make: *** [/sandbox/mahajan/minotaur-test/src/engines/OsiLP/OsiLPEngine.o] Error 1
Errors in build-all-static:
#if CLP_HAS_ABC
#if CLP_HAS_ABC
#if CLP_HAS_ABC
Errors in build-ampl-debug:
from /sandbox/mahajan/minotaur-test/src/algorithms/qg.cpp:17:
from /sandbox/mahajan/minotaur-test/src/algorithms/McBnb.cpp:54:
from /sandbox/mahajan/minotaur-test/src/algorithms/Glob.cpp:45:
from /sandbox/mahajan/minotaur-test/src/algorithms/QPDive.cpp:43:
from /sandbox/mahajan/minotaur-test/src/algorithms/MsBnb.cpp:52:
from /sandbox/mahajan/minotaur-test/src/algorithms/Bnb.cpp:50:
/usr/bin/ld: ../../../third-party-0.2.1-linux-x86_64/lib/amplsolver.a(f_read.o): unrecognized relocation (0x2a) in section `.text'
/usr/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
make[2]: *** [src/algorithms/glob] Error 1
make[1]: *** [src/algorithms/CMakeFiles/glob.dir/all] Error 2
make[2]: *** [src/algorithms/qpd] Error 1
make[1]: *** [src/algorithms/CMakeFiles/qpd.dir/all] Error 2
make[2]: *** [src/algorithms/msbnb] Error 1
make[1]: *** [src/algorithms/CMakeFiles/msbnb.dir/all] Error 2
make[2]: *** [src/algorithms/bnb] Error 1
make[1]: *** [src/algorithms/CMakeFiles/bnb.dir/all] Error 2
make[2]: *** [src/algorithms/mcbnb] Error 1
make[1]: *** [src/algorithms/CMakeFiles/mcbnb.dir/all] Error 2
make[2]: *** [src/algorithms/qg] Error 1
make[1]: *** [src/algorithms/CMakeFiles/qg.dir/all] Error 2
from /sandbox/mahajan/minotaur-test/src/testing/AMPLInstanceUT.h:18,
from /sandbox/mahajan/minotaur-test/src/testing/AMPLInstanceUT.cpp:8:
from /sandbox/mahajan/minotaur-test/src/testing/AMPLCGraphUT.h:18,
from /sandbox/mahajan/minotaur-test/src/testing/AMPLCGraphUT.cpp:8:
from /sandbox/mahajan/minotaur-test/src/testing/PolySolverUT.h:18,
from /sandbox/mahajan/minotaur-test/src/testing/PolySolverUT.cpp:10:
from /sandbox/mahajan/minotaur-test/src/testing/TransformerUT.h:18,
from /sandbox/mahajan/minotaur-test/src/testing/TransformerUT.cpp:8:
/usr/bin/ld: /sandbox/mahajan/minotaur-test/third-party-0.2.1-linux-x86_64/lib/libcppunit.a(Asserter.o): unrecognized relocation (0x2a) in section `.text'
make[3]: *** [src/testing/unittest] Error 1
make[2]: *** [src/testing/CMakeFiles/unittest.dir/all] Error 2
Errors in build-ampl:
CMakeFiles/unittest.dir/LoggerUT.cpp.o: In function `CppUnit::TestSuiteFactory<LoggerUT>::makeTest()':
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x2c): undefined reference to `CppUnit::TestNamer::getFixtureName() const'
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x49): undefined reference to `CppUnit::TestSuite::TestSuite(std::string)'
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x195): undefined reference to `CppUnit::TestSuiteBuilderContextBase::getTestNameFor(std::string const&) const'
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x1bf): undefined reference to `CppUnit::TestCase::TestCase(std::string const&)'
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x24e): undefined reference to `CppUnit::TestSuiteBuilderContextBase::getTestNameFor(std::string const&) const'
LoggerUT.cpp:(.text._ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv[_ZN7CppUnit16TestSuiteFactoryI8LoggerUTE8makeTestEv]+0x278): undefined reference to `CppUnit::TestCase::TestCase(std::string const&)'
CMakeFiles/unittest.dir/LoggerUT.cpp.o: In function `_GLOBAL__sub_I__ZN8LoggerUT13testMsgStreamEv':
LoggerUT.cpp:(.text.startup+0x3d): undefined reference to `CppUnit::TestFactoryRegistry::getRegistry(std::string const&)'
LoggerUT.cpp:(.text.startup+0xa5): undefined reference to `CppUnit::TestFactoryRegistry::getRegistry(std::string const&)'
CMakeFiles/unittest.dir/LoggerUT.cpp.o:(.rodata._ZTVN7CppUnit10TestCallerI8LoggerUTEE[_ZTVN7CppUnit10TestCallerI8LoggerUTEE]+0x40): undefined reference to `CppUnit::TestCase::getName() const'
