[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan mahajan at mcs.anl.gov
Thu Oct 27 23:15:39 CDT 2016
Minotaur daily test report
Thu Oct 27 22:57:02 CDT 2016
petsc.mcs.anl.gov
Linux petsc 3.5.0-30-generic #51~precise1-Ubuntu SMP Wed May 15 08:48:19 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at  http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Minotaur src directory checked out.
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (39)
compiling build-base-static: OK.
make utest output for build-base-static: OK (39)
compiling build-filter: OK.
make utest output for build-filter: OK (39)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (39)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (39)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (42)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (42)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (42)
compiling build-osi: OK.
make utest output for build-osi: OK (39)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (39)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (39)
compiling build-ampl: OK.
make utest output for build-ampl: OK (58)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (58)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (58)
compiling build-all: OK.
make utest output for build-all: OK (69)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (69)
compiling build-all-static: OK.
make utest output for build-all-static: OK (69)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
/usr/bin/ld: Warning: alignment 16 of symbol `epsc_' in /sandbox/mahajan/minotaur-test/minotaur-externals/bqpd-3/libbqpd.a(bqpd.o) is smaller than 32 in /sandbox/mahajan/minotaur-test/minotaur-externals/filter-102/src/libfiltersqp.a(QPsolves.o)
/usr/bin/ld: Warning: alignment 16 of symbol `wsc_' in /sandbox/mahajan/minotaur-test/minotaur-externals/bqpd-3/libbqpd.a(bqpd.o) is smaller than 32 in /sandbox/mahajan/minotaur-test/minotaur-externals/filter-102/src/libfiltersqp.a(filter.o)
: logger ok! OK (69)
==23432== Memcheck, a memory error detector
==23432== Copyright (C) 2002-2011, and GNU GPL'd, by Julian Seward et al.
==23432== Using Valgrind-3.7.0 and LibVEX; rerun with -h for copyright info
==23432== Command: ./unittest all
==23432==
: logger ok! ==23432== Conditional jump or move depends on uninitialised value(s)
==23432==    at 0x4D7146: bqpd_ (in /sandbox/mahajan/minotaur-test/build-all-debug/src/testing/unittest)
==23432==    by 0x52885B2: Minotaur::BqpdEngine::solve_(int, double&) (BqpdEngine.cpp:512)
==23432==    by 0x528802C: Minotaur::BqpdEngine::solve() (BqpdEngine.cpp:432)
==23432==    by 0x4CA2B3: AMPLBqpdUT::testNLP() (AMPLBqpdUT.cpp:57)
==23432==    by 0x4CB99C: CppUnit::TestCaller<AMPLBqpdUT>::runTest() (TestCaller.h:166)
==23432==    by 0x4E55820: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==23432==    by 0x4E4BEA4: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==23432==    by 0x4E52B71: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==23432==    by 0x4E5B3C4: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==23432==    by 0x4E5552E: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==23432==    by 0x4E55B62: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==23432==    by 0x4E55A85: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==23432==
OK (69)
==23432==
==23432== HEAP SUMMARY:
==23432==     in use at exit: 0 bytes in 0 blocks
==23432==   total heap usage: 174,306 allocs, 174,306 frees, 910,105,877 bytes allocated
==23432==
==23432== All heap blocks were freed -- no leaks are possible
==23432==
==23432== For counts of detected and suppressed errors, rerun with: -v
==23432== Use --track-origins=yes to see where uninitialised values come from
==23432== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 2 from 2)
Errors in build-all:
Errors in build-all-manual:
Makefile:534: minotaur.d: No such file or directory
/sandbox/mahajan/minotaur-test/src/base/MsProcessor.cpp:13:5: warning: "USE_OPENMP" is not defined [-Wundef]
/sandbox/mahajan/minotaur-test/src/base/MsProcessor.cpp:697:5: warning: "USE_OPENMP" is not defined [-Wundef]
/sandbox/mahajan/minotaur-test/src/base/MsProcessor.cpp:719:5: warning: "USE_OPENMP" is not defined [-Wundef]
/sandbox/mahajan/minotaur-test/src/base/MsProcessor.cpp:839:5: warning: "USE_OPENMP" is not defined [-Wundef]
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (58)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (39)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
: logger ok! OK (42)
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
More information about the Minotaur-dev mailing list
