Minotaur daily test report
Sun Nov 27 22:37:01 IST 2016
origin.ieor.iitb.ac.in
Linux origin 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2-117-gb7c2518
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (39)
compiling build-base-static: OK.
make utest output for build-base-static: OK (39)
compiling build-filter: OK.
make utest output for build-filter: OK (39)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (39)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (39)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (42)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (42)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (42)
compiling build-osi: OK.
make utest output for build-osi: OK (39)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (39)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (39)
compiling build-ampl: OK.
make utest output for build-ampl: OK (58)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (58)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (58)
compiling build-all: OK.
make utest output for build-all: OK (69)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (69)
compiling build-all-static: OK.
make utest output for build-all-static: OK (69)
compiling build-all-manual: ERROR. bin/qg not built.
Errors:
Errors in build-all-debug:
: logger ok! OK (69)
==16368== Memcheck, a memory error detector
==16368== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==16368== Using Valgrind-3.10.0 and LibVEX; rerun with -h for copyright info
==16368== Command: ./unittest all
==16368==
: logger ok! TimerUT.cpp:36:Assertion
Test name: TimerUT::testSleep
assertion failed
- Expression: time_used <= 0.001
Failures !!!
Run: 69 Failure total: 1 Failures: 1 Errors: 0
==16368==
==16368== HEAP SUMMARY:
==16368== in use at exit: 160 bytes in 1 blocks
==16368== total heap usage: 171,218 allocs, 171,217 frees, 888,052,003 bytes allocated
==16368==
==16368== 160 bytes in 1 blocks are definitely lost in loss record 1 of 1
==16368== at 0x4C29180: operator new(unsigned long) (vg_replace_malloc.c:324)
==16368== by 0x4A4CDA: Minotaur::TimerFactory::getTimer() (Timer.h:162)
==16368== by 0x4A3F59: TimerUT::testSleep() (TimerUT.cpp:30)
==16368== by 0x4A5655: CppUnit::TestCaller<TimerUT>::runTest() (TestCaller.h:166)
==16368== by 0x4E576A1: CppUnit::TestCaseMethodFunctor::operator()() const (TestCase.cpp:32)
==16368== by 0x4E4DD6F: CppUnit::DefaultProtector::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (DefaultProtector.cpp:15)
==16368== by 0x4E54A7C: operator() (ProtectorChain.cpp:20)
==16368== by 0x4E54A7C: CppUnit::ProtectorChain::protect(CppUnit::Functor const&, CppUnit::ProtectorContext const&) (ProtectorChain.cpp:77)
==16368== by 0x4E5D418: CppUnit::TestResult::protect(CppUnit::Functor const&, CppUnit::Test*, std::string const&) (TestResult.cpp:181)
==16368== by 0x4E573F9: CppUnit::TestCase::run(CppUnit::TestResult*) (TestCase.cpp:92)
==16368== by 0x4E57A22: CppUnit::TestComposite::doRunChildTests(CppUnit::TestResult*) (TestComposite.cpp:64)
==16368== by 0x4E5793D: CppUnit::TestComposite::run(CppUnit::TestResult*) (TestComposite.cpp:23)
==16368==
==16368== LEAK SUMMARY:
==16368== definitely lost: 160 bytes in 1 blocks
==16368== indirectly lost: 0 bytes in 0 blocks
==16368== possibly lost: 0 bytes in 0 blocks
==16368== still reachable: 0 bytes in 0 blocks
==16368== suppressed: 0 bytes in 0 blocks
==16368==
==16368== For counts of detected and suppressed errors, rerun with: -v
==16368== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:540: minotaur.d: No such file or directory
In file included from ./include/minotaur/PerspCutHandler.h:18:0,
from /home/amahajan/tmp/minotaur-test/src/algorithms/qg.cpp:49:
./include/minotaur/PerspCutGenerator.h:25:17: fatal error: Cut.h: No such file or directory
#include "Cut.h"
compilation terminated.
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (58)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (39)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
: logger ok! OK (42)
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Sun Nov 27 22:54:47 IST 2016