CMakeFiles/unittest.dir/LoggerUT.cpp.o:(.rodata._ZTVN7CppUnit10TestCallerI8LoggerUTEE[_ZTVN7CppUnit10TestCallerI8LoggerUTEE]+0x48): undefined reference to `CppUnit::Test::findTestPath(std::string const&, CppUnit::TestPath&) const'
CMakeFiles/unittest.dir/LoggerUT.cpp.o:(.rodata._ZTVN7CppUnit10TestCallerI8LoggerUTEE[_ZTVN7CppUnit10TestCallerI8LoggerUTEE]+0x58): undefined reference to `CppUnit::Test::findTest(std::string const&) const'
CMakeFiles/unittest.dir/LoggerUT.cpp.o:(.rodata._ZTVN7CppUnit10TestCallerI8LoggerUTEE[_ZTVN7CppUnit10TestCallerI8LoggerUTEE]+0x60): undefined reference to `CppUnit::Test::resolveTestPath(std::string const&) const'
Errors in build-ampl-static:
Errors in build-base-debug:
Errors in build-base:
--2017-04-30 22:57:03-- http://www.mcs.anl.gov/research/projects/minotaur/dist/third-party-0.2.1-linux-x86_64.tar.gz
Resolving www.mcs.anl.gov (www.mcs.anl.gov)... 140.221.6.95
Connecting to www.mcs.anl.gov (www.mcs.anl.gov)|140.221.6.95|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 12156146 (12M) [application/x-gzip]
Saving to: ‘third-party-0.2.1-linux-x86_64.tar.gz’
0K .......... .......... .......... .......... .......... 0% 32.3M 0s
50K .......... .......... .......... .......... .......... 0% 19.0M 0s
100K .......... .......... .......... .......... .......... 1% 6.98M 1s
150K .......... .......... .......... .......... .......... 1% 75.5M 1s
200K .......... .......... .......... .......... .......... 2% 72.6M 1s
250K .......... .......... .......... .......... .......... 2% 3.09M 1s
300K .......... .......... .......... .......... .......... 2% 84.5M 1s
350K .......... .......... .......... .......... .......... 3% 5.27M 1s
400K .......... .......... .......... .......... .......... 3% 63.1M 1s
450K .......... .......... .......... .......... .......... 4% 133M 1s
500K .......... .......... .......... .......... .......... 4% 101M 1s
550K .......... .......... .......... .......... .......... 5% 118M 1s
600K .......... .......... .......... .......... .......... 5% 13.5M 1s
650K .......... .......... .......... .......... .......... 5% 135M 1s
700K .......... .......... .......... .......... .......... 6% 8.49M 1s
750K .......... .......... .......... .......... .......... 6% 122M 1s
800K .......... .......... .......... .......... .......... 7% 105M 1s
850K .......... .......... .......... .......... .......... 7% 1.96M 1s
900K .......... .......... .......... .......... .......... 8% 109M 1s
950K .......... .......... .......... .......... .......... 8% 120M 1s
1000K .......... .......... .......... .......... .......... 8% 108M 1s
1050K .......... .......... .......... .......... .......... 9% 4.79M 1s
1100K .......... .......... .......... .......... .......... 9% 123M 1s
1150K .......... .......... .......... .......... .......... 10% 114M 1s
1200K .......... .......... .......... .......... .......... 10% 111M 1s
1250K .......... .......... .......... .......... .......... 10% 3.68M 1s
1300K .......... .......... .......... .......... .......... 11% 94.5M 1s
1350K .......... .......... .......... .......... .......... 11% 32.5M 1s
1400K .......... .......... .......... .......... .......... 12% 118M 1s
1450K .......... .......... .......... .......... .......... 12% 103M 1s
1500K .......... .......... .......... .......... .......... 13% 114M 1s
1550K .......... .......... .......... .......... .......... 13% 106M 1s
1600K .......... .......... .......... .......... .......... 13% 4.79M 1s
1650K .......... .......... .......... .......... .......... 14% 115M 1s
1700K .......... .......... .......... .......... .......... 14% 111M 1s
1750K .......... .......... .......... .......... .......... 15% 127M 1s
1800K .......... .......... .......... .......... .......... 15% 104M 1s
