[Minotaur-dev] minotaur daily test results
amahajan amahajan at iitb.ac.in
Sun Nov 13 11:24:21 CST 2016
Minotaur daily test report
Sun Nov 13 22:37:01 IST 2016
origin.ieor.iitb.ac.in
Linux origin 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux
Detailed log available at  http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (39)
compiling build-base-static: OK.
make utest output for build-base-static: OK (39)
compiling build-filter: OK.
make utest output for build-filter: OK (39)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (39)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (39)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (42)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (42)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (42)
compiling build-osi: OK.
make utest output for build-osi: OK (39)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (39)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (39)
compiling build-ampl: OK.
make utest output for build-ampl: OK (58)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (58)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (58)
compiling build-all: OK.
make utest output for build-all: OK (69)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (69)
compiling build-all-static: OK.
make utest output for build-all-static: OK (69)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
/usr/bin/ld: Warning: alignment 16 of symbol `epsc_' in /home/amahajan/tmp/minotaur-test/minotaur-externals/bqpd-3/libbqpd.a(bqpd.o) is smaller than 64 in /home/amahajan/tmp/minotaur-test/minotaur-externals/filter-102/src/libfiltersqp.a(QPsolves.o)
/usr/bin/ld: Warning: alignment 16 of symbol `wsc_' in /home/amahajan/tmp/minotaur-test/minotaur-externals/bqpd-3/libbqpd.a(bqpd.o) is smaller than 64 in /home/amahajan/tmp/minotaur-test/minotaur-externals/filter-102/src/libfiltersqp.a(filter.o)
/usr/bin/ld: Warning: alignment 16 of symbol `epsc_' in //usrhome//binamahajan//ldtmp:/ minotaurWarning-:test /alignmentminotaur -16externals /ofbqpd -symbol3 /`libbqpd.aepsc_('bqpd.o )in  is/ homesmaller/ amahajanthan/ tmp64/ minotaurin- test//homeminotaur/-amahajanexternals//tmpbqpd/-minotaur3-/testlibbqpd.a/(minotaurbqpd.o-)externals /isfilter -smaller102 /thansrc /64libfiltersqp.a (inQPsolves.o )/
home//usramahajan//bintmp//ldminotaur:- testWarning/:minotaur -alignmentexternals /16filter -of102 /symbolsrc /`libfiltersqp.awsc_('QPsolves.o )in
 //usrhome//binamahajan//ldtmp:// usrminotaurWarning/-:bintest //alignmentldminotaur :-16 externals Warning/of:bqpd  -symbolalignment3  /`16libbqpd.awsc_ ('ofbqpd.o  )insymbol   is/` homeepsc_smaller/' amahajan than/in tmp 64// minotaurhomein-/ testamahajan///homeminotaurtmp/-/amahajanexternalsminotaur//-tmpbqpdtest/-/minotaur3minotaur-/-testlibbqpd.aexternals/(/minotaurbqpd.obqpd-)-externals 3/is/filter libbqpd.a-smaller(102 bqpd.o/than)src  /64islibfiltersqp.a  (insmallerfilter.o  )/than
home /64amahajan /intmp //minotaurhome-/testamahajan//minotaurtmp-/externalsminotaur/-filtertest-/102minotaur/-srcexternals//libfiltersqp.afilter(-filter.o102)/
: logger ok! OK (69)
==14181== Memcheck, a memory error detector
==14181== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==14181== Using Valgrind-3.10.0 and LibVEX; rerun with -h for copyright info
==14181== Command: ./unittest all
==14181==
==14181==
==14181== HEAP SUMMARY:
==14181==     in use at exit: 0 bytes in 0 blocks
==14181==   total heap usage: 170,795 allocs, 170,795 frees, 888,031,086 bytes allocated
==14181==
==14181== All heap blocks were freed -- no leaks are possible
==14181==
==14181== For counts of detected and suppressed errors, rerun with: -v
==14181== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:534: minotaur.d: No such file or directory
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (58)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (39)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
: logger ok! OK (42)
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Sun Nov 13 22:54:21 IST 2016
More information about the Minotaur-dev mailing list
