[Minotaur-dev] minotaur daily test results
amahajan
amahajan at iitb.ac.in
Mon Oct 17 23:32:49 CDT 2016
Minotaur daily test report
Tue Oct 18 09:45:01 IST 2016
origin.ieor.iitb.ac.in
Linux origin 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u1 (2016-09-03) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (39)
compiling build-base-static: OK.
make utest output for build-base-static: OK (39)
compiling build-filter: OK.
make utest output for build-filter: OK (39)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (39)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (39)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (42)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (42)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (42)
compiling build-osi: OK.
make utest output for build-osi: OK (39)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (39)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (39)
compiling build-ampl: OK.
make utest output for build-ampl: OK (58)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (58)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (58)
compiling build-all: OK.
make utest output for build-all: OK (69)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (69)
compiling build-all-static: OK.
make utest output for build-all-static: OK (69)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
//usrusr//binbin//ldld:: WarningWarning:: alignmentalignment 1616 ofof symbolsymbol ``epsc_epsc_'' inin //homehome//amahajanamahajan//tmptmp//minotaurminotaur--testtest//minotaurminotaur--externalsexternals//bqpdbqpd--33//libbqpd.alibbqpd.a((bqpd.obqpd.o)) isis smallersmaller thanthan 6464 inin //homehome//amahajanamahajan//tmptmp//minotaurminotaur--testtest//minotaurminotaur--externalsexternals//filterfilter--102102//srcsrc//libfiltersqp.alibfiltersqp.a((QPsolves.oQPsolves.o))
//usrusr//binbin//ldld:: WarningWarning:: alignmentalignment 1616 ofof symbolsymbol ``wsc_wsc_'' inin //homehome//amahajanamahajan//tmptmp//minotaurminotaur--testtest//minotaurminotaur--externalsexternals//bqpdbqpd--33//libbqpd.alibbqpd.a((bqpd.obqpd.o)) isis smallersmaller thanthan 6464 inin //homehome//amahajanamahajan//tmptmp//minotaurminotaur--testtest//minotaurminotaur--externalsexternals//filterfilter--102102//srcsrc//libfiltersqp.alibfiltersqp.a((filter.ofilter.o))
/usr/bin/ld: Warning: alignment 16 of symbol `epsc_' in /home/amahajan/tmp/minotaur-test/minotaur-externals/bqpd-3/libbqpd.a(bqpd.o) is smaller than 64 in /home/amahajan/tmp/minotaur-test/minotaur-externals/filter-102/src/libfiltersqp.a(QPsolves.o)
/usr/bin/ld: Warning: alignment 16 of symbol `wsc_' in /home/amahajan/tmp/minotaur-test/minotaur-externals/bqpd-3/libbqpd.a(bqpd.o) is smaller than 64 in /home/amahajan/tmp/minotaur-test/minotaur-externals/filter-102/src/libfiltersqp.a(filter.o)
: logger ok! OK (69)
==28172== Memcheck, a memory error detector
==28172== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==28172== Using Valgrind-3.10.0 and LibVEX; rerun with -h for copyright info
==28172== Command: ./unittest all
==28172==
==28172==
==28172== HEAP SUMMARY:
==28172== in use at exit: 0 bytes in 0 blocks
==28172== total heap usage: 170,795 allocs, 170,795 frees, 888,031,086 bytes allocated
==28172==
==28172== All heap blocks were freed -- no leaks are possible
==28172==
==28172== For counts of detected and suppressed errors, rerun with: -v
==28172== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:534: minotaur.d: No such file or directory
/home/amahajan/tmp/minotaur-test/src/base/MsProcessor.cpp:13:5: warning: "USE_OPENMP" is not defined [-Wundef]
#if USE_OPENMP
/home/amahajan/tmp/minotaur-test/src/base/MsProcessor.cpp:697:5: warning: "USE_OPENMP" is not defined [-Wundef]
#if USE_OPENMP
/home/amahajan/tmp/minotaur-test/src/base/MsProcessor.cpp:719:5: warning: "USE_OPENMP" is not defined [-Wundef]
#if USE_OPENMP
/home/amahajan/tmp/minotaur-test/src/base/MsProcessor.cpp:839:5: warning: "USE_OPENMP" is not defined [-Wundef]
#if USE_OPENMP
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (58)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (39)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
: logger ok! OK (42)
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Tue Oct 18 10:02:49 IST 2016
More information about the Minotaur-dev