1850K .......... .......... .......... .......... .......... 16% 118M 1s
1900K .......... .......... .......... .......... .......... 16% 109M 1s
1950K .......... .......... .......... .......... .......... 16% 118M 1s
2000K .......... .......... .......... .......... .......... 17% 106M 1s
2050K .......... .......... .......... .......... .......... 17% 119M 1s
2100K .......... .......... .......... .......... .......... 18% 115M 1s
2150K .......... .......... .......... .......... .......... 18% 104M 1s
2200K .......... .......... .......... .......... .......... 18% 123M 1s
2250K .......... .......... .......... .......... .......... 19% 107M 1s
2300K .......... .......... .......... .......... .......... 19% 124M 0s
2350K .......... .......... .......... .......... .......... 20% 110M 0s
2400K .......... .......... .......... .......... .......... 20% 111M 0s
2450K .......... .......... .......... .......... .......... 21% 115M 0s
2500K .......... .......... .......... .......... .......... 21% 3.88M 0s
2550K .......... .......... .......... .......... .......... 21% 104M 0s
2600K .......... .......... .......... .......... .......... 22% 39.4M 0s
2650K .......... .......... .......... .......... .......... 22% 84.3M 0s
2700K .......... .......... .......... .......... .......... 23% 102M 0s
2750K .......... .......... .......... .......... .......... 23% 117M 0s
2800K .......... .......... .......... .......... .......... 24% 124M 0s
2850K .......... .......... .......... .......... .......... 24% 108M 0s
2900K .......... .......... .......... .......... .......... 24% 111M 0s
2950K .......... .......... .......... .......... .......... 25% 113M 0s
3000K .......... .......... .......... .......... .......... 25% 120M 0s
3050K .......... .......... .......... .......... .......... 26% 110M 0s
3100K .......... .......... .......... .......... .......... 26% 108M 0s
3150K .......... .......... .......... .......... .......... 26% 125M 0s
3200K .......... .......... .......... .......... .......... 27% 95.3M 0s
3250K .......... .......... .......... .......... .......... 27% 125M 0s
3300K .......... .......... .......... .......... .......... 28% 101M 0s
3350K .......... .......... .......... .......... .......... 28% 119M 0s
3400K .......... .......... .......... .......... .......... 29% 115M 0s
3450K .......... .......... .......... .......... .......... 29% 121M 0s
3500K .......... .......... .......... .......... .......... 29% 102M 0s
3550K .......... .......... .......... .......... .......... 30% 47.6M 0s
3600K .......... .......... .......... .......... .......... 30% 182M 0s
3650K .......... .......... .......... .......... .......... 31% 132M 0s
3700K .......... .......... .......... .......... .......... 31% 109M 0s
3750K .......... .......... .......... .......... .......... 32% 63.3M 0s
3800K .......... .......... .......... .......... .......... 32% 98.3M 0s
3850K .......... .......... .......... .......... .......... 32% 112M 0s
3900K .......... .......... .......... .......... .......... 33% 109M 0s
3950K .......... .......... .......... .......... .......... 33% 64.8M 0s
4000K .......... .......... .......... .......... .......... 34% 136M 0s
4050K .......... .......... .......... .......... .......... 34% 105M 0s
4100K .......... .......... .......... .......... .......... 34% 108M 0s
4150K .......... .......... .......... .......... .......... 35% 115M 0s
4200K .......... .......... .......... .......... .......... 35% 61.0M 0s
4250K .......... .......... .......... .......... .......... 36% 79.6M 0s
4300K .......... .......... .......... .......... .......... 36% 117M 0s
4350K .......... .......... .......... .......... .......... 37% 66.6M 0s
4400K .......... .......... .......... .......... .......... 37% 94.7M 0s
