[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan
mahajan at mcs.anl.gov
Tue Nov 22 18:09:51 CST 2016
Minotaur daily mac test report
Tue Nov 22 17:35:02 CST 2016
Detailed log available at http://www.mcs.anl.gov/minotaur/nightly/build-log/petsc-mini
petsc-mini.mcs.anl.gov
Darwin petsc-mini.mcs.anl.gov 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
Not using any user specified doxygen installation
Minotaur src directory checked out.
Summary
compiling build-base-debug-static: OK.
make utest output for build-base-debug-static: OK (39)
compiling build-base-static: OK.
make utest output for build-base-static: OK (39)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (39)
compiling build-filter-debug-static: OK.
make utest output for build-filter-debug-static: OK (39)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (42)
compiling build-ipopt-debug-static: OK.
make utest output for build-ipopt-debug-static: OK (42)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (39)
compiling build-osi-debug-static: OK.
make utest output for build-osi-debug-static: OK (39)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (58)
compiling build-ampl-debug-static: OK.
make utest output for build-ampl-debug-static: OK (58)
compiling build-all-static: OK.
make utest output for build-all-static: OK (69)
compiling build-all-debug-static: OK.
make utest output for build-all-debug-static: OK (69)
compiling build-all-manual: ERROR. lib/libminotaur.a not built.
Errors:
Errors in build-all-debug-static:
In file included from /Users/mahajan/src/minotaur-test/src/base/PerspCutGenerator.cpp:24:
/Users/mahajan/src/minotaur-test/src/base/PerspCutGenerator.h:181:12: warning: private field 'objtol_' is not used [-Wunused-private-field]
double objtol_;
/Users/mahajan/src/minotaur-test/src/base/PerspCutGenerator.h:191:12: warning: private field 'intTol_' is not used [-Wunused-private-field]
double intTol_;
/Users/mahajan/src/minotaur-test/src/base/PerspCutGenerator.h:194:12: warning: private field 'solAbsTol_' is not used [-Wunused-private-field]
double solAbsTol_;
/Users/mahajan/src/minotaur-test/src/base/PerspCutGenerator.h:195:12: warning: private field 'solRelTol_' is not used [-Wunused-private-field]
double solRelTol_;
/Users/mahajan/src/minotaur-test/src/base/PerspCutGenerator.h:198:12: warning: private field 'eTol_' is not used [-Wunused-private-field]
double eTol_;
5 warnings generated.
: logger ok! OK (69)
Errors in build-all-manual:
Makefile:534: minotaur.d: No such file or directory
/Users/mahajan/src/minotaur-test/src/base/Environment.cpp: In member function ‘std::string Minotaur::Environment::getVersion()’:
/Users/mahajan/src/minotaur-test/src/base/Environment.cpp:570: error: ‘MINOTAUR_GIT_VERSION’ was not declared in this scope
make: *** [/Users/mahajan/src/minotaur-test/src/base/Environment.o] Error 1
Errors in build-all-static:
double objtol_;
double intTol_;
double solAbsTol_;
double solRelTol_;
double eTol_;
Errors in build-ampl-debug-static:
double objtol_;
double intTol_;
double solAbsTol_;
double solRelTol_;
double eTol_;
: logger ok! OK (58)
Errors in build-ampl-static:
double objtol_;
double intTol_;
double solAbsTol_;
double solRelTol_;
double eTol_;
Errors in build-base-debug-static:
double objtol_;
double intTol_;
double solAbsTol_;
double solRelTol_;
double eTol_;
: logger ok! OK (39)
Errors in build-base-static:
double objtol_;
double intTol_;
double solAbsTol_;
double solRelTol_;
double eTol_;
Errors in build-filter-debug-static:
double objtol_;
double intTol_;
double solAbsTol_;
double solRelTol_;
double eTol_;
Errors in build-filter-static:
double objtol_;
double intTol_;
double solAbsTol_;
double solRelTol_;
double eTol_;
Errors in build-ipopt-debug-static:
double objtol_;
double intTol_;
double solAbsTol_;
double solRelTol_;
double eTol_;
: logger ok! OK (42)
Errors in build-ipopt-static:
double objtol_;
double intTol_;
double solAbsTol_;
double solRelTol_;
double eTol_;
Errors in build-osi-debug-static:
double objtol_;
double intTol_;
double solAbsTol_;
double solRelTol_;
double eTol_;
Errors in build-osi-static:
double objtol_;
double intTol_;
double solAbsTol_;
double solRelTol_;
double eTol_;
End of tests
More information about the Minotaur-dev