4450K .......... .......... .......... .......... .......... 37% 81.2M 0s
4500K .......... .......... .......... .......... .......... 38% 119M 0s
4550K .......... .......... .......... .......... .......... 38% 119M 0s
4600K .......... .......... .......... .......... .......... 39% 87.7M 0s
4650K .......... .......... .......... .......... .......... 39% 103M 0s
4700K .......... .......... .......... .......... .......... 40% 109M 0s
4750K .......... .......... .......... .......... .......... 40% 87.5M 0s
4800K .......... .......... .......... .......... .......... 40% 128M 0s
4850K .......... .......... .......... .......... .......... 41% 115M 0s
4900K .......... .......... .......... .......... .......... 41% 47.7M 0s
4950K .......... .......... .......... .......... .......... 42% 134M 0s
5000K .......... .......... .......... .......... .......... 42% 81.9M 0s
5050K .......... .......... .......... .......... .......... 42% 85.1M 0s
5100K .......... .......... .......... .......... .......... 43% 111M 0s
5150K .......... .......... .......... .......... .......... 43% 90.5M 0s
5200K .......... .......... .......... .......... .......... 44% 111M 0s
5250K .......... .......... .......... .......... .......... 44% 119M 0s
5300K .......... .......... .......... .......... .......... 45% 94.5M 0s
5350K .......... .......... .......... .......... .......... 45% 99.2M 0s
5400K .......... .......... .......... .......... .......... 45% 106M 0s
5450K .......... .......... .......... .......... .......... 46% 119M 0s
5500K .......... .......... .......... .......... .......... 46% 82.8M 0s
5550K .......... .......... .......... .......... .......... 47% 100M 0s
5600K .......... .......... .......... .......... .......... 47% 109M 0s
5650K .......... .......... .......... .......... .......... 48% 119M 0s
5700K .......... .......... .......... .......... .......... 48% 119M 0s
5750K .......... .......... .......... .......... .......... 48% 88.2M 0s
5800K .......... .......... .......... .......... .......... 49% 106M 0s
5850K .......... .......... .......... .......... .......... 49% 119M 0s
5900K .......... .......... .......... .......... .......... 50% 104M 0s
5950K .......... .......... .......... .......... .......... 50% 62.6M 0s
6000K .......... .......... .......... .......... .......... 50% 114M 0s
6050K .......... .......... .......... .......... .......... 51% 94.6M 0s
6100K .......... .......... .......... .......... .......... 51% 101M 0s
6150K .......... .......... .......... .......... .......... 52% 65.8M 0s
6200K .......... .......... .......... .......... .......... 52% 96.5M 0s
6250K .......... .......... .......... .......... .......... 53% 104M 0s
6300K .......... .......... .......... .......... .......... 53% 95.1M 0s
6350K .......... .......... .......... .......... .......... 53% 133M 0s
6400K .......... .......... .......... .......... .......... 54% 73.8M 0s
6450K .......... .......... .......... .......... .......... 54% 110M 0s
6500K .......... .......... .......... .......... .......... 55% 107M 0s
6550K .......... .......... .......... .......... .......... 55% 66.4M 0s
6600K .......... .......... .......... .......... .......... 56% 93.1M 0s
6650K .......... .......... .......... .......... .......... 56% 128M 0s
6700K .......... .......... .......... .......... .......... 56% 62.1M 0s
6750K .......... .......... .......... .......... .......... 57% 107M 0s
6800K .......... .......... .......... .......... .......... 57% 122M 0s
6850K .......... .......... .......... .......... .......... 58% 96.0M 0s
6900K .......... .......... .......... .......... .......... 58% 125M 0s
6950K .......... .......... .......... .......... .......... 58% 72.2M 0s
7000K .......... .......... .......... .......... .......... 59% 85.6M 0s
7050K .......... .......... .......... .......... .......... 59% 118M 0s
7100K .......... .......... .......... .......... .......... 60% 107M 0s
7150K .......... .......... .......... .......... .......... 60% 113M 0s
7200K .......... .......... .......... .......... .......... 61% 100M 0s
7250K .......... .......... .......... .......... .......... 61% 113M 0s
7300K .......... .......... .......... .......... .......... 61% 107M 0s
7350K .......... .......... .......... .......... .......... 62% 97.0M 0s
7400K .......... .......... .......... .......... .......... 62% 96.1M 0s
7450K .......... .......... .......... .......... .......... 63% 108M 0s
7500K .......... .......... .......... .......... .......... 63% 103M 0s
7550K .......... .......... .......... .......... .......... 64% 73.5M 0s
7600K .......... .......... .......... .......... .......... 64% 112M 0s
7650K .......... .......... .......... .......... .......... 64% 133M 0s
7700K .......... .......... .......... .......... .......... 65% 97.5M 0s
7750K .......... .......... .......... .......... .......... 65% 139M 0s
7800K .......... .......... .......... .......... .......... 66% 70.6M 0s
7850K .......... .......... .......... .......... .......... 66% 122M 0s
7900K .......... .......... .......... .......... .......... 66% 111M 0s
7950K .......... .......... .......... .......... .......... 67% 80.5M 0s
8000K .......... .......... .......... .......... .......... 67% 117M 0s
8050K .......... .......... .......... .......... .......... 68% 97.6M 0s
8100K .......... .......... .......... .......... .......... 68% 118M 0s
8150K .......... .......... .......... .......... .......... 69% 83.1M 0s
8200K .......... .......... .......... .......... .......... 69% 105M 0s
8250K .......... .......... .......... .......... .......... 69% 114M 0s
8300K .......... .......... .......... .......... .......... 70% 120M 0s
8350K .......... .......... .......... .......... .......... 70% 80.0M 0s
8400K .......... .......... .......... .......... .......... 71% 101M 0s
8450K .......... .......... .......... .......... .......... 71% 116M 0s
8500K .......... .......... .......... .......... .......... 72% 121M 0s
8550K .......... .......... .......... .......... .......... 72% 82.3M 0s
8600K .......... .......... .......... .......... .......... 72% 112M 0s
8650K .......... .......... .......... .......... .......... 73% 106M 0s
8700K .......... .......... .......... .......... .......... 73% 111M 0s
8750K .......... .......... .......... .......... .......... 74% 113M 0s
8800K .......... .......... .......... .......... .......... 74% 109M 0s
8850K .......... .......... .......... .......... .......... 74% 62.1M 0s
8900K .......... .......... .......... .......... .......... 75% 99.6M 0s
8950K .......... .......... .......... .......... .......... 75% 116M 0s
9000K .......... .......... .......... .......... .......... 76% 80.8M 0s
9050K .......... .......... .......... .......... .......... 76% 125M 0s
9100K .......... .......... .......... .......... .......... 77% 69.2M 0s
9150K .......... .......... .......... .......... .......... 77% 129M 0s
9200K .......... .......... .......... .......... .......... 77% 105M 0s
9250K .......... .......... .......... .......... .......... 78% 116M 0s
9300K .......... .......... .......... .......... .......... 78% 88.6M 0s
9350K .......... .......... .......... .......... .......... 79% 123M 0s
9400K .......... .......... .......... .......... .......... 79% 98.0M 0s
9450K .......... .......... .......... .......... .......... 80% 110M 0s
9500K .......... .......... .......... .......... .......... 80% 66.1M 0s
9550K .......... .......... .......... .......... .......... 80% 134M 0s
9600K .......... .......... .......... .......... .......... 81% 100M 0s
9650K .......... .......... .......... .......... .......... 81% 122M 0s
9700K .......... .......... .......... .......... .......... 82% 102M 0s
9750K .......... .......... .......... .......... .......... 82% 105M 0s
9800K .......... .......... .......... .......... .......... 82% 112M 0s
9850K .......... .......... .......... .......... .......... 83% 118M 0s
9900K .......... .......... .......... .......... .......... 83% 110M 0s
9950K .......... .......... .......... .......... .......... 84% 98.0M 0s
10000K .......... .......... .......... .......... .......... 84% 123M 0s
10050K .......... .......... .......... .......... .......... 85% 120M 0s
10100K .......... .......... .......... .......... .......... 85% 95.1M 0s
10150K .......... .......... .......... .......... .......... 85% 118M 0s
10200K .......... .......... .......... .......... .......... 86% 100M 0s
10250K .......... .......... .......... .......... .......... 86% 118M 0s
10300K .......... .......... .......... .......... .......... 87% 112M 0s
10350K .......... .......... .......... .......... .......... 87% 118M 0s
10400K .......... .......... .......... .......... .......... 88% 104M 0s
10450K .......... .......... .......... .......... .......... 88% 108M 0s
10500K .......... .......... .......... .......... .......... 88% 113M 0s
10550K .......... .......... .......... .......... .......... 89% 122M 0s
10600K .......... .......... .......... .......... .......... 89% 106M 0s
10650K .......... .......... .......... .......... .......... 90% 107M 0s
10700K .......... .......... .......... .......... .......... 90% 104M 0s
10750K .......... .......... .......... .......... .......... 90% 60.6M 0s
10800K .......... .......... .......... .......... .......... 91% 102M 0s
10850K .......... .......... .......... .......... .......... 91% 115M 0s
10900K .......... .......... .......... .......... .......... 92% 119M 0s
10950K .......... .......... .......... .......... .......... 92% 84.7M 0s
11000K .......... .......... .......... .......... .......... 93% 115M 0s
11050K .......... .......... .......... .......... .......... 93% 112M 0s
11100K .......... .......... .......... .......... .......... 93% 121M 0s
11150K .......... .......... .......... .......... .......... 94% 76.0M 0s
11200K .......... .......... .......... .......... .......... 94% 114M 0s
11250K .......... .......... .......... .......... .......... 95% 121M 0s
11300K .......... .......... .......... .......... .......... 95% 108M 0s
11350K .......... .......... .......... .......... .......... 96% 113M 0s
11400K .......... .......... .......... .......... .......... 96% 107M 0s
11450K .......... .......... .......... .......... .......... 96% 108M 0s
11500K .......... .......... .......... .......... .......... 97% 124M 0s
11550K .......... .......... .......... .......... .......... 97% 106M 0s
11600K .......... .......... .......... .......... .......... 98% 112M 0s
11650K .......... .......... .......... .......... .......... 98% 126M 0s
11700K .......... .......... .......... .......... .......... 98% 105M 0s
11750K .......... .......... .......... .......... .......... 99% 117M 0s
11800K .......... .......... .......... .......... .......... 99% 108M 0s
11850K .......... .......... . 100% 146M=0.2s
2017-04-30 22:57:03 (51.1 MB/s) - ‘third-party-0.2.1-linux-x86_64.tar.gz’ saved [12156146/12156146]
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
#if CLP_HAS_ABC
#if CLP_HAS_ABC
#if CLP_HAS_ABC
Errors in build-osi:
#if CLP_HAS_ABC
#if CLP_HAS_ABC
#if CLP_HAS_ABC
Errors in build-osi-static:
#if CLP_HAS_ABC
#if CLP_HAS_ABC
#if CLP_HAS_ABC
End of tests
More information about the Minotaur-dev
